5 Replies Latest reply on Apr 18, 2017 9:12 AM by kglad
    Walk a character using mouse event AS3
    cjyoon1227
      Hello everyone! I'm creating an Android game for our thesis. I want to walk my character after I click the stage (in one direction only), and the character goes to the key. I've searched about this thing on an internet then I found a code about this but it fails. I really don't know what code that I can put on an Actions (F9), I've tried and tried but until now, it fails.
      My character has 9 keyframes on it, one movement per keyframe:
      Here's the picture of my actual game interface (with edited texts):
      Note: The long arrow shows that I want my character to go thru the key after clicking a stage.
      And I don't think that my frames are right because I did two keyframes per game because after I got a key, the questionnaire will appear and after the "correct!" window appears, the door will open and the character will disappear after it enters to the door.
      And here's my code:
      stop();
      import flash.text.*;
      import flash.display.MovieClip;
      import flash.net.URLLoader;
      import flash.net.URLRequest;
      import flash.events.MouseEvent;
      import flash.events.Event;
      import flash.events.*;
      import flash.display.DisplayObject;
      import flash.geom.Point;
      import flash.display.Stage;
      import flash.display.Sprite;
      var buhay = 3;
      var iskoru = 0;
      var hinto = 3;
      var iswalking = false;
      var goX = playergril.x; // goX - the point on the X axis to which playergril must move
      var goY = playergril.y; // same as goX but on the Y axis
      var movespeed = 5; // movespeed of our hero
      var dir = "step1"; // current direction of movement
      var keyCollected: Boolean = false;
      var doorOpen: Boolean = false;
      var limiterX = key.x;
      var limiterY = key.y;
      var min_x = 10;
      var min_y = 5;
      var max_x = 20;
      var max_y = 10;
      stage.addEventListener(Event.ENTER_FRAME, loop);
      function loop(Event) {
        // animation handling
        // direction handling
        playergril.gotoAndStop(dir);
        // movement handling
        if ((goX - movespeed) > playergril.x) {
        playergril.x += movespeed;
        if(playergril.x > max_x){
        playergril.x = max_x;
        dir = "step1";
        iswalking = true;
        } else if ((goX + movespeed) < playergril.x) {
        playergril.x -= movespeed;
        if(playergril.x > min_x){
        playergril.x = min_x;
        dir = "step3";
        iswalking = true;
        } else if ((goY - movespeed) > playergril.y) {
        playergril.y += movespeed;
        if(playergril.y > max_y){
        playergril.y = max_y;
        dir = "step6";
        iswalking = true;
        } else if ((goY + movespeed) < playergril.y) {
        playergril.y -= movespeed;
        if(playergril.y > min_y){
        playergril.y = min_y;
        dir = "step9";
        iswalking = true;
        } else {
        iswalking = false;
      stage.addEventListener(MouseEvent.CLICK, setposition);
      // set the position to which playergril must move on click
      function setposition(MouseEvent) {
        goX = mouseX;
        goY = mouseY;
      if (keyCollected == false) {
        if (playergril.hitTestObject(key)) {
        key.visible = false;
        keyCollected = true;
        trace("key collected");
      btnForward.addEventListener(MouseEvent.CLICK, forward);
      function forward(event: MouseEvent): void {
        gotoAndStop(76);
        playergril.visible = false;
      Is there something wrong on that code? Any suggestions or code that may solve on my problem? Any help will be appreciated. Thanks!
