1 Reply Latest reply on Apr 15, 2017 12:04 PM by peterw14909681
    ClevertTap-cordova plugin applicationId
    NielsvdBoogaart Level 1
      Link to plugin: GitHub - CleverTap/clevertap-cordova: CleverTap Cordova Plugin
      Followed it's documentation into installing the plugin
      Attempt to run $: phonegap build android
      (Ios is working just fine)
      App ID: 2570045
      Error log:
      Build Date: 2017-04-14 09:14:00 +0000
      Subproject Path: CordovaLib
      Configuration on demand is an incubating feature.
      Incremental java compilation is an incubating feature.
      :preBuild UP-TO-DATE
      :preReleaseBuild UP-TO-DATE
      :checkReleaseManifest
      :preDebugBuild UP-TO-DATE
      :CordovaLib:preBuild UP-TO-DATE
      :CordovaLib:preDebugBuild UP-TO-DATE
      :CordovaLib:checkDebugManifest
      :CordovaLib:prepareDebugDependencies
      :CordovaLib:compileDebugAidl
      :CordovaLib:compileDebugNdk UP-TO-DATE
      :CordovaLib:compileLint
      :CordovaLib:copyDebugLint UP-TO-DATE
      :CordovaLib:mergeDebugShaders
      :CordovaLib:compileDebugShaders
      :CordovaLib:generateDebugAssets
      :CordovaLib:mergeDebugAssets
      :CordovaLib:mergeDebugProguardFiles
      :CordovaLib:packageDebugRenderscript UP-TO-DATE
      :CordovaLib:compileDebugRenderscript
      :CordovaLib:generateDebugResValues
      :CordovaLib:generateDebugResources
      :CordovaLib:packageDebugResources
      :CordovaLib:processDebugManifest
      :CordovaLib:generateDebugBuildConfig
      :CordovaLib:processDebugResources
      :CordovaLib:generateDebugSources
      :CordovaLib:incrementalDebugJavaCompilationSafeguard
      :CordovaLib:compileDebugJavaWithJavac
      :CordovaLib:compileDebugJavaWithJavac - is not incremental (e.g. outputs have changed, no previous execution, etc.).
      Note: Some input files use or override a deprecated API.
      Note: Recompile with -Xlint:deprecation for details.
      :CordovaLib:processDebugJavaRes UP-TO-DATE
      :CordovaLib:transformResourcesWithMergeJavaResForDebug
      :CordovaLib:transformClassesAndResourcesWithSyncLibJarsForDebug
      :CordovaLib:mergeDebugJniLibFolders
      :CordovaLib:transformNative_libsWithMergeJniLibsForDebug
      :CordovaLib:transformNative_libsWithSyncJniLibsForDebug
      :CordovaLib:bundleDebug
      :CordovaLib:preReleaseBuild UP-TO-DATE
      :CordovaLib:checkReleaseManifest
      :CordovaLib:prepareReleaseDependencies
      :CordovaLib:compileReleaseAidl
      :CordovaLib:compileReleaseNdk UP-TO-DATE
      :CordovaLib:copyReleaseLint UP-TO-DATE
      :CordovaLib:mergeReleaseShaders
      :CordovaLib:compileReleaseShaders
      :CordovaLib:generateReleaseAssets
      :CordovaLib:mergeReleaseAssets
      :CordovaLib:mergeReleaseProguardFiles
      :CordovaLib:packageReleaseRenderscript UP-TO-DATE
      :CordovaLib:compileReleaseRenderscript
      :CordovaLib:generateReleaseResValues
      :CordovaLib:generateReleaseResources
      :CordovaLib:packageReleaseResources
      :CordovaLib:processReleaseManifest
      :CordovaLib:generateReleaseBuildConfig
      :CordovaLib:processReleaseResources
      :CordovaLib:generateReleaseSources
      :CordovaLib:incrementalReleaseJavaCompilationSafeguard
      :CordovaLib:compileReleaseJavaWithJavac
      :CordovaLib:compileReleaseJavaWithJavac - is not incremental (e.g. outputs have changed, no previous execution, etc.).
      :CordovaLib:processReleaseJavaRes UP-TO-DATE
      :CordovaLib:transformResourcesWithMergeJavaResForRelease
      :CordovaLib:transformClassesAndResourcesWithSyncLibJarsForRelease
      :CordovaLib:mergeReleaseJniLibFolders
      :CordovaLib:transformNative_libsWithMergeJniLibsForRelease
      :CordovaLib:transformNative_libsWithSyncJniLibsForRelease
      :CordovaLib:bundleRelease
      :prepareComAndroidSupportAnimatedVectorDrawable2520Library
      :prepareComAndroidSupportAppcompatV72520Library
      :prepareComAndroidSupportCardviewV72340Library
      :prepareComAndroidSupportCustomtabs2340Library
      :prepareComAndroidSupportSupportCompat2520Library
      :prepareComAndroidSupportSupportCoreUi2520Library
      :prepareComAndroidSupportSupportCoreUtils2520Library
      :prepareComAndroidSupportSupportFragment2520Library
      :prepareComAndroidSupportSupportMediaCompat2520Library
      :prepareComAndroidSupportSupportV132340Library
      :prepareComAndroidSupportSupportV42520Library
      :prepareComAndroidSupportSupportVectorDrawable2520Library
      :prepareComDigitsSdkAndroidDigits140Library
      :prepareComFacebookAndroidFacebookAndroidSdk4141Library
      :prepareComGoogleAndroidGmsPlayServicesBase980Library
      :prepareComGoogleAndroidGmsPlayServicesBasement980Library
      :prepareComGoogleAndroidGmsPlayServicesGcm980Library
      :prepareComGoogleAndroidGmsPlayServicesIid980Library
      :prepareComGoogleAndroidGmsPlayServicesTasks980Library
      :prepareComTwitterCobaltPerformanceMetrics020Library
      :prepareComTwitterSdkAndroidTweetComposer073Library
      :prepareComTwitterSdkAndroidTweetUi110Library
      :prepareComTwitterSdkAndroidTwitter140Library
      :prepareComTwitterSdkAndroidTwitterCore132Library
      :prepareIoFabricSdkAndroidFabric130Library
      :prepareMeLeolinShortcutBadger114Library
      :prepareProjectCordovaLibUnspecifiedReleaseLibrary
      :compileReleaseAidl
      :mergeReleaseResources
      :processReleaseManifest FAILED
      FAILURE: Build failed with an exception.
      * What went wrong:
      Execution failed for task ':processReleaseManifest'.
      > No record for key [category#${applicationId}]
      * Try:
      Run with --stacktrace option to get the stack trace. Run with --info or --debug option to get more log output.
      BUILD FAILED
      Total time: 4.809 secs
      Error: /project/gradlew: Command failed with exit code 1 Error output:
      * What went wrong:
      * Try:
        at ChildProcess.whenDone (/project/cordova/node_modules/cordova-common/src/superspawn.js:169:23)
        at emitTwo (events.js:106:13)
        at ChildProcess.emit (events.js:191:7)
        at maybeClose (internal/child_process.js:877:16)
        at Process.ChildProcess._handle.onexit (internal/child_process.js:226:5)
