16 Replies Latest reply on May 4, 2017 10:35 AM by edgardm65525479
    Phonegap ios build fails due to missing parameter
    rssc
      Hello everyone,
      Since a couple of days my ios phonegap build suddenly fails with the following error:
      Error - One of your plugins requires a parameter: URL_SCHEME - You can fix this here
      This is a customized Moodle mobile app, which uses the cordova custom url scheme plugin.  However, the parameter URL_SCHEME is correctly defined in the config.xml as follows:
      <gap:plugin name="cordova-plugin-customurlscheme" source="npm">
           <param name="URL_SCHEME" value="moodlemobile" />
      </gap:plugin>
      The log states the following:
      "plugman install --platform ios --project /project --plugin cordova-plugin-customurlscheme": Fetching plugin "cordova-plugin-customurlscheme" via npm
      Installing "cordova-plugin-customurlscheme" for ios
      Failed to install 'cordova-plugin-customurlscheme':Error: Variable(s) missing: URL_SCHEME
          at /usr/local/lib/node_modules/plugman/node_modules/cordova-lib/src/plugman/install.js:362:2 3
          at _fulfilled (/usr/local/lib/node_modules/plugman/node_modules/q/q.js:787:54)
          at self.promiseDispatch.done (/usr/local/lib/node_modules/plugman/node_modules/q/q.js:816:30)
          at Promise.promise.promiseDispatch (/usr/local/lib/node_modules/plugman/node_modules/q/q.js:749:13)
          at /usr/local/lib/node_modules/plugman/node_modules/q/q.js:557:44
          at flush (/usr/local/lib/node_modules/plugman/node_modules/q/q.js:108:17)
          at _combinedTickCallback (internal/process/next_tick.js:67:7)
          at process._tickCallback (internal/process/next_tick.js:98:9)
      The build was working fine with the same codebase last week, something must have changed in the last couple of days.  The Android build still works without any issues.  A few other users seem to have the same issue:
      Moodle in English: Phonegap build fails due to missing parameter: URL_SCHEME
      Any ideas?  Many thanks!
