5 Replies Latest reply on Apr 17, 2017 6:04 PM by Chuck Uebele
    Replaced the scroll bar with a drop down list. A dialog box.
    Ps-Design Level 1
      I needed to create a menu by adding a scrollbar on radio buttons to a dialog box.
      How to make a scrollbar work in a dialog box.
      Our friend Chuck Uebele gave me a wonderful idea and helped me create a dropdown list, it really is a great idea and it was a marvel, however, I needed to add 3 more buttons (two radio) and a checkbox, all Organized by groups of panels:
      GP1: (Dropdown list)
      GP2: (Radio and Checkox)
      I noticed that clicking on the "OK" button, the events in Group 2 (GP2) did not work
      I need all events to run only when I click the OK button.
      Script:
      var dlg = new Window('dialog','Caneca Opções');
          dlg.orientation = "column";
          dlg.alignChildren = "top";  // insert this line
          var GP1 = dlg.add('group')
                 GP1.orientation = 'row';
                 GP1.alignment = ['left','top'];
          var GP2 = dlg.add('group')
                 GP2.orientation = 'row';
                 GP2.alignment = ['left','top'];
          var list = GP1.add('panel',undefined,'Modelo da Caneca');
                  list.orientation = 'row';
                  list.alignment = ['left','top'];
           var listdropDown =list.add ("dropdownlist", undefined, [
           "Alça e Interior Azul",
           "Alça e Interior Vermelho", "Alça e Interior Preta             ",
           "Alça e Interior Roso", "Do Tipo Toda Branca",
           "Do Tipo Pratiada", "Do Tipo Caneca Mágica",
           "Interior Azul", "Interior Roso", "Interior Verde",
           "Interior Vermelho", "Interior Preto", "Modelo dia dos Pais",
           "Caneca de Aluminio", "Meia Estampa " , "Caneca Dupla"
       listdropDown.selection = 0;
      var radio_group = GP2.add('panel', undefined, "Complement Settings ");
      //var radio_group2 = GP2.add('panel',undefined,'Backup');
          // Radio
              radio_group.orientation="row";
              radio_group.alignChildren = "left";
              radio_group.add("radiobutton", undefined, "2 vezes");
              radio_group.add("radiobutton", undefined, "Juntar");
              radio_grouporientation = 'row';
              radio_group.alignChildren = ['left','top'];
              var check1 = radio_group.add('checkbox',undefined,'Save');
              check1.value = true;
          var btnGroup = GP1.add("group");
              btnGroup.orientation = "column";
              btnGroup.alignment = ['left','top'];
              btnGroup.add ('button', {x:90, y:125, width:90, height:25}, 'Ok', {name:'ok'});
              btnGroup.add ('button', {x:240, y:125, width:90, height:25}, 'Cancel', {name:'cancel'});
      btnGroup.ok.onClick = function(){
      dlg.close()
          switch(parseInt(listdropDown.selection)){
                  case 0:
                  //code here
                  alert("Alça e Interior Azul");
                  break;
              case 1:
                  //code here
                  alert("Alça e Interior Vermelho");
                  break;
              case 2:
                  //code here
                  alert("Alça e Interior Preta");
                  break;
         // Radio
         // radio_group.children[0].value = true;
        function selected_rbutton(rbuttons) {
              for (var i = 0; i < rbuttons.children.length; i++) {
                  if (rbuttons.children[i].value == true) {
                      return rbuttons.children[i].text;
          // Linkar com os Scrips.jsx
          if (dlg.show() == 1) {
              var chosenRadioButton = selected_rbutton(radio_group);
              switch (chosenRadioButton) {
              case "2 vezes":
                  alert("2x a Mesma");
                  break;
              case "2 x":
                  alert("Juntar");
                  break;
            if(check1.value){alert('Save')}
      I think it has something related to this line:
      BtnGroup.ok.onClick = function () {
      Friends, how do you fix this problem? Any suggestions or help will be valid. Thank you
        • 1. Re: Replaced the scroll bar with a drop down list. A dialog box.
          Chuck Uebele Adobe Community Professional & MVP
          Put everything in either the btnGroup.ok.onClick function or in the if(dlg.show()==1.These are redundant and most likely only one will work.
          • 2. Re: Replaced the scroll bar with a drop down list. A dialog box.
            Ps-Design Level 1
            Hi, Chuck Uebele I'm sorry for my lack of understanding: As I put it in practice, do I put everything in the btnGroup.ok.onClick function or in the if (dlg.show () == 1? How to do this as a checkbox too? I do not know how to modify.
            • 3. Re: Replaced the scroll bar with a drop down list. A dialog box.
              You can add it to either one. I like using the onClick one. You need to also add a dlg.show() statement when you use that and not the other method:
                      // Radio
                  dlg.close()
                              case 0:
                              //code here
                              break;
                          case 1:
                              //code here
                              break;
                          case 2:
                              //code here
                              break;
                          case "2 vezes":
                              break;
                          case "2 x":
                              alert("Juntar");
                              break;
                     // Radio
                  dlg.show();//add a show statement
               /*  This entire part csn be deleted
                          case "2 vezes":
                              break;
                          case "2 x":
                              alert("Juntar");
                              break;
              • 4. Re: Replaced the scroll bar with a drop down list. A dialog box.
                Ps-Design Level 1
                Perfect! It works divinely well, I'm very happy with the result. ... Thank you very much for your help and for sharing your knowledge with us. nice to talk to you.
