• Global community
    • Language:
      • Deutsch
      • English
      • Español
      • Français
      • Português
  • 日本語コミュニティ
  • 한국 커뮤니티
Exit
0
When I import a video clip, it's blown up to a huge size every time
Participant ,
Apr 16, 2017 Apr 16, 2017
I didn't used to have this problem, and I don't remember changing any settings.  It all started when I imported a png of a projection-mapping layout (exported from Madmapper) so that I could work with it in AE.  When I did that, the preview window showed a hugely blown-up image, and transforming it manually to fit the screen didn't work. Now, AE distorts everything I try importing--even mov clips where I had no issues with size before.  Has anyone had this issue? How did you fix it?
Views
393
Translate
Translate
Report
Report
Community guidelines
community guidelines
Enthusiast , Apr 18, 2017 Apr 18, 2017
You have the composition view set at 200%. Look at the drop-down at the bottom-left of the composition window to change it to "Fit" or "100%".
Votes
Translate
Translate
LEGEND ,
Show us some screenshots and provide system information and Ae version full numbers.
Votes
Translate
Translate
Report
Report
Participant ,
Am running AE CC 2015.3.  If you look at the screenshot, the preview shows only part of the entire drum kit (this is just sample footage to show as an example) The left-hand thumbnail at the top shows what the entire image is supposed to look like.Screen Shot 2017-04-18 at 7.09.57 PM.png
Votes
Translate
Translate
Report
Report
Enthusiast ,
Votes
Translate
Translate
Report
Report
Participant ,
Apr 19, 2017 Apr 19, 2017
Thank you Horshack.  funny I don't remember putting it on that setting, but this has happened before so I should've guessed lol
Votes
Translate
Translate
Report
Report
LEGEND ,
If your mouse is over the composition window and you hit the scroll wheel, it zooms. Handy feature unless you do it by accident without realizing you've done it
Votes
Translate
Translate
Report
Report
Participant ,
Update: This solved the problem with videos, but I am still having the problem with still images (png) even though the settings are on "fit".
Votes
Translate
Translate
Report
Report
LEGEND ,
You may need to scale your images down smaller to fit inside your composition.
Votes
Translate
Translate
Report
Report
LEGEND ,
LATEST
maybe the still is bigger than the size of your composition? right click on the layer, choose transform, you will see options to fit to comp, fit to comp height, fit to comp width.
Votes
Translate
Translate
Report
Report
