hello I am trying to print a document that I have downloaded form Nevada state gov. I have filled it out saved it as a pdf but I t will not print I have tried everything can you help
[Moved from non-technical Lounge Forum to an Acrobat forum... Mod]
[Here is the list of all Adobe forums... https://forums.adobe.com/welcome]
In the print dialog in either Reader or Acrobat, make sure under Comments & Forms you specify Documents and Markups as opposed to Document. Otherwise, the forms fields do not print.
- Dov
Small correction: Form fields will always print (unless they are set as non-printable, of course). The setting you mentioned only affects comments.
