4 Replies Latest reply on Apr 28, 2017 7:00 AM by stephens17708265
    How do I use RestEasy in CF
    stephens17708265 Level 1
      We are attempting to deploy a java client in CF to make talking to webservices (specifically, parsing the response) a lot simpler. The problem we appear to be running into is that the server is using the Jersey Jackson provider and Client Builder instead of the RestEasy jars provided with the distribution. Does anyone know how to force CF to use the RestEasy jars? We have deployed the client jar and all required dependency jars (including RestEasy) under their own path. We have confirmed that CF is seeing the client jar by instantiating the java client  and calling certain functions. We can get up to the point where it attempts to call out to the server. Unfortunately, the error information we are receiving in CF is not particularly helpful. I believe the last one just simply told us that there was an error but nothing us any use.
      ** Note: I am the Java side of this implementation and do not know CF very well. I built the client jar used the maven assembly plugin to provide a zip file containing all of the required dependency jars. I then confirmed that I had all the required required dependencies by writing a java se app which simply made a call through the client. Unfortunately, using Jersey is not an option. It simply does not support the calls in the correct way. We need to be able to use RestEasy. Any assistance will be greatly appreciated.
        • 1. Re: How do I use RestEasy in CF
          BKBK Adobe Community Professional & MVP
          By "the server", do you mean ColdFusion? If so, how did you integrate the Jersey Jackson provider and Client Builder in ColdFusion?
          Did you try the usual method? That is, stopping ColdFusion, copying the jars to ColdFusion's lib directory (after temporarily removing any related custom JARs from this directory), and then restarting ColdFusion.
          • 2. Re: How do I use RestEasy in CF
            You are correct, when I said "server" I meant ColdFusion.
            We did deploy by stopping CF, copying the jars over and restarting. We didn't deploy the java jars and dependencies in the Cold Fusion lib directory, we put them in a custom path via the Application.cfc this.javaSettings.
            We did not integrate the Jersey Jackson provider or the Client Builder. We do find the following jersey jars in the cf lib directory:
            :/opt/coldfusion11/cfusion/bin/opt/coldfusion11/cfusion/lib/jersey-core.jar: :/opt/coldfusion11/cfusion/bin/opt/coldfusion11/cfusion/lib/jersey-server.jar: :/opt/coldfusion11/cfusion/bin/opt/coldfusion11/cfusion/lib/jersey-servlet.jar:
            • 3. Re: How do I use RestEasy in CF
              System:
              ColdFusion 2016 Developer Edition on Windows 7 Ultimate
              I did a test to integrate RestEasy in ColdFusion 2016 as follows:
              1) Download the file resteasy-jaxrs-3.1.2.Final-all.zip
              2) Unzip it and copy the folder resteasy-jaxrs-3.1.2.Final to the C: drive
              3) Stop ColdFusion.
              4) Open the file C:\ColdFusion2016\cfusion\bin\jvm.config in a text editor. (First create a backup of the file). Add RestEasy's lib directories to ColdFusion's classpath, by changing the line
              java.args=-server  -Xms256m -Xmx1024m -Xdebug -Xrunjdwp:transport=dt_socket,server=y,suspend=n,address=5005 -XX:MaxMetaspaceSize=192m -XX:+UseParallelGC -Xbatch -Dcoldfusion.home={application.home} -Duser.language=en -Dcoldfusion.rootDir={application.home} -Dcoldfusion.libPath={application.home}/lib -Dorg.apache.coyote.USE_CUSTOM_STATUS_MSG_IN_HEADER=true -Dcoldfusion.jsafe.defaultalgo=FIPS186Random -Dorg.eclipse.jetty.util.log.class=org.eclipse.jetty.util.log.JavaUtilLog -Djava.util.logging.config.file={application.home}/lib/logging.properties -Duser.language=en -Duser.country=US -Dcoldfusion.classPath={application.home}/lib/updates,{application.home}/lib,{application .home}/lib/axis2,{application.home}/gateway/lib/,{application.home}/wwwroot/WEB-INF/flex/j ars,{application.home}/wwwroot/WEB-INF/cfform/jars
              to
              java.args=-server  -Xms256m -Xmx1024m -Xdebug -Xrunjdwp:transport=dt_socket,server=y,suspend=n,address=5005 -XX:MaxMetaspaceSize=192m -XX:+UseParallelGC -Xbatch -Dcoldfusion.home={application.home} -Duser.language=en -Dcoldfusion.rootDir={application.home} -Dcoldfusion.libPath={application.home}/lib -Dorg.apache.coyote.USE_CUSTOM_STATUS_MSG_IN_HEADER=true -Dcoldfusion.jsafe.defaultalgo=FIPS186Random -Dorg.eclipse.jetty.util.log.class=org.eclipse.jetty.util.log.JavaUtilLog -Djava.util.logging.config.file={application.home}/lib/logging.properties -Duser.language=en -Duser.country=US -Dcoldfusion.classPath={application.home}/lib/updates,{application.home}/lib,{application .home}/lib/axis2,{application.home}/gateway/lib/,{application.home}/wwwroot/WEB-INF/flex/j ars,{application.home}/wwwroot/WEB-INF/cfform/jars,C:/resteasy-jaxrs-3.1.2.Final/lib,C:/resteasy-jaxrs-3.1.2.Final/embedded-lib
              5) Save the file jvm.config and restart ColdFusion.
              6) Run the following test code in a CFM page:
              <cfset testObject = createobject("java","javax.ws.rs.Path")>
              <cfdump var="#testObject#">
              7) The successful result:
              • 4. Re: How do I use RestEasy in CF
                Thank you for the step by step directions. We were able to follow them and get the same results. Our "regular" duties have gotten in the way this week so we haven't had the chance to do any further work on attempting to get our client to work but at least we know that we are able to force the resteasy implementation to load. I will mark this answer as correct as it answered my question and will update this thread with our results.
                Thanks!
