1 Reply Latest reply on Apr 13, 2017 8:28 PM by JJMack
    Photoshop CC auto-connects small curves with tablet
    jaredc77835418
      At the moment I am using a Wacom Intuos Pro, however the problem I'm experiencing happened for my Huion H610PRO as well. The issue does not occur when I am drawing with my mouse. Essentially, if I draw a small curve or angle, Photoshop automatically connects the two ends. Hopefully this image will help to explain it; 1 represents what Photoshop creates, while 2 represents what I create. All I drew is what's represented by red, yet Photoshop creates the full shape. I'm sure I've done an awful job explaining this, so if you have any clarifying questions, please ask.
      [Moved from non-technical Lounge Forum to specific Program forum... Mod]
      [Here is the list of all Adobe forums... https://forums.adobe.com/welcome]
        • 1. Re: Photoshop CC auto-connects small curves with tablet
          Problems like this have been discussed many times.  There is no one solution for there are OS versions both Windows and Mac. Different devices and device driver versions and different API on Platforms and Photoshop versions.  All must work together.
          There are OS settings, Device profiles, and Photoshop settings and configuration files. All must work together.  Please do some searching here.
          Also in the future Supply pertinent information for quicker answers
          • The more information you supply about your situation, the better equipped other community members will be to answer. Consider including the following in your question:
          • Adobe product and version number
          • Operating system and version number
          • The full text of any error message(s)
          • What you were doing when the problem occurred
          • Screenshots of the problem
          • Computer hardware, such as CPU; GPU; amount of RAM; etc.
          For example Windows 10 CC 2017.1 Wacom Intuos Pro device diver screen capture.
