11 Replies Latest reply on Apr 14, 2017 11:51 AM by Jarda Bereza
    How to make a scrollbar work in a dialog box.
    Ps-Design Level 1
      I have a dialog box containing a group with "16 radio button options". My goal is to pack it so it looks smaller. The best way I found it was by adding a scrollbar in the group of buttons, I searched and got a script but could not get it to work. Anyone have any ideas how to help me with this project? Any help is valid. Thank you...
      var w = new Window ("dialog", "scrollbar");
           w.orientation = "row";
        w.alignChildren = "top";  // insert this line
           w.location = [600,180]
          var radio_group = w.add ('panel', [0,0,160,190],);
          var sbar = w.add ("scrollbar", [5,0,20,190]);
           radio_group.alignChildren = "left";
        radio_group.add ("radiobutton",[5, 10, 100,   0], "Alça e Interior Azul");
        radio_group.add ("radiobutton",[5, 35, 100,  0], "Alça e Interior Vermelho");
           radio_group.add ("radiobutton",[5, 60, 100,   0], "Alça e Interior Preta");
           radio_group.add ("radiobutton",[5, 85, 100,  0], "Alça e Interior Roso");
           radio_group.add ("radiobutton",[5, 110, 100, 0], "Do Tipo Toda Branca");
           radio_group.add ("radiobutton",[5, 135, 100, 0], "Do Tipo Toda Preta");
           radio_group.add ("radiobutton",[5, 160, 100, 0], "Do Tipo Pratiada");
           radio_group.add ("radiobutton",[5, 185, 100, 0], "Do Tipo Caneca Mágica");
           radio_group.add ("radiobutton",[5, 210, 100, 0], "Interior Azul");
           radio_group.add ("radiobutton",[5, 235, 100, 0], "Interior Roso");
           radio_group.add ("radiobutton",[5, 255, 100, 0], "Interior Verde");
           radio_group.add ("radiobutton",[5, 285, 100, 0], "Interior Vermelho");
           radio_group.add ("radiobutton",[5, 310, 100, 0], "Interior Preto");
           radio_group.add ("radiobutton",[5, 335, 100, 0], "Modelo dia dos Pais");
           radio_group.add ("radiobutton",[5, 360, 100, 0], "Caneca de Aluminio");
        radio_group.add ("radiobutton",[5, 385, 100, 0], "Modelo Simples");
          var btnGroup = w.add("group");
          btnGroup.orientation = "column";
          btnGroup.add ('button', {x:90, y:125, width:80, height:25}, 'Ok', {name:'ok'});
          btnGroup.add ('button', {x:240, y:125, width:80, height:25}, 'Cancel', {name:'cancel'});
        // set dialog defaults
        radio_group.children[0].value = true;
      function selected_rbutton (rbuttons) {
        for (var i = 0; i < rbuttons.children.length; i++) {
        if (rbuttons.children[i].value == true) {
        return rbuttons.children[i].text;
        // Linkar com os Scrips.jsx
      w.show ()
        • 1. Re: How to make a scrollbar work in a dialog box.
          Chuck Uebele Adobe Community Professional & MVP
          Rather than use radio buttons, if you have that many, you should use a drop down list.
          • 2. Re: How to make a scrollbar work in a dialog box.
            Ps-Design Level 1
            I found this simple model of Drop dow list:
            The problem is that every drop-down list I encounter, the event executes before confirming with the OK button. It would be interesting to choose the option, click ok and then the event.Chuck Uebele How do I change?
            var w = new Window ("dialog", "dropdownlist" );
            w.orientation = "column";
            //w.add ("statictext", undefined, "Intens:");
            var lista = w.add ("dropdownlist", undefined, [
            "Alça e Interior Azul",
            "Alça e Interior Vermelho", "Alça e Interior Preta",
            "Alça e Interior Roso", "Do Tipo Toda Branca",
            "Do Tipo Pratiada", "Do Tipo Caneca Mágica",
            "Interior Azul", "Interior Roso", "Interior Verde",
            "Interior Vermelho", "Interior Preto", "Modelo dia dos Pais",
            "Caneca de Aluminio", "Modelo Simples"
            var btnGroup = w.add ("group");
            btnGroup.orientation = "row";
            lista.selection = 0;
            btnGroup.add ("button",{x:240, y:125, width:60, height:25}, 'Cancel', {name:'cancel'});
            btnGroup.add ("button",{x:90, y:125, width:60, height:25}, "OK");
            btnGroup.alignment = "right";
            lista.onChange = function(){
                  switch(parseInt( lista.selection)){
                    case 0:
                        //code here
                        alert("Alça e Interior Azul");
                        break;
                    case 1:
                        //code here
                        alert("Alça e Interior Vermelho");
                        break;
                    case 2:
                        //code here
                        alert("Alça e Interior Preta");
                        break;
            w.show ();
            • 3. Re: How to make a scrollbar work in a dialog box.
              Don't put the code to do something in the onChange function for the dropdownlist. Add it to an onClick function for the Okay button.
              • 4. Re: How to make a scrollbar work in a dialog box.
                var dlg = new Window('dialog','Dropdown Sample');
                var dropList = ["Alça e Interior Azul", "Alça e Interior Vermelho", "Alça e Interior Preta",
                "Caneca de Aluminio", "Modelo Simples" ];
                dlg.dropDown = dlg.add('dropdownlist', undefined, dropList);
                dlg.ok = dlg.add('button', undefined, 'Okay');
                dlg.cancel = dlg.add('button', undefined, 'Cancel');
                dlg.ok.onClick = function(){
                    dlg.close()
                    switch(parseInt(dlg.dropDown.selection)){
                            case 0:
                            //code here
                            break;
                        case 1:
                            //code here
                            break;
                        case 2:
                            //code here
                            break;
                dlg.cancel.onClick = function(){dlg.close()}
                dlg.show()
                • 5. Re: How to make a scrollbar work in a dialog box.
                  Ps-Design Level 1
                  It looks great! Nice work Chuck Uebele To be perfect, it would be nice to have the first item on the list appear when the dialog box opens. Thank you.
                  In my script this is possible with this line:
                  • 6. Re: How to make a scrollbar work in a dialog box.
                    Yes you can do that. I normally do that also.
                    • 7. Re: How to make a scrollbar work in a dialog box.
                      Jarda Bereza Level 4
                      I have same question, but I can't use dropdown because I already have many dropdowns.
                      I guess I should move panel position on scrollbar event or something similar.
                      • 8. Re: How to make a scrollbar work in a dialog box.
                        AFAIK, you can't add a scroll bar to the UI, unfortunately. That's why I'm using tabs now for mine:
                        • 9. Re: How to make a scrollbar work in a dialog box.
                          I created scrollable panel and it works for me. Anyway it is not so good as native support would be.
                          app.bringToFront();
                          #target Photoshop
                          var windowResource = """dialog {
                              orientation: 'column',
                              alignChildren: ['fill', 'top'],
                              preferredSize:[300, 230],
                              text: 'Scroll panel example',
                              margins:15,
                              scrollPanel: Panel {
                                  orientation: 'row',
                                  alignChildren: 'top',
                                  margins:0,
                                  spacing:0,
                                  text: '',
                                  innerScrollPanel: Panel{
                                      alignChildren: 'left',
                                      alignment: 'top',
                                      margins:0,
                                      spacing:0,
                                      text: '',
                                      properties: {borderStyle:'none'}
                                  panelScrollbar: Scrollbar {
                                      alignment: 'fill',
                                      margins:0,
                                      spacing:0
                              bottomGroup: Group{
                                  cancelButton: Button { text: 'Cancel', properties:{name:'cancel'}, size: [120,24], alignment:['right', 'center'] },
                                  applyButton: Button { text: 'OK', properties:{name:'ok'}, size: [120,24], alignment:['right', 'center'] },
                                  orientation: 'row'
                          var win = new Window(windowResource);
                          var scrollPanel = win.scrollPanel;
                          var innerScrollPanel = scrollPanel.innerScrollPanel;
                          var scrollBar = scrollPanel.panelScrollbar;
                          scrollPanel.size=[300,400];
                          innerScrollPanel.preferredSize.width = 300-20;
                          scrollBar.preferredSize.width = 16;
                          scrollBar.onChanging = function (){
                              var outerPanel = this.parent;
                              var innerPanel = outerPanel.children[0];
                              var innerWidth = innerPanel.bounds.width;
                              var innerHeight = innerPanel.bounds.height;
                              var outerHeight = outerPanel.bounds.height;
                              this.minvalue = 0;
                              this.maxvalue = innerHeight-outerHeight;
                              this.stepdelta = Math.round(outerHeight / 10);
                              this.jumpdelta = Math.round(outerHeight / 5);
                              var topOffset = -this.value;
                              innerPanel.bounds = {x:0, y:topOffset, width:innerWidth,height:innerHeight};
                          // Storing reference to elements
                          var dropdown = {};
                          var label = {};
                          var panel = {};
                          // Add some sample UI content
                          for(var i = 0; i < 15; i++){
                              panel[i] = win.scrollPanel.innerScrollPanel.add('panel',undefined,'',{justify:'left', borderStyle:'none'});
                              panel[i].orientation = 'row';
                              panel[i].alignment = 'fill';
                              label[i] = panel[i].add('statictext',undefined,"Test dropdown "+i+":");
                              dropdown[i] = panel[i].add('dropdownlist',undefined,["a","b"]);
                          win.bottomGroup.applyButton.onClick = function() {
                              win.close();
                          win.show();
                          • 10. Re: How to make a scrollbar work in a dialog box.
                            Nice! It would be good to have a native option.
                            • 11. Re: How to make a scrollbar work in a dialog box.
                              Only "staticText" and "editText" has native scrollbar.
                              They also has some properties as panels. I will try use is it as panel. But I don't think this will work properly :-D
