2 Replies Latest reply on Apr 15, 2017 6:14 PM by rikis10295378
    Adobe Acrobat X-Pro
    rikis10295378
      A short time after HP recently remotely worked on a separate problem on my computer, I noticed I could no longer print to pdf!
      1. Convert a Word doc to pdf - In the past, I hit Print, and then changed the setting from Printer, to print to Adobe PDF. Now when I attempt to do
        same, a pop-up appears that says “We couldn’t print because there doesn’t seem to be a printer installed. :-( “
      2. Convert a PDF to another PDF – I would do same as for Word (#1), but now instead of converting to pdf, or getting an advisement pop-up, document just prints directly to my printer!
      How do I get things back to where they used to be?
        • 1. Re: Adobe Acrobat X-Pro
          Acrobat X is quit old and is no longer supported by Adobe. Acrobat X has not been updated to work with MS Office 2013 and 2016.
          • 2. Re: Adobe Acrobat X-Pro
            rikis10295378 Level 1
            Appreciate your responding to my question. Yes, I am aware that Acrobat X-Pro is no longer supported by Adobe. That is the reason why I have been relegated to the Forum, to find solutions for my Adobe problems. And to date, I haven't any answers. I happen to have MS Office 2013, and Adobe Acrobat X-Pro has worked fine for years, until as I had noted above, things only changed after HP recently remotely worked on a separate problem on my computer.
            Would you happen to know how to fix the Adobe issues I have?
            Thank you.
            RKS
