2 Replies Latest reply on Apr 16, 2017 12:15 AM by akiva_atwood
    Prototype issue
    akiva_atwood Level 1
      I'm playing with adding FP functionality -- but prototype isn't working for me.
      A code sample - I get an "a.indexOf is not a function" error. Anyone see why I'm getting that error? It works fine in a javascript editor.
      main();
      function main(){
      var a=[4,9,16];
      alert(a);
      b=a.indexOf(9);
      alert(b);
      Array.prototype.indexOf = function (elem, fromIndex){
          fromIndex = Number(fromIndex) || 0;
          var len = this.length;
          if (fromIndex < 0){
              fromIndex += len;
          for(var i=fromIndex;i<this.length;i++){
              if(this[i] == elem){
                  return i;
          return -1;
        • 1. Re: Prototype issue
          declare your prototype inside of main() before using it.
          This is working:
          main();
          function main()
                  if (fromIndex < 0)
                      fromIndex += len;
                      if(this[i] == elem)
                          return i;
                  return -1;
              var a=[4,9,16];
              alert(a);
              b=a.indexOf(9);
              alert(b);
          Or declare your prototype before everything else:
              if (fromIndex < 0)
                  fromIndex += len;
                  if(this[i] == elem)
                      return i;
              return -1;
          main();
          function main()
              var a=[4,9,16];
              alert(a);
              b=a.indexOf(9);
              alert(b);
          But e.g. this is not working:
          main();
          function main()
              var a=[4,9,16];
              alert(a);
              b=a.indexOf(9);
              alert(b);
                  if (fromIndex < 0)
                      fromIndex += len;
                      if(this[i] == elem)
                          return i;
                  return -1;
          ExtendScript is a bit picky on prototype.
          BTW: You can use the forum's Advanced Editing feature to format your text as code.
          >> Insert > Syntax Highlighting > javascript
          Regards,
          Uwe
          • 2. Re: Prototype issue
            Thanks. I figured scope would take care of that...
