1 Reply Latest reply on Apr 15, 2017 6:03 AM by JJMack
    Paste in multiple files
    kailynm8623
      Is there a way to paste across multiple files at once? I need to put my watermark on multiple images, but don't want to paste on every single file. Can I just open all of my files and paste on everything? Thanks!
        • 1. Re: Paste in multiple files
          Paste would not be a good way to batch process your watermark onto you images if you have different size and aspect ratio images. You most likely would want to size and position the watermark for the image being processed.  A simple action could watermark you image.  You could than use the image processor  script from Adobe Bridge menu  Tools>Photoshop>Images processor. Where you first select the thumbnails for the images files you want to watermark.  The image processor would then  process the files select in the bridge and save watermarked Image files of the image to where you want them saved fitted to any size you need. The action may be very simple like use is a script to watermark the current document. I have posted a script the is easy to modify to use your watermark. Your Watermark files will be placed onto the image sized for the image and position the the bottom right corner by my script.  The action could re-position the watermark layers and add a layer style if you wanted to.
          PlaceWatermark.jsx
          #target photoshop;
          app.bringToFront();
          var logoFile = "~/Desktop/JJMack.png"; // Watermark file should be large for resize down works better than up
          var LogoSize = 10; // percent of document height to resize Watermark to
          var LogoMargin = 1;                                         // percent of Document height the Watermark should have as a margin
          placeWatermark(logoFile, LogoSize, LogoMargin);             // Place Watermark  into the bottom right of document
          function placeWatermark(Image,Size,Margin){
            if(!documents.length) return;   // if no document return
            try{
            var doc = app.activeDocument; // set Doc object to active document
            app.displayDialogs = DialogModes.NO; // Dialog off
            var strtRulerUnits = app.preferences.rulerUnits; // Save Users ruler units
            var strtTypeUnits = app.preferences.typeUnits; // Save Users Type units
            app.preferences.rulerUnits = Units.PIXELS; // work with pixels
            app.preferences.typeUnits = TypeUnits.PIXELS; // work with pixels
            var fileObj = new File(Image);                 // the passed file
            if(!fileObj.exists){   // If file does not exits tell user
            alert(fileObj.name  + " does not exist!");
            return;
            placeFile(fileObj); // Place in file the Watermark png file
            activeDocument.activeLayer.resize(100 ,100,AnchorPosition.MIDDLECENTER); // Insure Place did not scale layer
            var SB = activeDocument.activeLayer.bounds; // get layers bounds
            var layerHeight = SB[3] - SB[1]; // get layers height
            var resizePercent = (100/layerHeight)*(Size/100*doc.height.value); // Percent to resize by
            activeDocument.activeLayer.resize(resizePercent ,resizePercent,AnchorPosition.MIDDLECENTER);  // Resize width and height by percentage
            SB = activeDocument.activeLayer.bounds; // get resized layers bounds
            activeDocument.activeLayer.translate(-SB[0].value,-SB[1].value); // Move resized layer to top left canvas corner
            var LayerWidth = (SB[2].value - SB[0].value);
            var LayerHeight = (SB[3].value - SB[1].value);
            marginSize = Margin/100*doc.height.value; // move resized watermark into the document lower right corner with some margin
            activeDocument.activeLayer.translate((doc.width.value -marginSize - LayerWidth),( doc.height.value -marginSize - LayerHeight));
            catch(e) { alert(e + ': on line ' + e.line); } // inform user of error
            finally{
            app.preferences.rulerUnits = strtRulerUnits; // Restore user ruler units
            app.preferences.typeUnits = strtTypeUnits; // Restore user type units
          function placeFile(placeFile) {
              var desc21 = new ActionDescriptor();
              desc21.putPath( charIDToTypeID('null'), new File(placeFile) );
              desc21.putEnumerated( charIDToTypeID('FTcs'), charIDToTypeID('QCSt'), charIDToTypeID('Qcsa') );
              var desc22 = new ActionDescriptor();
              desc22.putUnitDouble( charIDToTypeID('Hrzn'), charIDToTypeID('#Pxl'), 0.000000 );
              desc22.putUnitDouble( charIDToTypeID('Vrtc'), charIDToTypeID('#Pxl'), 0.000000 );
              desc21.putObject( charIDToTypeID('Ofst'), charIDToTypeID('Ofst'), desc22 );
              executeAction( charIDToTypeID('Plc '), desc21, DialogModes.NO );
