9 Replies Latest reply on Apr 12, 2017 3:17 PM by mkreibohm
    Lightroom CC + Olympus OMD E-M5 II
      Hi there,
      I have a Lightroom CC (2015) subscription and both Lightroom (5.7.1) and Camera RAW (8.7.1) are up to date.
      However, Lightroom is unable to open the RAW files (.ORF) from my Olympus OMD E-M5 II.
      According to Adobe, these files require Camera RAW 8.8 or higher and/or Lightroom 6 or higher. However, as stated, I am on a Adobe CC plan and my CC app tells me everything is up to date, i.e. there's no apparent way for me to go any higher than the versions stated above.
      was under the impression that a CC subscription automatically meant having the latest release of Lightroom, but apparently that's not the case.
      Do I need to upgrade to Lightroom 6 somehow (if so, how?) to make this work?
      Thanks in advance!
        • 1. Re: Lightroom CC + Olympus OMD E-M5 II
          Akash Sharma Adobe Employee
          Hi Michael,
          Could you please open Lightroom and post the Help>>System info report here so that we can confirm the version of Lightroom in use?
          • 2. Re: Lightroom CC + Olympus OMD E-M5 II
            mkreibohm Level 1
            Sure, here you go:
            Version von Lightroom: 5.7.1 [994773]
            Lizenztyp: Creative Cloud
            Betriebssystem: Mac OS 10
            Version: 10.12 [4]
            Anwendungsarchitektur: x64
            Anzahl logischer Prozessoren: 4
            Prozessorgeschwindigkeit: 3,4 GHz
            Integrierter Speicher: 8192,0 MB
            Für Lightroom verfügbarer phys. Speicher: 8192,0 MB
            Von Lightroom verwendeter phys. Speicher: 350,7 MB (4,2%)
            Von Lightroom verwendeter virtueller Speicher: 977,5 MB
            Cache-Speichergröße: 0,0 MB
            Maximale Anzahl Threads, die Camera Raw verwendet: 4
            Monitore/Anzeigegeräte: 1) 2560x1440
            Installierte Zusatzmodule:
            1) Aperture/iPhoto-Import-Zusatzmodul
            2) Behance
            3) Canon Tether-Zusatzmodul
            4) Facebook
            5) Flickr
            6) Leica Tether-Zusatzmodul
            7) LR/Mogrify 2
            8) Nikon Tether-Zusatzmodul
            Config.lua-Flags: None
            AudioDeviceIOBlockSize: 512
            AudioDeviceName: Ausgang (integriert)
            AudioDeviceNumberOfChannels: 2
            AudioDeviceSampleRate: 44100
            Build: LR5x89
            CoreImage: true
            GL_ACCUM_ALPHA_BITS: 0
            GL_ACCUM_BLUE_BITS: 0
            GL_ACCUM_GREEN_BITS: 0
            GL_ACCUM_RED_BITS: 0
            GL_ALPHA_BITS: 8
            GL_BLUE_BITS: 8
            GL_DEPTH_BITS: 24
            GL_GREEN_BITS: 8
            GL_MAX_3D_TEXTURE_SIZE: 2048
            GL_MAX_TEXTURE_SIZE: 16384
            GL_MAX_TEXTURE_UNITS: 8
            GL_MAX_VIEWPORT_DIMS: 16384,16384
            GL_RED_BITS: 8
            GL_RENDERER: NVIDIA GeForce GTX 780M OpenGL Engine
            GL_STENCIL_BITS: 8
            GL_VENDOR: NVIDIA Corporation
            GL_VERSION: 2.1 NVIDIA-10.16.34 355.10.05.35f05
            GL_EXTENSIONS: GL_ARB_color_buffer_float GL_ARB_depth_buffer_float GL_ARB_depth_clamp GL_ARB_depth_texture GL_ARB_draw_buffers GL_ARB_draw_elements_base_vertex GL_ARB_draw_instanced GL_ARB_fragment_program GL_ARB_fragment_program_shadow GL_ARB_fragment_shader GL_ARB_framebuffer_object GL_ARB_framebuffer_sRGB GL_ARB_half_float_pixel GL_ARB_half_float_vertex GL_ARB_imaging GL_ARB_instanced_arrays GL_ARB_multisample GL_ARB_multitexture GL_ARB_occlusion_query GL_ARB_pixel_buffer_object GL_ARB_point_parameters GL_ARB_point_sprite GL_ARB_provoking_vertex GL_ARB_seamless_cube_map GL_ARB_shader_objects GL_ARB_shader_texture_lod GL_ARB_shading_language_100 GL_ARB_shadow GL_ARB_sync GL_ARB_texture_border_clamp GL_ARB_texture_compression GL_ARB_texture_compression_rgtc GL_ARB_texture_cube_map GL_ARB_texture_env_add GL_ARB_texture_env_combine GL_ARB_texture_env_crossbar GL_ARB_texture_env_dot3 GL_ARB_texture_float GL_ARB_texture_mirrored_repeat GL_ARB_texture_non_power_of_two GL_ARB_texture_rectangle GL_ARB_texture_rg GL_ARB_transpose_matrix GL_ARB_vertex_array_bgra GL_ARB_vertex_blend GL_ARB_vertex_buffer_object GL_ARB_vertex_program GL_ARB_vertex_shader GL_ARB_window_pos GL_EXT_abgr GL_EXT_bgra GL_EXT_bindable_uniform GL_EXT_blend_color GL_EXT_blend_equation_separate GL_EXT_blend_func_separate GL_EXT_blend_minmax GL_EXT_blend_subtract GL_EXT_clip_volume_hint GL_EXT_debug_label GL_EXT_debug_marker GL_EXT_depth_bounds_test GL_EXT_draw_buffers2 GL_EXT_draw_range_elements GL_EXT_fog_coord GL_EXT_framebuffer_blit GL_EXT_framebuffer_multisample GL_EXT_framebuffer_multisample_blit_scaled GL_EXT_framebuffer_object GL_EXT_framebuffer_sRGB GL_EXT_geometry_shader4 GL_EXT_gpu_program_parameters GL_EXT_gpu_shader4 GL_EXT_multi_draw_arrays GL_EXT_packed_depth_stencil GL_EXT_packed_float GL_EXT_provoking_vertex GL_EXT_rescale_normal GL_EXT_secondary_color GL_EXT_separate_specular_color GL_EXT_shadow_funcs GL_EXT_stencil_two_side GL_EXT_stencil_wrap GL_EXT_texture_array GL_EXT_texture_compression_dxt1 GL_EXT_texture_compression_s3tc GL_EXT_texture_env_add GL_EXT_texture_filter_anisotropic GL_EXT_texture_integer GL_EXT_texture_lod_bias GL_EXT_texture_mirror_clamp GL_EXT_texture_rectangle GL_EXT_texture_shared_exponent GL_EXT_texture_sRGB GL_EXT_texture_sRGB_decode GL_EXT_timer_query GL_EXT_transform_feedback GL_EXT_vertex_array_bgra GL_APPLE_aux_depth_stencil GL_APPLE_client_storage GL_APPLE_element_array GL_APPLE_fence GL_APPLE_float_pixels GL_APPLE_flush_buffer_range GL_APPLE_flush_render GL_APPLE_object_purgeable GL_APPLE_packed_pixels GL_APPLE_pixel_buffer GL_APPLE_rgb_422 GL_APPLE_row_bytes GL_APPLE_specular_vector GL_APPLE_texture_range GL_APPLE_transform_hint GL_APPLE_vertex_array_object GL_APPLE_vertex_array_range GL_APPLE_vertex_point_size GL_APPLE_vertex_program_evaluators GL_APPLE_ycbcr_422 GL_ATI_separate_stencil GL_ATI_texture_env_combine3 GL_ATI_texture_float GL_ATI_texture_mirror_once GL_IBM_rasterpos_clip GL_NV_blend_square GL_NV_conditional_render GL_NV_depth_clamp GL_NV_fog_distance GL_NV_fragment_program_option GL_NV_fragment_program2 GL_NV_light_max_exponent GL_NV_multisample_filter_hint GL_NV_point_sprite GL_NV_texgen_reflection GL_NV_texture_barrier GL_NV_vertex_program2_option GL_NV_vertex_program3 GL_SGIS_generate_mipmap GL_SGIS_texture_edge_clamp GL_SGIS_texture_lod
            • 3. Re: Lightroom CC + Olympus OMD E-M5 II
              If you are subscribed to Lightroom CC 2015 you are NOT up to date. Lightroom 5.7.1 is old and out of date. The only reason you would be using that is if you have a 32-bit operating system. That version of Lightroom will not support your camera. You should be using Lightroom CC 2015.10. And if you are keeping up to date with Photoshop then you should have Photoshop CC 2017 along with Camera Raw 9.9. There is no Camera Raw version to associate directly with the operation of Lightroom because it doesn't use the camera raw plug-in. The Camera Raw plug-in is only integrated when transferring an image from Lightroom to Photoshop, and it's Photoshop that utilizes the plug-in.
              2 people found this helpful
              • 4. Re: Lightroom CC + Olympus OMD E-M5 II
                DdeGannes Adobe Community Professional
                Do you in fact have Lightroom CC 2015 installed? If so use the Creative Cloud Application to check your account for updates. See the screen capture.
                • 5. Re: Lightroom CC + Olympus OMD E-M5 II
                  mkreibohm Level 1
                  Hi there,
                  thanks for your replies!
                  As I've said, the Adobe CC app tells me all my apps are up to date (after checking for updates):
                  As you can see, I am one the current Photoshop version, so I have no idea why Lightroom CC would be outdated (without the app telling me so).
                  What can I do to update to Lightroom CC 2015.10? As you can see in my system info report above, I am using a 64-bit OS.
                  • 6. Re: Lightroom CC + Olympus OMD E-M5 II
                    Go to the following website and download Lightroom CC 2015. After you install it then you will need to download and install the most recent update. It won't be necessary to install all of the interim updates.
                    Download Photoshop Lightroom
                    I am in the United States. Scroll to the bottom of the page and change to the appropriate region to where you are living.
                    • 7. Re: Lightroom CC + Olympus OMD E-M5 II
                      Jao vdL Adobe Community Professional & MVP
                      You probably have both Lightroom 5.7 and Lightroom CC installed and are opening the Lightroom 5.7 version instead of CC. Probably your Dock icon is still pointing to the old Lightroom. Make sure you run the CC version.
                      • 8. Re: Lightroom CC + Olympus OMD E-M5 II
                        Yes indeed. From your system info: "Version von Lightroom: 5.7.1 [994773]"
                        You are starting the previous Lightroom version, not the 2015 CC version which probably is completely updated.
                        • 9. Re: Lightroom CC + Olympus OMD E-M5 II
                          mkreibohm Level 1
                          That was it! Thank you!
                          I hadn't even considered this posibility... no idea why both were installed in parallel. Anyway, the new version is there, as suspected, and works fine.
                          Thanks again!
