0 Replies Latest reply on Apr 14, 2017 11:49 PM by photoe56999331
    I am Creating creative sdk image editor in Phonegap but i am build failed error
    photoe56999331
      Build Date: 2017-04-15 06:42:06 +0000
      PLUGIN OUTPUT
      Fetching plugin "cordova-plugin-whitelist@~1.2.1" via npm
      Installing "cordova-plugin-whitelist" at "1.2.2" for android
        This plugin is only applicable for versions of cordova-android greater than 4.0. If you have a previous platform version, you do *not* need this plugin since the whitelist will be built in.
      Fetching plugin "phonegap-plugin-csdk-client-auth@~1.0.0" via npm
      Installing "phonegap-plugin-csdk-client-auth" at "1.0.6" for android
      Subproject Path: CordovaLib
      Fetching plugin "phonegap-plugin-csdk-image-editor@~1.0.0" via npm
      Installing "phonegap-plugin-csdk-image-editor" at "1.0.0" for android
      Fetching plugin "cordova-plugin-camera@~2.2.0" via npm
      Installing "cordova-plugin-camera" at "2.2.0" for android
      Fetching plugin "cordova-plugin-compat" via npm
      Installing "cordova-plugin-compat" at "1.1.0" for android
      COMPILE OUTPUT
      Configuration on demand is an incubating feature.
      Incremental java compilation is an incubating feature.
      WARNING: Ignoring Android API artifact com.google.android:android:2.2.1 for debug
      WARNING: Ignoring Android API artifact com.google.android:android:2.2.1 for release
      :preBuild UP-TO-DATE
      :preDebugBuild UP-TO-DATE
      :checkDebugManifest
      :preReleaseBuild UP-TO-DATE
      :CordovaLib:preBuild UP-TO-DATE
      :CordovaLib:preDebugBuild UP-TO-DATE
      :CordovaLib:checkDebugManifest
      :CordovaLib:prepareDebugDependencies
      :CordovaLib:compileDebugAidl
      :CordovaLib:compileDebugNdk UP-TO-DATE
      :CordovaLib:compileLint
      :CordovaLib:copyDebugLint UP-TO-DATE
      :CordovaLib:mergeDebugShaders
      :CordovaLib:compileDebugShaders
      :CordovaLib:generateDebugAssets
      :CordovaLib:mergeDebugAssets
      :CordovaLib:mergeDebugProguardFiles
      :CordovaLib:packageDebugRenderscript UP-TO-DATE
      :CordovaLib:compileDebugRenderscript
      :CordovaLib:generateDebugResValues
      :CordovaLib:generateDebugResources
      :CordovaLib:packageDebugResources
      :CordovaLib:processDebugManifest
      :CordovaLib:generateDebugBuildConfig
      :CordovaLib:processDebugResources
      :CordovaLib:generateDebugSources
      :CordovaLib:incrementalDebugJavaCompilationSafeguard
      :CordovaLib:compileDebugJavaWithJavac
      :CordovaLib:compileDebugJavaWithJavac - is not incremental (e.g. outputs have changed, no previous execution, etc.).
      Note: Some input files use or override a deprecated API.
      Note: Recompile with -Xlint:deprecation for details.
      :CordovaLib:processDebugJavaRes UP-TO-DATE
      :CordovaLib:transformResourcesWithMergeJavaResForDebug
      :CordovaLib:transformClassesAndResourcesWithSyncLibJarsForDebug
      :CordovaLib:mergeDebugJniLibFolders
      :CordovaLib:transformNative_libsWithMergeJniLibsForDebug
      :CordovaLib:transformNative_libsWithSyncJniLibsForDebug
      :CordovaLib:bundleDebug
      :CordovaLib:preReleaseBuild UP-TO-DATE
      :CordovaLib:checkReleaseManifest
      :CordovaLib:prepareReleaseDependencies
      :CordovaLib:compileReleaseAidl
      :CordovaLib:compileReleaseNdk UP-TO-DATE
      :CordovaLib:copyReleaseLint UP-TO-DATE
      :CordovaLib:mergeReleaseShaders
      :CordovaLib:compileReleaseShaders
      :CordovaLib:generateReleaseAssets
      :CordovaLib:mergeReleaseAssets
      :CordovaLib:mergeReleaseProguardFiles
      :CordovaLib:packageReleaseRenderscript UP-TO-DATE
      :CordovaLib:compileReleaseRenderscript
      :CordovaLib:generateReleaseResValues
      :CordovaLib:generateReleaseResources
      :CordovaLib:packageReleaseResources
      :CordovaLib:processReleaseManifest
      :CordovaLib:generateReleaseBuildConfig
      :CordovaLib:processReleaseResources
      :CordovaLib:generateReleaseSources
      :CordovaLib:incrementalReleaseJavaCompilationSafeguard
      :CordovaLib:compileReleaseJavaWithJavac
      :CordovaLib:compileReleaseJavaWithJavac - is not incremental (e.g. outputs have changed, no previous execution, etc.).
      :CordovaLib:processReleaseJavaRes UP-TO-DATE
      :CordovaLib:transformResourcesWithMergeJavaResForRelease
      :CordovaLib:transformClassesAndResourcesWithSyncLibJarsForRelease
      :CordovaLib:mergeReleaseJniLibFolders
      :CordovaLib:transformNative_libsWithMergeJniLibsForRelease
      :CordovaLib:transformNative_libsWithSyncJniLibsForRelease
      :CordovaLib:bundleRelease
      :prepareComAdobeCreativesdkAndroidSharedAndroidShared006Library
      :prepareComAdobeCreativesdkAndroidSharedCommonCommonUi115Library
      :prepareComAdobeCreativesdkFoundationAuth091186Library
      :prepareComAdobeCreativesdkImage463Library
      :prepareComAdobeCreativesdkImageNative11335Library
      :prepareComAndroidSupportAnimatedVectorDrawable2421Library
      :prepareComAndroidSupportAppcompatV72421Library
      :prepareComAndroidSupportCardviewV72340Library
      :prepareComAndroidSupportDesign2340Library
      :preDebugAndroidTestBuild UP-TO-DATE
      :prepareComAndroidSupportMultidex101Library
      :prepareComAndroidSupportPaletteV72340Library
      :prepareComAndroidSupportRecyclerviewV72340Library
      :prepareComAndroidSupportSupportCompat2421Library
      :prepareComAndroidSupportSupportCoreUi2421Library
      :prepareComAndroidSupportSupportCoreUtils2421Library
      :prepareComAndroidSupportSupportFragment2421Library
      :prepareComAndroidSupportSupportMediaCompat2421Library
      :prepareComAndroidSupportSupportV42421Library
      :prepareComAndroidSupportSupportVectorDrawable2421Library
      :prepareComBirbitAndroidPriorityJobqueue200Beta2Library
      :prepareComGetbaseFloatingactionbutton1100Library
      :prepareComGithubFengdaiAlertdialogproCore026Library
      :prepareComGithubFengdaiAlertdialogproThemeMaterial026Library
      :prepareComGoogleAndroidGmsPlayServicesBase840Library
      :prepareComGoogleAndroidGmsPlayServicesBasement840Library
      :prepareComInfstoryProguardAnnotations102Library
      :prepareComJakewhartonRxbindingRxbinding040Library
      :prepareComJakewhartonRxbindingRxbindingAppcompatV7040Library
      :prepareComJakewhartonRxbindingRxbindingSupportV4040Library
      :prepareComLocalyticsAndroidLibrary380Library
      :prepareComSothreeSlidinguppanelLibrary300Library
      :prepareComTimehopStickyheadersrecyclerviewLibrary043Library
      :prepareComTrelloRxlifecycle061Library
      :prepareComTrelloRxlifecycleComponents061Library
      :prepareDeHdodenhofCircleimageview200Library
      :prepareIoReactivexRxandroid120Library
      :prepareItSephirothAndroidExifAndroidExifExtended106Library
      :prepareItSephirothAndroidLibraryAbAbTest205Library
      :prepareItSephirothAndroidLibraryDisklrumulticacheDisklrumulticache108Library
      :prepareItSephirothAndroidLibraryImagezoomImagezoom225Library
      :prepareItSephirothAndroidLibraryPicassoPicasso2524bLibrary
      :prepareItSephirothAndroidLibraryTargettooltipTargetTooltipLibrary1314Library
      :prepareItSephirothAndroidLibraryViewrevealanimatorViewRevealAnimator114Library
      :prepareItSephirothRxbroadcast002Library
      :prepareProjectCordovaLibUnspecifiedDebugLibrary
      :compileDebugAidl
      :mergeDebugResources
      :processDebugManifest/project/AndroidManifest.xml:3:132-159 Error:
      Attribute supports-screens@smallScreens value=(true) from AndroidManifest.xml:3:132-159
      is also present at [com.adobe.creativesdk:image:4.6.3] AndroidManifest.xml:15:9-37 value=(false).
      Suggestion: add 'tools:replace="android:smallScreens"' to <supports-screens> element at AndroidManifest.xml:3:5-191 to override.
      See http://g.co/androidstudio/manifest-merger for more information about the manifest merger.
      :processDebugManifest FAILED
      FAILURE: Build failed with an exception.
      * What went wrong:
      Execution failed for task ':processDebugManifest'.
      > Manifest merger failed : Attribute supports-screens@smallScreens value=(true) from AndroidManifest.xml:3:132-159
      * Try:
      Run with --stacktrace option to get the stack trace. Run with --info or --debug option to get more log output.
      BUILD FAILED
      Total time: 10.892 secs
      Error: /project/gradlew: Command failed with exit code 1 Error output:
      * What went wrong:
      * Try:
        at ChildProcess.whenDone (/project/cordova/node_modules/cordova-common/src/superspawn.js:169:23)
        at emitTwo (events.js:106:13)
        at ChildProcess.emit (events.js:191:7)
        at maybeClose (internal/child_process.js:877:16)
        at Process.ChildProcess._handle.onexit (internal/child_process.js:226:5)
