0 Replies Latest reply on Apr 15, 2017 10:26 PM by ablopezmty
    iOS Archive step FAILING in PhoneGap Build
    ablopezmty Level 1
      Starting today iOS build is failing to complete, without any changes to the config.xml, where it worked previously. App ID in PGB is: 2540237.
      It seems the build is failing on the archiving step, here's the log output:
      === BUILD TARGET DeportivoBancario OF PROJECT DeportivoBancario WITH CONFIGURATION Release ===
      Check dependencies
      “Use Legacy Swift Language Version” (SWIFT_VERSION) is required to be configured correctly for targets which use Swift. Use the [Edit > Convert > To Current Swift Syntax…] menu to choose a Swift version or use the Build Settings editor to configure the build setting directly.
      ** ARCHIVE FAILED **
      The following build commands failed:
      Check dependencies
      (1 failure)
      Error code 65 for command: xcodebuild with args: -xcconfig,/private/tmp/gimlet/2540237/project/cordova/build-release.xcconfig,-workspace,D eportivoBancario.xcworkspace,-scheme,DeportivoBancario,-configuration,Release,-destination ,generic/platform=iOS,-archivePath,DeportivoBancario.xcarchive,archive,CONFIGURATION_BUILD _DIR=/private/tmp/gimlet/2540237/project/build/device,SHARED_PRECOMPS_DIR=/private/tmp/gim let/2540237/project/build/sharedpch
