Hi
Using After Effects CC 2017. (I have the original clip in Premiere CC 2017, but figure that AE would give me the most options....)
Below is a link to the short clip:
I have a few very short sequences where I need to match the color of a solid yellow Tshirt (and solid yellow baseball cap)
The clips were shot on two different days with two different cameras.
In the example below the first couple of shots have less saturation of the yellow then the final shot -- where the person is with the Robot.
I would like to mask the area because in another shot there is a person in the distance wearing a similar yellow color.
So I guess I am looking for...
Masking a short clip using the pen tool --- and then applying either a color change or a more elaborate color correction --- just to affect the shirt and cap.)
Thanks!
Rowby
I am not sure you need to leave premiere. This is under secondary color correction and the Lumetri effect has a great tool for isolating an area by color in Premiere (or Ae). a rough mask could subtract other areas if needed or cut out just the area you want. only if you need a more refined roto process then I would use Ae if I wasn't using it to begin with.
