3 Replies Latest reply on Apr 13, 2017 8:49 AM by winterm
    Colour Swatches...how to see where they are used?
    PAWU Level 1
      I have a document with some colour swatches that I know to be and stay unused (Changed to spot->output PDF, in the PDF, there is no plate with that spot colour). But when selecting the unused swatches, they do not get selected. I was able to detect the culprit for 2 colours (unused character style). But now, I have no unused character or paragraph styles anymore and still colours that indicate usage.
      Isn't there a find command to find those elements?
        • 1. Re: Colour Swatches...how to see where they are used?
          vinny38 Level 4
          There are many places where those unused swatches can hide...
          Here's probably the most common one:
          1. Paragraph style B is based on paragraph style A
          2. Paragraph style A uses swatch X (the one you wan't to get rid of)
          3. Paragraph style B uses swatch Y
          4. Paragraph style A is not in use in your document. But... it is said to be in use (because of 1.) and so will be swatch X
          About a method (script?) helping to clean this up, or at least to point those swatches, I'm not aware of any.
          I'd be glad to hear about one...
          • 2. Re: Colour Swatches...how to see where they are used?
            vladan saveljic Level 4
            try to save your file in idml.
            then reopen it and select unused swatches
            • 3. Re: Colour Swatches...how to see where they are used?
              winterm Level 5
              You may still find interesting this old thread, and the script in the last post.
              It didn’t find simple colored text for me.
              However: it found a line with 0 pt weight and ’filled’ with some test color. You’re right - such an object is simply invisible. However, script found it for me.
              So: not a Swiss knife, but can be useful sometimes. Especially if you’re not going to get rid of a color, just want to find out where it is used.
