7 Replies Latest reply on May 23, 2017 2:34 PM by Kevin-Monahan
    After_EffectsCC (version 14.1.0.57) Can't use Mercury GPU Acceleration on Win(10.0.14393 Build 14393)
    JonHutt22
      I am unable to use Mercury GPU Acceleration. The problem started when I converted a piece of Footage from Premiere Pro CC into a After-effects Composition I got the following message:
      Error Message: This project was last used with Mercury GPU Acceleration (OpenCL), which is not
      avaliable on this system. Mercury Software Only will be Used.
      Since the initial error I check and the Mercury GPU Acceleration is not avaliable on several different project files.
      I have tried reloading the after-effects project. I have tried resetting the After-Effect Preference file. I have also updated my video card drivers. I have checked and it appears I have to most upto date verison of After-Effects. Hardware specs are listed below:
      SystemVideo Card
      Windows 10 Home Version: 1607,
      OS Build: 14393.1066
      Processor Intel(R) Core(TM) i7 CPU 860 @2.80GHz 2.80 GHz
      Installed Memory (RAM) 16.0 GB
      System Type: 64-bit Operating System, x64 Based Processor
      My Main Drive is a Samsung SSD Drive PRO 512GB
        AMD Radeon HD 5800 Series
                            Radeon Settings Version - 2016.0226.1531.27895
                            Driver Packaging Version - 15.301.1901-160226a-299900E
                            Provider - Advanced Micro Devices, Inc.
                            2D Driver Version - 8.1.1.1533
                            Direct3D® Version - 9.14.10.1171
                            OpenGL® Version - 6.14.10.13417
                            OpenCL™ Version - 2.0.4.0
                            AMD Mantle Version - 9.1.10.99
                            AMD Mantle API Version - Not Available
                            AMD Audio Driver Version - 10.0.0.2
      Any suggestions are greatly appreciatated. Thank You,
