• Global community
    • Language:
      • Deutsch
      • English
      • Español
      • Français
      • Português
  • 日本語コミュニティ
  • 한국 커뮤니티
Exit
0
Scaling down images with light border
Enthusiast ,
Apr 13, 2017 Apr 13, 2017
Is there a chance that Adobe removes the slightly light 1px border around images when I scale down an image
on a transparent layer. The light border is annoying. This side effect did not occur in earlier versions, indipendent
of different scaling methods.
THANK YOU.
Views
298
Translate
Translate
Report
Report
Community guidelines
community guidelines
Adobe
Community Expert ,
How did the border get created. You could try selecting the layers transparency. Contract the selection by a pixel or two. Invert the selection and clear. Its best not to create the border in the first place.
Sizing and masking to aspect ratio is a good way to go.
JJMack
Votes
Translate
Translate
Report
Report
Enthusiast ,
Apr 14, 2017 Apr 14, 2017
I have a 300dpi image on a layer with a transparent background.
1. I select the image using the selection tool
2. Copy
3. New document by using the exact image size
4. Pasting the image on a new layer
5. Scaling the image down using 72dpi
=> The scaled image has a 1px lighter
border around the image
I need to scale the image up again in order to eliminate the 1px border.
It's annoying. I don't want the image to obtain a slightly lighter 1px border around the image after the scaling down process.
THANK YOU
Votes
Translate
Translate
Report
Report
Community Expert ,
LATEST
That does not happen on my machine with any version of Photoshop I have installed,  I have CS2, CS6, CC, CC 2014, CC 2015, CC 2015.5 and CC 2017 installed.  Try using menu File>Place and use the place transform to size your image for the document you working on.  Also make sure you zoom to 100% when you judge.  Viewing at any other zoom percent you are not looking your documents pixels. You may or may not see some scaling artifacts like layer edges.   Photoshop scaling is done quickly for performance at some zoom percent Photoshop scaling looks very bad. You not looking at your actual documents pixels.
Changing a document resolution to 72DPI   does not change a single pixel.  You need to resample the image to change the number of pixels and when you do that you wind up with a new resized image the original image is out on your disk and in Photoshop history.
JJMack
Votes
Translate
Translate
Report
Report
