10 Replies Latest reply on Apr 13, 2017 10:14 AM by K´mo
    Logo created in photoshop causing print issues
    Ciaranm Level 1
      Hi all,
      A job i'm working on came back from the printer with a white box around the logo, the printer asked me to flatten the logo (which is a psd file) but if i flatten it i will lose the navy colour.
      (the logo is placed into indesign with no effects added in indesign)
      This is how my high res pdf appears and this is how the logo SHOULD look...
      this is the printers proof...
      This is how the logo looks in photoshop and the layers and channels.
      Screen Shot 2017-04-13 at 11.37.43.pngScreen Shot 2017-04-13 at 11.40.50.png
      I wouldnt be the best at photoshop so i've no idea how to flatten the logo but keep the navy colour (in cmyk rather then pantone) and transparencies
      Any help would be greatly appreciated!
      PS. im only showing a sample of the logo to somewhat hide the identity of the client
        • 1. Re: Logo created in photoshop causing print issues
          I think the printer asking you to flatten in InDesign, to overcome whatever is broken in his system (losing your design and putting the responsibility on you is frankly not a good sign). Doesn't doubd like you need to flatten in Photoshop.
          • 2. Re: Logo created in photoshop causing print issues
            A key problem, by the way, is that "flatten" is used to mean many different things. For example: combine layers in Photoshop (which by definition applies transpatencty y effects); combine layers in InDesign (which does not affect transparency); removing transparency effects in InDesign; removing transparency effects in PDF; removing form fields in PDF; removing layer tags from a PDF; rasterising a PDF.
            • 3. Re: Logo created in photoshop causing print issues
              Eternal Warrior Level 4
              To further Test Screen Name's point I would add this:
              FIND another printer!
              I would avoid flattening the logo at all costs... mostly because transparency is so useful and it makes things easier for you in the long run.
              It appears that either the printer's system cannot handle transparency (...Red flag).
              What format are you supplying to the printer when you send the artwork?
              Best,
              EW
              • 4. Re: Logo created in photoshop causing print issues
                Ciaranm Level 1
                hey thanks! cant change printers unfortunately.
                I'm supplying high res pdf exported from indesign.
                I've been in touch with the client and another studio came across the same issue and made a vector version of the logo which is darker and less textured and of course has lost its transparency :/ see below.
                Surely theres a better way to make this logo work, so frustrating!
                • 5. Re: Logo created in photoshop causing print issues
                  Have you tried saving a copy and then flattening only the layers that create the Logo in Photoshop first?
                  If you get to that stage it may be possible to look at retaining the colour as this seems to be the issue if you can't change printer.
                  Best,
                  EW
                  • 6. Re: Logo created in photoshop causing print issues
                    K´mo Level 3
                    Maybe the printer has some problems with your spot-channel (that pantone color). Try to convert all spots to process when you export the pdf from inDesign. It's in [Output] -> Ink Manager.
                    Other workaround would be that you make standard color-layer in photoshop instead of extra color channel.
                    • 7. Re: Logo created in photoshop causing print issues
                      Ciaranm Level 1
                      im not sure what you mean? Could you break that down?
                      You can see the layers in the first post
                      • 8. Re: Logo created in photoshop causing print issues
                        It looks to me like some of the colouring is achieved through multiple (stacked) layering as seen here:
                        In fact - depending on if what can be seen in this is true. This is originally a black and white image.
                        I was suggesting that you flatten (combine the layers) in Photoshop so that you could apply the colour "physically" to the logo.
                        By this I mean that the logo layer is made with that colour as opposed to created by combining multiple colours.
                        Considering the colour is pretty uniform aside from the transparency > I thought this was worth a go if you are stuck with the same printing company etc.
                        Or you could always correct the Illustrator file to the correct colours?
                        Best,
                        EW
                        • 9. Re: Logo created in photoshop causing print issues
                          Theresa J Adobe Community Professional
                          A good printer should be able to take your Photoshop file of the logo and separate a Pantone plate for the blue color with the extra channel you show in your screen grab. The extra channel should be identified as a Spot color channel. If your printer doesn't know how to do this, you may need to find a higher end commercial printer who does.
                          Your other option is to print the blue color as process CMYK, which is what your printer is already attempting to do. The problem is with transparency flattening when saving a PDF out of InDesign. You can solve this problem by combining the background (cardboard texture) with the logo in Photoshop first.
                          I would create a Photoshop document the size of the InDesign page. Place the background in the document, and then the logo on top in it's correct position. Save the Photoshop composited document and place that into your InDesign layout. Personally, I design like this all the time to avoid challenges with transparency.
                          • 10. Re: Logo created in photoshop causing print issues
                            K´mo Level 3
                            Also very effective way to avoid this is to export pdf to older version. Some older RIP's can't handle the transparency right, specially with spot colors. Try version 1.3, that should work as it flattens the transparency (with converting spot color to process colors as I said earlier).
                            I'm quite sure that this problem is caused by the use of extra color channel and transparency in pdf. And the printer's software can't handle them right.
                            Sometimes there can be color shifts if there is RGB image with transparency over CMYK elements, if the color management isn't done correctly, but the white box is really rare.
