5 Replies Latest reply on Apr 20, 2017 10:01 PM by infod18708743
    The following build commands failed: CopyPlistFile
    michaelg10034009
      We've started receiving the above error intermittently (more often then not though).  This problem began when we added a custom custom Plugin to copy to the GoogleService-Info.plist file required by Firebase Cloud Messaging.
      Android is building and running fine.  Please note, that the build sometimes does work and sometimes doesn't.
      The Plugin's plugin.xml file is
      <?xml version="1.0" encoding="UTF-8"?>
      <plugin xmlns="http://apache.org/cordova/ns/plugins/1.0" xmlns:android="http://schemas.android.com/apk/res/android" id="cordova-plugin-fcm-config" version="1.0.0">
          <name>cordova-plugin-fcm-config</name>
          <description>This plugin copies the required fcm configurations in the project folder</description>
          <platform name="android">
              <source-file src="google-services.json" target-dir="./"/>
          </platform>
          <platform name="ios">
              <source-file src="GoogleService-Info.plist" />
          </platform>
      </plugin>
      And the iOS log file is as follows.
      Build Date: 2017-04-17 04:19:16 -0700
      PLUGIN OUTPUT
      Fetching plugin "cordova-plugin-inappbrowser" via npm
      Installing "cordova-plugin-inappbrowser" for ios
      Fetching plugin "cordova-plugin-customurlscheme" via npm
      Installing "cordova-plugin-customurlscheme" for ios
      Fetching plugin "cordova-plugin-whitelist" via npm
      Installing "cordova-plugin-whitelist" for ios
      Fetching plugin "cordova-plugin-device@latest" via npm
      Installing "cordova-plugin-device" for ios
      Fetching plugin "cordova-plugin-fullscreen@latest" via npm
      Installing "cordova-plugin-fullscreen" for ios
      Fetching plugin "cordova-plugin-badge@latest" via npm
      Installing "cordova-plugin-badge" for ios
      Fetching plugin "cordova-plugin-app-event" via npm
      Installing "cordova-plugin-app-event" for ios
      Fetching plugin "cordova-plugin-fcm@latest" via npm
      Installing "cordova-plugin-fcm" for ios
      Cordova FCM plugin v2.1.1 installed
      For more details visit https://github.com/fechanique/cordova-plugin-fcm
      Fetching plugin "@kickstep/cordova-plugin-fcm-config-branch@latest" via npm
      Installing "cordova-plugin-fcm-config" for ios
      COMPILE OUTPUT
      Now using system ruby.
      Building project: /private/tmp/gimlet/1645041/project/RBBranch.xcworkspace
      Configuration: Release
      Platform: device
      User defaults from command line:
        IDEArchivePathOverride = /private/tmp/gimlet/1645041/project/RBBranch.xcarchive
      Build settings from command line:
        CONFIGURATION_BUILD_DIR = /private/tmp/gimlet/1645041/project/build/device
        SHARED_PRECOMPS_DIR = /private/tmp/gimlet/1645041/project/build/sharedpch
      Build settings from configuration file '/private/tmp/gimlet/1645041/project/cordova/build-release.xcconfig':
        ARCHS = armv7 arm64
        CLANG_ALLOW_NON_MODULAR_INCLUDES_IN_FRAMEWORK_MODULES = YES
        CODE_SIGN_ENTITLEMENTS = /tmp/gimlet/1645041/project/app.entitlements
        CODE_SIGN_IDENTITY = iPhone Developer
        CONFIGURATION_BUILD_DIR = /tmp/gimlet/1645041/project/build
        CORDOVALIB = /tmp/gimlet/1645041/project/CordovaLib
        DEVELOPMENT_TEAM = EDYSEYDY5S
        ENABLE_BITCODE = false
        HEADER_SEARCH_PATHS = "$(TARGET_BUILD_DIR)/usr/local/lib/include" "$(OBJROOT)/UninstalledProducts/include" "$(OBJROOT)/UninstalledProducts/$(PLATFORM_NAME)/include" "$(BUILT_PRODUCTS_DIR)"
        IPHONEOS_DEPLOYMENT_TARGET = 8.0
        ONLY_ACTIVE_ARCH = NO
        OTHER_CODE_SIGN_FLAGS = --keychain /tmp/gimlet/1645041/secure.keychain
        OTHER_LDFLAGS = -ObjC
        PROVISIONING_PROFILE = 7979e044-0a91-46d9-8b33-d4d834bfba47
        SWIFT_OBJC_BRIDGING_HEADER = $(PROJECT_DIR)/$(PROJECT_NAME)/Bridging-Header.h
        TARGETED_DEVICE_FAMILY = 1
      === BUILD TARGET CordovaLib OF PROJECT CordovaLib WITH CONFIGURATION Release ===
      Check dependencies
      Write auxiliary files
      write-file /Users/phonegap/Library/Developer/Xcode/DerivedData/RBBranch-eoelrkktfohkitdezostyrfmside /Build/Intermediates/ArchiveIntermediates/RBBranch/IntermediateBuildFilesPath/CordovaLib.b uild/Release-iphoneos/CordovaLib.build/Cordova-own-target-headers.hmap
      /bin/mkdir -p /private/tmp/gimlet/1645041/project/build/sharedpch/CordovaLib_Prefix-bknepzhfpvjnqgasjij tpxgnfeww
      write-file /private/tmp/gimlet/1645041/project/build/sharedpch/CordovaLib_Prefix-bknepzhfpvjnqgasjij tpxgnfeww/CordovaLib_Prefix.pch.pch.hash-criteria
      write-file /Users/phonegap/Library/Developer/Xcode/DerivedData/RBBranch-eoelrkktfohkitdezostyrfmside /Build/Intermediates/ArchiveIntermediates/RBBranch/IntermediateBuildFilesPath/CordovaLib.b uild/Release-iphoneos/CordovaLib.build/Cordova-generated-files.hmap
      /bin/mkdir -p /Users/phonegap/Library/Developer/Xcode/DerivedData/RBBranch-eoelrkktfohkitdezostyrfmside /Build/Intermediates/ArchiveIntermediates/RBBranch/IntermediateBuildFilesPath/CordovaLib.b uild/Release-iphoneos/CordovaLib.build/Objects-normal/armv7
      write-file /Users/phonegap/Library/Developer/Xcode/DerivedData/RBBranch-eoelrkktfohkitdezostyrfmside /Build/Intermediates/ArchiveIntermediates/RBBranch/IntermediateBuildFilesPath/CordovaLib.b uild/Release-iphoneos/CordovaLib.build/Objects-normal/armv7/Cordova.LinkFileList
      write-file /Users/phonegap/Library/Developer/Xcode/DerivedData/RBBranch-eoelrkktfohkitdezostyrfmside /Build/Intermediates/ArchiveIntermediates/RBBranch/IntermediateBuildFilesPath/CordovaLib.b uild/Release-iphoneos/CordovaLib.build/Cordova-project-headers.hmap
      /bin/mkdir -p /private/tmp/gimlet/1645041/project/build/sharedpch/CordovaLib_Prefix-hagqdysfamtkhngolen foajtzops
      write-file /private/tmp/gimlet/1645041/project/build/sharedpch/CordovaLib_Prefix-hagqdysfamtkhngolen foajtzops/CordovaLib_Prefix.pch.pch.hash-criteria
      write-file /Users/phonegap/Library/Developer/Xcode/DerivedData/RBBranch-eoelrkktfohkitdezostyrfmside /Build/Intermediates/ArchiveIntermediates/RBBranch/IntermediateBuildFilesPath/CordovaLib.b uild/Release-iphoneos/CordovaLib.build/Cordova.hmap
      /bin/mkdir -p /Users/phonegap/Library/Developer/Xcode/DerivedData/RBBranch-eoelrkktfohkitdezostyrfmside /Build/Intermediates/ArchiveIntermediates/RBBranch/IntermediateBuildFilesPath/CordovaLib.b uild/Release-iphoneos/CordovaLib.build/Objects-normal/arm64
      write-file /Users/phonegap/Library/Developer/Xcode/DerivedData/RBBranch-eoelrkktfohkitdezostyrfmside /Build/Intermediates/ArchiveIntermediates/RBBranch/IntermediateBuildFilesPath/CordovaLib.b uild/Release-iphoneos/CordovaLib.build/Objects-normal/arm64/Cordova.LinkFileList
      write-file /Users/phonegap/Library/Developer/Xcode/DerivedData/RBBranch-eoelrkktfohkitdezostyrfmside /Build/Intermediates/ArchiveIntermediates/RBBranch/IntermediateBuildFilesPath/CordovaLib.b uild/Release-iphoneos/CordovaLib.build/Cordova-all-non-framework-target-headers.hmap
      write-file /Users/phonegap/Library/Developer/Xcode/DerivedData/RBBranch-eoelrkktfohkitdezostyrfmside /Build/Intermediates/ArchiveIntermediates/RBBranch/IntermediateBuildFilesPath/CordovaLib.b uild/Release-iphoneos/CordovaLib.build/Cordova-all-target-headers.hmap
      SymLink /tmp/gimlet/1645041/project/build/libCordova.a /Users/phonegap/Library/Developer/Xcode/DerivedData/RBBranch-eoelrkktfohkitdezostyrfmside /Build/Intermediates/ArchiveIntermediates/RBBranch/IntermediateBuildFilesPath/UninstalledP roducts/iphoneos/libCordova.a
        cd /tmp/gimlet/1645041/project/CordovaLib
        /bin/ln -sfh /Users/phonegap/Library/Developer/Xcode/DerivedData/RBBranch-eoelrkktfohkitdezostyrfmside /Build/Intermediates/ArchiveIntermediates/RBBranch/IntermediateBuildFilesPath/UninstalledP roducts/iphoneos/libCordova.a /tmp/gimlet/1645041/project/build/libCordova.a
      CpHeader Classes/Public/CDVScreenOrientationDelegate.h /Users/phonegap/Library/Developer/Xcode/DerivedData/RBBranch-eoelrkktfohkitdezostyrfmside /Build/Intermediates/ArchiveIntermediates/RBBranch/IntermediateBuildFilesPath/UninstalledP roducts/iphoneos/include/Cordova/CDVScreenOrientationDelegate.h
        builtin-copy -exclude .DS_Store -exclude CVS -exclude .svn -exclude .git -exclude .hg -strip-debug-symbols -strip-tool /Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/bin/st rip -resolve-src-symlinks /tmp/gimlet/1645041/project/CordovaLib/Classes/Public/CDVScreenOrientationDelegate.h /Users/phonegap/Library/Developer/Xcode/DerivedData/RBBranch-eoelrkktfohkitdezostyrfmside /Build/Intermediates/ArchiveIntermediates/RBBranch/IntermediateBuildFilesPath/UninstalledP roducts/iphoneos/include/Cordova
      CpHeader Classes/Public/CDVWebViewEngineProtocol.h /Users/phonegap/Library/Developer/Xcode/DerivedData/RBBranch-eoelrkktfohkitdezostyrfmside /Build/Intermediates/ArchiveIntermediates/RBBranch/IntermediateBuildFilesPath/UninstalledP roducts/iphoneos/include/Cordova/CDVWebViewEngineProtocol.h
        builtin-copy -exclude .DS_Store -exclude CVS -exclude .svn -exclude .git -exclude .hg -strip-debug-symbols -strip-tool /Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/bin/st rip -resolve-src-symlinks /tmp/gimlet/1645041/project/CordovaLib/Classes/Public/CDVWebViewEngineProtocol.h /Users/phonegap/Library/Developer/Xcode/DerivedData/RBBranch-eoelrkktfohkitdezostyrfmside /Build/Intermediates/ArchiveIntermediates/RBBranch/IntermediateBuildFilesPath/UninstalledP roducts/iphoneos/include/Cordova
      CpHeader Classes/Public/CDV.h /Users/phonegap/Library/Developer/Xcode/DerivedData/RBBranch-eoelrkktfohkitdezostyrfmside /Build/Intermediates/ArchiveIntermediates/RBBranch/IntermediateBuildFilesPath/UninstalledP roducts/iphoneos/include/Cordova/CDV.h
        builtin-copy -exclude .DS_Store -exclude CVS -exclude .svn -exclude .git -exclude .hg -strip-debug-symbols -strip-tool /Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/bin/st rip -resolve-src-symlinks /tmp/gimlet/1645041/project/CordovaLib/Classes/Public/CDV.h /Users/phonegap/Library/Developer/Xcode/DerivedData/RBBranch-eoelrkktfohkitdezostyrfmside /Build/Intermediates/ArchiveIntermediates/RBBranch/IntermediateBuildFilesPath/UninstalledP roducts/iphoneos/include/Cordova
      CpHeader Classes/Public/CDVCommandQueue.h /Users/phonegap/Library/Developer/Xcode/DerivedData/RBBranch-eoelrkktfohkitdezostyrfmside /Build/Intermediates/ArchiveIntermediates/RBBranch/IntermediateBuildFilesPath/UninstalledP roducts/iphoneos/include/Cordova/CDVCommandQueue.h
        builtin-copy -exclude .DS_Store -exclude CVS -exclude .svn -exclude .git -exclude .hg -strip-debug-symbols -strip-tool /Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/bin/st rip -resolve-src-symlinks /tmp/gimlet/1645041/project/CordovaLib/Classes/Public/CDVCommandQueue.h /Users/phonegap/Library/Developer/Xcode/DerivedData/RBBranch-eoelrkktfohkitdezostyrfmside /Build/Intermediates/ArchiveIntermediates/RBBranch/IntermediateBuildFilesPath/UninstalledP roducts/iphoneos/include/Cordova
      CpHeader Classes/Public/CDVWhitelist.h /Users/phonegap/Library/Developer/Xcode/DerivedData/RBBranch-eoelrkktfohkitdezostyrfmside /Build/Intermediates/ArchiveIntermediates/RBBranch/IntermediateBuildFilesPath/UninstalledP roducts/iphoneos/include/Cordova/CDVWhitelist.h
        builtin-copy -exclude .DS_Store -exclude CVS -exclude .svn -exclude .git -exclude .hg -strip-debug-symbols -strip-tool /Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/bin/st rip -resolve-src-symlinks /tmp/gimlet/1645041/project/CordovaLib/Classes/Public/CDVWhitelist.h /Users/phonegap/Library/Developer/Xcode/DerivedData/RBBranch-eoelrkktfohkitdezostyrfmside /Build/Intermediates/ArchiveIntermediates/RBBranch/IntermediateBuildFilesPath/UninstalledP roducts/iphoneos/include/Cordova
      CpHeader Classes/Public/CDVAppDelegate.h /Users/phonegap/Library/Developer/Xcode/DerivedData/RBBranch-eoelrkktfohkitdezostyrfmside /Build/Intermediates/ArchiveIntermediates/RBBranch/IntermediateBuildFilesPath/UninstalledP roducts/iphoneos/include/Cordova/CDVAppDelegate.h
        builtin-copy -exclude .DS_Store -exclude CVS -exclude .svn -exclude .git -exclude .hg -strip-debug-symbols -strip-tool /Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/bin/st rip -resolve-src-symlinks /tmp/gimlet/1645041/project/CordovaLib/Classes/Public/CDVAppDelegate.h /Users/phonegap/Library/Developer/Xcode/DerivedData/RBBranch-eoelrkktfohkitdezostyrfmside /Build/Intermediates/ArchiveIntermediates/RBBranch/IntermediateBuildFilesPath/UninstalledP roducts/iphoneos/include/Cordova
      CpHeader Classes/Public/CDVCommandDelegateImpl.h /Users/phonegap/Library/Developer/Xcode/DerivedData/RBBranch-eoelrkktfohkitdezostyrfmside /Build/Intermediates/ArchiveIntermediates/RBBranch/IntermediateBuildFilesPath/UninstalledP roducts/iphoneos/include/Cordova/CDVCommandDelegateImpl.h
        builtin-copy -exclude .DS_Store -exclude CVS -exclude .svn -exclude .git -exclude .hg -strip-debug-symbols -strip-tool /Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/bin/st rip -resolve-src-symlinks /tmp/gimlet/1645041/project/CordovaLib/Classes/Public/CDVCommandDelegateImpl.h /Users/phonegap/Library/Developer/Xcode/DerivedData/RBBranch-eoelrkktfohkitdezostyrfmside /Build/Intermediates/ArchiveIntermediates/RBBranch/IntermediateBuildFilesPath/UninstalledP roducts/iphoneos/include/Cordova
      CpHeader Classes/Public/CDVPlugin+Resources.h /Users/phonegap/Library/Developer/Xcode/DerivedData/RBBranch-eoelrkktfohkitdezostyrfmside /Build/Intermediates/ArchiveIntermediates/RBBranch/IntermediateBuildFilesPath/UninstalledP roducts/iphoneos/include/Cordova/CDVPlugin+Resources.h
        builtin-copy -exclude .DS_Store -exclude CVS -exclude .svn -exclude .git -exclude .hg -strip-debug-symbols -strip-tool /Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/bin/st rip -resolve-src-symlinks /tmp/gimlet/1645041/project/CordovaLib/Classes/Public/CDVPlugin+Resources.h /Users/phonegap/Library/Developer/Xcode/DerivedData/RBBranch-eoelrkktfohkitdezostyrfmside /Build/Intermediates/ArchiveIntermediates/RBBranch/IntermediateBuildFilesPath/UninstalledP roducts/iphoneos/include/Cordova
      CpHeader Classes/Public/CDVAvailability.h /Users/phonegap/Library/Developer/Xcode/DerivedData/RBBranch-eoelrkktfohkitdezostyrfmside /Build/Intermediates/ArchiveIntermediates/RBBranch/IntermediateBuildFilesPath/UninstalledP roducts/iphoneos/include/Cordova/CDVAvailability.h
        builtin-copy -exclude .DS_Store -exclude CVS -exclude .svn -exclude .git -exclude .hg -strip-debug-symbols -strip-tool /Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/bin/st rip -resolve-src-symlinks /tmp/gimlet/1645041/project/CordovaLib/Classes/Public/CDVAvailability.h /Users/phonegap/Library/Developer/Xcode/DerivedData/RBBranch-eoelrkktfohkitdezostyrfmside /Build/Intermediates/ArchiveIntermediates/RBBranch/IntermediateBuildFilesPath/UninstalledP roducts/iphoneos/include/Cordova
      CpHeader Classes/Public/CDVPluginResult.h /Users/phonegap/Library/Developer/Xcode/DerivedData/RBBranch-eoelrkktfohkitdezostyrfmside /Build/Intermediates/ArchiveIntermediates/RBBranch/IntermediateBuildFilesPath/UninstalledP roducts/iphoneos/include/Cordova/CDVPluginResult.h
        builtin-copy -exclude .DS_Store -exclude CVS -exclude .svn -exclude .git -exclude .hg -strip-debug-symbols -strip-tool /Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/bin/st rip -resolve-src-symlinks /tmp/gimlet/1645041/project/CordovaLib/Classes/Public/CDVPluginResult.h /Users/phonegap/Library/Developer/Xcode/DerivedData/RBBranch-eoelrkktfohkitdezostyrfmside /Build/Intermediates/ArchiveIntermediates/RBBranch/IntermediateBuildFilesPath/UninstalledP roducts/iphoneos/include/Cordova
      CpHeader Classes/Public/NSMutableArray+QueueAdditions.h /Users/phonegap/Library/Developer/Xcode/DerivedData/RBBranch-eoelrkktfohkitdezostyrfmside /Build/Intermediates/ArchiveIntermediates/RBBranch/IntermediateBuildFilesPath/UninstalledP roducts/iphoneos/include/Cordova/NSMutableArray+QueueAdditions.h
        builtin-copy -exclude .DS_Store -exclude CVS -exclude .svn -exclude .git -exclude .hg -strip-debug-symbols -strip-tool /Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/bin/st rip -resolve-src-symlinks /tmp/gimlet/1645041/project/CordovaLib/Classes/Public/NSMutableArray+QueueAdditions.h /Users/phonegap/Library/Developer/Xcode/DerivedData/RBBranch-eoelrkktfohkitdezostyrfmside /Build/Intermediates/ArchiveIntermediates/RBBranch/IntermediateBuildFilesPath/UninstalledP roducts/iphoneos/include/Cordova
      CpHeader Classes/Private/Plugins/CDVUIWebViewEngine/CDVUIWebViewDelegate.h /Users/phonegap/Library/Developer/Xcode/DerivedData/RBBranch-eoelrkktfohkitdezostyrfmside /Build/Intermediates/ArchiveIntermediates/RBBranch/IntermediateBuildFilesPath/UninstalledP roducts/iphoneos/include/Cordova/CDVUIWebViewDelegate.h
        builtin-copy -exclude .DS_Store -exclude CVS -exclude .svn -exclude .git -exclude .hg -strip-debug-symbols -strip-tool /Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/bin/st rip -resolve-src-symlinks /tmp/gimlet/1645041/project/CordovaLib/Classes/Private/Plugins/CDVUIWebViewEngine/CDVUIWe bViewDelegate.h /Users/phonegap/Library/Developer/Xcode/DerivedData/RBBranch-eoelrkktfohkitdezostyrfmside /Build/Intermediates/ArchiveIntermediates/RBBranch/IntermediateBuildFilesPath/UninstalledP roducts/iphoneos/include/Cordova
      CpHeader Classes/Public/CDVInvokedUrlCommand.h /Users/phonegap/Library/Developer/Xcode/DerivedData/RBBranch-eoelrkktfohkitdezostyrfmside /Build/Intermediates/ArchiveIntermediates/RBBranch/IntermediateBuildFilesPath/UninstalledP roducts/iphoneos/include/Cordova/CDVInvokedUrlCommand.h
        builtin-copy -exclude .DS_Store -exclude CVS -exclude .svn -exclude .git -exclude .hg -strip-debug-symbols -strip-tool /Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/bin/st rip -resolve-src-symlinks /tmp/gimlet/1645041/project/CordovaLib/Classes/Public/CDVInvokedUrlCommand.h /Users/phonegap/Library/Developer/Xcode/DerivedData/RBBranch-eoelrkktfohkitdezostyrfmside /Build/Intermediates/ArchiveIntermediates/RBBranch/IntermediateBuildFilesPath/UninstalledP roducts/iphoneos/include/Cordova
      CpHeader Classes/Public/NSDictionary+CordovaPreferences.h /Users/phonegap/Library/Developer/Xcode/DerivedData/RBBranch-eoelrkktfohkitdezostyrfmside /Build/Intermediates/ArchiveIntermediates/RBBranch/IntermediateBuildFilesPath/UninstalledP roducts/iphoneos/include/Cordova/NSDictionary+CordovaPreferences.h
        builtin-copy -exclude .DS_Store -exclude CVS -exclude .svn -exclude .git -exclude .hg -strip-debug-symbols -strip-tool /Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/bin/st rip -resolve-src-symlinks /tmp/gimlet/1645041/project/CordovaLib/Classes/Public/NSDictionary+CordovaPreferences.h /Users/phonegap/Library/Developer/Xcode/DerivedData/RBBranch-eoelrkktfohkitdezostyrfmside /Build/Intermediates/ArchiveIntermediates/RBBranch/IntermediateBuildFilesPath/UninstalledP roducts/iphoneos/include/Cordova
      CpHeader Classes/Public/CDVPlugin.h /Users/phonegap/Library/Developer/Xcode/DerivedData/RBBranch-eoelrkktfohkitdezostyrfmside /Build/Intermediates/ArchiveIntermediates/RBBranch/IntermediateBuildFilesPath/UninstalledP roducts/iphoneos/include/Cordova/CDVPlugin.h
        builtin-copy -exclude .DS_Store -exclude CVS -exclude .svn -exclude .git -exclude .hg -strip-debug-symbols -strip-tool /Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/bin/st rip -resolve-src-symlinks /tmp/gimlet/1645041/project/CordovaLib/Classes/Public/CDVPlugin.h /Users/phonegap/Library/Developer/Xcode/DerivedData/RBBranch-eoelrkktfohkitdezostyrfmside /Build/Intermediates/ArchiveIntermediates/RBBranch/IntermediateBuildFilesPath/UninstalledP roducts/iphoneos/include/Cordova
      CpHeader Classes/Public/CDVURLProtocol.h /Users/phonegap/Library/Developer/Xcode/DerivedData/RBBranch-eoelrkktfohkitdezostyrfmside /Build/Intermediates/ArchiveIntermediates/RBBranch/IntermediateBuildFilesPath/UninstalledP roducts/iphoneos/include/Cordova/CDVURLProtocol.h
        builtin-copy -exclude .DS_Store -exclude CVS -exclude .svn -exclude .git -exclude .hg -strip-debug-symbols -strip-tool /Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/bin/st rip -resolve-src-symlinks /tmp/gimlet/1645041/project/CordovaLib/Classes/Public/CDVURLProtocol.h /Users/phonegap/Library/Developer/Xcode/DerivedData/RBBranch-eoelrkktfohkitdezostyrfmside /Build/Intermediates/ArchiveIntermediates/RBBranch/IntermediateBuildFilesPath/UninstalledP roducts/iphoneos/include/Cordova
      CpHeader Classes/Public/CDVCommandDelegate.h /Users/phonegap/Library/Developer/Xcode/DerivedData/RBBranch-eoelrkktfohkitdezostyrfmside /Build/Intermediates/ArchiveIntermediates/RBBranch/IntermediateBuildFilesPath/UninstalledP roducts/iphoneos/include/Cordova/CDVCommandDelegate.h
        builtin-copy -exclude .DS_Store -exclude CVS -exclude .svn -exclude .git -exclude .hg -strip-debug-symbols -strip-tool /Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/bin/st rip -resolve-src-symlinks /tmp/gimlet/1645041/project/CordovaLib/Classes/Public/CDVCommandDelegate.h /Users/phonegap/Library/Developer/Xcode/DerivedData/RBBranch-eoelrkktfohkitdezostyrfmside /Build/Intermediates/ArchiveIntermediates/RBBranch/IntermediateBuildFilesPath/UninstalledP roducts/iphoneos/include/Cordova
      CpHeader Classes/Public/CDVAvailabilityDeprecated.h /Users/phonegap/Library/Developer/Xcode/DerivedData/RBBranch-eoelrkktfohkitdezostyrfmside /Build/Intermediates/ArchiveIntermediates/RBBranch/IntermediateBuildFilesPath/UninstalledP roducts/iphoneos/include/Cordova/CDVAvailabilityDeprecated.h
        builtin-copy -exclude .DS_Store -exclude CVS -exclude .svn -exclude .git -exclude .hg -strip-debug-symbols -strip-tool /Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/bin/st rip -resolve-src-symlinks /tmp/gimlet/1645041/project/CordovaLib/Classes/Public/CDVAvailabilityDeprecated.h /Users/phonegap/Library/Developer/Xcode/DerivedData/RBBranch-eoelrkktfohkitdezostyrfmside /Build/Intermediates/ArchiveIntermediates/RBBranch/IntermediateBuildFilesPath/UninstalledP roducts/iphoneos/include/Cordova
      CpHeader Classes/Public/CDVUserAgentUtil.h /Users/phonegap/Library/Developer/Xcode/DerivedData/RBBranch-eoelrkktfohkitdezostyrfmside /Build/Intermediates/ArchiveIntermediates/RBBranch/IntermediateBuildFilesPath/UninstalledP roducts/iphoneos/include/Cordova/CDVUserAgentUtil.h
        builtin-copy -exclude .DS_Store -exclude CVS -exclude .svn -exclude .git -exclude .hg -strip-debug-symbols -strip-tool /Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/bin/st rip -resolve-src-symlinks /tmp/gimlet/1645041/project/CordovaLib/Classes/Public/CDVUserAgentUtil.h /Users/phonegap/Library/Developer/Xcode/DerivedData/RBBranch-eoelrkktfohkitdezostyrfmside /Build/Intermediates/ArchiveIntermediates/RBBranch/IntermediateBuildFilesPath/UninstalledP roducts/iphoneos/include/Cordova
      CpHeader Classes/Public/CDVConfigParser.h /Users/phonegap/Library/Developer/Xcode/DerivedData/RBBranch-eoelrkktfohkitdezostyrfmside /Build/Intermediates/ArchiveIntermediates/RBBranch/IntermediateBuildFilesPath/UninstalledP roducts/iphoneos/include/Cordova/CDVConfigParser.h
        builtin-copy -exclude .DS_Store -exclude CVS -exclude .svn -exclude .git -exclude .hg -strip-debug-symbols -strip-tool /Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/bin/st rip -resolve-src-symlinks /tmp/gimlet/1645041/project/CordovaLib/Classes/Public/CDVConfigParser.h /Users/phonegap/Library/Developer/Xcode/DerivedData/RBBranch-eoelrkktfohkitdezostyrfmside /Build/Intermediates/ArchiveIntermediates/RBBranch/IntermediateBuildFilesPath/UninstalledP roducts/iphoneos/include/Cordova
      CpHeader Classes/Public/CDVViewController.h /Users/phonegap/Library/Developer/Xcode/DerivedData/RBBranch-eoelrkktfohkitdezostyrfmside /Build/Intermediates/ArchiveIntermediates/RBBranch/IntermediateBuildFilesPath/UninstalledP roducts/iphoneos/include/Cordova/CDVViewController.h
        builtin-copy -exclude .DS_Store -exclude CVS -exclude .svn -exclude .git -exclude .hg -strip-debug-symbols -strip-tool /Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/bin/st rip -resolve-src-symlinks /tmp/gimlet/1645041/project/CordovaLib/Classes/Public/CDVViewController.h /Users/phonegap/Library/Developer/Xcode/DerivedData/RBBranch-eoelrkktfohkitdezostyrfmside /Build/Intermediates/ArchiveIntermediates/RBBranch/IntermediateBuildFilesPath/UninstalledP roducts/iphoneos/include/Cordova
      CpHeader Classes/Public/CDVTimer.h /Users/phonegap/Library/Developer/Xcode/DerivedData/RBBranch-eoelrkktfohkitdezostyrfmside /Build/Intermediates/ArchiveIntermediates/RBBranch/IntermediateBuildFilesPath/UninstalledP roducts/iphoneos/include/Cordova/CDVTimer.h
        builtin-copy -exclude .DS_Store -exclude CVS -exclude .svn -exclude .git -exclude .hg -strip-debug-symbols -strip-tool /Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/bin/st rip -resolve-src-symlinks /tmp/gimlet/1645041/project/CordovaLib/Classes/Public/CDVTimer.h /Users/phonegap/Library/Developer/Xcode/DerivedData/RBBranch-eoelrkktfohkitdezostyrfmside /Build/Intermediates/ArchiveIntermediates/RBBranch/IntermediateBuildFilesPath/UninstalledP roducts/iphoneos/include/Cordova
      ProcessPCH /private/tmp/gimlet/1645041/project/build/sharedpch/CordovaLib_Prefix-bknepzhfpvjnqgasjij tpxgnfeww/CordovaLib_Prefix.pch.pch CordovaLib_Prefix.pch normal armv7 objective-c com.apple.compilers.llvm.clang.1_0.compiler
        export LANG=en_US.US-ASCII
        /Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/bin/cl ang -x objective-c-header -arch armv7 -fmessage-length=0 -fdiagnostics-show-note-include-stack -fmacro-backtrace-limit=0 -std=c99 -fobjc-arc -fmodules -fmodules-cache-path=/Users/phonegap/Library/Developer/Xcode/DerivedData/ModuleCache -fmodules-prune-interval=86400 -fmodules-prune-after=345600 -fbuild-session-file=/Users/phonegap/Library/Developer/Xcode/DerivedData/ModuleCache/Sess ion.modulevalidation -fmodules-validate-once-per-build-session -Wno-trigraphs -fpascal-strings -Os -Wno-missing-field-initializers -Wno-missing-prototypes -Wno-implicit-atomic-properties -Wno-arc-repeated-use-of-weak -Wduplicate-method-match -Wno-missing-braces -Wparentheses -Wswitch -Wunused-function -Wno-unused-label -Wno-unused-parameter -Wunused-variable -Wunused-value -Wempty-body -Wuninitialized -Wno-unknown-pragmas -Wno-shadow -Wno-four-char-constants -Wno-conversion -Wconstant-conversion -Wint-conversion -Wbool-conversion -Wenum-conversion -Wno-shorten-64-to-32 -Wpointer-sign -Wno-newline-eof -Wno-selector -Wno-strict-selector-match -Wundeclared-selector -Wno-deprecated-implementations -isysroot /Applications/Xcode.app/Contents/Developer/Platforms/iPhoneOS.platform/Developer/SDKs/iPh oneOS10.1.sdk -fstrict-aliasing -Wprotocol -Wdeprecated-declarations -miphoneos-version-min=8.0 -g -Wno-sign-conversion -Wno-infinite-recursion -iquote /Users/phonegap/Library/Developer/Xcode/DerivedData/RBBranch-eoelrkktfohkitdezostyrfmside /Build/Intermediates/ArchiveIntermediates/RBBranch/IntermediateBuildFilesPath/CordovaLib.b uild/Release-iphoneos/CordovaLib.build/Cordova-generated-files.hmap -I/Users/phonegap/Library/Developer/Xcode/DerivedData/RBBranch-eoelrkktfohkitdezostyrfmsi de/Build/Intermediates/ArchiveIntermediates/RBBranch/IntermediateBuildFilesPath/CordovaLib .build/Release-iphoneos/CordovaLib.build/Cordova-own-target-headers.hmap -I/Users/phonegap/Library/Developer/Xcode/DerivedData/RBBranch-eoelrkktfohkitdezostyrfmsi de/Build/Intermediates/ArchiveIntermediates/RBBranch/IntermediateBuildFilesPath/CordovaLib .build/Release-iphoneos/CordovaLib.build/Cordova-all-target-headers.hmap -iquote /Users/phonegap/Library/Developer/Xcode/DerivedData/RBBranch-eoelrkktfohkitdezostyrfmside /Build/Intermediates/ArchiveIntermediates/RBBranch/IntermediateBuildFilesPath/CordovaLib.b uild/Release-iphoneos/CordovaLib.build/Cordova-project-headers.hmap -I/tmp/gimlet/1645041/project/build/include -I/Users/phonegap/Library/Developer/Xcode/DerivedData/RBBranch-eoelrkktfohkitdezostyrfmsi de/Build/Intermediates/ArchiveIntermediates/RBBranch/IntermediateBuildFilesPath/Uninstalle dProducts/iphoneos/usr/local/lib/include -I/Users/phonegap/Library/Developer/Xcode/DerivedData/RBBranch-eoelrkktfohkitdezostyrfmsi de/Build/Intermediates/ArchiveIntermediates/RBBranch/IntermediateBuildFilesPath/Uninstalle dProducts/include -I/Users/phonegap/Library/Developer/Xcode/DerivedData/RBBranch-eoelrkktfohkitdezostyrfmsi de/Build/Intermediates/ArchiveIntermediates/RBBranch/IntermediateBuildFilesPath/Uninstalle dProducts/iphoneos/include -I/tmp/gimlet/1645041/project/build -I/Users/phonegap/Library/Developer/Xcode/DerivedData/RBBranch-eoelrkktfohkitdezostyrfmsi de/Build/Intermediates/ArchiveIntermediates/RBBranch/IntermediateBuildFilesPath/CordovaLib .build/Release-iphoneos/CordovaLib.build/DerivedSources/armv7 -I/Users/phonegap/Library/Developer/Xcode/DerivedData/RBBranch-eoelrkktfohkitdezostyrfmsi de/Build/Intermediates/ArchiveIntermediates/RBBranch/IntermediateBuildFilesPath/CordovaLib .build/Release-iphoneos/CordovaLib.build/DerivedSources -F/tmp/gimlet/1645041/project/build -MD -MT dependencies -MF /private/tmp/gimlet/1645041/project/build/sharedpch/CordovaLib_Prefix-bknepzhfpvjnqgasjij tpxgnfeww/CordovaLib_Prefix.pch.d -c /tmp/gimlet/1645041/project/CordovaLib/CordovaLib_Prefix.pch -o /private/tmp/gimlet/1645041/project/build/sharedpch/CordovaLib_Prefix-bknepzhfpvjnqgasjij tpxgnfeww/CordovaLib_Prefix.pch.pch --serialize-diagnostics /private/tmp/gimlet/1645041/project/build/sharedpch/CordovaLib_Prefix-bknepzhfpvjnqgasjij tpxgnfeww/CordovaLib_Prefix.pch.dia
      ProcessPCH /private/tmp/gimlet/1645041/project/build/sharedpch/CordovaLib_Prefix-hagqdysfamtkhngolen foajtzops/CordovaLib_Prefix.pch.pch CordovaLib_Prefix.pch normal arm64 objective-c com.apple.compilers.llvm.clang.1_0.compiler
        /Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/bin/cl ang -x objective-c-header -arch arm64 -fmessage-length=0 -fdiagnostics-show-note-include-stack -fmacro-backtrace-limit=0 -std=c99 -fobjc-arc -fmodules -fmodules-cache-path=/Users/phonegap/Library/Developer/Xcode/DerivedData/ModuleCache -fmodules-prune-interval=86400 -fmodules-prune-after=345600 -fbuild-session-file=/Users/phonegap/Library/Developer/Xcode/DerivedData/ModuleCache/Sess ion.modulevalidation -fmodules-validate-once-per-build-session -Wno-trigraphs -fpascal-strings -Os -Wno-missing-field-initializers -Wno-missing-prototypes -Wno-implicit-atomic-properties -Wno-arc-repeated-use-of-weak -Wduplicate-method-match -Wno-missing-braces -Wparentheses -Wswitch -Wunused-function -Wno-unused-label -Wno-unused-parameter -Wunused-variable -Wunused-value -Wempty-body -Wuninitialized -Wno-unknown-pragmas -Wno-shadow -Wno-four-char-constants -Wno-conversion -Wconstant-conversion -Wint-conversion -Wbool-conversion -Wenum-conversion -Wshorten-64-to-32 -Wpointer-sign -Wno-newline-eof -Wno-selector -Wno-strict-selector-match -Wundeclared-selector -Wno-deprecated-implementations -isysroot /Applications/Xcode.app/Contents/Developer/Platforms/iPhoneOS.platform/Developer/SDKs/iPh oneOS10.1.sdk -fstrict-aliasing -Wprotocol -Wdeprecated-declarations -miphoneos-version-min=8.0 -g -Wno-sign-conversion -Wno-infinite-recursion -iquote /Users/phonegap/Library/Developer/Xcode/DerivedData/RBBranch-eoelrkktfohkitdezostyrfmside /Build/Intermediates/ArchiveIntermediates/RBBranch/IntermediateBuildFilesPath/CordovaLib.b uild/Release-iphoneos/CordovaLib.build/Cordova-generated-files.hmap -I/Users/phonegap/Library/Developer/Xcode/DerivedData/RBBranch-eoelrkktfohkitdezostyrfmsi de/Build/Intermediates/ArchiveIntermediates/RBBranch/IntermediateBuildFilesPath/CordovaLib .build/Release-iphoneos/CordovaLib.build/Cordova-own-target-headers.hmap -I/Users/phonegap/Library/Developer/Xcode/DerivedData/RBBranch-eoelrkktfohkitdezostyrfmsi de/Build/Intermediates/ArchiveIntermediates/RBBranch/IntermediateBuildFilesPath/CordovaLib .build/Release-iphoneos/CordovaLib.build/Cordova-all-target-headers.hmap -iquote /Users/phonegap/Library/Developer/Xcode/DerivedData/RBBranch-eoelrkktfohkitdezostyrfmside /Build/Intermediates/ArchiveIntermediates/RBBranch/IntermediateBuildFilesPath/CordovaLib.b uild/Release-iphoneos/CordovaLib.build/Cordova-project-headers.hmap -I/tmp/gimlet/1645041/project/build/include -I/Users/phonegap/Library/Developer/Xcode/DerivedData/RBBranch-eoelrkktfohkitdezostyrfmsi de/Build/Intermediates/ArchiveIntermediates/RBBranch/IntermediateBuildFilesPath/Uninstalle dProducts/iphoneos/usr/local/lib/include -I/Users/phonegap/Library/Developer/Xcode/DerivedData/RBBranch-eoelrkktfohkitdezostyrfmsi de/Build/Intermediates/ArchiveIntermediates/RBBranch/IntermediateBuildFilesPath/Uninstalle dProducts/include -I/Users/phonegap/Library/Developer/Xcode/DerivedData/RBBranch-eoelrkktfohkitdezostyrfmsi de/Build/Intermediates/ArchiveIntermediates/RBBranch/IntermediateBuildFilesPath/Uninstalle dProducts/iphoneos/include -I/tmp/gimlet/1645041/project/build -I/Users/phonegap/Library/Developer/Xcode/DerivedData/RBBranch-eoelrkktfohkitdezostyrfmsi de/Build/Intermediates/ArchiveIntermediates/RBBranch/IntermediateBuildFilesPath/CordovaLib .build/Release-iphoneos/CordovaLib.build/DerivedSources/arm64 -I/Users/phonegap/Library/Developer/Xcode/DerivedData/RBBranch-eoelrkktfohkitdezostyrfmsi de/Build/Intermediates/ArchiveIntermediates/RBBranch/IntermediateBuildFilesPath/CordovaLib .build/Release-iphoneos/CordovaLib.build/DerivedSources -F/tmp/gimlet/1645041/project/build -MD -MT dependencies -MF /private/tmp/gimlet/1645041/project/build/sharedpch/CordovaLib_Prefix-hagqdysfamtkhngolen foajtzops/CordovaLib_Prefix.pch.d -c /tmp/gimlet/1645041/project/CordovaLib/CordovaLib_Prefix.pch -o /private/tmp/gimlet/1645041/project/build/sharedpch/CordovaLib_Prefix-hagqdysfamtkhngolen foajtzops/CordovaLib_Prefix.pch.pch --serialize-diagnostics /private/tmp/gimlet/1645041/project/build/sharedpch/CordovaLib_Prefix-hagqdysfamtkhngolen foajtzops/CordovaLib_Prefix.pch.dia
      CompileC /Users/phonegap/Library/Developer/Xcode/DerivedData/RBBranch-eoelrkktfohkitdezostyrfmside /Build/Intermediates/ArchiveIntermediates/RBBranch/IntermediateBuildFilesPath/CordovaLib.b uild/Release-iphoneos/CordovaLib.build/Objects-normal/armv7/CDVViewController.o Classes/Public/CDVViewController.m normal armv7 objective-c com.apple.compilers.llvm.clang.1_0.compiler
        /Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/bin/cl ang -x objective-c -arch armv7 -fmessage-length=0 -fdiagnostics-show-note-include-stack -fmacro-backtrace-limit=0 -std=c99 -fobjc-arc -fmodules -fmodules-cache-path=/Users/phonegap/Library/Developer/Xcode/DerivedData/ModuleCache -fmodules-prune-interval=86400 -fmodules-prune-after=345600 -fbuild-session-file=/Users/phonegap/Library/Developer/Xcode/DerivedData/ModuleCache/Sess ion.modulevalidation -fmodules-validate-once-per-build-session -Wno-trigraphs -fpascal-strings -Os -Wno-missing-field-initializers -Wno-missing-prototypes -Wno-implicit-atomic-properties -Wno-arc-repeated-use-of-weak -Wduplicate-method-match -Wno-missing-braces -Wparentheses -Wswitch -Wunused-function -Wno-unused-label -Wno-unused-parameter -Wunused-variable -Wunused-value -Wempty-body -Wuninitialized -Wno-unknown-pragmas -Wno-shadow -Wno-four-char-constants -Wno-conversion -Wconstant-conversion -Wint-conversion -Wbool-conversion -Wenum-conversion -Wno-shorten-64-to-32 -Wpointer-sign -Wno-newline-eof -Wno-selector -Wno-strict-selector-match -Wundeclared-selector -Wno-deprecated-implementations -isysroot /Applications/Xcode.app/Contents/Developer/Platforms/iPhoneOS.platform/Developer/SDKs/iPh oneOS10.1.sdk -fstrict-aliasing -Wprotocol -Wdeprecated-declarations -miphoneos-version-min=8.0 -g -Wno-sign-conversion -Wno-infinite-recursion -iquote /Users/phonegap/Library/Developer/Xcode/DerivedData/RBBranch-eoelrkktfohkitdezostyrfmside /Build/Intermediates/ArchiveIntermediates/RBBranch/IntermediateBuildFilesPath/CordovaLib.b uild/Release-iphoneos/CordovaLib.build/Cordova-generated-files.hmap -I/Users/phonegap/Library/Developer/Xcode/DerivedData/RBBranch-eoelrkktfohkitdezostyrfmsi de/Build/Intermediates/ArchiveIntermediates/RBBranch/IntermediateBuildFilesPath/CordovaLib .build/Release-iphoneos/CordovaLib.build/Cordova-own-target-headers.hmap -I/Users/phonegap/Library/Developer/Xcode/DerivedData/RBBranch-eoelrkktfohkitdezostyrfmsi de/Build/Intermediates/ArchiveIntermediates/RBBranch/IntermediateBuildFilesPath/CordovaLib .build/Release-iphoneos/CordovaLib.build/Cordova-all-target-headers.hmap -iquote /Users/phonegap/Library/Developer/Xcode/DerivedData/RBBranch-eoelrkktfohkitdezostyrfmside /Build/Intermediates/ArchiveIntermediates/RBBranch/IntermediateBuildFilesPath/CordovaLib.b uild/Release-iphoneos/CordovaLib.build/Cordova-project-headers.hmap -I/tmp/gimlet/1645041/project/build/include -I/Users/phonegap/Library/Developer/Xcode/DerivedData/RBBranch-eoelrkktfohkitdezostyrfmsi de/Build/Intermediates/ArchiveIntermediates/RBBranch/IntermediateBuildFilesPath/Uninstalle dProducts/iphoneos/usr/local/lib/include -I/Users/phonegap/Library/Developer/Xcode/DerivedData/RBBranch-eoelrkktfohkitdezostyrfmsi de/Build/Intermediates/ArchiveIntermediates/RBBranch/IntermediateBuildFilesPath/Uninstalle dProducts/include -I/Users/phonegap/Library/Developer/Xcode/DerivedData/RBBranch-eoelrkktfohkitdezostyrfmsi de/Build/Intermediates/ArchiveIntermediates/RBBranch/IntermediateBuildFilesPath/Uninstalle dProducts/iphoneos/include -I/tmp/gimlet/1645041/project/build -I/Users/phonegap/Library/Developer/Xcode/DerivedData/RBBranch-eoelrkktfohkitdezostyrfmsi de/Build/Intermediates/ArchiveIntermediates/RBBranch/IntermediateBuildFilesPath/CordovaLib .build/Release-iphoneos/CordovaLib.build/DerivedSources/armv7 -I/Users/phonegap/Library/Developer/Xcode/DerivedData/RBBranch-eoelrkktfohkitdezostyrfmsi de/Build/Intermediates/ArchiveIntermediates/RBBranch/IntermediateBuildFilesPath/CordovaLib .build/Release-iphoneos/CordovaLib.build/DerivedSources -F/tmp/gimlet/1645041/project/build -include /private/tmp/gimlet/1645041/project/build/sharedpch/CordovaLib_Prefix-bknepzhfpvjnqgasjij tpxgnfeww/CordovaLib_Prefix.pch -MMD -MT dependencies -MF /Users/phonegap/Library/Developer/Xcode/DerivedData/RBBranch-eoelrkktfohkitdezostyrfmside /Build/Intermediates/ArchiveIntermediates/RBBranch/IntermediateBuildFilesPath/CordovaLib.b uild/Release-iphoneos/CordovaLib.build/Objects-normal/armv7/CDVViewController.d --serialize-diagnostics /Users/phonegap/Library/Developer/Xcode/DerivedData/RBBranch-eoelrkktfohkitdezostyrfmside /Build/Intermediates/ArchiveIntermediates/RBBranch/IntermediateBuildFilesPath/CordovaLib.b uild/Release-iphoneos/CordovaLib.build/Objects-normal/armv7/CDVViewController.dia -c /tmp/gimlet/1645041/project/CordovaLib/Classes/Public/CDVViewController.m -o /Users/phonegap/Library/Developer/Xcode/DerivedData/RBBranch-eoelrkktfohkitdezostyrfmside /Build/Intermediates/ArchiveIntermediates/RBBranch/IntermediateBuildFilesPath/CordovaLib.b uild/Release-iphoneos/CordovaLib.build/Objects-normal/armv7/CDVViewController.o
      CompileC /Users/phonegap/Library/Developer/Xcode/DerivedData/RBBranch-eoelrkktfohkitdezostyrfmside /Build/Intermediates/ArchiveIntermediates/RBBranch/IntermediateBuildFilesPath/CordovaLib.b uild/Release-iphoneos/CordovaLib.build/Objects-normal/armv7/CDVAppDelegate.o Classes/Public/CDVAppDelegate.m normal armv7 objective-c com.apple.compilers.llvm.clang.1_0.compiler
        /Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/bin/cl ang -x objective-c -arch armv7 -fmessage-length=0 -fdiagnostics-show-note-include-stack -fmacro-backtrace-limit=0 -std=c99 -fobjc-arc -fmodules -fmodules-cache-path=/Users/phonegap/Library/Developer/Xcode/DerivedData/ModuleCache -fmodules-prune-interval=86400 -fmodules-prune-after=345600 -fbuild-session-file=/Users/phonegap/Library/Developer/Xcode/DerivedData/ModuleCache/Sess ion.modulevalidation -fmodules-validate-once-per-build-session -Wno-trigraphs -fpascal-strings -Os -Wno-missing-field-initializers -Wno-missing-prototypes -Wno-implicit-atomic-properties -Wno-arc-repeated-use-of-weak -Wduplicate-method-match -Wno-missing-braces -Wparentheses -Wswitch -Wunused-function -Wno-unused-label -Wno-unused-parameter -Wunused-variable -Wunused-value -Wempty-body -Wuninitialized -Wno-unknown-pragmas -Wno-shadow -Wno-four-char-constants -Wno-conversion -Wconstant-conversion -Wint-conversion -Wbool-conversion -Wenum-conversion -Wno-shorten-64-to-32 -Wpointer-sign -Wno-newline-eof -Wno-selector -Wno-strict-selector-match -Wundeclared-selector -Wno-deprecated-implementations -isysroot /Applications/Xcode.app/Contents/Developer/Platforms/iPhoneOS.platform/Developer/SDKs/iPh oneOS10.1.sdk -fstrict-aliasing -Wprotocol -Wdeprecated-declarations -miphoneos-version-min=8.0 -g -Wno-sign-conversion -Wno-infinite-recursion -iquote /Users/phonegap/Library/Developer/Xcode/DerivedData/RBBranch-eoelrkktfohkitdezostyrfmside /Build/Intermediates/ArchiveIntermediates/RBBranch/IntermediateBuildFilesPath/CordovaLib.b uild/Release-iphoneos/CordovaLib.build/Cordova-generated-files.hmap -I/Users/phonegap/Library/Developer/Xcode/DerivedData/RBBranch-eoelrkktfohkitdezostyrfmsi de/Build/Intermediates/ArchiveIntermediates/RBBranch/IntermediateBuildFilesPath/CordovaLib .build/Release-iphoneos/CordovaLib.build/Cordova-own-target-headers.hmap -I/Users/phonegap/Library/Developer/Xcode/DerivedData/RBBranch-eoelrkktfohkitdezostyrfmsi de/Build/Intermediates/ArchiveIntermediates/RBBranch/IntermediateBuildFilesPath/CordovaLib .build/Release-iphoneos/CordovaLib.build/Cordova-all-target-headers.hmap -iquote /Users/phonegap/Library/Developer/Xcode/DerivedData/RBBranch-eoelrkktfohkitdezostyrfmside /Build/Intermediates/ArchiveIntermediates/RBBranch/IntermediateBuildFilesPath/CordovaLib.b uild/Release-iphoneos/CordovaLib.build/Cordova-project-headers.hmap -I/tmp/gimlet/1645041/project/build/include -I/Users/phonegap/Library/Developer/Xcode/DerivedData/RBBranch-eoelrkktfohkitdezostyrfmsi de/Build/Intermediates/ArchiveIntermediates/RBBranch/IntermediateBuildFilesPath/Uninstalle dProducts/iphoneos/usr/local/lib/include -I/Users/phonegap/Library/Developer/Xcode/DerivedData/RBBranch-eoelrkktfohkitdezostyrfmsi de/Build/Intermediates/ArchiveIntermediates/RBBranch/IntermediateBuildFilesPath/Uninstalle dProducts/include -I/Users/phonegap/Library/Developer/Xcode/DerivedData/RBBranch-eoelrkktfohkitdezostyrfmsi de/Build/Intermediates/ArchiveIntermediates/RBBranch/IntermediateBuildFilesPath/Uninstalle dProducts/iphoneos/include -I/tmp/gimlet/1645041/project/build -I/Users/phonegap/Library/Developer/Xcode/DerivedData/RBBranch-eoelrkktfohkitdezostyrfmsi de/Build/Intermediates/ArchiveIntermediates/RBBranch/IntermediateBuildFilesPath/CordovaLib .build/Release-iphoneos/CordovaLib.build/DerivedSources/armv7 -I/Users/phonegap/Library/Developer/Xcode/DerivedData/RBBranch-eoelrkktfohkitdezostyrfmsi de/Build/Intermediates/ArchiveIntermediates/RBBranch/IntermediateBuildFilesPath/CordovaLib .build/Release-iphoneos/CordovaLib.build/DerivedSources -F/tmp/gimlet/1645041/project/build -include /private/tmp/gimlet/1645041/project/build/sharedpch/CordovaLib_Prefix-bknepzhfpvjnqgasjij tpxgnfeww/CordovaLib_Prefix.pch -MMD -MT dependencies -MF /Users/phonegap/Library/Developer/Xcode/DerivedData/RBBranch-eoelrkktfohkitdezostyrfmside /Build/Intermediates/ArchiveIntermediates/RBBranch/IntermediateBuildFilesPath/CordovaLib.b uild/Release-iphoneos/CordovaLib.build/Objects-normal/armv7/CDVAppDelegate.d --serialize-diagnostics /Users/phonegap/Library/Developer/Xcode/DerivedData/RBBranch-eoelrkktfohkitdezostyrfmside /Build/Intermediates/ArchiveIntermediates/RBBranch/IntermediateBuildFilesPath/CordovaLib.b uild/Release-iphoneos/CordovaLib.build/Objects-normal/armv7/CDVAppDelegate.dia -c /tmp/gimlet/1645041/project/CordovaLib/Classes/Public/CDVAppDelegate.m -o /Users/phonegap/Library/Developer/Xcode/DerivedData/RBBranch-eoelrkktfohkitdezostyrfmside /Build/Intermediates/ArchiveIntermediates/RBBranch/IntermediateBuildFilesPath/CordovaLib.b uild/Release-iphoneos/CordovaLib.build/Objects-normal/armv7/CDVAppDelegate.o
      CompileC /Users/phonegap/Library/Developer/Xcode/DerivedData/RBBranch-eoelrkktfohkitdezostyrfmside /Build/Intermediates/ArchiveIntermediates/RBBranch/IntermediateBuildFilesPath/CordovaLib.b uild/Release-iphoneos/CordovaLib.build/Objects-normal/armv7/NSDictionary+CordovaPreference s.o Classes/Public/NSDictionary+CordovaPreferences.m normal armv7 objective-c com.apple.compilers.llvm.clang.1_0.compiler
        /Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/bin/cl ang -x objective-c -arch armv7 -fmessage-length=0 -fdiagnostics-show-note-include-stack -fmacro-backtrace-limit=0 -std=c99 -fobjc-arc -fmodules -fmodules-cache-path=/Users/phonegap/Library/Developer/Xcode/DerivedData/ModuleCache -fmodules-prune-interval=86400 -fmodules-prune-after=345600 -fbuild-session-file=/Users/phonegap/Library/Developer/Xcode/DerivedData/ModuleCache/Sess ion.modulevalidation -fmodules-validate-once-per-build-session -Wno-trigraphs -fpascal-strings -Os -Wno-missing-field-initializers -Wno-missing-prototypes -Wno-implicit-atomic-properties -Wno-arc-repeated-use-of-weak -Wduplicate-method-match -Wno-missing-braces -Wparentheses -Wswitch -Wunused-function -Wno-unused-label -Wno-unused-parameter -Wunused-variable -Wunused-value -Wempty-body -Wuninitialized -Wno-unknown-pragmas -Wno-shadow -Wno-four-char-constants -Wno-conversion -Wconstant-conversion -Wint-conversion -Wbool-conversion -Wenum-conversion -Wno-shorten-64-to-32 -Wpointer-sign -Wno-newline-eof -Wno-selector -Wno-strict-selector-match -Wundeclared-selector -Wno-deprecated-implementations -isysroot /Applications/Xcode.app/Contents/Developer/Platforms/iPhoneOS.platform/Developer/SDKs/iPh oneOS10.1.sdk -fstrict-aliasing -Wprotocol -Wdeprecated-declarations -miphoneos-version-min=8.0 -g -Wno-sign-conversion -Wno-infinite-recursion -iquote /Users/phonegap/Library/Developer/Xcode/DerivedData/RBBranch-eoelrkktfohkitdezostyrfmside /Build/Intermediates/ArchiveIntermediates/RBBranch/IntermediateBuildFilesPath/CordovaLib.b uild/Release-iphoneos/CordovaLib.build/Cordova-generated-files.hmap -I/Users/phonegap/Library/Developer/Xcode/DerivedData/RBBranch-eoelrkktfohkitdezostyrfmsi de/Build/Intermediates/ArchiveIntermediates/RBBranch/IntermediateBuildFilesPath/CordovaLib .build/Release-iphoneos/CordovaLib.build/Cordova-own-target-headers.hmap -I/Users/phonegap/Library/Developer/Xcode/DerivedData/RBBranch-eoelrkktfohkitdezostyrfmsi de/Build/Intermediates/ArchiveIntermediates/RBBranch/IntermediateBuildFilesPath/CordovaLib .build/Release-iphoneos/CordovaLib.build/Cordova-all-target-headers.hmap -iquote /Users/phonegap/Library/Developer/Xcode/DerivedData/RBBranch-eoelrkktfohkitdezostyrfmside /Build/Intermediates/ArchiveIntermediates/RBBranch/IntermediateBuildFilesPath/CordovaLib.b uild/Release-iphoneos/CordovaLib.build/Cordova-project-headers.hmap -I/tmp/gimlet/1645041/project/build/include -I/Users/phonegap/Library/Developer/Xcode/DerivedData/RBBranch-eoelrkktfohkitdezostyrfmsi de/Build/Intermediates/ArchiveIntermediates/RBBranch/IntermediateBuildFilesPath/Uninstalle dProducts/iphoneos/usr/local/lib/include -I/Users/phonegap/Library/Developer/Xcode/DerivedData/RBBranch-eoelrkktfohkitdezostyrfmsi de/Build/Intermediates/ArchiveIntermediates/RBBranch/IntermediateBuildFilesPath/Uninstalle dProducts/include -I/Users/phonegap/Library/Developer/Xcode/DerivedData/RBBranch-eoelrkktfohkitdezostyrfmsi de/Build/Intermediates/ArchiveIntermediates/RBBranch/IntermediateBuildFilesPath/Uninstalle dProducts/iphoneos/include -I/tmp/gimlet/1645041/project/build -I/Users/phonegap/Library/Developer/Xcode/DerivedData/RBBranch-eoelrkktfohkitdezostyrfmsi de/Build/Intermediates/ArchiveIntermediates/RBBranch/IntermediateBuildFilesPath/CordovaLib .build/Release-iphoneos/CordovaLib.build/DerivedSources/armv7 -I/Users/phonegap/Library/Developer/Xcode/DerivedData/RBBranch-eoelrkktfohkitdezostyrfmsi de/Build/Intermediates/ArchiveIntermediates/RBBranch/IntermediateBuildFilesPath/CordovaLib .build/Release-iphoneos/CordovaLib.build/DerivedSources -F/tmp/gimlet/1645041/project/build -include /private/tmp/gimlet/1645041/project/build/sharedpch/CordovaLib_Prefix-bknepzhfpvjnqgasjij tpxgnfeww/CordovaLib_Prefix.pch -MMD -MT dependencies -MF /Users/phonegap/Library/Developer/Xcode/DerivedData/RBBranch-eoelrkktfohkitdezostyrfmside /Build/Intermediates/ArchiveIntermediates/RBBranch/IntermediateBuildFilesPath/CordovaLib.b uild/Release-iphoneos/CordovaLib.build/Objects-normal/armv7/NSDictionary+CordovaPreference s.d --serialize-diagnostics /Users/phonegap/Library/Developer/Xcode/DerivedData/RBBranch-eoelrkktfohkitdezostyrfmside /Build/Intermediates/ArchiveIntermediates/RBBranch/IntermediateBuildFilesPath/CordovaLib.b uild/Release-iphoneos/CordovaLib.build/Objects-normal/armv7/NSDictionary+CordovaPreference s.dia -c /tmp/gimlet/1645041/project/CordovaLib/Classes/Public/NSDictionary+CordovaPreferences.m -o /Users/phonegap/Library/Developer/Xcode/DerivedData/RBBranch-eoelrkktfohkitdezostyrfmside /Build/Intermediates/ArchiveIntermediates/RBBranch/IntermediateBuildFilesPath/CordovaLib.b uild/Release-iphoneos/CordovaLib.build/Objects-normal/armv7/NSDictionary+CordovaPreference s.o
      CompileC /Users/phonegap/Library/Developer/Xcode/DerivedData/RBBranch-eoelrkktfohkitdezostyrfmside /Build/Intermediates/ArchiveIntermediates/RBBranch/IntermediateBuildFilesPath/CordovaLib.b uild/Release-iphoneos/CordovaLib.build/Objects-normal/armv7/CDVUIWebViewDelegate.o Classes/Private/Plugins/CDVUIWebViewEngine/CDVUIWebViewDelegate.m normal armv7 objective-c com.apple.compilers.llvm.clang.1_0.compiler
        /Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/bin/cl ang -x objective-c -arch armv7 -fmessage-length=0 -fdiagnostics-show-note-include-stack -fmacro-backtrace-limit=0 -std=c99 -fobjc-arc -fmodules -fmodules-cache-path=/Users/phonegap/Library/Developer/Xcode/DerivedData/ModuleCache -fmodules-prune-interval=86400 -fmodules-prune-after=345600 -fbuild-session-file=/Users/phonegap/Library/Developer/Xcode/DerivedData/ModuleCache/Sess ion.modulevalidation -fmodules-validate-once-per-build-session -Wno-trigraphs -fpascal-strings -Os -Wno-missing-field-initializers -Wno-missing-prototypes -Wno-implicit-atomic-properties -Wno-arc-repeated-use-of-weak -Wduplicate-method-match -Wno-missing-braces -Wparentheses -Wswitch -Wunused-function -Wno-unused-label -Wno-unused-parameter -Wunused-variable -Wunused-value -Wempty-body -Wuninitialized -Wno-unknown-pragmas -Wno-shadow -Wno-four-char-constants -Wno-conversion -Wconstant-conversion -Wint-conversion -Wbool-conversion -Wenum-conversion -Wno-shorten-64-to-32 -Wpointer-sign -Wno-newline-eof -Wno-selector -Wno-strict-selector-match -Wundeclared-selector -Wno-deprecated-implementations -isysroot /Applications/Xcode.app/Contents/Developer/Platforms/iPhoneOS.platform/Developer/SDKs/iPh oneOS10.1.sdk -fstrict-aliasing -Wprotocol -Wdeprecated-declarations -miphoneos-version-min=8.0 -g -Wno-sign-conversion -Wno-infinite-recursion -iquote /Users/phonegap/Library/Developer/Xcode/DerivedData/RBBranch-eoelrkktfohkitdezostyrfmside /Build/Intermediates/ArchiveIntermediates/RBBranch/IntermediateBuildFilesPath/CordovaLib.b uild/Release-iphoneos/CordovaLib.build/Cordova-generated-files.hmap -I/Users/phonegap/Library/Developer/Xcode/DerivedData/RBBranch-eoelrkktfohkitdezostyrfmsi de/Build/Intermediates/ArchiveIntermediates/RBBranch/IntermediateBuildFilesPath/CordovaLib .build/Release-iphoneos/CordovaLib.build/Cordova-own-target-headers.hmap -I/Users/phonegap/Library/Developer/Xcode/DerivedData/RBBranch-eoelrkktfohkitdezostyrfmsi de/Build/Intermediates/ArchiveIntermediates/RBBranch/IntermediateBuildFilesPath/CordovaLib .build/Release-iphoneos/CordovaLib.build/Cordova-all-target-headers.hmap -iquote /Users/phonegap/Library/Developer/Xcode/DerivedData/RBBranch-eoelrkktfohkitdezostyrfmside /Build/Intermediates/ArchiveIntermediates/RBBranch/IntermediateBuildFilesPath/CordovaLib.b uild/Release-iphoneos/CordovaLib.build/Cordova-project-headers.hmap -I/tmp/gimlet/1645041/project/build/include -I/Users/phonegap/Library/Developer/Xcode/DerivedData/RBBranch-eoelrkktfohkitdezostyrfmsi de/Build/Intermediates/ArchiveIntermediates/RBBranch/IntermediateBuildFilesPath/Uninstalle dProducts/iphoneos/usr/local/lib/include -I/Users/phonegap/Library/Developer/Xcode/DerivedData/RBBranch-eoelrkktfohkitdezostyrfmsi de/Build/Intermediates/ArchiveIntermediates/RBBranch/IntermediateBuildFilesPath/Uninstalle dProducts/include -I/Users/phonegap/Library/Developer/Xcode/DerivedData/RBBranch-eoelrkktfohkitdezostyrfmsi de/Build/Intermediates/ArchiveIntermediates/RBBranch/IntermediateBuildFilesPath/Uninstalle dProducts/iphoneos/include -I/tmp/gimlet/1645041/project/build -I/Users/phonegap/Library/Developer/Xcode/DerivedData/RBBranch-eoelrkktfohkitdezostyrfmsi de/Build/Intermediates/ArchiveIntermediates/RBBranch/IntermediateBuildFilesPath/CordovaLib .build/Release-iphoneos/CordovaLib.build/DerivedSources/armv7 -I/Users/phonegap/Library/Developer/Xcode/DerivedData/RBBranch-eoelrkktfohkitdezostyrfmsi de/Build/Intermediates/ArchiveIntermediates/RBBranch/IntermediateBuildFilesPath/CordovaLib .build/Release-iphoneos/CordovaLib.build/DerivedSources -F/tmp/gimlet/1645041/project/build -include /private/tmp/gimlet/1645041/project/build/sharedpch/CordovaLib_Prefix-bknepzhfpvjnqgasjij tpxgnfeww/CordovaLib_Prefix.pch -MMD -MT dependencies -MF /Users/phonegap/Library/Developer/Xcode/DerivedData/RBBranch-eoelrkktfohkitdezostyrfmside /Build/Intermediates/ArchiveIntermediates/RBBranch/IntermediateBuildFilesPath/CordovaLib.b uild/Release-iphoneos/CordovaLib.build/Objects-normal/armv7/CDVUIWebViewDelegate.d --serialize-diagnostics /Users/phonegap/Library/Developer/Xcode/DerivedData/RBBranch-eoelrkktfohkitdezostyrfmside /Build/Intermediates/ArchiveIntermediates/RBBranch/IntermediateBuildFilesPath/CordovaLib.b uild/Release-iphoneos/CordovaLib.build/Objects-normal/armv7/CDVUIWebViewDelegate.dia -c /tmp/gimlet/1645041/project/CordovaLib/Classes/Private/Plugins/CDVUIWebViewEngine/CDVUIWe bViewDelegate.m -o /Users/phonegap/Library/Developer/Xcode/DerivedData/RBBranch-eoelrkktfohkitdezostyrfmside /Build/Intermediates/ArchiveIntermediates/RBBranch/IntermediateBuildFilesPath/CordovaLib.b uild/Release-iphoneos/CordovaLib.build/Objects-normal/armv7/CDVUIWebViewDelegate.o
      CompileC /Users/phonegap/Library/Developer/Xcode/DerivedData/RBBranch-eoelrkktfohkitdezostyrfmside /Build/Intermediates/ArchiveIntermediates/RBBranch/IntermediateBuildFilesPath/CordovaLib.b uild/Release-iphoneos/CordovaLib.build/Objects-normal/armv7/CDVCommandDelegateImpl.o Classes/Public/CDVCommandDelegateImpl.m normal armv7 objective-c com.apple.compilers.llvm.clang.1_0.compiler
        /Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/bin/cl ang -x objective-c -arch armv7 -fmessage-length=0 -fdiagnostics-show-note-include-stack -fmacro-backtrace-limit=0 -std=c99 -fobjc-arc -fmodules -fmodules-cache-path=/Users/phonegap/Library/Developer/Xcode/DerivedData/ModuleCache -fmodules-prune-interval=86400 -fmodules-prune-after=345600 -fbuild-session-file=/Users/phonegap/Library/Developer/Xcode/DerivedData/ModuleCache/Sess ion.modulevalidation -fmodules-validate-once-per-build-session -Wno-trigraphs -fpascal-strings -Os -Wno-missing-field-initializers -Wno-missing-prototypes -Wno-implicit-atomic-properties -Wno-arc-repeated-use-of-weak -Wduplicate-method-match -Wno-missing-braces -Wparentheses -Wswitch -Wunused-function -Wno-unused-label -Wno-unused-parameter -Wunused-variable -Wunused-value -Wempty-body -Wuninitialized -Wno-unknown-pragmas -Wno-shadow -Wno-four-char-constants -Wno-conversion -Wconstant-conversion -Wint-conversion -Wbool-conversion -Wenum-conversion -Wno-shorten-64-to-32 -Wpointer-sign -Wno-newline-eof -Wno-selector -Wno-strict-selector-match -Wundeclared-selector -Wno-deprecated-implementations -isysroot /Applications/Xcode.app/Contents/Developer/Platforms/iPhoneOS.platform/Developer/SDKs/iPh oneOS10.1.sdk -fstrict-aliasing -Wprotocol -Wdeprecated-declarations -miphoneos-version-min=8.0 -g -Wno-sign-conversion -Wno-infinite-recursion -iquote /Users/phonegap/Library/Developer/Xcode/DerivedData/RBBranch-eoelrkktfohkitdezostyrfmside /Build/Intermediates/ArchiveIntermediates/RBBranch/IntermediateBuildFilesPath/CordovaLib.b uild/Release-iphoneos/CordovaLib.build/Cordova-generated-files.hmap -I/Users/phonegap/Library/Developer/Xcode/DerivedData/RBBranch-eoelrkktfohkitdezostyrfmsi de/Build/Intermediates/ArchiveIntermediates/RBBranch/IntermediateBuildFilesPath/CordovaLib .build/Release-iphoneos/CordovaLib.build/Cordova-own-target-headers.hmap -I/Users/phonegap/Library/Developer/Xcode/DerivedData/RBBranch-eoelrkktfohkitdezostyrfmsi de/Build/Intermediates/ArchiveIntermediates/RBBranch/IntermediateBuildFilesPath/CordovaLib .build/Release-iphoneos/CordovaLib.build/Cordova-all-target-headers.hmap -iquote /Users/phonegap/Library/Developer/Xcode/DerivedData/RBBranch-eoelrkktfohkitdezostyrfmside /Build/Intermediates/ArchiveIntermediates/RBBranch/IntermediateBuildFilesPath/CordovaLib.b uild/Release-iphoneos/CordovaLib.build/Cordova-project-headers.hmap -I/tmp/gimlet/1645041/project/build/include -I/Users/phonegap/Library/Developer/Xcode/DerivedData/RBBranch-eoelrkktfohkitdezostyrfmsi de/Build/Intermediates/ArchiveIntermediates/RBBranch/IntermediateBuildFilesPath/Uninstalle dProducts/iphoneos/usr/local/lib/include -I/Users/phonegap/Library/Developer/Xcode/DerivedData/RBBranch-eoelrkktfohkitdezostyrfmsi de/Build/Intermediates/ArchiveIntermediates/RBBranch/IntermediateBuildFilesPath/Uninstalle dProducts/include -I/Users/phonegap/Library/Developer/Xcode/DerivedData/RBBranch-eoelrkktfohkitdezostyrfmsi de/Build/Intermediates/ArchiveIntermediates/RBBranch/IntermediateBuildFilesPath/Uninstalle dProducts/iphoneos/include -I/tmp/gimlet/1645041/project/build -I/Users/phonegap/Library/Developer/Xcode/DerivedData/RBBranch-eoelrkktfohkitdezostyrfmsi de/Build/Intermediates/ArchiveIntermediates/RBBranch/IntermediateBuildFilesPath/CordovaLib .build/Release-iphoneos/CordovaLib.build/DerivedSources/armv7 -I/Users/phonegap/Library/Developer/Xcode/DerivedData/RBBranch-eoelrkktfohkitdezostyrfmsi de/Build/Intermediates/ArchiveIntermediates/RBBranch/IntermediateBuildFilesPath/CordovaLib .build/Release-iphoneos/CordovaLib.build/DerivedSources -F/tmp/gimlet/1645041/project/build -include /private/tmp/gimlet/1645041/project/build/sharedpch/CordovaLib_Prefix-bknepzhfpvjnqgasjij tpxgnfeww/CordovaLib_Prefix.pch -MMD -MT dependencies -MF /Users/phonegap/Library/Developer/Xcode/DerivedData/RBBranch-eoelrkktfohkitdezostyrfmside /Build/Intermediates/ArchiveIntermediates/RBBranch/IntermediateBuildFilesPath/CordovaLib.b uild/Release-iphoneos/CordovaLib.build/Objects-normal/armv7/CDVCommandDelegateImpl.d --serialize-diagnostics /Users/phonegap/Library/Developer/Xcode/DerivedData/RBBranch-eoelrkktfohkitdezostyrfmside /Build/Intermediates/ArchiveIntermediates/RBBranch/IntermediateBuildFilesPath/CordovaLib.b uild/Release-iphoneos/CordovaLib.build/Objects-normal/armv7/CDVCommandDelegateImpl.dia -c /tmp/gimlet/1645041/project/CordovaLib/Classes/Public/CDVCommandDelegateImpl.m -o /Users/phonegap/Library/Developer/Xcode/DerivedData/RBBranch-eoelrkktfohkitdezostyrfmside /Build/Intermediates/ArchiveIntermediates/RBBranch/IntermediateBuildFilesPath/CordovaLib.b uild/Release-iphoneos/CordovaLib.build/Objects-normal/armv7/CDVCommandDelegateImpl.o
      CompileC /Users/phonegap/Library/Developer/Xcode/DerivedData/RBBranch-eoelrkktfohkitdezostyrfmside /Build/Intermediates/ArchiveIntermediates/RBBranch/IntermediateBuildFilesPath/CordovaLib.b uild/Release-iphoneos/CordovaLib.build/Objects-normal/armv7/CDVJSON_private.o Classes/Private/CDVJSON_private.m normal armv7 objective-c com.apple.compilers.llvm.clang.1_0.compiler
        /Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/bin/cl ang -x objective-c -arch armv7 -fmessage-length=0 -fdiagnostics-show-note-include-stack -fmacro-backtrace-limit=0 -std=c99 -fobjc-arc -fmodules -fmodules-cache-path=/Users/phonegap/Library/Developer/Xcode/DerivedData/ModuleCache -fmodules-prune-interval=86400 -fmodules-prune-after=345600 -fbuild-session-file=/Users/phonegap/Library/Developer/Xcode/DerivedData/ModuleCache/Sess ion.modulevalidation -fmodules-validate-once-per-build-session -Wno-trigraphs -fpascal-strings -Os -Wno-missing-field-initializers -Wno-missing-prototypes -Wno-implicit-atomic-properties -Wno-arc-repeated-use-of-weak -Wduplicate-method-match -Wno-missing-braces -Wparentheses -Wswitch -Wunused-function -Wno-unused-label -Wno-unused-parameter -Wunused-variable -Wunused-value -Wempty-body -Wuninitialized -Wno-unknown-pragmas -Wno-shadow -Wno-four-char-constants -Wno-conversion -Wconstant-conversion -Wint-conversion -Wbool-conversion -Wenum-conversion -Wno-shorten-64-to-32 -Wpointer-sign -Wno-newline-eof -Wno-selector -Wno-strict-selector-match -Wundeclared-selector -Wno-deprecated-implementations -isysroot /Applications/Xcode.app/Contents/Developer/Platforms/iPhoneOS.platform/Developer/SDKs/iPh oneOS10.1.sdk -fstrict-aliasing -Wprotocol -Wdeprecated-declarations -miphoneos-version-min=8.0 -g -Wno-sign-conversion -Wno-infinite-recursion -iquote /Users/phonegap/Library/Developer/Xcode/DerivedData/RBBranch-eoelrkktfohkitdezostyrfmside /Build/Intermediates/ArchiveIntermediates/RBBranch/IntermediateBuildFilesPath/CordovaLib.b uild/Release-iphoneos/CordovaLib.build/Cordova-generated-files.hmap -I/Users/phonegap/Library/Developer/Xcode/DerivedData/RBBranch-eoelrkktfohkitdezostyrfmsi de/Build/Intermediates/ArchiveIntermediates/RBBranch/IntermediateBuildFilesPath/CordovaLib .build/Release-iphoneos/CordovaLib.build/Cordova-own-target-headers.hmap -I/Users/phonegap/Library/Developer/Xcode/DerivedData/RBBranch-eoelrkktfohkitdezostyrfmsi de/Build/Intermediates/ArchiveIntermediates/RBBranch/IntermediateBuildFilesPath/CordovaLib .build/Release-iphoneos/CordovaLib.build/Cordova-all-target-headers.hmap -iquote /Users/phonegap/Library/Developer/Xcode/DerivedData/RBBranch-eoelrkktfohkitdezostyrfmside /Build/Intermediates/ArchiveIntermediates/RBBranch/IntermediateBuildFilesPath/CordovaLib.b uild/Release-iphoneos/CordovaLib.build/Cordova-project-headers.hmap -I/tmp/gimlet/1645041/project/build/include -I/Users/phonegap/Library/Developer/Xcode/DerivedData/RBBranch-eoelrkktfohkitdezostyrfmsi de/Build/Intermediates/ArchiveIntermediates/RBBranch/IntermediateBuildFilesPath/Uninstalle dProducts/iphoneos/usr/local/lib/include -I/Users/phonegap/Library/Developer/Xcode/DerivedData/RBBranch-eoelrkktfohkitdezostyrfmsi de/Build/Intermediates/ArchiveIntermediates/RBBranch/IntermediateBuildFilesPath/Uninstalle dProducts/include -I/Users/phonegap/Library/Developer/Xcode/DerivedData/RBBranch-eoelrkktfohkitdezostyrfmsi de/Build/Intermediates/ArchiveIntermediates/RBBranch/IntermediateBuildFilesPath/Uninstalle dProducts/iphoneos/include -I/tmp/gimlet/1645041/project/build -I/Users/phonegap/Library/Developer/Xcode/DerivedData/RBBranch-eoelrkktfohkitdezostyrfmsi de/Build/Intermediates/ArchiveIntermediates/RBBranch/IntermediateBuildFilesPath/CordovaLib .build/Release-iphoneos/CordovaLib.build/DerivedSources/armv7 -I/Users/phonegap/Library/Developer/Xcode/DerivedData/RBBranch-eoelrkktfohkitdezostyrfmsi de/Build/Intermediates/ArchiveIntermediates/RBBranch/IntermediateBuildFilesPath/CordovaLib .build/Release-iphoneos/CordovaLib.build/DerivedSources -F/tmp/gimlet/1645041/project/build -include /private/tmp/gimlet/1645041/project/build/sharedpch/CordovaLib_Prefix-bknepzhfpvjnqgasjij tpxgnfeww/CordovaLib_Prefix.pch -MMD -MT dependencies -MF /Users/phonegap/Library/Developer/Xcode/DerivedData/RBBranch-eoelrkktfohkitdezostyrfmside /Build/Intermediates/ArchiveIntermediates/RBBranch/IntermediateBuildFilesPath/CordovaLib.b uild/Release-iphoneos/CordovaLib.build/Objects-normal/armv7/CDVJSON_private.d --serialize-diagnostics /Users/phonegap/Library/Developer/Xcode/DerivedData/RBBranch-eoelrkktfohkitdezostyrfmside /Build/Intermediates/ArchiveIntermediates/RBBranch/IntermediateBuildFilesPath/CordovaLib.b uild/Release-iphoneos/CordovaLib.build/Objects-normal/armv7/CDVJSON_private.dia -c /tmp/gimlet/1645041/project/CordovaLib/Classes/Private/CDVJSON_private.m -o /Users/phonegap/Library/Developer/Xcode/DerivedData/RBBranch-eoelrkktfohkitdezostyrfmside /Build/Intermediates/ArchiveIntermediates/RBBranch/IntermediateBuildFilesPath/CordovaLib.b uild/Release-iphoneos/CordovaLib.build/Objects-normal/armv7/CDVJSON_private.o
      CompileC /Users/phonegap/Library/Developer/Xcode/DerivedData/RBBranch-eoelrkktfohkitdezostyrfmside /Build/Intermediates/ArchiveIntermediates/RBBranch/IntermediateBuildFilesPath/CordovaLib.b uild/Release-iphoneos/CordovaLib.build/Objects-normal/armv7/CDVWhitelist.o Classes/Public/CDVWhitelist.m normal armv7 objective-c com.apple.compilers.llvm.clang.1_0.compiler
        /Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/bin/cl ang -x objective-c -arch armv7 -fmessage-length=0 -fdiagnostics-show-note-include-stack -fmacro-backtrace-limit=0 -std=c99 -fobjc-arc -fmodules -fmodules-cache-path=/Users/phonegap/Library/Developer/Xcode/DerivedData/ModuleCache -fmodules-prune-interval=86400 -fmodules-prune-after=345600 -fbuild-session-file=/Users/phonegap/Library/Developer/Xcode/DerivedData/ModuleCache/Sess ion.modulevalidation -fmodules-validate-once-per-build-session -Wno-trigraphs -fpascal-strings -Os -Wno-missing-field-initializers -Wno-missing-prototypes -Wno-implicit-atomic-properties -Wno-arc-repeated-use-of-weak -Wduplicate-method-match -Wno-missing-braces -Wparentheses -Wswitch -Wunused-function -Wno-unused-label -Wno-unused-parameter -Wunused-variable -Wunused-value -Wempty-body -Wuninitialized -Wno-unknown-pragmas -Wno-shadow -Wno-four-char-constants -Wno-conversion -Wconstant-conversion -Wint-conversion -Wbool-conversion -Wenum-conversion -Wno-shorten-64-to-32 -Wpointer-sign -Wno-newline-eof -Wno-selector -Wno-strict-selector-match -Wundeclared-selector -Wno-deprecated-implementations -isysroot /Applications/Xcode.app/Contents/Developer/Platforms/iPhoneOS.platform/Developer/SDKs/iPh oneOS10.1.sdk -fstrict-aliasing -Wprotocol -Wdeprecated-declarations -miphoneos-version-min=8.0 -g -Wno-sign-conversion -Wno-infinite-recursion -iquote /Users/phonegap/Library/Developer/Xcode/DerivedData/RBBranch-eoelrkktfohkitdezostyrfmside /Build/Intermediates/ArchiveIntermediates/RBBranch/IntermediateBuildFilesPath/CordovaLib.b uild/Release-iphoneos/CordovaLib.build/Cordova-generated-files.hmap -I/Users/phonegap/Library/Developer/Xcode/DerivedData/RBBranch-eoelrkktfohkitdezostyrfmsi de/Build/Intermediates/ArchiveIntermediates/RBBranch/IntermediateBuildFilesPath/CordovaLib .build/Release-iphoneos/CordovaLib.build/Cordova-own-target-headers.hmap -I/Users/phonegap/Library/Developer/Xcode/DerivedData/RBBranch-eoelrkktfohkitdezostyrfmsi de/Build/Intermediates/ArchiveIntermediates/RBBranch/IntermediateBuildFilesPath/CordovaLib .build/Release-iphoneos/CordovaLib.build/Cordova-all-target-headers.hmap -iquote /Users/phonegap/Library/Developer/Xcode/DerivedData/RBBranch-eoelrkktfohkitdezostyrfmside /Build/Intermediates/ArchiveIntermediates/RBBranch/IntermediateBuildFilesPath/CordovaLib.b uild/Release-iphoneos/CordovaLib.build/Cordova-project-headers.hmap -I/tmp/gimlet/1645041/project/build/include -I/Users/phonegap/Library/Developer/Xcode/DerivedData/RBBranch-eoelrkktfohkitdezostyrfmsi de/Build/Intermediates/ArchiveIntermediates/RBBranch/IntermediateBuildFilesPath/Uninstalle dProducts/iphoneos/usr/local/lib/include -I/Users/phonegap/Library/Developer/Xcode/DerivedData/RBBranch-eoelrkktfohkitdezostyrfmsi de/Build/Intermediates/ArchiveIntermediates/RBBranch/IntermediateBuildFilesPath/Uninstalle dProducts/include -I/Users/phonegap/Library/Developer/Xcode/DerivedData/RBBranch-eoelrkktfohkitdezostyrfmsi de/Build/Intermediates/ArchiveIntermediates/RBBranch/IntermediateBuildFilesPath/Uninstalle dProducts/iphoneos/include -I/tmp/gimlet/1645041/project/build -I/Users/phonegap/Library/Developer/Xcode/DerivedData/RBBranch-eoelrkktfohkitdezostyrfmsi de/Build/Intermediates/ArchiveIntermediates/RBBranch/IntermediateBuildFilesPath/CordovaLib .build/Release-iphoneos/CordovaLib.build/DerivedSources/armv7 -I/Users/phonegap/Library/Developer/Xcode/DerivedData/RBBranch-eoelrkktfohkitdezostyrfmsi de/Build/Intermediates/ArchiveIntermediates/RBBranch/IntermediateBuildFilesPath/CordovaLib .build/Release-iphoneos/CordovaLib.build/DerivedSources -F/tmp/gimlet/1645041/project/build -include /private/tmp/gimlet/1645041/project/build/sharedpch/CordovaLib_Prefix-bknepzhfpvjnqgasjij tpxgnfeww/CordovaLib_Prefix.pch -MMD -MT dependencies -MF /Users/phonegap/Library/Developer/Xcode/DerivedData/RBBranch-eoelrkktfohkitdezostyrfmside /Build/Intermediates/ArchiveIntermediates/RBBranch/IntermediateBuildFilesPath/CordovaLib.b uild/Release-iphoneos/CordovaLib.build/Objects-normal/armv7/CDVWhitelist.d --serialize-diagnostics /Users/phonegap/Library/Developer/Xcode/DerivedData/RBBranch-eoelrkktfohkitdezostyrfmside /Build/Intermediates/ArchiveIntermediates/RBBranch/IntermediateBuildFilesPath/CordovaLib.b uild/Release-iphoneos/CordovaLib.build/Objects-normal/armv7/CDVWhitelist.dia -c /tmp/gimlet/1645041/project/CordovaLib/Classes/Public/CDVWhitelist.m -o /Users/phonegap/Library/Developer/Xcode/DerivedData/RBBranch-eoelrkktfohkitdezostyrfmside /Build/Intermediates/ArchiveIntermediates/RBBranch/IntermediateBuildFilesPath/CordovaLib.b uild/Release-iphoneos/CordovaLib.build/Objects-normal/armv7/CDVWhitelist.o
      CompileC /Users/phonegap/Library/Developer/Xcode/DerivedData/RBBranch-eoelrkktfohkitdezostyrfmside /Build/Intermediates/ArchiveIntermediates/RBBranch/IntermediateBuildFilesPath/CordovaLib.b uild/Release-iphoneos/CordovaLib.build/Objects-normal/armv7/CDVInvokedUrlCommand.o Classes/Public/CDVInvokedUrlCommand.m normal armv7 objective-c com.apple.compilers.llvm.clang.1_0.compiler
        cd /tmp/gimlet/1645041/project/CordovaLib
        /Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/bin/cl ang -x objective-c -arch armv7 -fmessage-length=0 -fdiagnostics-show-note-include-stack -fmacro-backtrace-limit=0 -std=c99 -fobjc-arc -fmodules -fmodules-cache-path=/Users/phonegap/Library/Developer/Xcode/DerivedData/ModuleCache -fmodules-prune-interval=86400 -fmodules-prune-after=345600 -fbuild-session-file=/Users/phonegap/Library/Developer/Xcode/DerivedData/ModuleCache/Sess ion.modulevalidation -fmodules-validate-once-per-build-session -Wno-trigraphs -fpascal-strings -Os -Wno-missing-field-initializers -Wno-missing-prototypes -Wno-implicit-atomic-properties -Wno-arc-repeated-use-of-weak -Wduplicate-method-match -Wno-missing-braces -Wparentheses -Wswitch -Wunused-function -Wno-unused-label -Wno-unused-parameter -Wunused-variable -Wunused-value -Wempty-body -Wuninitialized -Wno-unknown-pragmas -Wno-shadow -Wno-four-char-constants -Wno-conversion -Wconstant-conversion -Wint-conversion -Wbool-conversion -Wenum-conversion -Wno-shorten-64-to-32 -Wpointer-sign -Wno-newline-eof -Wno-selector -Wno-strict-selector-match -Wundeclared-selector -Wno-deprecated-implementations -isysroot /Applications/Xcode.app/Contents/Developer/Platforms/iPhoneOS.platform/Developer/SDKs/iPh oneOS10.1.sdk -fstrict-aliasing -Wprotocol -Wdeprecated-declarations -miphoneos-version-min=8.0 -g -Wno-sign-conversion -Wno-infinite-recursion -iquote /Users/phonegap/Library/Developer/Xcode/DerivedData/RBBranch-eoelrkktfohkitdezostyrfmside /Build/Intermediates/ArchiveIntermediates/RBBranch/IntermediateBuildFilesPath/CordovaLib.b uild/Release-iphoneos/CordovaLib.build/Cordova-generated-files.hmap -I/Users/phonegap/Library/Developer/Xcode/DerivedData/RBBranch-eoelrkktfohkitdezostyrfmsi de/Build/Intermediates/ArchiveIntermediates/RBBranch/IntermediateBuildFilesPath/CordovaLib .build/Release-iphoneos/CordovaLib.build/Cordova-own-target-headers.hmap -I/Users/phonegap/Library/Developer/Xcode/DerivedData/RBBranch-eoelrkktfohkitdezostyrfmsi de/Build/Intermediates/ArchiveIntermediates/RBBranch/IntermediateBuildFilesPath/CordovaLib .build/Release-iphoneos/CordovaLib.build/Cordova-all-target-headers.hmap -iquote /Users/phonegap/Library/Developer/Xcode/DerivedData/RBBranch-eoelrkktfohkitdezostyrfmside /Build/Intermediates/ArchiveIntermediates/RBBranch/IntermediateBuildFilesPath/CordovaLib.b uild/Release-iphoneos/CordovaLib.build/Cordova-project-headers.hmap -I/tmp/gimlet/1645041/project/build/include -I/Users/phonegap/Library/Developer/Xcode/DerivedData/RBBranch-eoelrkktfohkitdezostyrfmsi de/Build/Intermediates/ArchiveIntermediates/RBBranch/IntermediateBuildFilesPath/Uninstalle dProducts/iphoneos/usr/local/lib/include -I/Users/phonegap/Library/Developer/Xcode/DerivedData/RBBranch-eoelrkktfohkitdezostyrfmsi de/Build/Intermediates/ArchiveIntermediates/RBBranch/IntermediateBuildFilesPath/Uninstalle dProducts/include -I/Users/phonegap/Library/Developer/Xcode/DerivedData/RBBranch-eoelrkktfohkitdezostyrfmsi de/Build/Intermediates/ArchiveIntermediates/RBBranch/IntermediateBuildFilesPath/Uninstalle dProducts/iphoneos/include -I/tmp/gimlet/1645041/project/build -I/Users/phonegap/Library/Developer/Xcode/DerivedData/RBBranch-eoelrkktfohkitdezostyrfmsi de/Build/Intermediates/ArchiveIntermediates/RBBranch/IntermediateBuildFilesPath/CordovaLib .build/Release-iphoneos/CordovaLib.build/DerivedSources/armv7 -I/Users/phonegap/Library/Developer/Xcode/DerivedData/RBBranch-eoelrkktfohkitdezostyrfmsi de/Build/Intermediates/ArchiveIntermediates/RBBranch/IntermediateBuildFilesPath/CordovaLib .build/Release-iphoneos/CordovaLib.build/DerivedSources -F/tmp/gimlet/1645041/project/build -include /private/tmp/gimlet/1645041/project/build/sharedpch/CordovaLib_Prefix-bknepzhfpvjnqgasjij tpxgnfeww/CordovaLib_Prefix.pch -MMD -MT dependencies -MF /Users/phonegap/Library/Developer/Xcode/DerivedData/RBBranch-eoelrkktfohkitdezostyrfmside /Build/Intermediates/ArchiveIntermediates/RBBranch/IntermediateBuildFilesPath/CordovaLib.b uild/Release-iphoneos/CordovaLib.build/Objects-normal/armv7/CDVInvokedUrlCommand.d --serialize-diagnostics /Users/phonegap/Library/Developer/Xcode/DerivedData/RBBranch-eoelrkktfohkitdezostyrfmside /Build/Intermediates/ArchiveIntermediates/RBBranch/IntermediateBuildFilesPath/CordovaLib.b uild/Release-iphoneos/CordovaLib.build/Objects-normal/armv7/CDVInvokedUrlCommand.dia -c /tmp/gimlet/1645041/project/CordovaLib/Classes/Public/CDVInvokedUrlCommand.m -o /Users/phonegap/Library/Developer/Xcode/DerivedData/RBBranch-eoelrkktfohkitdezostyrfmside /Build/Intermediates/ArchiveIntermediates/RBBranch/IntermediateBuildFilesPath/CordovaLib.b uild/Release-iphoneos/CordovaLib.build/Objects-normal/armv7/CDVInvokedUrlCommand.o
      CompileC /Users/phonegap/Library/Developer/Xcode/DerivedData/RBBranch-eoelrkktfohkitdezostyrfmside /Build/Intermediates/ArchiveIntermediates/RBBranch/IntermediateBuildFilesPath/CordovaLib.b uild/Release-iphoneos/CordovaLib.build/Objects-normal/armv7/CDVTimer.o Classes/Public/CDVTimer.m normal armv7 objective-c com.apple.compilers.llvm.clang.1_0.compiler
        /Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/bin/cl ang -x objective-c -arch armv7 -fmessage-length=0 -fdiagnostics-show-note-include-stack -fmacro-backtrace-limit=0 -std=c99 -fobjc-arc -fmodules -fmodules-cache-path=/Users/phonegap/Library/Developer/Xcode/DerivedData/ModuleCache -fmodules-prune-interval=86400 -fmodules-prune-after=345600 -fbuild-session-file=/Users/phonegap/Library/Developer/Xcode/DerivedData/ModuleCache/Sess ion.modulevalidation -fmodules-validate-once-per-build-session -Wno-trigraphs -fpascal-strings -Os -Wno-missing-field-initializers -Wno-missing-prototypes -Wno-implicit-atomic-properties -Wno-arc-repeated-use-of-weak -Wduplicate-method-match -Wno-missing-braces -Wparentheses -Wswitch -Wunused-function -Wno-unused-label -Wno-unused-parameter -Wunused-variable -Wunused-value -Wempty-body -Wuninitialized -Wno-unknown-pragmas -Wno-shadow -Wno-four-char-constants -Wno-conversion -Wconstant-conversion -Wint-conversion -Wbool-conversion -Wenum-conversion -Wno-shorten-64-to-32 -Wpointer-sign -Wno-newline-eof -Wno-selector -Wno-strict-selector-match -Wundeclared-selector -Wno-deprecated-implementations -isysroot /Applications/Xcode.app/Contents/Developer/Platforms/iPhoneOS.platform/Developer/SDKs/iPh oneOS10.1.sdk -fstrict-aliasing -Wprotocol -Wdeprecated-declarations -miphoneos-version-min=8.0 -g -Wno-sign-conversion -Wno-infinite-recursion -iquote /Users/phonegap/Library/Developer/Xcode/DerivedData/RBBranch-eoelrkktfohkitdezostyrfmside /Build/Intermediates/ArchiveIntermediates/RBBranch/IntermediateBuildFilesPath/CordovaLib.b uild/Release-iphoneos/CordovaLib.build/Cordova-generated-files.hmap -I/Users/phonegap/Library/Developer/Xcode/DerivedData/RBBranch-eoelrkktfohkitdezostyrfmsi de/Build/Intermediates/ArchiveIntermediates/RBBranch/IntermediateBuildFilesPath/CordovaLib .build/Release-iphoneos/CordovaLib.build/Cordova-own-target-headers.hmap -I/Users/phonegap/Library/Developer/Xcode/DerivedData/RBBranch-eoelrkktfohkitdezostyrfmsi de/Build/Intermediates/ArchiveIntermediates/RBBranch/IntermediateBuildFilesPath/CordovaLib .build/Release-iphoneos/CordovaLib.build/Cordova-all-target-headers.hmap -iquote /Users/phonegap/Library/Developer/Xcode/DerivedData/RBBranch-eoelrkktfohkitdezostyrfmside /Build/Intermediates/ArchiveIntermediates/RBBranch/IntermediateBuildFilesPath/CordovaLib.b uild/Release-iphoneos/CordovaLib.build/Cordova-project-headers.hmap -I/tmp/gimlet/1645041/project/build/include -I/Users/phonegap/Library/Developer/Xcode/DerivedData/RBBranch-eoelrkktfohkitdezostyrfmsi de/Build/Intermediates/ArchiveIntermediates/RBBranch/IntermediateBuildFilesPath/Uninstalle dProducts/iphoneos/usr/local/lib/include -I/Users/phonegap/Library/Developer/Xcode/DerivedData/RBBranch-eoelrkktfohkitdezostyrfmsi de/Build/Intermediates/ArchiveIntermediates/RBBranch/IntermediateBuildFilesPath/Uninstalle dProducts/include -I/Users/phonegap/Library/Developer/Xcode/DerivedData/RBBranch-eoelrkktfohkitdezostyrfmsi de/Build/Intermediates/ArchiveIntermediates/RBBranch/IntermediateBuildFilesPath/Uninstalle dProducts/iphoneos/include -I/tmp/gimlet/1645041/project/build -I/Users/phonegap/Library/Developer/Xcode/DerivedData/RBBranch-eoelrkktfohkitdezostyrfmsi de/Build/Intermediates/ArchiveIntermediates/RBBranch/IntermediateBuildFilesPath/CordovaLib .build/Release-iphoneos/CordovaLib.build/DerivedSources/armv7 -I/Users/phonegap/Library/Developer/Xcode/DerivedData/RBBranch-eoelrkktfohkitdezostyrfmsi de/Build/Intermediates/ArchiveIntermediates/RBBranch/IntermediateBuildFilesPath/CordovaLib .build/Release-iphoneos/CordovaLib.build/DerivedSources -F/tmp/gimlet/1645041/project/build -include /private/tmp/gimlet/1645041/project/build/sharedpch/CordovaLib_Prefix-bknepzhfpvjnqgasjij tpxgnfeww/CordovaLib_Prefix.pch -MMD -MT dependencies -MF /Users/phonegap/Library/Developer/Xcode/DerivedData/RBBranch-eoelrkktfohkitdezostyrfmside /Build/Intermediates/ArchiveIntermediates/RBBranch/IntermediateBuildFilesPath/CordovaLib.b uild/Release-iphoneos/CordovaLib.build/Objects-normal/armv7/CDVTimer.d --serialize-diagnostics /Users/phonegap/Library/Developer/Xcode/DerivedData/RBBranch-eoelrkktfohkitdezostyrfmside /Build/Intermediates/ArchiveIntermediates/RBBranch/IntermediateBuildFilesPath/CordovaLib.b uild/Release-iphoneos/CordovaLib.build/Objects-normal/armv7/CDVTimer.dia -c /tmp/gimlet/1645041/project/CordovaLib/Classes/Public/CDVTimer.m -o /Users/phonegap/Library/Developer/Xcode/DerivedData/RBBranch-eoelrkktfohkitdezostyrfmside /Build/Intermediates/ArchiveIntermediates/RBBranch/IntermediateBuildFilesPath/CordovaLib.b uild/Release-iphoneos/CordovaLib.build/Objects-normal/armv7/CDVTimer.o
      CompileC /Users/phonegap/Library/Developer/Xcode/DerivedData/RBBranch-eoelrkktfohkitdezostyrfmside /Build/Intermediates/ArchiveIntermediates/RBBranch/IntermediateBuildFilesPath/CordovaLib.b uild/Release-iphoneos/CordovaLib.build/Objects-normal/armv7/CDVUserAgentUtil.o Classes/Public/CDVUserAgentUtil.m normal armv7 objective-c com.apple.compilers.llvm.clang.1_0.compiler
        /Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/bin/cl ang -x objective-c -arch armv7 -fmessage-length=0 -fdiagnostics-show-note-include-stack -fmacro-backtrace-limit=0 -std=c99 -fobjc-arc -fmodules -fmodules-cache-path=/Users/phonegap/Library/Developer/Xcode/DerivedData/ModuleCache -fmodules-prune-interval=86400 -fmodules-prune-after=345600 -fbuild-session-file=/Users/phonegap/Library/Developer/Xcode/DerivedData/ModuleCache/Sess ion.modulevalidation -fmodules-validate-once-per-build-session -Wno-trigraphs -fpascal-strings -Os -Wno-missing-field-initializers -Wno-missing-prototypes -Wno-implicit-atomic-properties -Wno-arc-repeated-use-of-weak -Wduplicate-method-match -Wno-missing-braces -Wparentheses -Wswitch -Wunused-function -Wno-unused-label -Wno-unused-parameter -Wunused-variable -Wunused-value -Wempty-body -Wuninitialized -Wno-unknown-pragmas -Wno-shadow -Wno-four-char-constants -Wno-conversion -Wconstant-conversion -Wint-conversion -Wbool-conversion -Wenum-conversion -Wno-shorten-64-to-32 -Wpointer-sign -Wno-newline-eof -Wno-selector -Wno-strict-selector-match -Wundeclared-selector -Wno-deprecated-implementations -isysroot /Applications/Xcode.app/Contents/Developer/Platforms/iPhoneOS.platform/Developer/SDKs/iPh oneOS10.1.sdk -fstrict-aliasing -Wprotocol -Wdeprecated-declarations -miphoneos-version-min=8.0 -g -Wno-sign-conversion -Wno-infinite-recursion -iquote /Users/phonegap/Library/Developer/Xcode/DerivedData/RBBranch-eoelrkktfohkitdezostyrfmside /Build/Intermediates/ArchiveIntermediates/RBBranch/IntermediateBuildFilesPath/CordovaLib.b uild/Release-iphoneos/CordovaLib.build/Cordova-generated-files.hmap -I/Users/phonegap/Library/Developer/Xcode/DerivedData/RBBranch-eoelrkktfohkitdezostyrfmsi de/Build/Intermediates/ArchiveIntermediates/RBBranch/IntermediateBuildFilesPath/CordovaLib .build/Release-iphoneos/CordovaLib.build/Cordova-own-target-headers.hmap -I/Users/phonegap/Library/Developer/Xcode/DerivedData/RBBranch-eoelrkktfohkitdezostyrfmsi de/Build/Intermediates/ArchiveIntermediates/RBBranch/IntermediateBuildFilesPath/CordovaLib .build/Release-iphoneos/CordovaLib.build/Cordova-all-target-headers.hmap -iquote /Users/phonegap/Library/Developer/Xcode/DerivedData/RBBranch-eoelrkktfohkitdezostyrfmside /Build/Intermediates/ArchiveIntermediates/RBBranch/IntermediateBuildFilesPath/CordovaLib.b uild/Release-iphoneos/CordovaLib.build/Cordova-project-headers.hmap -I/tmp/gimlet/1645041/project/build/include -I/Users/phonegap/Library/Developer/Xcode/DerivedData/RBBranch-eoelrkktfohkitdezostyrfmsi de/Build/Intermediates/ArchiveIntermediates/RBBranch/IntermediateBuildFilesPath/Uninstalle dProducts/iphoneos/usr/local/lib/include -I/Users/phonegap/Library/Developer/Xcode/DerivedData/RBBranch-eoelrkktfohkitdezostyrfmsi de/Build/Intermediates/ArchiveIntermediates/RBBranch/IntermediateBuildFilesPath/Uninstalle dProducts/include -I/Users/phonegap/Library/Developer/Xcode/DerivedData/RBBranch-eoelrkktfohkitdezostyrfmsi de/Build/Intermediates/ArchiveIntermediates/RBBranch/IntermediateBuildFilesPath/Uninstalle dProducts/iphoneos/include -I/tmp/gimlet/1645041/project/build -I/Users/phonegap/Library/Developer/Xcode/DerivedData/RBBranch-eoelrkktfohkitdezostyrfmsi de/Build/Intermediates/ArchiveIntermediates/RBBranch/IntermediateBuildFilesPath/CordovaLib .build/Release-iphoneos/CordovaLib.build/DerivedSources/armv7 -I/Users/phonegap/Library/Developer/Xcode/DerivedData/RBBranch-eoelrkktfohkitdezostyrfmsi de/Build/Intermediates/ArchiveIntermediates/RBBranch/IntermediateBuildFilesPath/CordovaLib .build/Release-iphoneos/CordovaLib.build/DerivedSources -F/tmp/gimlet/1645041/project/build -include /private/tmp/gimlet/1645041/project/build/sharedpch/CordovaLib_Prefix-bknepzhfpvjnqgasjij tpxgnfeww/CordovaLib_Prefix.pch -MMD -MT dependencies -MF /Users/phonegap/Library/Developer/Xcode/DerivedData/RBBranch-eoelrkktfohkitdezostyrfmside /Build/Intermediates/ArchiveIntermediates/RBBranch/IntermediateBuildFilesPath/CordovaLib.b uild/Release-iphoneos/CordovaLib.build/Objects-normal/armv7/CDVUserAgentUtil.d --serialize-diagnostics /Users/phonegap/Library/Developer/Xcode/DerivedData/RBBranch-eoelrkktfohkitdezostyrfmside /Build/Intermediates/ArchiveIntermediates/RBBranch/IntermediateBuildFilesPath/CordovaLib.b uild/Release-iphoneos/CordovaLib.build/Objects-normal/armv7/CDVUserAgentUtil.dia -c /tmp/gimlet/1645041/project/CordovaLib/Classes/Public/CDVUserAgentUtil.m -o /Users/phonegap/Library/Developer/Xcode/DerivedData/RBBranch-eoelrkktfohkitdezostyrfmside /Build/Intermediates/ArchiveIntermediates/RBBranch/IntermediateBuildFilesPath/CordovaLib.b uild/Release-iphoneos/CordovaLib.build/Objects-normal/armv7/CDVUserAgentUtil.o
      CompileC /Users/phonegap/Library/Developer/Xcode/DerivedData/RBBranch-eoelrkktfohkitdezostyrfmside /Build/Intermediates/ArchiveIntermediates/RBBranch/IntermediateBuildFilesPath/CordovaLib.b uild/Release-iphoneos/CordovaLib.build/Objects-normal/armv7/CDVConfigParser.o Classes/Public/CDVConfigParser.m normal armv7 objective-c com.apple.compilers.llvm.clang.1_0.compiler
        /Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/bin/cl ang -x objective-c -arch armv7 -fmessage-length=0 -fdiagnostics-show-note-include-stack -fmacro-backtrace-limit=0 -std=c99 -fobjc-arc -fmodules -fmodules-cache-path=/Users/phonegap/Library/Developer/Xcode/DerivedData/ModuleCache -fmodules-prune-interval=86400 -fmodules-prune-after=345600 -fbuild-session-file=/Users/phonegap/Library/Developer/Xcode/DerivedData/ModuleCache/Sess ion.modulevalidation -fmodules-validate-once-per-build-session -Wno-trigraphs -fpascal-strings -Os -Wno-missing-field-initializers -Wno-missing-prototypes -Wno-implicit-atomic-properties -Wno-arc-repeated-use-of-weak -Wduplicate-method-match -Wno-missing-braces -Wparentheses -Wswitch -Wunused-function -Wno-unused-label -Wno-unused-parameter -Wunused-variable -Wunused-value -Wempty-body -Wuninitialized -Wno-unknown-pragmas -Wno-shadow -Wno-four-char-constants -Wno-conversion -Wconstant-conversion -Wint-conversion -Wbool-conversion -Wenum-conversion -Wno-shorten-64-to-32 -Wpointer-sign -Wno-newline-eof -Wno-selector -Wno-strict-selector-match -Wundeclared-selector -Wno-deprecated-implementations -isysroot /Applications/Xcode.app/Contents/Developer/Platforms/iPhoneOS.platform/Developer/SDKs/iPh oneOS10.1.sdk -fstrict-aliasing -Wprotocol -Wdeprecated-declarations -miphoneos-version-min=8.0 -g -Wno-sign-conversion -Wno-infinite-recursion -iquote /Users/phonegap/Library/Developer/Xcode/DerivedData/RBBranch-eoelrkktfohkitdezostyrfmside /Build/Intermediates/ArchiveIntermediates/RBBranch/IntermediateBuildFilesPath/CordovaLib.b uild/Release-iphoneos/CordovaLib.build/Cordova-generated-files.hmap -I/Users/phonegap/Library/Developer/Xcode/DerivedData/RBBranch-eoelrkktfohkitdezostyrfmsi de/Build/Intermediates/ArchiveIntermediates/RBBranch/IntermediateBuildFilesPath/CordovaLib .build/Release-iphoneos/CordovaLib.build/Cordova-own-target-headers.hmap -I/Users/phonegap/Library/Developer/Xcode/DerivedData/RBBranch-eoelrkktfohkitdezostyrfmsi de/Build/Intermediates/ArchiveIntermediates/RBBranch/IntermediateBuildFilesPath/CordovaLib .build/Release-iphoneos/CordovaLib.build/Cordova-all-target-headers.hmap -iquote /Users/phonegap/Library/Developer/Xcode/DerivedData/RBBranch-eoelrkktfohkitdezostyrfmside /Build/Intermediates/ArchiveIntermediates/RBBranch/IntermediateBuildFilesPath/CordovaLib.b uild/Release-iphoneos/CordovaLib.build/Cordova-project-headers.hmap -I/tmp/gimlet/1645041/project/build/include -I/Users/phonegap/Library/Developer/Xcode/DerivedData/RBBranch-eoelrkktfohkitdezostyrfmsi de/Build/Intermediates/ArchiveIntermediates/RBBranch/IntermediateBuildFilesPath/Uninstalle dProducts/iphoneos/usr/local/lib/include -I/Users/phonegap/Library/Developer/Xcode/DerivedData/RBBranch-eoelrkktfohkitdezostyrfmsi de/Build/Intermediates/ArchiveIntermediates/RBBranch/IntermediateBuildFilesPath/Uninstalle dProducts/include -I/Users/phonegap/Library/Developer/Xcode/DerivedData/RBBranch-eoelrkktfohkitdezostyrfmsi de/Build/Intermediates/ArchiveIntermediates/RBBranch/IntermediateBuildFilesPath/Uninstalle dProducts/iphoneos/include -I/tmp/gimlet/1645041/project/build -I/Users/phonegap/Library/Developer/Xcode/DerivedData/RBBranch-eoelrkktfohkitdezostyrfmsi de/Build/Intermediates/ArchiveIntermediates/RBBranch/IntermediateBuildFilesPath/CordovaLib .build/Release-iphoneos/CordovaLib.build/DerivedSources/armv7 -I/Users/phonegap/Library/Developer/Xcode/DerivedData/RBBranch-eoelrkktfohkitdezostyrfmsi de/Build/Intermediates/ArchiveIntermediates/RBBranch/IntermediateBuildFilesPath/CordovaLib .build/Release-iphoneos/CordovaLib.build/DerivedSources -F/tmp/gimlet/1645041/project/build -include /private/tmp/gimlet/1645041/project/build/sharedpch/CordovaLib_Prefix-bknepzhfpvjnqgasjij tpxgnfeww/CordovaLib_Prefix.pch -MMD -MT dependencies -MF /Users/phonegap/Library/Developer/Xcode/DerivedData/RBBranch-eoelrkktfohkitdezostyrfmside /Build/Intermediates/ArchiveIntermediates/RBBranch/IntermediateBuildFilesPath/CordovaLib.b uild/Release-iphoneos/CordovaLib.build/Objects-normal/armv7/CDVConfigParser.d --serialize-diagnostics /Users/phonegap/Library/Developer/Xcode/DerivedData/RBBranch-eoelrkktfohkitdezostyrfmside /Build/Intermediates/ArchiveIntermediates/RBBranch/IntermediateBuildFilesPath/CordovaLib.b uild/Release-iphoneos/CordovaLib.build/Objects-normal/armv7/CDVConfigParser.dia -c /tmp/gimlet/1645041/project/CordovaLib/Classes/Public/CDVConfigParser.m -o /Users/phonegap/Library/Developer/Xcode/DerivedData/RBBranch-eoelrkktfohkitdezostyrfmside /Build/Intermediates/ArchiveIntermediates/RBBranch/IntermediateBuildFilesPath/CordovaLib.b uild/Release-iphoneos/CordovaLib.build/Objects-normal/armv7/CDVConfigParser.o
      CompileC /Users/phonegap/Library/Developer/Xcode/DerivedData/RBBranch-eoelrkktfohkitdezostyrfmside /Build/Intermediates/ArchiveIntermediates/RBBranch/IntermediateBuildFilesPath/CordovaLib.b uild/Release-iphoneos/CordovaLib.build/Objects-normal/armv7/CDVGestureHandler.o Classes/Private/Plugins/CDVGestureHandler/CDVGestureHandler.m normal armv7 objective-c com.apple.compilers.llvm.clang.1_0.compiler
        export LANG=en_US.US-ASCII
        /Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/bin/cl ang -x objective-c -arch armv7 -fmessage-length=0 -fdiagnostics-show-note-include-stack -fmacro-backtrace-limit=0 -std=c99 -fobjc-arc -fmodules -fmodules-cache-path=/Users/phonegap/Library/Developer/Xcode/DerivedData/ModuleCache -fmodules-prune-interval=86400 -fmodules-prune-after=345600 -fbuild-session-file=/Users/phonegap/Library/Developer/Xcode/DerivedData/ModuleCache/Sess ion.modulevalidation -fmodules-validate-once-per-build-session -Wno-trigraphs -fpascal-strings -Os -Wno-missing-field-initializers -Wno-missing-prototypes -Wno-implicit-atomic-properties -Wno-arc-repeated-use-of-weak -Wduplicate-method-match -Wno-missing-braces -Wparentheses -Wswitch -Wunused-function -Wno-unused-label -Wno-unused-parameter -Wunused-variable -Wunused-value -Wempty-body -Wuninitialized -Wno-unknown-pragmas -Wno-shadow -Wno-four-char-constants -Wno-conversion -Wconstant-conversion -Wint-conversion -Wbool-conversion -Wenum-conversion -Wno-shorten-64-to-32 -Wpointer-sign -Wno-newline-eof -Wno-selector -Wno-strict-selector-match -Wundeclared-selector -Wno-deprecated-implementations -isysroot /Applications/Xcode.app/Contents/Developer/Platforms/iPhoneOS.platform/Developer/SDKs/iPh oneOS10.1.sdk -fstrict-aliasing -Wprotocol -Wdeprecated-declarations -miphoneos-version-min=8.0 -g -Wno-sign-conversion -Wno-infinite-recursion -iquote /Users/phonegap/Library/Developer/Xcode/DerivedData/RBBranch-eoelrkktfohkitdezostyrfmside /Build/Intermediates/ArchiveIntermediates/RBBranch/IntermediateBuildFilesPath/CordovaLib.b uild/Release-iphoneos/CordovaLib.build/Cordova-generated-files.hmap -I/Users/phonegap/Library/Developer/Xcode/DerivedData/RBBranch-eoelrkktfohkitdezostyrfmsi de/Build/Intermediates/ArchiveIntermediates/RBBranch/IntermediateBuildFilesPath/CordovaLib .build/Release-iphoneos/CordovaLib.build/Cordova-own-target-headers.hmap -I/Users/phonegap/Library/Developer/Xcode/DerivedData/RBBranch-eoelrkktfohkitdezostyrfmsi de/Build/Intermediates/ArchiveIntermediates/RBBranch/IntermediateBuildFilesPath/CordovaLib .build/Release-iphoneos/CordovaLib.build/Cordova-all-target-headers.hmap -iquote /Users/phonegap/Library/Developer/Xcode/DerivedData/RBBranch-eoelrkktfohkitdezostyrfmside /Build/Intermediates/ArchiveIntermediates/RBBranch/IntermediateBuildFilesPath/CordovaLib.b uild/Release-iphoneos/CordovaLib.build/Cordova-project-headers.hmap -I/tmp/gimlet/1645041/project/build/include -I/Users/phonegap/Library/Developer/Xcode/DerivedData/RBBranch-eoelrkktfohkitdezostyrfmsi de/Build/Intermediates/ArchiveIntermediates/RBBranch/IntermediateBuildFilesPath/Uninstalle dProducts/iphoneos/usr/local/lib/include -I/Users/phonegap/Library/Developer/Xcode/DerivedData/RBBranch-eoelrkktfohkitdezostyrfmsi de/Build/Intermediates/ArchiveIntermediates/RBBranch/IntermediateBuildFilesPath/Uninstalle dProducts/include -I/Users/phonegap/Library/Developer/Xcode/DerivedData/RBBranch-eoelrkktfohkitdezostyrfmsi de/Build/Intermediates/ArchiveIntermediates/RBBranch/IntermediateBuildFilesPath/Uninstalle dProducts/iphoneos/include -I/tmp/gimlet/1645041/project/build -I/Users/phonegap/Library/Developer/Xcode/DerivedData/RBBranch-eoelrkktfohkitdezostyrfmsi de/Build/Intermediates/ArchiveIntermediates/RBBranch/IntermediateBuildFilesPath/CordovaLib .build/Release-iphoneos/CordovaLib.build/DerivedSources/armv7 -I/Users/phonegap/Library/Developer/Xcode/DerivedData/RBBranch-eoelrkktfohkitdezostyrfmsi de/Build/Intermediates/ArchiveIntermediates/RBBranch/IntermediateBuildFilesPath/CordovaLib .build/Release-iphoneos/CordovaLib.build/DerivedSources -F/tmp/gimlet/1645041/project/build -include /private/tmp/gimlet/1645041/project/build/sharedpch/CordovaLib_Prefix-bknepzhfpvjnqgasjij tpxgnfeww/CordovaLib_Prefix.pch -MMD -MT dependencies -MF /Users/phonegap/Library/Developer/Xcode/DerivedData/RBBranch-eoelrkktfohkitdezostyrfmside /Build/Intermediates/ArchiveIntermediates/RBBranch/IntermediateBuildFilesPath/CordovaLib.b uild/Release-iphoneos/CordovaLib.build/Objects-normal/armv7/CDVGestureHandler.d --serialize-diagnostics /Users/phonegap/Library/Developer/Xcode/DerivedData/RBBranch-eoelrkktfohkitdezostyrfmside /Build/Intermediates/ArchiveIntermediates/RBBranch/IntermediateBuildFilesPath/CordovaLib.b uild/Release-iphoneos/CordovaLib.build/Objects-normal/armv7/CDVGestureHandler.dia -c /tmp/gimlet/1645041/project/CordovaLib/Classes/Private/Plugins/CDVGestureHandler/CDVGestu reHandler.m -o /Users/phonegap/Library/Developer/Xcode/DerivedData/RBBranch-eoelrkktfohkitdezostyrfmside /Build/Intermediates/ArchiveIntermediates/RBBranch/IntermediateBuildFilesPath/CordovaLib.b uild/Release-iphoneos/CordovaLib.build/Objects-normal/armv7/CDVGestureHandler.o
      CompileC /Users/phonegap/Library/Developer/Xcode/DerivedData/RBBranch-eoelrkktfohkitdezostyrfmside /Build/Intermediates/ArchiveIntermediates/RBBranch/IntermediateBuildFilesPath/CordovaLib.b uild/Release-iphoneos/CordovaLib.build/Objects-normal/armv7/CDVHandleOpenURL.o Classes/Private/Plugins/CDVHandleOpenURL/CDVHandleOpenURL.m normal armv7 objective-c com.apple.compilers.llvm.clang.1_0.compiler
        /Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/bin/cl ang -x objective-c -arch armv7 -fmessage-length=0 -fdiagnostics-show-note-include-stack -fmacro-backtrace-limit=0 -std=c99 -fobjc-arc -fmodules -fmodules-cache-path=/Users/phonegap/Library/Developer/Xcode/DerivedData/ModuleCache -fmodules-prune-interval=86400 -fmodules-prune-after=345600 -fbuild-session-file=/Users/phonegap/Library/Developer/Xcode/DerivedData/ModuleCache/Sess ion.modulevalidation -fmodules-validate-once-per-build-session -Wno-trigraphs -fpascal-strings -Os -Wno-missing-field-initializers -Wno-missing-prototypes -Wno-implicit-atomic-properties -Wno-arc-repeated-use-of-weak -Wduplicate-method-match -Wno-missing-braces -Wparentheses -Wswitch -Wunused-function -Wno-unused-label -Wno-unused-parameter -Wunused-variable -Wunused-value -Wempty-body -Wuninitialized -Wno-unknown-pragmas -Wno-shadow -Wno-four-char-constants -Wno-conversion -Wconstant-conversion -Wint-conversion -Wbool-conversion -Wenum-conversion -Wno-shorten-64-to-32 -Wpointer-sign -Wno-newline-eof -Wno-selector -Wno-strict-selector-match -Wundeclared-selector -Wno-deprecated-implementations -isysroot /Applications/Xcode.app/Contents/Developer/Platforms/iPhoneOS.platform/Developer/SDKs/iPh oneOS10.1.sdk -fstrict-aliasing -Wprotocol -Wdeprecated-declarations -miphoneos-version-min=8.0 -g -Wno-sign-conversion -Wno-infinite-recursion -iquote /Users/phonegap/Library/Developer/Xcode/DerivedData/RBBranch-eoelrkktfohkitdezostyrfmside /Build/Intermediates/ArchiveIntermediates/RBBranch/IntermediateBuildFilesPath/CordovaLib.b uild/Release-iphoneos/CordovaLib.build/Cordova-generated-files.hmap -I/Users/phonegap/Library/Developer/Xcode/DerivedData/RBBranch-eoelrkktfohkitdezostyrfmsi de/Build/Intermediates/ArchiveIntermediates/RBBranch/IntermediateBuildFilesPath/CordovaLib .build/Release-iphoneos/CordovaLib.build/Cordova-own-target-headers.hmap -I/Users/phonegap/Library/Developer/Xcode/DerivedData/RBBranch-eoelrkktfohkitdezostyrfmsi de/Build/Intermediates/ArchiveIntermediates/RBBranch/IntermediateBuildFilesPath/CordovaLib .build/Release-iphoneos/CordovaLib.build/Cordova-all-target-headers.hmap -iquote /Users/phonegap/Library/Developer/Xcode/DerivedData/RBBranch-eoelrkktfohkitdezostyrfmside /Build/Intermediates/ArchiveIntermediates/RBBranch/IntermediateBuildFilesPath/CordovaLib.b uild/Release-iphoneos/CordovaLib.build/Cordova-project-headers.hmap -I/tmp/gimlet/1645041/project/build/include -I/Users/phonegap/Library/Developer/Xcode/DerivedData/RBBranch-eoelrkktfohkitdezostyrfmsi de/Build/Intermediates/ArchiveIntermediates/RBBranch/IntermediateBuildFilesPath/Uninstalle dProducts/iphoneos/usr/local/lib/include -I/Users/phonegap/Library/Developer/Xcode/DerivedData/RBBranch-eoelrkktfohkitdezostyrfmsi de/Build/Intermediates/ArchiveIntermediates/RBBranch/IntermediateBuildFilesPath/Uninstalle dProducts/include -I/Users/phonegap/Library/Developer/Xcode/DerivedData/RBBranch-eoelrkktfohkitdezostyrfmsi de/Build/Intermediates/ArchiveIntermediates/RBBranch/IntermediateBuildFilesPath/Uninstalle dProducts/iphoneos/include -I/tmp/gimlet/1645041/project/build -I/Users/phonegap/Library/Developer/Xcode/DerivedData/RBBranch-eoelrkktfohkitdezostyrfmsi de/Build/Intermediates/ArchiveIntermediates/RBBranch/IntermediateBuildFilesPath/CordovaLib .build/Release-iphoneos/CordovaLib.build/DerivedSources/armv7 -I/Users/phonegap/Library/Developer/Xcode/DerivedData/RBBranch-eoelrkktfohkitdezostyrfmsi de/Build/Intermediates/ArchiveIntermediates/RBBranch/IntermediateBuildFilesPath/CordovaLib .build/Release-iphoneos/CordovaLib.build/DerivedSources -F/tmp/gimlet/1645041/project/build -include /private/tmp/gimlet/1645041/project/build/sharedpch/CordovaLib_Prefix-bknepzhfpvjnqgasjij tpxgnfeww/CordovaLib_Prefix.pch -MMD -MT dependencies -MF /Users/phonegap/Library/Developer/Xcode/DerivedData/RBBranch-eoelrkktfohkitdezostyrfmside /Build/Intermediates/ArchiveIntermediates/RBBranch/IntermediateBuildFilesPath/CordovaLib.b uild/Release-iphoneos/CordovaLib.build/Objects-normal/armv7/CDVHandleOpenURL.d --serialize-diagnostics /Users/phonegap/Library/Developer/Xcode/DerivedData/RBBranch-eoelrkktfohkitdezostyrfmside /Build/Intermediates/ArchiveIntermediates/RBBranch/IntermediateBuildFilesPath/CordovaLib.b uild/Release-iphoneos/CordovaLib.build/Objects-normal/armv7/CDVHandleOpenURL.dia -c /tmp/gimlet/1645041/project/CordovaLib/Classes/Private/Plugins/CDVHandleOpenURL/CDVHandle OpenURL.m -o /Users/phonegap/Library/Developer/Xcode/DerivedData/RBBranch-eoelrkktfohkitdezostyrfmside /Build/Intermediates/ArchiveIntermediates/RBBranch/IntermediateBuildFilesPath/CordovaLib.b uild/Release-iphoneos/CordovaLib.build/Objects-normal/armv7/CDVHandleOpenURL.o
      CompileC /Users/phonegap/Library/Developer/Xcode/DerivedData/RBBranch-eoelrkktfohkitdezostyrfmside /Build/Intermediates/ArchiveIntermediates/RBBranch/IntermediateBuildFilesPath/CordovaLib.b uild/Release-iphoneos/CordovaLib.build/Objects-normal/armv7/CDVUIWebViewNavigationDelegate .o Classes/Private/Plugins/CDVUIWebViewEngine/CDVUIWebViewNavigationDelegate.m normal armv7 objective-c com.apple.compilers.llvm.clang.1_0.compiler
        /Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/bin/cl ang -x objective-c -arch armv7 -fmessage-length=0 -fdiagnostics-show-note-include-stack -fmacro-backtrace-limit=0 -std=c99 -fobjc-arc -fmodules -fmodules-cache-path=/Users/phonegap/Library/Developer/Xcode/DerivedData/ModuleCache -fmodules-prune-interval=86400 -fmodules-prune-after=345600 -fbuild-session-file=/Users/phonegap/Library/Developer/Xcode/DerivedData/ModuleCache/Sess ion.modulevalidation -fmodules-validate-once-per-build-session -Wno-trigraphs -fpascal-strings -Os -Wno-missing-field-initializers -Wno-missing-prototypes -Wno-implicit-atomic-properties -Wno-arc-repeated-use-of-weak -Wduplicate-method-match -Wno-missing-braces -Wparentheses -Wswitch -Wunused-function -Wno-unused-label -Wno-unused-parameter -Wunused-variable -Wunused-value -Wempty-body -Wuninitialized -Wno-unknown-pragmas -Wno-shadow -Wno-four-char-constants -Wno-conversion -Wconstant-conversion -Wint-conversion -Wbool-conversion -Wenum-conversion -Wno-shorten-64-to-32 -Wpointer-sign -Wno-newline-eof -Wno-selector -Wno-strict-selector-match -Wundeclared-selector -Wno-deprecated-implementations -isysroot /Applications/Xcode.app/Contents/Developer/Platforms/iPhoneOS.platform/Developer/SDKs/iPh oneOS10.1.sdk -fstrict-aliasing -Wprotocol -Wdeprecated-declarations -miphoneos-version-min=8.0 -g -Wno-sign-conversion -Wno-infinite-recursion -iquote /Users/phonegap/Library/Developer/Xcode/DerivedData/RBBranch-eoelrkktfohkitdezostyrfmside /Build/Intermediates/ArchiveIntermediates/RBBranch/IntermediateBuildFilesPath/CordovaLib.b uild/Release-iphoneos/CordovaLib.build/Cordova-generated-files.hmap -I/Users/phonegap/Library/Developer/Xcode/DerivedData/RBBranch-eoelrkktfohkitdezostyrfmsi de/Build/Intermediates/ArchiveIntermediates/RBBranch/IntermediateBuildFilesPath/CordovaLib .build/Release-iphoneos/CordovaLib.build/Cordova-own-target-headers.hmap -I/Users/phonegap/Library/Developer/Xcode/DerivedData/RBBranch-eoelrkktfohkitdezostyrfmsi de/Build/Intermediates/ArchiveIntermediates/RBBranch/IntermediateBuildFilesPath/CordovaLib .build/Release-iphoneos/CordovaLib.build/Cordova-all-target-headers.hmap -iquote /Users/phonegap/Library/Developer/Xcode/DerivedData/RBBranch-eoelrkktfohkitdezostyrfmside /Build/Intermediates/ArchiveIntermediates/RBBranch/IntermediateBuildFilesPath/CordovaLib.b uild/Release-iphoneos/CordovaLib.build/Cordova-project-headers.hmap -I/tmp/gimlet/1645041/project/build/include -I/Users/phonegap/Library/Developer/Xcode/DerivedData/RBBranch-eoelrkktfohkitdezostyrfmsi de/Build/Intermediates/ArchiveIntermediates/RBBranch/IntermediateBuildFilesPath/Uninstalle dProducts/iphoneos/usr/local/lib/include -I/Users/phonegap/Library/Developer/Xcode/DerivedData/RBBranch-eoelrkktfohkitdezostyrfmsi de/Build/Intermediates/ArchiveIntermediates/RBBranch/IntermediateBuildFilesPath/Uninstalle dProducts/include -I/Users/phonegap/Library/Developer/Xcode/DerivedData/RBBranch-eoelrkktfohkitdezostyrfmsi de/Build/Intermediates/ArchiveIntermediates/RBBranch/IntermediateBuildFilesPath/Uninstalle dProducts/iphoneos/include -I/tmp/gimlet/1645041/project/build -I/Users/phonegap/Library/Developer/Xcode/DerivedData/RBBranch-eoelrkktfohkitdezostyrfmsi de/Build/Intermediates/ArchiveIntermediates/RBBranch/IntermediateBuildFilesPath/CordovaLib .build/Release-iphoneos/CordovaLib.build/DerivedSources/armv7 -I/Users/phonegap/Library/Developer/Xcode/DerivedData/RBBranch-eoelrkktfohkitdezostyrfmsi de/Build/Intermediates/ArchiveIntermediates/RBBranch/IntermediateBuildFilesPath/CordovaLib .build/Release-iphoneos/CordovaLib.build/DerivedSources -F/tmp/gimlet/1645041/project/build -include /private/tmp/gimlet/1645041/project/build/sharedpch/CordovaLib_Prefix-bknepzhfpvjnqgasjij tpxgnfeww/CordovaLib_Prefix.pch -MMD -MT dependencies -MF /Users/phonegap/Library/Developer/Xcode/DerivedData/RBBranch-eoelrkktfohkitdezostyrfmside /Build/Intermediates/ArchiveIntermediates/RBBranch/IntermediateBuildFilesPath/CordovaLib.b uild/Release-iphoneos/CordovaLib.build/Objects-normal/armv7/CDVUIWebViewNavigationDelegate .d --serialize-diagnostics /Users/phonegap/Library/Developer/Xcode/DerivedData/RBBranch-eoelrkktfohkitdezostyrfmside /Build/Intermediates/ArchiveIntermediates/RBBranch/IntermediateBuildFilesPath/CordovaLib.b uild/Release-iphoneos/CordovaLib.build/Objects-normal/armv7/CDVUIWebViewNavigationDelegate .dia -c /tmp/gimlet/1645041/project/CordovaLib/Classes/Private/Plugins/CDVUIWebViewEngine/CDVUIWe bViewNavigationDelegate.m -o /Users/phonegap/Library/Developer/Xcode/DerivedData/RBBranch-eoelrkktfohkitdezostyrfmside /Build/Intermediates/ArchiveIntermediates/RBBranch/IntermediateBuildFilesPath/CordovaLib.b uild/Release-iphoneos/CordovaLib.build/Objects-normal/armv7/CDVUIWebViewNavigationDelegate .o
      CompileC /Users/phonegap/Library/Developer/Xcode/DerivedData/RBBranch-eoelrkktfohkitdezostyrfmside /Build/Intermediates/ArchiveIntermediates/RBBranch/IntermediateBuildFilesPath/CordovaLib.b uild/Release-iphoneos/CordovaLib.build/Objects-normal/armv7/NSMutableArray+QueueAdditions. o Classes/Public/NSMutableArray+QueueAdditions.m normal armv7 objective-c com.apple.compilers.llvm.clang.1_0.compiler
        /Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/bin/cl ang -x objective-c -arch armv7 -fmessage-length=0 -fdiagnostics-show-note-include-stack -fmacro-backtrace-limit=0 -std=c99 -fobjc-arc -fmodules -fmodules-cache-path=/Users/phonegap/Library/Developer/Xcode/DerivedData/ModuleCache -fmodules-prune-interval=86400 -fmodules-prune-after=345600 -fbuild-session-file=/Users/phonegap/Library/Developer/Xcode/DerivedData/ModuleCache/Sess ion.modulevalidation -fmodules-validate-once-per-build-session -Wno-trigraphs -fpascal-strings -Os -Wno-missing-field-initializers -Wno-missing-prototypes -Wno-implicit-atomic-properties -Wno-arc-repeated-use-of-weak -Wduplicate-method-match -Wno-missing-braces -Wparentheses -Wswitch -Wunused-function -Wno-unused-label -Wno-unused-parameter -Wunused-variable -Wunused-value -Wempty-body -Wuninitialized -Wno-unknown-pragmas -Wno-shadow -Wno-four-char-constants -Wno-conversion -Wconstant-conversion -Wint-conversion -Wbool-conversion -Wenum-conversion -Wno-shorten-64-to-32 -Wpointer-sign -Wno-newline-eof -Wno-selector -Wno-strict-selector-match -Wundeclared-selector -Wno-deprecated-implementations -isysroot /Applications/Xcode.app/Contents/Developer/Platforms/iPhoneOS.platform/Developer/SDKs/iPh oneOS10.1.sdk -fstrict-aliasing -Wprotocol -Wdeprecated-declarations -miphoneos-version-min=8.0 -g -Wno-sign-conversion -Wno-infinite-recursion -iquote /Users/phonegap/Library/Developer/Xcode/DerivedData/RBBranch-eoelrkktfohkitdezostyrfmside /Build/Intermediates/ArchiveIntermediates/RBBranch/IntermediateBuildFilesPath/CordovaLib.b uild/Release-iphoneos/CordovaLib.build/Cordova-generated-files.hmap -I/Users/phonegap/Library/Developer/Xcode/DerivedData/RBBranch-eoelrkktfohkitdezostyrfmsi de/Build/Intermediates/ArchiveIntermediates/RBBranch/IntermediateBuildFilesPath/CordovaLib .build/Release-iphoneos/CordovaLib.build/Cordova-own-target-headers.hmap -I/Users/phonegap/Library/Developer/Xcode/DerivedData/RBBranch-eoelrkktfohkitdezostyrfmsi de/Build/Intermediates/ArchiveIntermediates/RBBranch/IntermediateBuildFilesPath/CordovaLib .build/Release-iphoneos/CordovaLib.build/Cordova-all-target-headers.hmap -iquote /Users/phonegap/Library/Developer/Xcode/DerivedData/RBBranch-eoelrkktfohkitdezostyrfmside /Build/Intermediates/ArchiveIntermediates/RBBranch/IntermediateBuildFilesPath/CordovaLib.b uild/Release-iphoneos/CordovaLib.build/Cordova-project-headers.hmap -I/tmp/gimlet/1645041/project/build/include -I/Users/phonegap/Library/Developer/Xcode/DerivedData/RBBranch-eoelrkktfohkitdezostyrfmsi de/Build/Intermediates/ArchiveIntermediates/RBBranch/IntermediateBuildFilesPath/Uninstalle dProducts/iphoneos/usr/local/lib/include -I/Users/phonegap/Library/Developer/Xcode/DerivedData/RBBranch-eoelrkktfohkitdezostyrfmsi de/Build/Intermediates/ArchiveIntermediates/RBBranch/IntermediateBuildFilesPath/Uninstalle dProducts/include -I/Users/phonegap/Library/Developer/Xcode/DerivedData/RBBranch-eoelrkktfohkitdezostyrfmsi de/Build/Intermediates/ArchiveIntermediates/RBBranch/IntermediateBuildFilesPath/Uninstalle dProducts/iphoneos/include -I/tmp/gimlet/1645041/project/build -I/Users/phonegap/Library/Developer/Xcode/DerivedData/RBBranch-eoelrkktfohkitdezostyrfmsi de/Build/Intermediates/ArchiveIntermediates/RBBranch/IntermediateBuildFilesPath/CordovaLib .build/Release-iphoneos/CordovaLib.build/DerivedSources/armv7 -I/Users/phonegap/Library/Developer/Xcode/DerivedData/RBBranch-eoelrkktfohkitdezostyrfmsi de/Build/Intermediates/ArchiveIntermediates/RBBranch/IntermediateBuildFilesPath/CordovaLib .build/Release-iphoneos/CordovaLib.build/DerivedSources -F/tmp/gimlet/1645041/project/build -include /private/tmp/gimlet/1645041/project/build/sharedpch/CordovaLib_Prefix-bknepzhfpvjnqgasjij tpxgnfeww/CordovaLib_Prefix.pch -MMD -MT dependencies -MF /Users/phonegap/Library/Developer/Xcode/DerivedData/RBBranch-eoelrkktfohkitdezostyrfmside /Build/Intermediates/ArchiveIntermediates/RBBranch/IntermediateBuildFilesPath/CordovaLib.b uild/Release-iphoneos/CordovaLib.build/Objects-normal/armv7/NSMutableArray+QueueAdditions. d --serialize-diagnostics /Users/phonegap/Library/Developer/Xcode/DerivedData/RBBranch-eoelrkktfohkitdezostyrfmside /Build/Intermediates/ArchiveIntermediates/RBBranch/IntermediateBuildFilesPath/CordovaLib.b uild/Release-iphoneos/CordovaLib.build/Objects-normal/armv7/NSMutableArray+QueueAdditions. dia -c /tmp/gimlet/1645041/project/CordovaLib/Classes/Public/NSMutableArray+QueueAdditions.m -o /Users/phonegap/Library/Developer/Xcode/DerivedData/RBBranch-eoelrkktfohkitdezostyrfmside /Build/Intermediates/ArchiveIntermediates/RBBranch/IntermediateBuildFilesPath/CordovaLib.b uild/Release-iphoneos/CordovaLib.build/Objects-normal/armv7/NSMutableArray+QueueAdditions. o
      CompileC /Users/phonegap/Library/Developer/Xcode/DerivedData/RBBranch-eoelrkktfohkitdezostyrfmside /Build/Intermediates/ArchiveIntermediates/RBBranch/IntermediateBuildFilesPath/CordovaLib.b uild/Release-iphoneos/CordovaLib.build/Objects-normal/armv7/CDVCommandQueue.o Classes/Public/CDVCommandQueue.m normal armv7 objective-c com.apple.compilers.llvm.clang.1_0.compiler
        /Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/bin/cl ang -x objective-c -arch armv7 -fmessage-length=0 -fdiagnostics-show-note-include-stack -fmacro-backtrace-limit=0 -std=c99 -fobjc-arc -fmodules -fmodules-cache-path=/Users/phonegap/Library/Developer/Xcode/DerivedData/ModuleCache -fmodules-prune-interval=86400 -fmodules-prune-after=345600 -fbuild-session-file=/Users/phonegap/Library/Developer/Xcode/DerivedData/ModuleCache/Sess ion.modulevalidation -fmodules-validate-once-per-build-session -Wno-trigraphs -fpascal-strings -Os -Wno-missing-field-initializers -Wno-missing-prototypes -Wno-implicit-atomic-properties -Wno-arc-repeated-use-of-weak -Wduplicate-method-match -Wno-missing-braces -Wparentheses -Wswitch -Wunused-function -Wno-unused-label -Wno-unused-parameter -Wunused-variable -Wunused-value -Wempty-body -Wuninitialized -Wno-unknown-pragmas -Wno-shadow -Wno-four-char-constants -Wno-conversion -Wconstant-conversion -Wint-conversion -Wbool-conversion -Wenum-conversion -Wno-shorten-64-to-32 -Wpointer-sign -Wno-newline-eof -Wno-selector -Wno-strict-selector-match -Wundeclared-selector -Wno-deprecated-implementations -isysroot /Applications/Xcode.app/Contents/Developer/Platforms/iPhoneOS.platform/Developer/SDKs/iPh oneOS10.1.sdk -fstrict-aliasing -Wprotocol -Wdeprecated-declarations -miphoneos-version-min=8.0 -g -Wno-sign-conversion -Wno-infinite-recursion -iquote /Users/phonegap/Library/Developer/Xcode/DerivedData/RBBranch-eoelrkktfohkitdezostyrfmside /Build/Intermediates/ArchiveIntermediates/RBBranch/IntermediateBuildFilesPath/CordovaLib.b uild/Release-iphoneos/CordovaLib.build/Cordova-generated-files.hmap -I/Users/phonegap/Library/Developer/Xcode/DerivedData/RBBranch-eoelrkktfohkitdezostyrfmsi de/Build/Intermediates/ArchiveIntermediates/RBBranch/IntermediateBuildFilesPath/CordovaLib .build/Release-iphoneos/CordovaLib.build/Cordova-own-target-headers.hmap -I/Users/phonegap/Library/Developer/Xcode/DerivedData/RBBranch-eoelrkktfohkitdezostyrfmsi de/Build/Intermediates/ArchiveIntermediates/RBBranch/IntermediateBuildFilesPath/CordovaLib .build/Release-iphoneos/CordovaLib.build/Cordova-all-target-headers.hmap -iquote /Users/phonegap/Library/Developer/Xcode/DerivedData/RBBranch-eoelrkktfohkitdezostyrfmside /Build/Intermediates/ArchiveIntermediates/RBBranch/IntermediateBuildFilesPath/CordovaLib.b uild/Release-iphoneos/CordovaLib.build/Cordova-project-headers.hmap -I/tmp/gimlet/1645041/project/build/include -I/Users/phonegap/Library/Developer/Xcode/DerivedData/RBBranch-eoelrkktfohkitdezostyrfmsi de/Build/Intermediates/ArchiveIntermediates/RBBranch/IntermediateBuildFilesPath/Uninstalle dProducts/iphoneos/usr/local/lib/include -I/Users/phonegap/Library/Developer/Xcode/DerivedData/RBBranch-eoelrkktfohkitdezostyrfmsi de/Build/Intermediates/ArchiveIntermediates/RBBranch/IntermediateBuildFilesPath/Uninstalle dProducts/include -I/Users/phonegap/Library/Developer/Xcode/DerivedData/RBBranch-eoelrkktfohkitdezostyrfmsi de/Build/Intermediates/ArchiveIntermediates/RBBranch/IntermediateBuildFilesPath/Uninstalle dProducts/iphoneos/include -I/tmp/gimlet/1645041/project/build -I/Users/phonegap/Library/Developer/Xcode/DerivedData/RBBranch-eoelrkktfohkitdezostyrfmsi de/Build/Intermediates/ArchiveIntermediates/RBBranch/IntermediateBuildFilesPath/CordovaLib .build/Release-iphoneos/CordovaLib.build/DerivedSources/armv7 -I/Users/phonegap/Library/Developer/Xcode/DerivedData/RBBranch-eoelrkktfohkitdezostyrfmsi de/Build/Intermediates/ArchiveIntermediates/RBBranch/IntermediateBuildFilesPath/CordovaLib .build/Release-iphoneos/CordovaLib.build/DerivedSources -F/tmp/gimlet/1645041/project/build -include /private/tmp/gimlet/1645041/project/build/sharedpch/CordovaLib_Prefix-bknepzhfpvjnqgasjij tpxgnfeww/CordovaLib_Prefix.pch -MMD -MT dependencies -MF /Users/phonegap/Library/Developer/Xcode/DerivedData/RBBranch-eoelrkktfohkitdezostyrfmside /Build/Intermediates/ArchiveIntermediates/RBBranch/IntermediateBuildFilesPath/CordovaLib.b uild/Release-iphoneos/CordovaLib.build/Objects-normal/armv7/CDVCommandQueue.d --serialize-diagnostics /Users/phonegap/Library/Developer/Xcode/DerivedData/RBBranch-eoelrkktfohkitdezostyrfmside /Build/Intermediates/ArchiveIntermediates/RBBranch/IntermediateBuildFilesPath/CordovaLib.b uild/Release-iphoneos/CordovaLib.build/Objects-normal/armv7/CDVCommandQueue.dia -c /tmp/gimlet/1645041/project/CordovaLib/Classes/Public/CDVCommandQueue.m -o /Users/phonegap/Library/Developer/Xcode/DerivedData/RBBranch-eoelrkktfohkitdezostyrfmside /Build/Intermediates/ArchiveIntermediates/RBBranch/IntermediateBuildFilesPath/CordovaLib.b uild/Release-iphoneos/CordovaLib.build/Objects-normal/armv7/CDVCommandQueue.o
      CompileC /Users/phonegap/Library/Developer/Xcode/DerivedData/RBBranch-eoelrkktfohkitdezostyrfmside /Build/Intermediates/ArchiveIntermediates/RBBranch/IntermediateBuildFilesPath/CordovaLib.b uild/Release-iphoneos/CordovaLib.build/Objects-normal/armv7/CDVPlugin+Resources.o Classes/Public/CDVPlugin+Resources.m normal armv7 objective-c com.apple.compilers.llvm.clang.1_0.compiler
        /Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/bin/cl ang -x objective-c -arch armv7 -fmessage-length=0 -fdiagnostics-show-note-include-stack -fmacro-backtrace-limit=0 -std=c99 -fobjc-arc -fmodules -fmodules-cache-path=/Users/phonegap/Library/Developer/Xcode/DerivedData/ModuleCache -fmodules-prune-interval=86400 -fmodules-prune-after=345600 -fbuild-session-file=/Users/phonegap/Library/Developer/Xcode/DerivedData/ModuleCache/Sess ion.modulevalidation -fmodules-validate-once-per-build-session -Wno-trigraphs -fpascal-strings -Os -Wno-missing-field-initializers -Wno-missing-prototypes -Wno-implicit-atomic-properties -Wno-arc-repeated-use-of-weak -Wduplicate-method-match -Wno-missing-braces -Wparentheses -Wswitch -Wunused-function -Wno-unused-label -Wno-unused-parameter -Wunused-variable -Wunused-value -Wempty-body -Wuninitialized -Wno-unknown-pragmas -Wno-shadow -Wno-four-char-constants -Wno-conversion -Wconstant-conversion -Wint-conversion -Wbool-conversion -Wenum-conversion -Wno-shorten-64-to-32 -Wpointer-sign -Wno-newline-eof -Wno-selector -Wno-strict-selector-match -Wundeclared-selector -Wno-deprecated-implementations -isysroot /Applications/Xcode.app/Contents/Developer/Platforms/iPhoneOS.platform/Developer/SDKs/iPh oneOS10.1.sdk -fstrict-aliasing -Wprotocol -Wdeprecated-declarations -miphoneos-version-min=8.0 -g -Wno-sign-conversion -Wno-infinite-recursion -iquote /Users/phonegap/Library/Developer/Xcode/DerivedData/RBBranch-eoelrkktfohkitdezostyrfmside /Build/Intermediates/ArchiveIntermediates/RBBranch/IntermediateBuildFilesPath/CordovaLib.b uild/Release-iphoneos/CordovaLib.build/Cordova-generated-files.hmap -I/Users/phonegap/Library/Developer/Xcode/DerivedData/RBBranch-eoelrkktfohkitdezostyrfmsi de/Build/Intermediates/ArchiveIntermediates/RBBranch/IntermediateBuildFilesPath/CordovaLib .build/Release-iphoneos/CordovaLib.build/Cordova-own-target-headers.hmap -I/Users/phonegap/Library/Developer/Xcode/DerivedData/RBBranch-eoelrkktfohkitdezostyrfmsi de/Build/Intermediates/ArchiveIntermediates/RBBranch/IntermediateBuildFilesPath/CordovaLib .build/Release-iphoneos/CordovaLib.build/Cordova-all-target-headers.hmap -iquote /Users/phonegap/Library/Developer/Xcode/DerivedData/RBBranch-eoelrkktfohkitdezostyrfmside /Build/Intermediates/ArchiveIntermediates/RBBranch/IntermediateBuildFilesPath/CordovaLib.b uild/Release-iphoneos/CordovaLib.build/Cordova-project-headers.hmap -I/tmp/gimlet/1645041/project/build/include -I/Users/phonegap/Library/Developer/Xcode/DerivedData/RBBranch-eoelrkktfohkitdezostyrfmsi de/Build/Intermediates/ArchiveIntermediates/RBBranch/IntermediateBuildFilesPath/Uninstalle dProducts/iphoneos/usr/local/lib/include -I/Users/phonegap/Library/Developer/Xcode/DerivedData/RBBranch-eoelrkktfohkitdezostyrfmsi de/Build/Intermediates/ArchiveIntermediates/RBBranch/IntermediateBuildFilesPath/Uninstalle dProducts/include -I/Users/phonegap/Library/Developer/Xcode/DerivedData/RBBranch-eoelrkktfohkitdezostyrfmsi de/Build/Intermediates/ArchiveIntermediates/RBBranch/IntermediateBuildFilesPath/Uninstalle dProducts/iphoneos/include -I/tmp/gimlet/1645041/project/build -I/Users/phonegap/Library/Developer/Xcode/DerivedData/RBBranch-eoelrkktfohkitdezostyrfmsi de/Build/Intermediates/ArchiveIntermediates/RBBranch/IntermediateBuildFilesPath/CordovaLib .build/Release-iphoneos/CordovaLib.build/DerivedSources/armv7 -I/Users/phonegap/Library/Developer/Xcode/DerivedData/RBBranch-eoelrkktfohkitdezostyrfmsi de/Build/Intermediates/ArchiveIntermediates/RBBranch/IntermediateBuildFilesPath/CordovaLib .build/Release-iphoneos/CordovaLib.build/DerivedSources -F/tmp/gimlet/1645041/project/build -include /private/tmp/gimlet/1645041/project/build/sharedpch/CordovaLib_Prefix-bknepzhfpvjnqgasjij tpxgnfeww/CordovaLib_Prefix.pch -MMD -MT dependencies -MF /Users/phonegap/Library/Developer/Xcode/DerivedData/RBBranch-eoelrkktfohkitdezostyrfmside /Build/Intermediates/ArchiveIntermediates/RBBranch/IntermediateBuildFilesPath/CordovaLib.b uild/Release-iphoneos/CordovaLib.build/Objects-normal/armv7/CDVPlugin+Resources.d --serialize-diagnostics /Users/phonegap/Library/Developer/Xcode/DerivedData/RBBranch-eoelrkktfohkitdezostyrfmside /Build/Intermediates/ArchiveIntermediates/RBBranch/IntermediateBuildFilesPath/CordovaLib.b uild/Release-iphoneos/CordovaLib.build/Objects-normal/armv7/CDVPlugin+Resources.dia -c /tmp/gimlet/1645041/project/CordovaLib/Classes/Public/CDVPlugin+Resources.m -o /Users/phonegap/Library/Developer/Xcode/DerivedData/RBBranch-eoelrkktfohkitdezostyrfmside /Build/Intermediates/ArchiveIntermediates/RBBranch/IntermediateBuildFilesPath/CordovaLib.b uild/Release-iphoneos/CordovaLib.build/Objects-normal/armv7/CDVPlugin+Resources.o
      CompileC /Users/phonegap/Library/Developer/Xcode/DerivedData/RBBranch-eoelrkktfohkitdezostyrfmside /Build/Intermediates/ArchiveIntermediates/RBBranch/IntermediateBuildFilesPath/CordovaLib.b uild/Release-iphoneos/CordovaLib.build/Objects-normal/armv7/CDVPluginResult.o Classes/Public/CDVPluginResult.m normal armv7 objective-c com.apple.compilers.llvm.clang.1_0.compiler
        /Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/bin/cl ang -x objective-c -arch armv7 -fmessage-length=0 -fdiagnostics-show-note-include-stack -fmacro-backtrace-limit=0 -std=c99 -fobjc-arc -fmodules -fmodules-cache-path=/Users/phonegap/Library/Developer/Xcode/DerivedData/ModuleCache -fmodules-prune-interval=86400 -fmodules-prune-after=345600 -fbuild-session-file=/Users/phonegap/Library/Developer/Xcode/DerivedData/ModuleCache/Sess ion.modulevalidation -fmodules-validate-once-per-build-session -Wno-trigraphs -fpascal-strings -Os -Wno-missing-field-initializers -Wno-missing-prototypes -Wno-implicit-atomic-properties -Wno-arc-repeated-use-of-weak -Wduplicate-method-match -Wno-missing-braces -Wparentheses -Wswitch -Wunused-function -Wno-unused-label -Wno-unused-parameter -Wunused-variable -Wunused-value -Wempty-body -Wuninitialized -Wno-unknown-pragmas -Wno-shadow -Wno-four-char-constants -Wno-conversion -Wconstant-conversion -Wint-conversion -Wbool-conversion -Wenum-conversion -Wno-shorten-64-to-32 -Wpointer-sign -Wno-newline-eof -Wno-selector -Wno-strict-selector-match -Wundeclared-selector -Wno-deprecated-implementations -isysroot /Applications/Xcode.app/Contents/Developer/Platforms/iPhoneOS.platform/Developer/SDKs/iPh oneOS10.1.sdk -fstrict-aliasing -Wprotocol -Wdeprecated-declarations -miphoneos-version-min=8.0 -g -Wno-sign-conversion -Wno-infinite-recursion -iquote /Users/phonegap/Library/Developer/Xcode/DerivedData/RBBranch-eoelrkktfohkitdezostyrfmside /Build/Intermediates/ArchiveIntermediates/RBBranch/IntermediateBuildFilesPath/CordovaLib.b uild/Release-iphoneos/CordovaLib.build/Cordova-generated-files.hmap -I/Users/phonegap/Library/Developer/Xcode/DerivedData/RBBranch-eoelrkktfohkitdezostyrfmsi de/Build/Intermediates/ArchiveIntermediates/RBBranch/IntermediateBuildFilesPath/CordovaLib .build/Release-iphoneos/CordovaLib.build/Cordova-own-target-headers.hmap -I/Users/phonegap/Library/Developer/Xcode/DerivedData/RBBranch-eoelrkktfohkitdezostyrfmsi de/Build/Intermediates/ArchiveIntermediates/RBBranch/IntermediateBuildFilesPath/CordovaLib .build/Release-iphoneos/CordovaLib.build/Cordova-all-target-headers.hmap -iquote /Users/phonegap/Library/Developer/Xcode/DerivedData/RBBranch-eoelrkktfohkitdezostyrfmside /Build/Intermediates/ArchiveIntermediates/RBBranch/IntermediateBuildFilesPath/CordovaLib.b uild/Release-iphoneos/CordovaLib.build/Cordova-project-headers.hmap -I/tmp/gimlet/1645041/project/build/include -I/Users/phonegap/Library/Developer/Xcode/DerivedData/RBBranch-eoelrkktfohkitdezostyrfmsi de/Build/Intermediates/ArchiveIntermediates/RBBranch/IntermediateBuildFilesPath/Uninstalle dProducts/iphoneos/usr/local/lib/include -I/Users/phonegap/Library/Developer/Xcode/DerivedData/RBBranch-eoelrkktfohkitdezostyrfmsi de/Build/Intermediates/ArchiveIntermediates/RBBranch/IntermediateBuildFilesPath/Uninstalle dProducts/include -I/Users/phonegap/Library/Developer/Xcode/DerivedData/RBBranch-eoelrkktfohkitdezostyrfmsi de/Build/Intermediates/ArchiveIntermediates/RBBranch/IntermediateBuildFilesPath/Uninstalle dProducts/iphoneos/include -I/tmp/gimlet/1645041/project/build -I/Users/phonegap/Library/Developer/Xcode/DerivedData/RBBranch-eoelrkktfohkitdezostyrfmsi de/Build/Intermediates/ArchiveIntermediates/RBBranch/IntermediateBuildFilesPath/CordovaLib .build/Release-iphoneos/CordovaLib.build/DerivedSources/armv7 -I/Users/phonegap/Library/Developer/Xcode/DerivedData/RBBranch-eoelrkktfohkitdezostyrfmsi de/Build/Intermediates/ArchiveIntermediates/RBBranch/IntermediateBuildFilesPath/CordovaLib .build/Release-iphoneos/CordovaLib.build/DerivedSources -F/tmp/gimlet/1645041/project/build -include /private/tmp/gimlet/1645041/project/build/sharedpch/CordovaLib_Prefix-bknepzhfpvjnqgasjij tpxgnfeww/CordovaLib_Prefix.pch -MMD -MT dependencies -MF /Users/phonegap/Library/Developer/Xcode/DerivedData/RBBranch-eoelrkktfohkitdezostyrfmside /Build/Intermediates/ArchiveIntermediates/RBBranch/IntermediateBuildFilesPath/CordovaLib.b uild/Release-iphoneos/CordovaLib.build/Objects-normal/armv7/CDVPluginResult.d --serialize-diagnostics /Users/phonegap/Library/Developer/Xcode/DerivedData/RBBranch-eoelrkktfohkitdezostyrfmside /Build/Intermediates/ArchiveIntermediates/RBBranch/IntermediateBuildFilesPath/CordovaLib.b uild/Release-iphoneos/CordovaLib.build/Objects-normal/armv7/CDVPluginResult.dia -c /tmp/gimlet/1645041/project/CordovaLib/Classes/Public/CDVPluginResult.m -o /Users/phonegap/Library/Developer/Xcode/DerivedData/RBBranch-eoelrkktfohkitdezostyrfmside /Build/Intermediates/ArchiveIntermediates/RBBranch/IntermediateBuildFilesPath/CordovaLib.b uild/Release-iphoneos/CordovaLib.build/Objects-normal/armv7/CDVPluginResult.o
      CompileC /Users/phonegap/Library/Developer/Xcode/DerivedData/RBBranch-eoelrkktfohkitdezostyrfmside /Build/Intermediates/ArchiveIntermediates/RBBranch/IntermediateBuildFilesPath/CordovaLib.b uild/Release-iphoneos/CordovaLib.build/Objects-normal/armv7/CDVURLProtocol.o Classes/Public/CDVURLProtocol.m normal armv7 objective-c com.apple.compilers.llvm.clang.1_0.compiler
        /Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/bin/cl ang -x objective-c -arch armv7 -fmessage-length=0 -fdiagnostics-show-note-include-stack -fmacro-backtrace-limit=0 -std=c99 -fobjc-arc -fmodules -fmodules-cache-path=/Users/phonegap/Library/Developer/Xcode/DerivedData/ModuleCache -fmodules-prune-interval=86400 -fmodules-prune-after=345600 -fbuild-session-file=/Users/phonegap/Library/Developer/Xcode/DerivedData/ModuleCache/Sess ion.modulevalidation -fmodules-validate-once-per-build-session -Wno-trigraphs -fpascal-strings -Os -Wno-missing-field-initializers -Wno-missing-prototypes -Wno-implicit-atomic-properties -Wno-arc-repeated-use-of-weak -Wduplicate-method-match -Wno-missing-braces -Wparentheses -Wswitch -Wunused-function -Wno-unused-label -Wno-unused-parameter -Wunused-variable -Wunused-value -Wempty-body -Wuninitialized -Wno-unknown-pragmas -Wno-shadow -Wno-four-char-constants -Wno-conversion -Wconstant-conversion -Wint-conversion -Wbool-conversion -Wenum-conversion -Wno-shorten-64-to-32 -Wpointer-sign -Wno-newline-eof -Wno-selector -Wno-strict-selector-match -Wundeclared-selector -Wno-deprecated-implementations -isysroot /Applications/Xcode.app/Contents/Developer/Platforms/iPhoneOS.platform/Developer/SDKs/iPh oneOS10.1.sdk -fstrict-aliasing -Wprotocol -Wdeprecated-declarations -miphoneos-version-min=8.0 -g -Wno-sign-conversion -Wno-infinite-recursion -iquote /Users/phonegap/Library/Developer/Xcode/DerivedData/RBBranch-eoelrkktfohkitdezostyrfmside /Build/Intermediates/ArchiveIntermediates/RBBranch/IntermediateBuildFilesPath/CordovaLib.b uild/Release-iphoneos/CordovaLib.build/Cordova-generated-files.hmap -I/Users/phonegap/Library/Developer/Xcode/DerivedData/RBBranch-eoelrkktfohkitdezostyrfmsi de/Build/Intermediates/ArchiveIntermediates/RBBranch/IntermediateBuildFilesPath/CordovaLib .build/Release-iphoneos/CordovaLib.build/Cordova-own-target-headers.hmap -I/Users/phonegap/Library/Developer/Xcode/DerivedData/RBBranch-eoelrkktfohkitdezostyrfmsi de/Build/Intermediates/ArchiveIntermediates/RBBranch/IntermediateBuildFilesPath/CordovaLib .build/Release-iphoneos/CordovaLib.build/Cordova-all-target-headers.hmap -iquote /Users/phonegap/Library/Developer/Xcode/DerivedData/RBBranch-eoelrkktfohkitdezostyrfmside /Build/Intermediates/ArchiveIntermediates/RBBranch/IntermediateBuildFilesPath/CordovaLib.b uild/Release-iphoneos/CordovaLib.build/Cordova-project-headers.hmap -I/tmp/gimlet/1645041/project/build/include -I/Users/phonegap/Library/Developer/Xcode/DerivedData/RBBranch-eoelrkktfohkitdezostyrfmsi de/Build/Intermediates/ArchiveIntermediates/RBBranch/IntermediateBuildFilesPath/Uninstalle dProducts/iphoneos/usr/local/lib/include -I/Users/phonegap/Library/Developer/Xcode/DerivedData/RBBranch-eoelrkktfohkitdezostyrfmsi de/Build/Intermediates/ArchiveIntermediates/RBBranch/IntermediateBuildFilesPath/Uninstalle dProducts/include -I/Users/phonegap/Library/Developer/Xcode/DerivedData/RBBranch-eoelrkktfohkitdezostyrfmsi de/Build/Intermediates/ArchiveIntermediates/RBBranch/IntermediateBuildFilesPath/Uninstalle dProducts/iphoneos/include -I/tmp/gimlet/1645041/project/build -I/Users/phonegap/Library/Developer/Xcode/DerivedData/RBBranch-eoelrkktfohkitdezostyrfmsi de/Build/Intermediates/ArchiveIntermediates/RBBranch/IntermediateBuildFilesPath/CordovaLib .build/Release-iphoneos/CordovaLib.build/DerivedSources/armv7 -I/Users/phonegap/Library/Developer/Xcode/DerivedData/RBBranch-eoelrkktfohkitdezostyrfmsi de/Build/Intermediates/ArchiveIntermediates/RBBranch/IntermediateBuildFilesPath/CordovaLib .build/Release-iphoneos/CordovaLib.build/DerivedSources -F/tmp/gimlet/1645041/project/build -include /private/tmp/gimlet/1645041/project/build/sharedpch/CordovaLib_Prefix-bknepzhfpvjnqgasjij tpxgnfeww/CordovaLib_Prefix.pch -MMD -MT dependencies -MF /Users/phonegap/Library/Developer/Xcode/DerivedData/RBBranch-eoelrkktfohkitdezostyrfmside /Build/Intermediates/ArchiveIntermediates/RBBranch/IntermediateBuildFilesPath/CordovaLib.b uild/Release-iphoneos/CordovaLib.build/Objects-normal/armv7/CDVURLProtocol.d --serialize-diagnostics /Users/phonegap/Library/Developer/Xcode/DerivedData/RBBranch-eoelrkktfohkitdezostyrfmside /Build/Intermediates/ArchiveIntermediates/RBBranch/IntermediateBuildFilesPath/CordovaLib.b uild/Release-iphoneos/CordovaLib.build/Objects-normal/armv7/CDVURLProtocol.dia -c /tmp/gimlet/1645041/project/CordovaLib/Classes/Public/CDVURLProtocol.m -o /Users/phonegap/Library/Developer/Xcode/DerivedData/RBBranch-eoelrkktfohkitdezostyrfmside /Build/Intermediates/ArchiveIntermediates/RBBranch/IntermediateBuildFilesPath/CordovaLib.b uild/Release-iphoneos/CordovaLib.build/Objects-normal/armv7/CDVURLProtocol.o
      CompileC /Users/phonegap/Library/Developer/Xcode/DerivedData/RBBranch-eoelrkktfohkitdezostyrfmside /Build/Intermediates/ArchiveIntermediates/RBBranch/IntermediateBuildFilesPath/CordovaLib.b uild/Release-iphoneos/CordovaLib.build/Objects-normal/armv7/CDVUIWebViewEngine.o Classes/Private/Plugins/CDVUIWebViewEngine/CDVUIWebViewEngine.m normal armv7 objective-c com.apple.compilers.llvm.clang.1_0.compiler
        cd /tmp/gimlet/1645041/project/CordovaLib
        /Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/bin/cl ang -x objective-c -arch armv7 -fmessage-length=0 -fdiagnostics-show-note-include-stack -fmacro-backtrace-limit=0 -std=c99 -fobjc-arc -fmodules -fmodules-cache-path=/Users/phonegap/Library/Developer/Xcode/DerivedData/ModuleCache -fmodules-prune-interval=86400 -fmodules-prune-after=345600 -fbuild-session-file=/Users/phonegap/Library/Developer/Xcode/DerivedData/ModuleCache/Sess ion.modulevalidation -fmodules-validate-once-per-build-session -Wno-trigraphs -fpascal-strings -Os -Wno-missing-field-initializers -Wno-missing-prototypes -Wno-implicit-atomic-properties -Wno-arc-repeated-use-of-weak -Wduplicate-method-match -Wno-missing-braces -Wparentheses -Wswitch -Wunused-function -Wno-unused-label -Wno-unused-parameter -Wunused-variable -Wunused-value -Wempty-body -Wuninitialized -Wno-unknown-pragmas -Wno-shadow -Wno-four-char-constants -Wno-conversion -Wconstant-conversion -Wint-conversion -Wbool-conversion -Wenum-conversion -Wno-shorten-64-to-32 -Wpointer-sign -Wno-newline-eof -Wno-selector -Wno-strict-selector-match -Wundeclared-selector -Wno-deprecated-implementations -isysroot /Applications/Xcode.app/Contents/Developer/Platforms/iPhoneOS.platform/Developer/SDKs/iPh oneOS10.1.sdk -fstrict-aliasing -Wprotocol -Wdeprecated-declarations -miphoneos-version-min=8.0 -g -Wno-sign-conversion -Wno-infinite-recursion -iquote /Users/phonegap/Library/Developer/Xcode/DerivedData/RBBranch-eoelrkktfohkitdezostyrfmside /Build/Intermediates/ArchiveIntermediates/RBBranch/IntermediateBuildFilesPath/CordovaLib.b uild/Release-iphoneos/CordovaLib.build/Cordova-generated-files.hmap -I/Users/phonegap/Library/Developer/Xcode/DerivedData/RBBranch-eoelrkktfohkitdezostyrfmsi de/Build/Intermediates/ArchiveIntermediates/RBBranch/IntermediateBuildFilesPath/CordovaLib .build/Release-iphoneos/CordovaLib.build/Cordova-own-target-headers.hmap -I/Users/phonegap/Library/Developer/Xcode/DerivedData/RBBranch-eoelrkktfohkitdezostyrfmsi de/Build/Intermediates/ArchiveIntermediates/RBBranch/IntermediateBuildFilesPath/CordovaLib .build/Release-iphoneos/CordovaLib.build/Cordova-all-target-headers.hmap -iquote /Users/phonegap/Library/Developer/Xcode/DerivedData/RBBranch-eoelrkktfohkitdezostyrfmside /Build/Intermediates/ArchiveIntermediates/RBBranch/IntermediateBuildFilesPath/CordovaLib.b uild/Release-iphoneos/CordovaLib.build/Cordova-project-headers.hmap -I/tmp/gimlet/1645041/project/build/include -I/Users/phonegap/Library/Developer/Xcode/DerivedData/RBBranch-eoelrkktfohkitdezostyrfmsi de/Build/Intermediates/ArchiveIntermediates/RBBranch/IntermediateBuildFilesPath/Uninstalle dProducts/iphoneos/usr/local/lib/include -I/Users/phonegap/Library/Developer/Xcode/DerivedData/RBBranch-eoelrkktfohkitdezostyrfmsi de/Build/Intermediates/ArchiveIntermediates/RBBranch/IntermediateBuildFilesPath/Uninstalle dProducts/include -I/Users/phonegap/Library/Developer/Xcode/DerivedData/RBBranch-eoelrkktfohkitdezostyrfmsi de/Build/Intermediates/ArchiveIntermediates/RBBranch/IntermediateBuildFilesPath/Uninstalle dProducts/iphoneos/include -I/tmp/gimlet/1645041/project/build -I/Users/phonegap/Library/Developer/Xcode/DerivedData/RBBranch-eoelrkktfohkitdezostyrfmsi de/Build/Intermediates/ArchiveIntermediates/RBBranch/IntermediateBuildFilesPath/CordovaLib .build/Release-iphoneos/CordovaLib.build/DerivedSources/armv7 -I/Users/phonegap/Library/Developer/Xcode/DerivedData/RBBranch-eoelrkktfohkitdezostyrfmsi de/Build/Intermediates/ArchiveIntermediates/RBBranch/IntermediateBuildFilesPath/CordovaLib .build/Release-iphoneos/CordovaLib.build/DerivedSources -F/tmp/gimlet/1645041/project/build -include /private/tmp/gimlet/1645041/project/build/sharedpch/CordovaLib_Prefix-bknepzhfpvjnqgasjij tpxgnfeww/CordovaLib_Prefix.pch -MMD -MT dependencies -MF /Users/phonegap/Library/Developer/Xcode/DerivedData/RBBranch-eoelrkktfohkitdezostyrfmside /Build/Intermediates/ArchiveIntermediates/RBBranch/IntermediateBuildFilesPath/CordovaLib.b uild/Release-iphoneos/CordovaLib.build/Objects-normal/armv7/CDVUIWebViewEngine.d --serialize-diagnostics /Users/phonegap/Library/Developer/Xcode/DerivedData/RBBranch-eoelrkktfohkitdezostyrfmside /Build/Intermediates/ArchiveIntermediates/RBBranch/IntermediateBuildFilesPath/CordovaLib.b uild/Release-iphoneos/CordovaLib.build/Objects-normal/armv7/CDVUIWebViewEngine.dia -c /tmp/gimlet/1645041/project/CordovaLib/Classes/Private/Plugins/CDVUIWebViewEngine/CDVUIWe bViewEngine.m -o /Users/phonegap/Library/Developer/Xcode/DerivedData/RBBranch-eoelrkktfohkitdezostyrfmside /Build/Intermediates/ArchiveIntermediates/RBBranch/IntermediateBuildFilesPath/CordovaLib.b uild/Release-iphoneos/CordovaLib.build/Objects-normal/armv7/CDVUIWebViewEngine.o
      CompileC /Users/phonegap/Library/Developer/Xcode/DerivedData/RBBranch-eoelrkktfohkitdezostyrfmside /Build/Intermediates/ArchiveIntermediates/RBBranch/IntermediateBuildFilesPath/CordovaLib.b uild/Release-iphoneos/CordovaLib.build/Objects-normal/armv7/CDVPlugin.o Classes/Public/CDVPlugin.m normal armv7 objective-c com.apple.compilers.llvm.clang.1_0.compiler
        /Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/bin/cl ang -x objective-c -arch armv7 -fmessage-length=0 -fdiagnostics-show-note-include-stack -fmacro-backtrace-limit=0 -std=c99 -fobjc-arc -fmodules -fmodules-cache-path=/Users/phonegap/Library/Developer/Xcode/DerivedData/ModuleCache -fmodules-prune-interval=86400 -fmodules-prune-after=345600 -fbuild-session-file=/Users/phonegap/Library/Developer/Xcode/DerivedData/ModuleCache/Sess ion.modulevalidation -fmodules-validate-once-per-build-session -Wno-trigraphs -fpascal-strings -Os -Wno-missing-field-initializers -Wno-missing-prototypes -Wno-implicit-atomic-properties -Wno-arc-repeated-use-of-weak -Wduplicate-method-match -Wno-missing-braces -Wparentheses -Wswitch -Wunused-function -Wno-unused-label -Wno-unused-parameter -Wunused-variable -Wunused-value -Wempty-body -Wuninitialized -Wno-unknown-pragmas -Wno-shadow -Wno-four-char-constants -Wno-conversion -Wconstant-conversion -Wint-conversion -Wbool-conversion -Wenum-conversion -Wno-shorten-64-to-32 -Wpointer-sign -Wno-newline-eof -Wno-selector -Wno-strict-selector-match -Wundeclared-selector -Wno-deprecated-implementations -isysroot /Applications/Xcode.app/Contents/Developer/Platforms/iPhoneOS.platform/Developer/SDKs/iPh oneOS10.1.sdk -fstrict-aliasing -Wprotocol -Wdeprecated-declarations -miphoneos-version-min=8.0 -g -Wno-sign-conversion -Wno-infinite-recursion -iquote /Users/phonegap/Library/Developer/Xcode/DerivedData/RBBranch-eoelrkktfohkitdezostyrfmside /Build/Intermediates/ArchiveIntermediates/RBBranch/IntermediateBuildFilesPath/CordovaLib.b uild/Release-iphoneos/CordovaLib.build/Cordova-generated-files.hmap -I/Users/phonegap/Library/Developer/Xcode/DerivedData/RBBranch-eoelrkktfohkitdezostyrfmsi de/Build/Intermediates/ArchiveIntermediates/RBBranch/IntermediateBuildFilesPath/CordovaLib .build/Release-iphoneos/CordovaLib.build/Cordova-own-target-headers.hmap -I/Users/phonegap/Library/Developer/Xcode/DerivedData/RBBranch-eoelrkktfohkitdezostyrfmsi de/Build/Intermediates/ArchiveIntermediates/RBBranch/IntermediateBuildFilesPath/CordovaLib .build/Release-iphoneos/CordovaLib.build/Cordova-all-target-headers.hmap -iquote /Users/phonegap/Library/Developer/Xcode/DerivedData/RBBranch-eoelrkktfohkitdezostyrfmside /Build/Intermediates/ArchiveIntermediates/RBBranch/IntermediateBuildFilesPath/CordovaLib.b uild/Release-iphoneos/CordovaLib.build/Cordova-project-headers.hmap -I/tmp/gimlet/1645041/project/build/include -I/Users/phonegap/Library/Developer/Xcode/DerivedData/RBBranch-eoelrkktfohkitdezostyrfmsi de/Build/Intermediates/ArchiveIntermediates/RBBranch/IntermediateBuildFilesPath/Uninstalle dProducts/iphoneos/usr/local/lib/include -I/Users/phonegap/Library/Developer/Xcode/DerivedData/RBBranch-eoelrkktfohkitdezostyrfmsi de/Build/Intermediates/ArchiveIntermediates/RBBranch/IntermediateBuildFilesPath/Uninstalle dProducts/include -I/Users/phonegap/Library/Developer/Xcode/DerivedData/RBBranch-eoelrkktfohkitdezostyrfmsi de/Build/Intermediates/ArchiveIntermediates/RBBranch/IntermediateBuildFilesPath/Uninstalle dProducts/iphoneos/include -I/tmp/gimlet/1645041/project/build -I/Users/phonegap/Library/Developer/Xcode/DerivedData/RBBranch-eoelrkktfohkitdezostyrfmsi de/Build/Intermediates/ArchiveIntermediates/RBBranch/IntermediateBuildFilesPath/CordovaLib .build/Release-iphoneos/CordovaLib.build/DerivedSources/armv7 -I/Users/phonegap/Library/Developer/Xcode/DerivedData/RBBranch-eoelrkktfohkitdezostyrfmsi de/Build/Intermediates/ArchiveIntermediates/RBBranch/IntermediateBuildFilesPath/CordovaLib .build/Release-iphoneos/CordovaLib.build/DerivedSources -F/tmp/gimlet/1645041/project/build -include /private/tmp/gimlet/1645041/project/build/sharedpch/CordovaLib_Prefix-bknepzhfpvjnqgasjij tpxgnfeww/CordovaLib_Prefix.pch -MMD -MT dependencies -MF /Users/phonegap/Library/Developer/Xcode/DerivedData/RBBranch-eoelrkktfohkitdezostyrfmside /Build/Intermediates/ArchiveIntermediates/RBBranch/IntermediateBuildFilesPath/CordovaLib.b uild/Release-iphoneos/CordovaLib.build/Objects-normal/armv7/CDVPlugin.d --serialize-diagnostics /Users/phonegap/Library/Developer/Xcode/DerivedData/RBBranch-eoelrkktfohkitdezostyrfmside /Build/Intermediates/ArchiveIntermediates/RBBranch/IntermediateBuildFilesPath/CordovaLib.b uild/Release-iphoneos/CordovaLib.build/Objects-normal/armv7/CDVPlugin.dia -c /tmp/gimlet/1645041/project/CordovaLib/Classes/Public/CDVPlugin.m -o /Users/phonegap/Library/Developer/Xcode/DerivedData/RBBranch-eoelrkktfohkitdezostyrfmside /Build/Intermediates/ArchiveIntermediates/RBBranch/IntermediateBuildFilesPath/CordovaLib.b uild/Release-iphoneos/CordovaLib.build/Objects-normal/armv7/CDVPlugin.o
      CompileC /Users/phonegap/Library/Developer/Xcode/DerivedData/RBBranch-eoelrkktfohkitdezostyrfmside /Build/Intermediates/ArchiveIntermediates/RBBranch/IntermediateBuildFilesPath/CordovaLib.b uild/Release-iphoneos/CordovaLib.build/Objects-normal/armv7/CDVLocalStorage.o Classes/Private/Plugins/CDVLocalStorage/CDVLocalStorage.m normal armv7 objective-c com.apple.compilers.llvm.clang.1_0.compiler
        /Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/bin/cl ang -x objective-c -arch armv7 -fmessage-length=0 -fdiagnostics-show-note-include-stack -fmacro-backtrace-limit=0 -std=c99 -fobjc-arc -fmodules -fmodules-cache-path=/Users/phonegap/Library/Developer/Xcode/DerivedData/ModuleCache -fmodules-prune-interval=86400 -fmodules-prune-after=345600 -fbuild-session-file=/Users/phonegap/Library/Developer/Xcode/DerivedData/ModuleCache/Sess ion.modulevalidation -fmodules-validate-once-per-build-session -Wno-trigraphs -fpascal-strings -Os -Wno-missing-field-initializers -Wno-missing-prototypes -Wno-implicit-atomic-properties -Wno-arc-repeated-use-of-weak -Wduplicate-method-match -Wno-missing-braces -Wparentheses -Wswitch -Wunused-function -Wno-unused-label -Wno-unused-parameter -Wunused-variable -Wunused-value -Wempty-body -Wuninitialized -Wno-unknown-pragmas -Wno-shadow -Wno-four-char-constants -Wno-conversion -Wconstant-conversion -Wint-conversion -Wbool-conversion -Wenum-conversion -Wno-shorten-64-to-32 -Wpointer-sign -Wno-newline-eof -Wno-selector -Wno-strict-selector-match -Wundeclared-selector -Wno-deprecated-implementations -isysroot /Applications/Xcode.app/Contents/Developer/Platforms/iPhoneOS.platform/Developer/SDKs/iPh oneOS10.1.sdk -fstrict-aliasing -Wprotocol -Wdeprecated-declarations -miphoneos-version-min=8.0 -g -Wno-sign-conversion -Wno-infinite-recursion -iquote /Users/phonegap/Library/Developer/Xcode/DerivedData/RBBranch-eoelrkktfohkitdezostyrfmside /Build/Intermediates/ArchiveIntermediates/RBBranch/IntermediateBuildFilesPath/CordovaLib.b uild/Release-iphoneos/CordovaLib.build/Cordova-generated-files.hmap -I/Users/phonegap/Library/Developer/Xcode/DerivedData/RBBranch-eoelrkktfohkitdezostyrfmsi de/Build/Intermediates/ArchiveIntermediates/RBBranch/IntermediateBuildFilesPath/CordovaLib .build/Release-iphoneos/CordovaLib.build/Cordova-own-target-headers.hmap -I/Users/phonegap/Library/Developer/Xcode/DerivedData/RBBranch-eoelrkktfohkitdezostyrfmsi de/Build/Intermediates/ArchiveIntermediates/RBBranch/IntermediateBuildFilesPath/CordovaLib .build/Release-iphoneos/CordovaLib.build/Cordova-all-target-headers.hmap -iquote /Users/phonegap/Library/Developer/Xcode/DerivedData/RBBranch-eoelrkktfohkitdezostyrfmside /Build/Intermediates/ArchiveIntermediates/RBBranch/IntermediateBuildFilesPath/CordovaLib.b uild/Release-iphoneos/CordovaLib.build/Cordova-project-headers.hmap -I/tmp/gimlet/1645041/project/build/include -I/Users/phonegap/Library/Developer/Xcode/DerivedData/RBBranch-eoelrkktfohkitdezostyrfmsi de/Build/Intermediates/ArchiveIntermediates/RBBranch/IntermediateBuildFilesPath/Uninstalle dProducts/iphoneos/usr/local/lib/include -I/Users/phonegap/Library/Developer/Xcode/DerivedData/RBBranch-eoelrkktfohkitdezostyrfmsi de/Build/Intermediates/ArchiveIntermediates/RBBranch/IntermediateBuildFilesPath/Uninstalle dProducts/include -I/Users/phonegap/Library/Developer/Xcode/DerivedData/RBBranch-eoelrkktfohkitdezostyrfmsi de/Build/Intermediates/ArchiveIntermediates/RBBranch/IntermediateBuildFilesPath/Uninstalle dProducts/iphoneos/include -I/tmp/gimlet/1645041/project/build -I/Users/phonegap/Library/Developer/Xcode/DerivedData/RBBranch-eoelrkktfohkitdezostyrfmsi de/Build/Intermediates/ArchiveIntermediates/RBBranch/IntermediateBuildFilesPath/CordovaLib .build/Release-iphoneos/CordovaLib.build/DerivedSources/armv7 -I/Users/phonegap/Library/Developer/Xcode/DerivedData/RBBranch-eoelrkktfohkitdezostyrfmsi de/Build/Intermediates/ArchiveIntermediates/RBBranch/IntermediateBuildFilesPath/CordovaLib .build/Release-iphoneos/CordovaLib.build/DerivedSources -F/tmp/gimlet/1645041/project/build -include /private/tmp/gimlet/1645041/project/build/sharedpch/CordovaLib_Prefix-bknepzhfpvjnqgasjij tpxgnfeww/CordovaLib_Prefix.pch -MMD -MT dependencies -MF /Users/phonegap/Library/Developer/Xcode/DerivedData/RBBranch-eoelrkktfohkitdezostyrfmside /Build/Intermediates/ArchiveIntermediates/RBBranch/IntermediateBuildFilesPath/CordovaLib.b uild/Release-iphoneos/CordovaLib.build/Objects-normal/armv7/CDVLocalStorage.d --serialize-diagnostics /Users/phonegap/Library/Developer/Xcode/DerivedData/RBBranch-eoelrkktfohkitdezostyrfmside /Build/Intermediates/ArchiveIntermediates/RBBranch/IntermediateBuildFilesPath/CordovaLib.b uild/Release-iphoneos/CordovaLib.build/Objects-normal/armv7/CDVLocalStorage.dia -c /tmp/gimlet/1645041/project/CordovaLib/Classes/Private/Plugins/CDVLocalStorage/CDVLocalSt orage.m -o /Users/phonegap/Library/Developer/Xcode/DerivedData/RBBranch-eoelrkktfohkitdezostyrfmside /Build/Intermediates/ArchiveIntermediates/RBBranch/IntermediateBuildFilesPath/CordovaLib.b uild/Release-iphoneos/CordovaLib.build/Objects-normal/armv7/CDVLocalStorage.o
      CompileC /Users/phonegap/Library/Developer/Xcode/DerivedData/RBBranch-eoelrkktfohkitdezostyrfmside /Build/Intermediates/ArchiveIntermediates/RBBranch/IntermediateBuildFilesPath/CordovaLib.b uild/Release-iphoneos/CordovaLib.build/Objects-normal/armv7/CDVIntentAndNavigationFilter.o Classes/Private/Plugins/CDVIntentAndNavigationFilter/CDVIntentAndNavigationFilter.m normal armv7 objective-c com.apple.compilers.llvm.clang.1_0.compiler
        /Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/bin/cl ang -x objective-c -arch armv7 -fmessage-length=0 -fdiagnostics-show-note-include-stack -fmacro-backtrace-limit=0 -std=c99 -fobjc-arc -fmodules -fmodules-cache-path=/Users/phonegap/Library/Developer/Xcode/DerivedData/ModuleCache -fmodules-prune-interval=86400 -fmodules-prune-after=345600 -fbuild-session-file=/Users/phonegap/Library/Developer/Xcode/DerivedData/ModuleCache/Sess ion.modulevalidation -fmodules-validate-once-per-build-session -Wno-trigraphs -fpascal-strings -Os -Wno-missing-field-initializers -Wno-missing-prototypes -Wno-implicit-atomic-properties -Wno-arc-repeated-use-of-weak -Wduplicate-method-match -Wno-missing-braces -Wparentheses -Wswitch -Wunused-function -Wno-unused-label -Wno-unused-parameter -Wunused-variable -Wunused-value -Wempty-body -Wuninitialized -Wno-unknown-pragmas -Wno-shadow -Wno-four-char-constants -Wno-conversion -Wconstant-conversion -Wint-conversion -Wbool-conversion -Wenum-conversion -Wno-shorten-64-to-32 -Wpointer-sign -Wno-newline-eof -Wno-selector -Wno-strict-selector-match -Wundeclared-selector -Wno-deprecated-implementations -isysroot /Applications/Xcode.app/Contents/Developer/Platforms/iPhoneOS.platform/Developer/SDKs/iPh oneOS10.1.sdk -fstrict-aliasing -Wprotocol -Wdeprecated-declarations -miphoneos-version-min=8.0 -g -Wno-sign-conversion -Wno-infinite-recursion -iquote /Users/phonegap/Library/Developer/Xcode/DerivedData/RBBranch-eoelrkktfohkitdezostyrfmside /Build/Intermediates/ArchiveIntermediates/RBBranch/IntermediateBuildFilesPath/CordovaLib.b uild/Release-iphoneos/CordovaLib.build/Cordova-generated-files.hmap -I/Users/phonegap/Library/Developer/Xcode/DerivedData/RBBranch-eoelrkktfohkitdezostyrfmsi de/Build/Intermediates/ArchiveIntermediates/RBBranch/IntermediateBuildFilesPath/CordovaLib .build/Release-iphoneos/CordovaLib.build/Cordova-own-target-headers.hmap -I/Users/phonegap/Library/Developer/Xcode/DerivedData/RBBranch-eoelrkktfohkitdezostyrfmsi de/Build/Intermediates/ArchiveIntermediates/RBBranch/IntermediateBuildFilesPath/CordovaLib .build/Release-iphoneos/CordovaLib.build/Cordova-all-target-headers.hmap -iquote /Users/phonegap/Library/Developer/Xcode/DerivedData/RBBranch-eoelrkktfohkitdezostyrfmside /Build/Intermediates/ArchiveIntermediates/RBBranch/IntermediateBuildFilesPath/CordovaLib.b uild/Release-iphoneos/CordovaLib.build/Cordova-project-headers.hmap -I/tmp/gimlet/1645041/project/build/include -I/Users/phonegap/Library/Developer/Xcode/DerivedData/RBBranch-eoelrkktfohkitdezostyrfmsi de/Build/Intermediates/ArchiveIntermediates/RBBranch/IntermediateBuildFilesPath/Uninstalle dProducts/iphoneos/usr/local/lib/include -I/Users/phonegap/Library/Developer/Xcode/DerivedData/RBBranch-eoelrkktfohkitdezostyrfmsi de/Build/Intermediates/ArchiveIntermediates/RBBranch/IntermediateBuildFilesPath/Uninstalle dProducts/include -I/Users/phonegap/Library/Developer/Xcode/DerivedData/RBBranch-eoelrkktfohkitdezostyrfmsi de/Build/Intermediates/ArchiveIntermediates/RBBranch/IntermediateBuildFilesPath/Uninstalle dProducts/iphoneos/include -I/tmp/gimlet/1645041/project/build -I/Users/phonegap/Library/Developer/Xcode/DerivedData/RBBranch-eoelrkktfohkitdezostyrfmsi de/Build/Intermediates/ArchiveIntermediates/RBBranch/IntermediateBuildFilesPath/CordovaLib .build/Release-iphoneos/CordovaLib.build/DerivedSources/armv7 -I/Users/phonegap/Library/Developer/Xcode/DerivedData/RBBranch-eoelrkktfohkitdezostyrfmsi de/Build/Intermediates/ArchiveIntermediates/RBBranch/IntermediateBuildFilesPath/CordovaLib .build/Release-iphoneos/CordovaLib.build/DerivedSources -F/tmp/gimlet/1645041/project/build -include /private/tmp/gimlet/1645041/project/build/sharedpch/CordovaLib_Prefix-bknepzhfpvjnqgasjij tpxgnfeww/CordovaLib_Prefix.pch -MMD -MT dependencies -MF /Users/phonegap/Library/Developer/Xcode/DerivedData/RBBranch-eoelrkktfohkitdezostyrfmside /Build/Intermediates/ArchiveIntermediates/RBBranch/IntermediateBuildFilesPath/CordovaLib.b uild/Release-iphoneos/CordovaLib.build/Objects-normal/armv7/CDVIntentAndNavigationFilter.d --serialize-diagnostics /Users/phonegap/Library/Developer/Xcode/DerivedData/RBBranch-eoelrkktfohkitdezostyrfmside /Build/Intermediates/ArchiveIntermediates/RBBranch/IntermediateBuildFilesPath/CordovaLib.b uild/Release-iphoneos/CordovaLib.build/Objects-normal/armv7/CDVIntentAndNavigationFilter.d ia -c /tmp/gimlet/1645041/project/CordovaLib/Classes/Private/Plugins/CDVIntentAndNavigationFilt er/CDVIntentAndNavigationFilter.m -o /Users/phonegap/Library/Developer/Xcode/DerivedData/RBBranch-eoelrkktfohkitdezostyrfmside /Build/Intermediates/ArchiveIntermediates/RBBranch/IntermediateBuildFilesPath/CordovaLib.b uild/Release-iphoneos/CordovaLib.build/Objects-normal/armv7/CDVIntentAndNavigationFilter.o
      CompileC /Users/phonegap/Library/Developer/Xcode/DerivedData/RBBranch-eoelrkktfohkitdezostyrfmside /Build/Intermediates/ArchiveIntermediates/RBBranch/IntermediateBuildFilesPath/CordovaLib.b uild/Release-iphoneos/CordovaLib.build/Objects-normal/arm64/CDVViewController.o Classes/Public/CDVViewController.m normal arm64 objective-c com.apple.compilers.llvm.clang.1_0.compiler
        export LANG=en_US.US-ASCII
        /Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/bin/cl ang -x objective-c -arch arm64 -fmessage-length=0 -fdiagnostics-show-note-include-stack -fmacro-backtrace-limit=0 -std=c99 -fobjc-arc -fmodules -fmodules-cache-path=/Users/phonegap/Library/Developer/Xcode/DerivedData/ModuleCache -fmodules-prune-interval=86400 -fmodules-prune-after=345600 -fbuild-session-file=/Users/phonegap/Library/Developer/Xcode/DerivedData/ModuleCache/Sess ion.modulevalidation -fmodules-validate-once-per-build-session -Wno-trigraphs -fpascal-strings -Os -Wno-missing-field-initializers -Wno-missing-prototypes -Wno-implicit-atomic-properties -Wno-arc-repeated-use-of-weak -Wduplicate-method-match -Wno-missing-braces -Wparentheses -Wswitch -Wunused-function -Wno-unused-label -Wno-unused-parameter -Wunused-variable -Wunused-value -Wempty-body -Wuninitialized -Wno-unknown-pragmas -Wno-shadow -Wno-four-char-constants -Wno-conversion -Wconstant-conversion -Wint-conversion -Wbool-conversion -Wenum-conversion -Wshorten-64-to-32 -Wpointer-sign -Wno-newline-eof -Wno-selector -Wno-strict-selector-match -Wundeclared-selector -Wno-deprecated-implementations -isysroot /Applications/Xcode.app/Contents/Developer/Platforms/iPhoneOS.platform/Developer/SDKs/iPh oneOS10.1.sdk -fstrict-aliasing -Wprotocol -Wdeprecated-declarations -miphoneos-version-min=8.0 -g -Wno-sign-conversion -Wno-infinite-recursion -iquote /Users/phonegap/Library/Developer/Xcode/DerivedData/RBBranch-eoelrkktfohkitdezostyrfmside /Build/Intermediates/ArchiveIntermediates/RBBranch/IntermediateBuildFilesPath/CordovaLib.b uild/Release-iphoneos/CordovaLib.build/Cordova-generated-files.hmap -I/Users/phonegap/Library/Developer/Xcode/DerivedData/RBBranch-eoelrkktfohkitdezostyrfmsi de/Build/Intermediates/ArchiveIntermediates/RBBranch/IntermediateBuildFilesPath/CordovaLib .build/Release-iphoneos/CordovaLib.build/Cordova-own-target-headers.hmap -I/Users/phonegap/Library/Developer/Xcode/DerivedData/RBBranch-eoelrkktfohkitdezostyrfmsi de/Build/Intermediates/ArchiveIntermediates/RBBranch/IntermediateBuildFilesPath/CordovaLib .build/Release-iphoneos/CordovaLib.build/Cordova-all-target-headers.hmap -iquote /Users/phonegap/Library/Developer/Xcode/DerivedData/RBBranch-eoelrkktfohkitdezostyrfmside /Build/Intermediates/ArchiveIntermediates/RBBranch/IntermediateBuildFilesPath/CordovaLib.b uild/Release-iphoneos/CordovaLib.build/Cordova-project-headers.hmap -I/tmp/gimlet/1645041/project/build/include -I/Users/phonegap/Library/Developer/Xcode/DerivedData/RBBranch-eoelrkktfohkitdezostyrfmsi de/Build/Intermediates/ArchiveIntermediates/RBBranch/IntermediateBuildFilesPath/Uninstalle dProducts/iphoneos/usr/local/lib/include -I/Users/phonegap/Library/Developer/Xcode/DerivedData/RBBranch-eoelrkktfohkitdezostyrfmsi de/Build/Intermediates/ArchiveIntermediates/RBBranch/IntermediateBuildFilesPath/Uninstalle dProducts/include -I/Users/phonegap/Library/Developer/Xcode/DerivedData/RBBranch-eoelrkktfohkitdezostyrfmsi de/Build/Intermediates/ArchiveIntermediates/RBBranch/IntermediateBuildFilesPath/Uninstalle dProducts/iphoneos/include -I/tmp/gimlet/1645041/project/build -I/Users/phonegap/Library/Developer/Xcode/DerivedData/RBBranch-eoelrkktfohkitdezostyrfmsi de/Build/Intermediates/ArchiveIntermediates/RBBranch/IntermediateBuildFilesPath/CordovaLib .build/Release-iphoneos/CordovaLib.build/DerivedSources/arm64 -I/Users/phonegap/Library/Developer/Xcode/DerivedData/RBBranch-eoelrkktfohkitdezostyrfmsi de/Build/Intermediates/ArchiveIntermediates/RBBranch/IntermediateBuildFilesPath/CordovaLib .build/Release-iphoneos/CordovaLib.build/DerivedSources -F/tmp/gimlet/1645041/project/build -include /private/tmp/gimlet/1645041/project/build/sharedpch/CordovaLib_Prefix-hagqdysfamtkhngolen foajtzops/CordovaLib_Prefix.pch -MMD -MT dependencies -MF /Users/phonegap/Library/Developer/Xcode/DerivedData/RBBranch-eoelrkktfohkitdezostyrfmside /Build/Intermediates/ArchiveIntermediates/RBBranch/IntermediateBuildFilesPath/CordovaLib.b uild/Release-iphoneos/CordovaLib.build/Objects-normal/arm64/CDVViewController.d --serialize-diagnostics /Users/phonegap/Library/Developer/Xcode/DerivedData/RBBranch-eoelrkktfohkitdezostyrfmside /Build/Intermediates/ArchiveIntermediates/RBBranch/IntermediateBuildFilesPath/CordovaLib.b uild/Release-iphoneos/CordovaLib.build/Objects-normal/arm64/CDVViewController.dia -c /tmp/gimlet/1645041/project/CordovaLib/Classes/Public/CDVViewController.m -o /Users/phonegap/Library/Developer/Xcode/DerivedData/RBBranch-eoelrkktfohkitdezostyrfmside /Build/Intermediates/ArchiveIntermediates/RBBranch/IntermediateBuildFilesPath/CordovaLib.b uild/Release-iphoneos/CordovaLib.build/Objects-normal/arm64/CDVViewController.o
      CompileC /Users/phonegap/Library/Developer/Xcode/DerivedData/RBBranch-eoelrkktfohkitdezostyrfmside /Build/Intermediates/ArchiveIntermediates/RBBranch/IntermediateBuildFilesPath/CordovaLib.b uild/Release-iphoneos/CordovaLib.build/Objects-normal/arm64/CDVUIWebViewDelegate.o Classes/Private/Plugins/CDVUIWebViewEngine/CDVUIWebViewDelegate.m normal arm64 objective-c com.apple.compilers.llvm.clang.1_0.compiler
        /Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/bin/cl ang -x objective-c -arch arm64 -fmessage-length=0 -fdiagnostics-show-note-include-stack -fmacro-backtrace-limit=0 -std=c99 -fobjc-arc -fmodules -fmodules-cache-path=/Users/phonegap/Library/Developer/Xcode/DerivedData/ModuleCache -fmodules-prune-interval=86400 -fmodules-prune-after=345600 -fbuild-session-file=/Users/phonegap/Library/Developer/Xcode/DerivedData/ModuleCache/Sess ion.modulevalidation -fmodules-validate-once-per-build-session -Wno-trigraphs -fpascal-strings -Os -Wno-missing-field-initializers -Wno-missing-prototypes -Wno-implicit-atomic-properties -Wno-arc-repeated-use-of-weak -Wduplicate-method-match -Wno-missing-braces -Wparentheses -Wswitch -Wunused-function -Wno-unused-label -Wno-unused-parameter -Wunused-variable -Wunused-value -Wempty-body -Wuninitialized -Wno-unknown-pragmas -Wno-shadow -Wno-four-char-constants -Wno-conversion -Wconstant-conversion -Wint-conversion -Wbool-conversion -Wenum-conversion -Wshorten-64-to-32 -Wpointer-sign -Wno-newline-eof -Wno-selector -Wno-strict-selector-match -Wundeclared-selector -Wno-deprecated-implementations -isysroot /Applications/Xcode.app/Contents/Developer/Platforms/iPhoneOS.platform/Developer/SDKs/iPh oneOS10.1.sdk -fstrict-aliasing -Wprotocol -Wdeprecated-declarations -miphoneos-version-min=8.0 -g -Wno-sign-conversion -Wno-infinite-recursion -iquote /Users/phonegap/Library/Developer/Xcode/DerivedData/RBBranch-eoelrkktfohkitdezostyrfmside /Build/Intermediates/ArchiveIntermediates/RBBranch/IntermediateBuildFilesPath/CordovaLib.b uild/Release-iphoneos/CordovaLib.build/Cordova-generated-files.hmap -I/Users/phonegap/Library/Developer/Xcode/DerivedData/RBBranch-eoelrkktfohkitdezostyrfmsi de/Build/Intermediates/ArchiveIntermediates/RBBranch/IntermediateBuildFilesPath/CordovaLib .build/Release-iphoneos/CordovaLib.build/Cordova-own-target-headers.hmap -I/Users/phonegap/Library/Developer/Xcode/DerivedData/RBBranch-eoelrkktfohkitdezostyrfmsi de/Build/Intermediates/ArchiveIntermediates/RBBranch/IntermediateBuildFilesPath/CordovaLib .build/Release-iphoneos/CordovaLib.build/Cordova-all-target-headers.hmap -iquote /Users/phonegap/Library/Developer/Xcode/DerivedData/RBBranch-eoelrkktfohkitdezostyrfmside /Build/Intermediates/ArchiveIntermediates/RBBranch/IntermediateBuildFilesPath/CordovaLib.b uild/Release-iphoneos/CordovaLib.build/Cordova-project-headers.hmap -I/tmp/gimlet/1645041/project/build/include -I/Users/phonegap/Library/Developer/Xcode/DerivedData/RBBranch-eoelrkktfohkitdezostyrfmsi de/Build/Intermediates/ArchiveIntermediates/RBBranch/IntermediateBuildFilesPath/Uninstalle dProducts/iphoneos/usr/local/lib/include -I/Users/phonegap/Library/Developer/Xcode/DerivedData/RBBranch-eoelrkktfohkitdezostyrfmsi de/Build/Intermediates/ArchiveIntermediates/RBBranch/IntermediateBuildFilesPath/Uninstalle dProducts/include -I/Users/phonegap/Library/Developer/Xcode/DerivedData/RBBranch-eoelrkktfohkitdezostyrfmsi de/Build/Intermediates/ArchiveIntermediates/RBBranch/IntermediateBuildFilesPath/Uninstalle dProducts/iphoneos/include -I/tmp/gimlet/1645041/project/build -I/Users/phonegap/Library/Developer/Xcode/DerivedData/RBBranch-eoelrkktfohkitdezostyrfmsi de/Build/Intermediates/ArchiveIntermediates/RBBranch/IntermediateBuildFilesPath/CordovaLib .build/Release-iphoneos/CordovaLib.build/DerivedSources/arm64 -I/Users/phonegap/Library/Developer/Xcode/DerivedData/RBBranch-eoelrkktfohkitdezostyrfmsi de/Build/Intermediates/ArchiveIntermediates/RBBranch/IntermediateBuildFilesPath/CordovaLib .build/Release-iphoneos/CordovaLib.build/DerivedSources -F/tmp/gimlet/1645041/project/build -include /private/tmp/gimlet/1645041/project/build/sharedpch/CordovaLib_Prefix-hagqdysfamtkhngolen foajtzops/CordovaLib_Prefix.pch -MMD -MT dependencies -MF /Users/phonegap/Library/Developer/Xcode/DerivedData/RBBranch-eoelrkktfohkitdezostyrfmside /Build/Intermediates/ArchiveIntermediates/RBBranch/IntermediateBuildFilesPath/CordovaLib.b uild/Release-iphoneos/CordovaLib.build/Objects-normal/arm64/CDVUIWebViewDelegate.d --serialize-diagnostics /Users/phonegap/Library/Developer/Xcode/DerivedData/RBBranch-eoelrkktfohkitdezostyrfmside /Build/Intermediates/ArchiveIntermediates/RBBranch/IntermediateBuildFilesPath/CordovaLib.b uild/Release-iphoneos/CordovaLib.build/Objects-normal/arm64/CDVUIWebViewDelegate.dia -c /tmp/gimlet/1645041/project/CordovaLib/Classes/Private/Plugins/CDVUIWebViewEngine/CDVUIWe bViewDelegate.m -o /Users/phonegap/Library/Developer/Xcode/DerivedData/RBBranch-eoelrkktfohkitdezostyrfmside /Build/Intermediates/ArchiveIntermediates/RBBranch/IntermediateBuildFilesPath/CordovaLib.b uild/Release-iphoneos/CordovaLib.build/Objects-normal/arm64/CDVUIWebViewDelegate.o
      CompileC /Users/phonegap/Library/Developer/Xcode/DerivedData/RBBranch-eoelrkktfohkitdezostyrfmside /Build/Intermediates/ArchiveIntermediates/RBBranch/IntermediateBuildFilesPath/CordovaLib.b uild/Release-iphoneos/CordovaLib.build/Objects-normal/arm64/NSDictionary+CordovaPreference s.o Classes/Public/NSDictionary+CordovaPreferences.m normal arm64 objective-c com.apple.compilers.llvm.clang.1_0.compiler
        /Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/bin/cl ang -x objective-c -arch arm64 -fmessage-length=0 -fdiagnostics-show-note-include-stack -fmacro-backtrace-limit=0 -std=c99 -fobjc-arc -fmodules -fmodules-cache-path=/Users/phonegap/Library/Developer/Xcode/DerivedData/ModuleCache -fmodules-prune-interval=86400 -fmodules-prune-after=345600 -fbuild-session-file=/Users/phonegap/Library/Developer/Xcode/DerivedData/ModuleCache/Sess ion.modulevalidation -fmodules-validate-once-per-build-session -Wno-trigraphs -fpascal-strings -Os -Wno-missing-field-initializers -Wno-missing-prototypes -Wno-implicit-atomic-properties -Wno-arc-repeated-use-of-weak -Wduplicate-method-match -Wno-missing-braces -Wparentheses -Wswitch -Wunused-function -Wno-unused-label -Wno-unused-parameter -Wunused-variable -Wunused-value -Wempty-body -Wuninitialized -Wno-unknown-pragmas -Wno-shadow -Wno-four-char-constants -Wno-conversion -Wconstant-conversion -Wint-conversion -Wbool-conversion -Wenum-conversion -Wshorten-64-to-32 -Wpointer-sign -Wno-newline-eof -Wno-selector -Wno-strict-selector-match -Wundeclared-selector -Wno-deprecated-implementations -isysroot /Applications/Xcode.app/Contents/Developer/Platforms/iPhoneOS.platform/Developer/SDKs/iPh oneOS10.1.sdk -fstrict-aliasing -Wprotocol -Wdeprecated-declarations -miphoneos-version-min=8.0 -g -Wno-sign-conversion -Wno-infinite-recursion -iquote /Users/phonegap/Library/Developer/Xcode/DerivedData/RBBranch-eoelrkktfohkitdezostyrfmside /Build/Intermediates/ArchiveIntermediates/RBBranch/IntermediateBuildFilesPath/CordovaLib.b uild/Release-iphoneos/CordovaLib.build/Cordova-generated-files.hmap -I/Users/phonegap/Library/Developer/Xcode/DerivedData/RBBranch-eoelrkktfohkitdezostyrfmsi de/Build/Intermediates/ArchiveIntermediates/RBBranch/IntermediateBuildFilesPath/CordovaLib .build/Release-iphoneos/CordovaLib.build/Cordova-own-target-headers.hmap -I/Users/phonegap/Library/Developer/Xcode/DerivedData/RBBranch-eoelrkktfohkitdezostyrfmsi de/Build/Intermediates/ArchiveIntermediates/RBBranch/IntermediateBuildFilesPath/CordovaLib .build/Release-iphoneos/CordovaLib.build/Cordova-all-target-headers.hmap -iquote /Users/phonegap/Library/Developer/Xcode/DerivedData/RBBranch-eoelrkktfohkitdezostyrfmside /Build/Intermediates/ArchiveIntermediates/RBBranch/IntermediateBuildFilesPath/CordovaLib.b uild/Release-iphoneos/CordovaLib.build/Cordova-project-headers.hmap -I/tmp/gimlet/1645041/project/build/include -I/Users/phonegap/Library/Developer/Xcode/DerivedData/RBBranch-eoelrkktfohkitdezostyrfmsi de/Build/Intermediates/ArchiveIntermediates/RBBranch/IntermediateBuildFilesPath/Uninstalle dProducts/iphoneos/usr/local/lib/include -I/Users/phonegap/Library/Developer/Xcode/DerivedData/RBBranch-eoelrkktfohkitdezostyrfmsi de/Build/Intermediates/ArchiveIntermediates/RBBranch/IntermediateBuildFilesPath/Uninstalle dProducts/include -I/Users/phonegap/Library/Developer/Xcode/DerivedData/RBBranch-eoelrkktfohkitdezostyrfmsi de/Build/Intermediates/ArchiveIntermediates/RBBranch/IntermediateBuildFilesPath/Uninstalle dProducts/iphoneos/include -I/tmp/gimlet/1645041/project/build -I/Users/phonegap/Library/Developer/Xcode/DerivedData/RBBranch-eoelrkktfohkitdezostyrfmsi de/Build/Intermediates/ArchiveIntermediates/RBBranch/IntermediateBuildFilesPath/CordovaLib .build/Release-iphoneos/CordovaLib.build/DerivedSources/arm64 -I/Users/phonegap/Library/Developer/Xcode/DerivedData/RBBranch-eoelrkktfohkitdezostyrfmsi de/Build/Intermediates/ArchiveIntermediates/RBBranch/IntermediateBuildFilesPath/CordovaLib .build/Release-iphoneos/CordovaLib.build/DerivedSources -F/tmp/gimlet/1645041/project/build -include /private/tmp/gimlet/1645041/project/build/sharedpch/CordovaLib_Prefix-hagqdysfamtkhngolen foajtzops/CordovaLib_Prefix.pch -MMD -MT dependencies -MF /Users/phonegap/Library/Developer/Xcode/DerivedData/RBBranch-eoelrkktfohkitdezostyrfmside /Build/Intermediates/ArchiveIntermediates/RBBranch/IntermediateBuildFilesPath/CordovaLib.b uild/Release-iphoneos/CordovaLib.build/Objects-normal/arm64/NSDictionary+CordovaPreference s.d --serialize-diagnostics /Users/phonegap/Library/Developer/Xcode/DerivedData/RBBranch-eoelrkktfohkitdezostyrfmside /Build/Intermediates/ArchiveIntermediates/RBBranch/IntermediateBuildFilesPath/CordovaLib.b uild/Release-iphoneos/CordovaLib.build/Objects-normal/arm64/NSDictionary+CordovaPreference s.dia -c /tmp/gimlet/1645041/project/CordovaLib/Classes/Public/NSDictionary+CordovaPreferences.m -o /Users/phonegap/Library/Developer/Xcode/DerivedData/RBBranch-eoelrkktfohkitdezostyrfmside /Build/Intermediates/ArchiveIntermediates/RBBranch/IntermediateBuildFilesPath/CordovaLib.b uild/Release-iphoneos/CordovaLib.build/Objects-normal/arm64/NSDictionary+CordovaPreference s.o
      CompileC /Users/phonegap/Library/Developer/Xcode/DerivedData/RBBranch-eoelrkktfohkitdezostyrfmside /Build/Intermediates/ArchiveIntermediates/RBBranch/IntermediateBuildFilesPath/CordovaLib.b uild/Release-iphoneos/CordovaLib.build/Objects-normal/arm64/CDVAppDelegate.o Classes/Public/CDVAppDelegate.m normal arm64 objective-c com.apple.compilers.llvm.clang.1_0.compiler
        /Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/bin/cl ang -x objective-c -arch arm64 -fmessage-length=0 -fdiagnostics-show-note-include-stack -fmacro-backtrace-limit=0 -std=c99 -fobjc-arc -fmodules -fmodules-cache-path=/Users/phonegap/Library/Developer/Xcode/DerivedData/ModuleCache -fmodules-prune-interval=86400 -fmodules-prune-after=345600 -fbuild-session-file=/Users/phonegap/Library/Developer/Xcode/DerivedData/ModuleCache/Sess ion.modulevalidation -fmodules-validate-once-per-build-session -Wno-trigraphs -fpascal-strings -Os -Wno-missing-field-initializers -Wno-missing-prototypes -Wno-implicit-atomic-properties -Wno-arc-repeated-use-of-weak -Wduplicate-method-match -Wno-missing-braces -Wparentheses -Wswitch -Wunused-function -Wno-unused-label -Wno-unused-parameter -Wunused-variable -Wunused-value -Wempty-body -Wuninitialized -Wno-unknown-pragmas -Wno-shadow -Wno-four-char-constants -Wno-conversion -Wconstant-conversion -Wint-conversion -Wbool-conversion -Wenum-conversion -Wshorten-64-to-32 -Wpointer-sign -Wno-newline-eof -Wno-selector -Wno-strict-selector-match -Wundeclared-selector -Wno-deprecated-implementations -isysroot /Applications/Xcode.app/Contents/Developer/Platforms/iPhoneOS.platform/Developer/SDKs/iPh oneOS10.1.sdk -fstrict-aliasing -Wprotocol -Wdeprecated-declarations -miphoneos-version-min=8.0 -g -Wno-sign-conversion -Wno-infinite-recursion -iquote /Users/phonegap/Library/Developer/Xcode/DerivedData/RBBranch-eoelrkktfohkitdezostyrfmside /Build/Intermediates/ArchiveIntermediates/RBBranch/IntermediateBuildFilesPath/CordovaLib.b uild/Release-iphoneos/CordovaLib.build/Cordova-generated-files.hmap -I/Users/phonegap/Library/Developer/Xcode/DerivedData/RBBranch-eoelrkktfohkitdezostyrfmsi de/Build/Intermediates/ArchiveIntermediates/RBBranch/IntermediateBuildFilesPath/CordovaLib .build/Release-iphoneos/CordovaLib.build/Cordova-own-target-headers.hmap -I/Users/phonegap/Library/Developer/Xcode/DerivedData/RBBranch-eoelrkktfohkitdezostyrfmsi de/Build/Intermediates/ArchiveIntermediates/RBBranch/IntermediateBuildFilesPath/CordovaLib .build/Release-iphoneos/CordovaLib.build/Cordova-all-target-headers.hmap -iquote /Users/phonegap/Library/Developer/Xcode/DerivedData/RBBranch-eoelrkktfohkitdezostyrfmside /Build/Intermediates/ArchiveIntermediates/RBBranch/IntermediateBuildFilesPath/CordovaLib.b uild/Release-iphoneos/CordovaLib.build/Cordova-project-headers.hmap -I/tmp/gimlet/1645041/project/build/include -I/Users/phonegap/Library/Developer/Xcode/DerivedData/RBBranch-eoelrkktfohkitdezostyrfmsi de/Build/Intermediates/ArchiveIntermediates/RBBranch/IntermediateBuildFilesPath/Uninstalle dProducts/iphoneos/usr/local/lib/include -I/Users/phonegap/Library/Developer/Xcode/DerivedData/RBBranch-eoelrkktfohkitdezostyrfmsi de/Build/Intermediates/ArchiveIntermediates/RBBranch/IntermediateBuildFilesPath/Uninstalle dProducts/include -I/Users/phonegap/Library/Developer/Xcode/DerivedData/RBBranch-eoelrkktfohkitdezostyrfmsi de/Build/Intermediates/ArchiveIntermediates/RBBranch/IntermediateBuildFilesPath/Uninstalle dProducts/iphoneos/include -I/tmp/gimlet/1645041/project/build -I/Users/phonegap/Library/Developer/Xcode/DerivedData/RBBranch-eoelrkktfohkitdezostyrfmsi de/Build/Intermediates/ArchiveIntermediates/RBBranch/IntermediateBuildFilesPath/CordovaLib .build/Release-iphoneos/CordovaLib.build/DerivedSources/arm64 -I/Users/phonegap/Library/Developer/Xcode/DerivedData/RBBranch-eoelrkktfohkitdezostyrfmsi de/Build/Intermediates/ArchiveIntermediates/RBBranch/IntermediateBuildFilesPath/CordovaLib .build/Release-iphoneos/CordovaLib.build/DerivedSources -F/tmp/gimlet/1645041/project/build -include /private/tmp/gimlet/1645041/project/build/sharedpch/CordovaLib_Prefix-hagqdysfamtkhngolen foajtzops/CordovaLib_Prefix.pch -MMD -MT dependencies -MF /Users/phonegap/Library/Developer/Xcode/DerivedData/RBBranch-eoelrkktfohkitdezostyrfmside /Build/Intermediates/ArchiveIntermediates/RBBranch/IntermediateBuildFilesPath/CordovaLib.b uild/Release-iphoneos/CordovaLib.build/Objects-normal/arm64/CDVAppDelegate.d --serialize-diagnostics /Users/phonegap/Library/Developer/Xcode/DerivedData/RBBranch-eoelrkktfohkitdezostyrfmside /Build/Intermediates/ArchiveIntermediates/RBBranch/IntermediateBuildFilesPath/CordovaLib.b uild/Release-iphoneos/CordovaLib.build/Objects-normal/arm64/CDVAppDelegate.dia -c /tmp/gimlet/1645041/project/CordovaLib/Classes/Public/CDVAppDelegate.m -o /Users/phonegap/Library/Developer/Xcode/DerivedData/RBBranch-eoelrkktfohkitdezostyrfmside /Build/Intermediates/ArchiveIntermediates/RBBranch/IntermediateBuildFilesPath/CordovaLib.b uild/Release-iphoneos/CordovaLib.build/Objects-normal/arm64/CDVAppDelegate.o
      CompileC /Users/phonegap/Library/Developer/Xcode/DerivedData/RBBranch-eoelrkktfohkitdezostyrfmside /Build/Intermediates/ArchiveIntermediates/RBBranch/IntermediateBuildFilesPath/CordovaLib.b uild/Release-iphoneos/CordovaLib.build/Objects-normal/arm64/CDVCommandDelegateImpl.o Classes/Public/CDVCommandDelegateImpl.m normal arm64 objective-c com.apple.compilers.llvm.clang.1_0.compiler
        /Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/bin/cl ang -x objective-c -arch arm64 -fmessage-length=0 -fdiagnostics-show-note-include-stack -fmacro-backtrace-limit=0 -std=c99 -fobjc-arc -fmodules -fmodules-cache-path=/Users/phonegap/Library/Developer/Xcode/DerivedData/ModuleCache -fmodules-prune-interval=86400 -fmodules-prune-after=345600 -fbuild-session-file=/Users/phonegap/Library/Developer/Xcode/DerivedData/ModuleCache/Sess ion.modulevalidation -fmodules-validate-once-per-build-session -Wno-trigraphs -fpascal-strings -Os -Wno-missing-field-initializers -Wno-missing-prototypes -Wno-implicit-atomic-properties -Wno-arc-repeated-use-of-weak -Wduplicate-method-match -Wno-missing-braces -Wparentheses -Wswitch -Wunused-function -Wno-unused-label -Wno-unused-parameter -Wunused-variable -Wunused-value -Wempty-body -Wuninitialized -Wno-unknown-pragmas -Wno-shadow -Wno-four-char-constants -Wno-conversion -Wconstant-conversion -Wint-conversion -Wbool-conversion -Wenum-conversion -Wshorten-64-to-32 -Wpointer-sign -Wno-newline-eof -Wno-selector -Wno-strict-selector-match -Wundeclared-selector -Wno-deprecated-implementations -isysroot /Applications/Xcode.app/Contents/Developer/Platforms/iPhoneOS.platform/Developer/SDKs/iPh oneOS10.1.sdk -fstrict-aliasing -Wprotocol -Wdeprecated-declarations -miphoneos-version-min=8.0 -g -Wno-sign-conversion -Wno-infinite-recursion -iquote /Users/phonegap/Library/Developer/Xcode/DerivedData/RBBranch-eoelrkktfohkitdezostyrfmside /Build/Intermediates/ArchiveIntermediates/RBBranch/IntermediateBuildFilesPath/CordovaLib.b uild/Release-iphoneos/CordovaLib.build/Cordova-generated-files.hmap -I/Users/phonegap/Library/Developer/Xcode/DerivedData/RBBranch-eoelrkktfohkitdezostyrfmsi de/Build/Intermediates/ArchiveIntermediates/RBBranch/IntermediateBuildFilesPath/CordovaLib .build/Release-iphoneos/CordovaLib.build/Cordova-own-target-headers.hmap -I/Users/phonegap/Library/Developer/Xcode/DerivedData/RBBranch-eoelrkktfohkitdezostyrfmsi de/Build/Intermediates/ArchiveIntermediates/RBBranch/IntermediateBuildFilesPath/CordovaLib .build/Release-iphoneos/CordovaLib.build/Cordova-all-target-headers.hmap -iquote /Users/phonegap/Library/Developer/Xcode/DerivedData/RBBranch-eoelrkktfohkitdezostyrfmside /Build/Intermediates/ArchiveIntermediates/RBBranch/IntermediateBuildFilesPath/CordovaLib.b uild/Release-iphoneos/CordovaLib.build/Cordova-project-headers.hmap -I/tmp/gimlet/1645041/project/build/include -I/Users/phonegap/Library/Developer/Xcode/DerivedData/RBBranch-eoelrkktfohkitdezostyrfmsi de/Build/Intermediates/ArchiveIntermediates/RBBranch/IntermediateBuildFilesPath/Uninstalle dProducts/iphoneos/usr/local/lib/include -I/Users/phonegap/Library/Developer/Xcode/DerivedData/RBBranch-eoelrkktfohkitdezostyrfmsi de/Build/Intermediates/ArchiveIntermediates/RBBranch/IntermediateBuildFilesPath/Uninstalle dProducts/include -I/Users/phonegap/Library/Developer/Xcode/DerivedData/RBBranch-eoelrkktfohkitdezostyrfmsi de/Build/Intermediates/ArchiveIntermediates/RBBranch/IntermediateBuildFilesPath/Uninstalle dProducts/iphoneos/include -I/tmp/gimlet/1645041/project/build -I/Users/phonegap/Library/Developer/Xcode/DerivedData/RBBranch-eoelrkktfohkitdezostyrfmsi de/Build/Intermediates/ArchiveIntermediates/RBBranch/IntermediateBuildFilesPath/CordovaLib .build/Release-iphoneos/CordovaLib.build/DerivedSources/arm64 -I/Users/phonegap/Library/Developer/Xcode/DerivedData/RBBranch-eoelrkktfohkitdezostyrfmsi de/Build/Intermediates/ArchiveIntermediates/RBBranch/IntermediateBuildFilesPath/CordovaLib .build/Release-iphoneos/CordovaLib.build/DerivedSources -F/tmp/gimlet/1645041/project/build -include /private/tmp/gimlet/1645041/project/build/sharedpch/CordovaLib_Prefix-hagqdysfamtkhngolen foajtzops/CordovaLib_Prefix.pch -MMD -MT dependencies -MF /Users/phonegap/Library/Developer/Xcode/DerivedData/RBBranch-eoelrkktfohkitdezostyrfmside /Build/Intermediates/ArchiveIntermediates/RBBranch/IntermediateBuildFilesPath/CordovaLib.b uild/Release-iphoneos/CordovaLib.build/Objects-normal/arm64/CDVCommandDelegateImpl.d --serialize-diagnostics /Users/phonegap/Library/Developer/Xcode/DerivedData/RBBranch-eoelrkktfohkitdezostyrfmside /Build/Intermediates/ArchiveIntermediates/RBBranch/IntermediateBuildFilesPath/CordovaLib.b uild/Release-iphoneos/CordovaLib.build/Objects-normal/arm64/CDVCommandDelegateImpl.dia -c /tmp/gimlet/1645041/project/CordovaLib/Classes/Public/CDVCommandDelegateImpl.m -o /Users/phonegap/Library/Developer/Xcode/DerivedData/RBBranch-eoelrkktfohkitdezostyrfmside /Build/Intermediates/ArchiveIntermediates/RBBranch/IntermediateBuildFilesPath/CordovaLib.b uild/Release-iphoneos/CordovaLib.build/Objects-normal/arm64/CDVCommandDelegateImpl.o
      CompileC /Users/phonegap/Library/Developer/Xcode/DerivedData/RBBranch-eoelrkktfohkitdezostyrfmside /Build/Intermediates/ArchiveIntermediates/RBBranch/IntermediateBuildFilesPath/CordovaLib.b uild/Release-iphoneos/CordovaLib.build/Objects-normal/arm64/CDVJSON_private.o Classes/Private/CDVJSON_private.m normal arm64 objective-c com.apple.compilers.llvm.clang.1_0.compiler
        /Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/bin/cl ang -x objective-c -arch arm64 -fmessage-length=0 -fdiagnostics-show-note-include-stack -fmacro-backtrace-limit=0 -std=c99 -fobjc-arc -fmodules -fmodules-cache-path=/Users/phonegap/Library/Developer/Xcode/DerivedData/ModuleCache -fmodules-prune-interval=86400 -fmodules-prune-after=345600 -fbuild-session-file=/Users/phonegap/Library/Developer/Xcode/DerivedData/ModuleCache/Sess ion.modulevalidation -fmodules-validate-once-per-build-session -Wno-trigraphs -fpascal-strings -Os -Wno-missing-field-initializers -Wno-missing-prototypes -Wno-implicit-atomic-properties -Wno-arc-repeated-use-of-weak -Wduplicate-method-match -Wno-missing-braces -Wparentheses -Wswitch -Wunused-function -Wno-unused-label -Wno-unused-parameter -Wunused-variable -Wunused-value -Wempty-body -Wuninitialized -Wno-unknown-pragmas -Wno-shadow -Wno-four-char-constants -Wno-conversion -Wconstant-conversion -Wint-conversion -Wbool-conversion -Wenum-conversion -Wshorten-64-to-32 -Wpointer-sign -Wno-newline-eof -Wno-selector -Wno-strict-selector-match -Wundeclared-selector -Wno-deprecated-implementations -isysroot /Applications/Xcode.app/Contents/Developer/Platforms/iPhoneOS.platform/Developer/SDKs/iPh oneOS10.1.sdk -fstrict-aliasing -Wprotocol -Wdeprecated-declarations -miphoneos-version-min=8.0 -g -Wno-sign-conversion -Wno-infinite-recursion -iquote /Users/phonegap/Library/Developer/Xcode/DerivedData/RBBranch-eoelrkktfohkitdezostyrfmside /Build/Intermediates/ArchiveIntermediates/RBBranch/IntermediateBuildFilesPath/CordovaLib.b uild/Release-iphoneos/CordovaLib.build/Cordova-generated-files.hmap -I/Users/phonegap/Library/Developer/Xcode/DerivedData/RBBranch-eoelrkktfohkitdezostyrfmsi de/Build/Intermediates/ArchiveIntermediates/RBBranch/IntermediateBuildFilesPath/CordovaLib .build/Release-iphoneos/CordovaLib.build/Cordova-own-target-headers.hmap -I/Users/phonegap/Library/Developer/Xcode/DerivedData/RBBranch-eoelrkktfohkitdezostyrfmsi de/Build/Intermediates/ArchiveIntermediates/RBBranch/IntermediateBuildFilesPath/CordovaLib .build/Release-iphoneos/CordovaLib.build/Cordova-all-target-headers.hmap -iquote /Users/phonegap/Library/Developer/Xcode/DerivedData/RBBranch-eoelrkktfohkitdezostyrfmside /Build/Intermediates/ArchiveIntermediates/RBBranch/IntermediateBuildFilesPath/CordovaLib.b uild/Release-iphoneos/CordovaLib.build/Cordova-project-headers.hmap -I/tmp/gimlet/1645041/project/build/include -I/Users/phonegap/Library/Developer/Xcode/DerivedData/RBBranch-eoelrkktfohkitdezostyrfmsi de/Build/Intermediates/ArchiveIntermediates/RBBranch/IntermediateBuildFilesPath/Uninstalle dProducts/iphoneos/usr/local/lib/include -I/Users/phonegap/Library/Developer/Xcode/DerivedData/RBBranch-eoelrkktfohkitdezostyrfmsi de/Build/Intermediates/ArchiveIntermediates/RBBranch/IntermediateBuildFilesPath/Uninstalle dProducts/include -I/Users/phonegap/Library/Developer/Xcode/DerivedData/RBBranch-eoelrkktfohkitdezostyrfmsi de/Build/Intermediates/ArchiveIntermediates/RBBranch/IntermediateBuildFilesPath/Uninstalle dProducts/iphoneos/include -I/tmp/gimlet/1645041/project/build -I/Users/phonegap/Library/Developer/Xcode/DerivedData/RBBranch-eoelrkktfohkitdezostyrfmsi de/Build/Intermediates/ArchiveIntermediates/RBBranch/IntermediateBuildFilesPath/CordovaLib .build/Release-iphoneos/CordovaLib.build/DerivedSources/arm64 -I/Users/phonegap/Library/Developer/Xcode/DerivedData/RBBranch-eoelrkktfohkitdezostyrfmsi de/Build/Intermediates/ArchiveIntermediates/RBBranch/IntermediateBuildFilesPath/CordovaLib .build/Release-iphoneos/CordovaLib.build/DerivedSources -F/tmp/gimlet/1645041/project/build -include /private/tmp/gimlet/1645041/project/build/sharedpch/CordovaLib_Prefix-hagqdysfamtkhngolen foajtzops/CordovaLib_Prefix.pch -MMD -MT dependencies -MF /Users/phonegap/Library/Developer/Xcode/DerivedData/RBBranch-eoelrkktfohkitdezostyrfmside /Build/Intermediates/ArchiveIntermediates/RBBranch/IntermediateBuildFilesPath/CordovaLib.b uild/Release-iphoneos/CordovaLib.build/Objects-normal/arm64/CDVJSON_private.d --serialize-diagnostics /Users/phonegap/Library/Developer/Xcode/DerivedData/RBBranch-eoelrkktfohkitdezostyrfmside /Build/Intermediates/ArchiveIntermediates/RBBranch/IntermediateBuildFilesPath/CordovaLib.b uild/Release-iphoneos/CordovaLib.build/Objects-normal/arm64/CDVJSON_private.dia -c /tmp/gimlet/1645041/project/CordovaLib/Classes/Private/CDVJSON_private.m -o /Users/phonegap/Library/Developer/Xcode/DerivedData/RBBranch-eoelrkktfohkitdezostyrfmside /Build/Intermediates/ArchiveIntermediates/RBBranch/IntermediateBuildFilesPath/CordovaLib.b uild/Release-iphoneos/CordovaLib.build/Objects-normal/arm64/CDVJSON_private.o
      CompileC /Users/phonegap/Library/Developer/Xcode/DerivedData/RBBranch-eoelrkktfohkitdezostyrfmside /Build/Intermediates/ArchiveIntermediates/RBBranch/IntermediateBuildFilesPath/CordovaLib.b uild/Release-iphoneos/CordovaLib.build/Objects-normal/arm64/CDVWhitelist.o Classes/Public/CDVWhitelist.m normal arm64 objective-c com.apple.compilers.llvm.clang.1_0.compiler
        /Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/bin/cl ang -x objective-c -arch arm64 -fmessage-length=0 -fdiagnostics-show-note-include-stack -fmacro-backtrace-limit=0 -std=c99 -fobjc-arc -fmodules -fmodules-cache-path=/Users/phonegap/Library/Developer/Xcode/DerivedData/ModuleCache -fmodules-prune-interval=86400 -fmodules-prune-after=345600 -fbuild-session-file=/Users/phonegap/Library/Developer/Xcode/DerivedData/ModuleCache/Sess ion.modulevalidation -fmodules-validate-once-per-build-session -Wno-trigraphs -fpascal-strings -Os -Wno-missing-field-initializers -Wno-missing-prototypes -Wno-implicit-atomic-properties -Wno-arc-repeated-use-of-weak -Wduplicate-method-match -Wno-missing-braces -Wparentheses -Wswitch -Wunused-function -Wno-unused-label -Wno-unused-parameter -Wunused-variable -Wunused-value -Wempty-body -Wuninitialized -Wno-unknown-pragmas -Wno-shadow -Wno-four-char-constants -Wno-conversion -Wconstant-conversion -Wint-conversion -Wbool-conversion -Wenum-conversion -Wshorten-64-to-32 -Wpointer-sign -Wno-newline-eof -Wno-selector -Wno-strict-selector-match -Wundeclared-selector -Wno-deprecated-implementations -isysroot /Applications/Xcode.app/Contents/Developer/Platforms/iPhoneOS.platform/Developer/SDKs/iPh oneOS10.1.sdk -fstrict-aliasing -Wprotocol -Wdeprecated-declarations -miphoneos-version-min=8.0 -g -Wno-sign-conversion -Wno-infinite-recursion -iquote /Users/phonegap/Library/Developer/Xcode/DerivedData/RBBranch-eoelrkktfohkitdezostyrfmside /Build/Intermediates/ArchiveIntermediates/RBBranch/IntermediateBuildFilesPath/CordovaLib.b uild/Release-iphoneos/CordovaLib.build/Cordova-generated-files.hmap -I/Users/phonegap/Library/Developer/Xcode/DerivedData/RBBranch-eoelrkktfohkitdezostyrfmsi de/Build/Intermediates/ArchiveIntermediates/RBBranch/IntermediateBuildFilesPath/CordovaLib .build/Release-iphoneos/CordovaLib.build/Cordova-own-target-headers.hmap -I/Users/phonegap/Library/Developer/Xcode/DerivedData/RBBranch-eoelrkktfohkitdezostyrfmsi de/Build/Intermediates/ArchiveIntermediates/RBBranch/IntermediateBuildFilesPath/CordovaLib .build/Release-iphoneos/CordovaLib.build/Cordova-all-target-headers.hmap -iquote /Users/phonegap/Library/Developer/Xcode/DerivedData/RBBranch-eoelrkktfohkitdezostyrfmside /Build/Intermediates/ArchiveIntermediates/RBBranch/IntermediateBuildFilesPath/CordovaLib.b uild/Release-iphoneos/CordovaLib.build/Cordova-project-headers.hmap -I/tmp/gimlet/1645041/project/build/include -I/Users/phonegap/Library/Developer/Xcode/DerivedData/RBBranch-eoelrkktfohkitdezostyrfmsi de/Build/Intermediates/ArchiveIntermediates/RBBranch/IntermediateBuildFilesPath/Uninstalle dProducts/iphoneos/usr/local/lib/include -I/Users/phonegap/Library/Developer/Xcode/DerivedData/RBBranch-eoelrkktfohkitdezostyrfmsi de/Build/Intermediates/ArchiveIntermediates/RBBranch/IntermediateBuildFilesPath/Uninstalle dProducts/include -I/Users/phonegap/Library/Developer/Xcode/DerivedData/RBBranch-eoelrkktfohkitdezostyrfmsi de/Build/Intermediates/ArchiveIntermediates/RBBranch/IntermediateBuildFilesPath/Uninstalle dProducts/iphoneos/include -I/tmp/gimlet/1645041/project/build -I/Users/phonegap/Library/Developer/Xcode/DerivedData/RBBranch-eoelrkktfohkitdezostyrfmsi de/Build/Intermediates/ArchiveIntermediates/RBBranch/IntermediateBuildFilesPath/CordovaLib .build/Release-iphoneos/CordovaLib.build/DerivedSources/arm64 -I/Users/phonegap/Library/Developer/Xcode/DerivedData/RBBranch-eoelrkktfohkitdezostyrfmsi de/Build/Intermediates/ArchiveIntermediates/RBBranch/IntermediateBuildFilesPath/CordovaLib .build/Release-iphoneos/CordovaLib.build/DerivedSources -F/tmp/gimlet/1645041/project/build -include /private/tmp/gimlet/1645041/project/build/sharedpch/CordovaLib_Prefix-hagqdysfamtkhngolen foajtzops/CordovaLib_Prefix.pch -MMD -MT dependencies -MF /Users/phonegap/Library/Developer/Xcode/DerivedData/RBBranch-eoelrkktfohkitdezostyrfmside /Build/Intermediates/ArchiveIntermediates/RBBranch/IntermediateBuildFilesPath/CordovaLib.b uild/Release-iphoneos/CordovaLib.build/Objects-normal/arm64/CDVWhitelist.d --serialize-diagnostics /Users/phonegap/Library/Developer/Xcode/DerivedData/RBBranch-eoelrkktfohkitdezostyrfmside /Build/Intermediates/ArchiveIntermediates/RBBranch/IntermediateBuildFilesPath/CordovaLib.b uild/Release-iphoneos/CordovaLib.build/Objects-normal/arm64/CDVWhitelist.dia -c /tmp/gimlet/1645041/project/CordovaLib/Classes/Public/CDVWhitelist.m -o /Users/phonegap/Library/Developer/Xcode/DerivedData/RBBranch-eoelrkktfohkitdezostyrfmside /Build/Intermediates/ArchiveIntermediates/RBBranch/IntermediateBuildFilesPath/CordovaLib.b uild/Release-iphoneos/CordovaLib.build/Objects-normal/arm64/CDVWhitelist.o
      CompileC /Users/phonegap/Library/Developer/Xcode/DerivedData/RBBranch-eoelrkktfohkitdezostyrfmside /Build/Intermediates/ArchiveIntermediates/RBBranch/IntermediateBuildFilesPath/CordovaLib.b uild/Release-iphoneos/CordovaLib.build/Objects-normal/arm64/CDVInvokedUrlCommand.o Classes/Public/CDVInvokedUrlCommand.m normal arm64 objective-c com.apple.compilers.llvm.clang.1_0.compiler
        /Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/bin/cl ang -x objective-c -arch arm64 -fmessage-length=0 -fdiagnostics-show-note-include-stack -fmacro-backtrace-limit=0 -std=c99 -fobjc-arc -fmodules -fmodules-cache-path=/Users/phonegap/Library/Developer/Xcode/DerivedData/ModuleCache -fmodules-prune-interval=86400 -fmodules-prune-after=345600 -fbuild-session-file=/Users/phonegap/Library/Developer/Xcode/DerivedData/ModuleCache/Sess ion.modulevalidation -fmodules-validate-once-per-build-session -Wno-trigraphs -fpascal-strings -Os -Wno-missing-field-initializers -Wno-missing-prototypes -Wno-implicit-atomic-properties -Wno-arc-repeated-use-of-weak -Wduplicate-method-match -Wno-missing-braces -Wparentheses -Wswitch -Wunused-function -Wno-unused-label -Wno-unused-parameter -Wunused-variable -Wunused-value -Wempty-body -Wuninitialized -Wno-unknown-pragmas -Wno-shadow -Wno-four-char-constants -Wno-conversion -Wconstant-conversion -Wint-conversion -Wbool-conversion -Wenum-conversion -Wshorten-64-to-32 -Wpointer-sign -Wno-newline-eof -Wno-selector -Wno-strict-selector-match -Wundeclared-selector -Wno-deprecated-implementations -isysroot /Applications/Xcode.app/Contents/Developer/Platforms/iPhoneOS.platform/Developer/SDKs/iPh oneOS10.1.sdk -fstrict-aliasing -Wprotocol -Wdeprecated-declarations -miphoneos-version-min=8.0 -g -Wno-sign-conversion -Wno-infinite-recursion -iquote /Users/phonegap/Library/Developer/Xcode/DerivedData/RBBranch-eoelrkktfohkitdezostyrfmside /Build/Intermediates/ArchiveIntermediates/RBBranch/IntermediateBuildFilesPath/CordovaLib.b uild/Release-iphoneos/CordovaLib.build/Cordova-generated-files.hmap -I/Users/phonegap/Library/Developer/Xcode/DerivedData/RBBranch-eoelrkktfohkitdezostyrfmsi de/Build/Intermediates/ArchiveIntermediates/RBBranch/IntermediateBuildFilesPath/CordovaLib .build/Release-iphoneos/CordovaLib.build/Cordova-own-target-headers.hmap -I/Users/phonegap/Library/Developer/Xcode/DerivedData/RBBranch-eoelrkktfohkitdezostyrfmsi de/Build/Intermediates/ArchiveIntermediates/RBBranch/IntermediateBuildFilesPath/CordovaLib .build/Release-iphoneos/CordovaLib.build/Cordova-all-target-headers.hmap -iquote /Users/phonegap/Library/Developer/Xcode/DerivedData/RBBranch-eoelrkktfohkitdezostyrfmside /Build/Intermediates/ArchiveIntermediates/RBBranch/IntermediateBuildFilesPath/CordovaLib.b uild/Release-iphoneos/CordovaLib.build/Cordova-project-headers.hmap -I/tmp/gimlet/1645041/project/build/include -I/Users/phonegap/Library/Developer/Xcode/DerivedData/RBBranch-eoelrkktfohkitdezostyrfmsi de/Build/Intermediates/ArchiveIntermediates/RBBranch/IntermediateBuildFilesPath/Uninstalle dProducts/iphoneos/usr/local/lib/include -I/Users/phonegap/Library/Developer/Xcode/DerivedData/RBBranch-eoelrkktfohkitdezostyrfmsi de/Build/Intermediates/ArchiveIntermediates/RBBranch/IntermediateBuildFilesPath/Uninstalle dProducts/include -I/Users/phonegap/Library/Developer/Xcode/DerivedData/RBBranch-eoelrkktfohkitdezostyrfmsi de/Build/Intermediates/ArchiveIntermediates/RBBranch/IntermediateBuildFilesPath/Uninstalle dProducts/iphoneos/include -I/tmp/gimlet/1645041/project/build -I/Users/phonegap/Library/Developer/Xcode/DerivedData/RBBranch-eoelrkktfohkitdezostyrfmsi de/Build/Intermediates/ArchiveIntermediates/RBBranch/IntermediateBuildFilesPath/CordovaLib .build/Release-iphoneos/CordovaLib.build/DerivedSources/arm64 -I/Users/phonegap/Library/Developer/Xcode/DerivedData/RBBranch-eoelrkktfohkitdezostyrfmsi de/Build/Intermediates/ArchiveIntermediates/RBBranch/IntermediateBuildFilesPath/CordovaLib .build/Release-iphoneos/CordovaLib.build/DerivedSources -F/tmp/gimlet/1645041/project/build -include /private/tmp/gimlet/1645041/project/build/sharedpch/CordovaLib_Prefix-hagqdysfamtkhngolen foajtzops/CordovaLib_Prefix.pch -MMD -MT dependencies -MF /Users/phonegap/Library/Developer/Xcode/DerivedData/RBBranch-eoelrkktfohkitdezostyrfmside /Build/Intermediates/ArchiveIntermediates/RBBranch/IntermediateBuildFilesPath/CordovaLib.b uild/Release-iphoneos/CordovaLib.build/Objects-normal/arm64/CDVInvokedUrlCommand.d --serialize-diagnostics /Users/phonegap/Library/Developer/Xcode/DerivedData/RBBranch-eoelrkktfohkitdezostyrfmside /Build/Intermediates/ArchiveIntermediates/RBBranch/IntermediateBuildFilesPath/CordovaLib.b uild/Release-iphoneos/CordovaLib.build/Objects-normal/arm64/CDVInvokedUrlCommand.dia -c /tmp/gimlet/1645041/project/CordovaLib/Classes/Public/CDVInvokedUrlCommand.m -o /Users/phonegap/Library/Developer/Xcode/DerivedData/RBBranch-eoelrkktfohkitdezostyrfmside /Build/Intermediates/ArchiveIntermediates/RBBranch/IntermediateBuildFilesPath/CordovaLib.b uild/Release-iphoneos/CordovaLib.build/Objects-normal/arm64/CDVInvokedUrlCommand.o
      CompileC /Users/phonegap/Library/Developer/Xcode/DerivedData/RBBranch-eoelrkktfohkitdezostyrfmside /Build/Intermediates/ArchiveIntermediates/RBBranch/IntermediateBuildFilesPath/CordovaLib.b uild/Release-iphoneos/CordovaLib.build/Objects-normal/arm64/CDVTimer.o Classes/Public/CDVTimer.m normal arm64 objective-c com.apple.compilers.llvm.clang.1_0.compiler
        cd /tmp/gimlet/1645041/project/CordovaLib
        /Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/bin/cl ang -x objective-c -arch arm64 -fmessage-length=0 -fdiagnostics-show-note-include-stack -fmacro-backtrace-limit=0 -std=c99 -fobjc-arc -fmodules -fmodules-cache-path=/Users/phonegap/Library/Developer/Xcode/DerivedData/ModuleCache -fmodules-prune-interval=86400 -fmodules-prune-after=345600 -fbuild-session-file=/Users/phonegap/Library/Developer/Xcode/DerivedData/ModuleCache/Sess ion.modulevalidation -fmodules-validate-once-per-build-session -Wno-trigraphs -fpascal-strings -Os -Wno-missing-field-initializers -Wno-missing-prototypes -Wno-implicit-atomic-properties -Wno-arc-repeated-use-of-weak -Wduplicate-method-match -Wno-missing-braces -Wparentheses -Wswitch -Wunused-function -Wno-unused-label -Wno-unused-parameter -Wunused-variable -Wunused-value -Wempty-body -Wuninitialized -Wno-unknown-pragmas -Wno-shadow -Wno-four-char-constants -Wno-conversion -Wconstant-conversion -Wint-conversion -Wbool-conversion -Wenum-conversion -Wshorten-64-to-32 -Wpointer-sign -Wno-newline-eof -Wno-selector -Wno-strict-selector-match -Wundeclared-selector -Wno-deprecated-implementations -isysroot /Applications/Xcode.app/Contents/Developer/Platforms/iPhoneOS.platform/Developer/SDKs/iPh oneOS10.1.sdk -fstrict-aliasing -Wprotocol -Wdeprecated-declarations -miphoneos-version-min=8.0 -g -Wno-sign-conversion -Wno-infinite-recursion -iquote /Users/phonegap/Library/Developer/Xcode/DerivedData/RBBranch-eoelrkktfohkitdezostyrfmside /Build/Intermediates/ArchiveIntermediates/RBBranch/IntermediateBuildFilesPath/CordovaLib.b uild/Release-iphoneos/CordovaLib.build/Cordova-generated-files.hmap -I/Users/phonegap/Library/Developer/Xcode/DerivedData/RBBranch-eoelrkktfohkitdezostyrfmsi de/Build/Intermediates/ArchiveIntermediates/RBBranch/IntermediateBuildFilesPath/CordovaLib .build/Release-iphoneos/CordovaLib.build/Cordova-own-target-headers.hmap -I/Users/phonegap/Library/Developer/Xcode/DerivedData/RBBranch-eoelrkktfohkitdezostyrfmsi de/Build/Intermediates/ArchiveIntermediates/RBBranch/IntermediateBuildFilesPath/CordovaLib .build/Release-iphoneos/CordovaLib.build/Cordova-all-target-headers.hmap -iquote /Users/phonegap/Library/Developer/Xcode/DerivedData/RBBranch-eoelrkktfohkitdezostyrfmside /Build/Intermediates/ArchiveIntermediates/RBBranch/IntermediateBuildFilesPath/CordovaLib.b uild/Release-iphoneos/CordovaLib.build/Cordova-project-headers.hmap -I/tmp/gimlet/1645041/project/build/include -I/Users/phonegap/Library/Developer/Xcode/DerivedData/RBBranch-eoelrkktfohkitdezostyrfmsi de/Build/Intermediates/ArchiveIntermediates/RBBranch/IntermediateBuildFilesPath/Uninstalle dProducts/iphoneos/usr/local/lib/include -I/Users/phonegap/Library/Developer/Xcode/DerivedData/RBBranch-eoelrkktfohkitdezostyrfmsi de/Build/Intermediates/ArchiveIntermediates/RBBranch/IntermediateBuildFilesPath/Uninstalle dProducts/include -I/Users/phonegap/Library/Developer/Xcode/DerivedData/RBBranch-eoelrkktfohkitdezostyrfmsi de/Build/Intermediates/ArchiveIntermediates/RBBranch/IntermediateBuildFilesPath/Uninstalle dProducts/iphoneos/include -I/tmp/gimlet/1645041/project/build -I/Users/phonegap/Library/Developer/Xcode/DerivedData/RBBranch-eoelrkktfohkitdezostyrfmsi de/Build/Intermediates/ArchiveIntermediates/RBBranch/IntermediateBuildFilesPath/CordovaLib .build/Release-iphoneos/CordovaLib.build/DerivedSources/arm64 -I/Users/phonegap/Library/Developer/Xcode/DerivedData/RBBranch-eoelrkktfohkitdezostyrfmsi de/Build/Intermediates/ArchiveIntermediates/RBBranch/IntermediateBuildFilesPath/CordovaLib .build/Release-iphoneos/CordovaLib.build/DerivedSources -F/tmp/gimlet/1645041/project/build -include /private/tmp/gimlet/1645041/project/build/sharedpch/CordovaLib_Prefix-hagqdysfamtkhngolen foajtzops/CordovaLib_Prefix.pch -MMD -MT dependencies -MF /Users/phonegap/Library/Developer/Xcode/DerivedData/RBBranch-eoelrkktfohkitdezostyrfmside /Build/Intermediates/ArchiveIntermediates/RBBranch/IntermediateBuildFilesPath/CordovaLib.b uild/Release-iphoneos/CordovaLib.build/Objects-normal/arm64/CDVTimer.d --serialize-diagnostics /Users/phonegap/Library/Developer/Xcode/DerivedData/RBBranch-eoelrkktfohkitdezostyrfmside /Build/Intermediates/ArchiveIntermediates/RBBranch/IntermediateBuildFilesPath/CordovaLib.b uild/Release-iphoneos/CordovaLib.build/Objects-normal/arm64/CDVTimer.dia -c /tmp/gimlet/1645041/project/CordovaLib/Classes/Public/CDVTimer.m -o /Users/phonegap/Library/Developer/Xcode/DerivedData/RBBranch-eoelrkktfohkitdezostyrfmside /Build/Intermediates/ArchiveIntermediates/RBBranch/IntermediateBuildFilesPath/CordovaLib.b uild/Release-iphoneos/CordovaLib.build/Objects-normal/arm64/CDVTimer.o
      CompileC /Users/phonegap/Library/Developer/Xcode/DerivedData/RBBranch-eoelrkktfohkitdezostyrfmside /Build/Intermediates/ArchiveIntermediates/RBBranch/IntermediateBuildFilesPath/CordovaLib.b uild/Release-iphoneos/CordovaLib.build/Objects-normal/arm64/CDVUserAgentUtil.o Classes/Public/CDVUserAgentUtil.m normal arm64 objective-c com.apple.compilers.llvm.clang.1_0.compiler
        /Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/bin/cl ang -x objective-c -arch arm64 -fmessage-length=0 -fdiagnostics-show-note-include-stack -fmacro-backtrace-limit=0 -std=c99 -fobjc-arc -fmodules -fmodules-cache-path=/Users/phonegap/Library/Developer/Xcode/DerivedData/ModuleCache -fmodules-prune-interval=86400 -fmodules-prune-after=345600 -fbuild-session-file=/Users/phonegap/Library/Developer/Xcode/DerivedData/ModuleCache/Sess ion.modulevalidation -fmodules-validate-once-per-build-session -Wno-trigraphs -fpascal-strings -Os -Wno-missing-field-initializers -Wno-missing-prototypes -Wno-implicit-atomic-properties -Wno-arc-repeated-use-of-weak -Wduplicate-method-match -Wno-missing-braces -Wparentheses -Wswitch -Wunused-function -Wno-unused-label -Wno-unused-parameter -Wunused-variable -Wunused-value -Wempty-body -Wuninitialized -Wno-unknown-pragmas -Wno-shadow -Wno-four-char-constants -Wno-conversion -Wconstant-conversion -Wint-conversion -Wbool-conversion -Wenum-conversion -Wshorten-64-to-32 -Wpointer-sign -Wno-newline-eof -Wno-selector -Wno-strict-selector-match -Wundeclared-selector -Wno-deprecated-implementations -isysroot /Applications/Xcode.app/Contents/Developer/Platforms/iPhoneOS.platform/Developer/SDKs/iPh oneOS10.1.sdk -fstrict-aliasing -Wprotocol -Wdeprecated-declarations -miphoneos-version-min=8.0 -g -Wno-sign-conversion -Wno-infinite-recursion -iquote /Users/phonegap/Library/Developer/Xcode/DerivedData/RBBranch-eoelrkktfohkitdezostyrfmside /Build/Intermediates/ArchiveIntermediates/RBBranch/IntermediateBuildFilesPath/CordovaLib.b uild/Release-iphoneos/CordovaLib.build/Cordova-generated-files.hmap -I/Users/phonegap/Library/Developer/Xcode/DerivedData/RBBranch-eoelrkktfohkitdezostyrfmsi de/Build/Intermediates/ArchiveIntermediates/RBBranch/IntermediateBuildFilesPath/CordovaLib .build/Release-iphoneos/CordovaLib.build/Cordova-own-target-headers.hmap -I/Users/phonegap/Library/Developer/Xcode/DerivedData/RBBranch-eoelrkktfohkitdezostyrfmsi de/Build/Intermediates/ArchiveIntermediates/RBBranch/IntermediateBuildFilesPath/CordovaLib .build/Release-iphoneos/CordovaLib.build/Cordova-all-target-headers.hmap -iquote /Users/phonegap/Library/Developer/Xcode/DerivedData/RBBranch-eoelrkktfohkitdezostyrfmside /Build/Intermediates/ArchiveIntermediates/RBBranch/IntermediateBuildFilesPath/CordovaLib.b uild/Release-iphoneos/CordovaLib.build/Cordova-project-headers.hmap -I/tmp/gimlet/1645041/project/build/include -I/Users/phonegap/Library/Developer/Xcode/DerivedData/RBBranch-eoelrkktfohkitdezostyrfmsi de/Build/Intermediates/ArchiveIntermediates/RBBranch/IntermediateBuildFilesPath/Uninstalle dProducts/iphoneos/usr/local/lib/include -I/Users/phonegap/Library/Developer/Xcode/DerivedData/RBBranch-eoelrkktfohkitdezostyrfmsi de/Build/Intermediates/ArchiveIntermediates/RBBranch/IntermediateBuildFilesPath/Uninstalle dProducts/include -I/Users/phonegap/Library/Developer/Xcode/DerivedData/RBBranch-eoelrkktfohkitdezostyrfmsi de/Build/Intermediates/ArchiveIntermediates/RBBranch/IntermediateBuildFilesPath/Uninstalle dProducts/iphoneos/include -I/tmp/gimlet/1645041/project/build -I/Users/phonegap/Library/Developer/Xcode/DerivedData/RBBranch-eoelrkktfohkitdezostyrfmsi de/Build/Intermediates/ArchiveIntermediates/RBBranch/IntermediateBuildFilesPath/CordovaLib .build/Release-iphoneos/CordovaLib.build/DerivedSources/arm64 -I/Users/phonegap/Library/Developer/Xcode/DerivedData/RBBranch-eoelrkktfohkitdezostyrfmsi de/Build/Intermediates/ArchiveIntermediates/RBBranch/IntermediateBuildFilesPath/CordovaLib .build/Release-iphoneos/CordovaLib.build/DerivedSources -F/tmp/gimlet/1645041/project/build -include /private/tmp/gimlet/1645041/project/build/sharedpch/CordovaLib_Prefix-hagqdysfamtkhngolen foajtzops/CordovaLib_Prefix.pch -MMD -MT dependencies -MF /Users/phonegap/Library/Developer/Xcode/DerivedData/RBBranch-eoelrkktfohkitdezostyrfmside /Build/Intermediates/ArchiveIntermediates/RBBranch/IntermediateBuildFilesPath/CordovaLib.b uild/Release-iphoneos/CordovaLib.build/Objects-normal/arm64/CDVUserAgentUtil.d --serialize-diagnostics /Users/phonegap/Library/Developer/Xcode/DerivedData/RBBranch-eoelrkktfohkitdezostyrfmside /Build/Intermediates/ArchiveIntermediates/RBBranch/IntermediateBuildFilesPath/CordovaLib.b uild/Release-iphoneos/CordovaLib.build/Objects-normal/arm64/CDVUserAgentUtil.dia -c /tmp/gimlet/1645041/project/CordovaLib/Classes/Public/CDVUserAgentUtil.m -o /Users/phonegap/Library/Developer/Xcode/DerivedData/RBBranch-eoelrkktfohkitdezostyrfmside /Build/Intermediates/ArchiveIntermediates/RBBranch/IntermediateBuildFilesPath/CordovaLib.b uild/Release-iphoneos/CordovaLib.build/Objects-normal/arm64/CDVUserAgentUtil.o
      CompileC /Users/phonegap/Library/Developer/Xcode/DerivedData/RBBranch-eoelrkktfohkitdezostyrfmside /Build/Intermediates/ArchiveIntermediates/RBBranch/IntermediateBuildFilesPath/CordovaLib.b uild/Release-iphoneos/CordovaLib.build/Objects-normal/arm64/CDVConfigParser.o Classes/Public/CDVConfigParser.m normal arm64 objective-c com.apple.compilers.llvm.clang.1_0.compiler
        /Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/bin/cl ang -x objective-c -arch arm64 -fmessage-length=0 -fdiagnostics-show-note-include-stack -fmacro-backtrace-limit=0 -std=c99 -fobjc-arc -fmodules -fmodules-cache-path=/Users/phonegap/Library/Developer/Xcode/DerivedData/ModuleCache -fmodules-prune-interval=86400 -fmodules-prune-after=345600 -fbuild-session-file=/Users/phonegap/Library/Developer/Xcode/DerivedData/ModuleCache/Sess ion.modulevalidation -fmodules-validate-once-per-build-session -Wno-trigraphs -fpascal-strings -Os -Wno-missing-field-initializers -Wno-missing-prototypes -Wno-implicit-atomic-properties -Wno-arc-repeated-use-of-weak -Wduplicate-method-match -Wno-missing-braces -Wparentheses -Wswitch -Wunused-function -Wno-unused-label -Wno-unused-parameter -Wunused-variable -Wunused-value -Wempty-body -Wuninitialized -Wno-unknown-pragmas -Wno-shadow -Wno-four-char-constants -Wno-conversion -Wconstant-conversion -Wint-conversion -Wbool-conversion -Wenum-conversion -Wshorten-64-to-32 -Wpointer-sign -Wno-newline-eof -Wno-selector -Wno-strict-selector-match -Wundeclared-selector -Wno-deprecated-implementations -isysroot /Applications/Xcode.app/Contents/Developer/Platforms/iPhoneOS.platform/Developer/SDKs/iPh oneOS10.1.sdk -fstrict-aliasing -Wprotocol -Wdeprecated-declarations -miphoneos-version-min=8.0 -g -Wno-sign-conversion -Wno-infinite-recursion -iquote /Users/phonegap/Library/Developer/Xcode/DerivedData/RBBranch-eoelrkktfohkitdezostyrfmside /Build/Intermediates/ArchiveIntermediates/RBBranch/IntermediateBuildFilesPath/CordovaLib.b uild/Release-iphoneos/CordovaLib.build/Cordova-generated-files.hmap -I/Users/phonegap/Library/Developer/Xcode/DerivedData/RBBranch-eoelrkktfohkitdezostyrfmsi de/Build/Intermediates/ArchiveIntermediates/RBBranch/IntermediateBuildFilesPath/CordovaLib .build/Release-iphoneos/CordovaLib.build/Cordova-own-target-headers.hmap -I/Users/phonegap/Library/Developer/Xcode/DerivedData/RBBranch-eoelrkktfohkitdezostyrfmsi de/Build/Intermediates/ArchiveIntermediates/RBBranch/IntermediateBuildFilesPath/CordovaLib .build/Release-iphoneos/CordovaLib.build/Cordova-all-target-headers.hmap -iquote /Users/phonegap/Library/Developer/Xcode/DerivedData/RBBranch-eoelrkktfohkitdezostyrfmside /Build/Intermediates/ArchiveIntermediates/RBBranch/IntermediateBuildFilesPath/CordovaLib.b uild/Release-iphoneos/CordovaLib.build/Cordova-project-headers.hmap -I/tmp/gimlet/1645041/project/build/include -I/Users/phonegap/Library/Developer/Xcode/DerivedData/RBBranch-eoelrkktfohkitdezostyrfmsi de/Build/Intermediates/ArchiveIntermediates/RBBranch/IntermediateBuildFilesPath/Uninstalle dProducts/iphoneos/usr/local/lib/include -I/Users/phonegap/Library/Developer/Xcode/DerivedData/RBBranch-eoelrkktfohkitdezostyrfmsi de/Build/Intermediates/ArchiveIntermediates/RBBranch/IntermediateBuildFilesPath/Uninstalle dProducts/include -I/Users/phonegap/Library/Developer/Xcode/DerivedData/RBBranch-eoelrkktfohkitdezostyrfmsi de/Build/Intermediates/ArchiveIntermediates/RBBranch/IntermediateBuildFilesPath/Uninstalle dProducts/iphoneos/include -I/tmp/gimlet/1645041/project/build -I/Users/phonegap/Library/Developer/Xcode/DerivedData/RBBranch-eoelrkktfohkitdezostyrfmsi de/Build/Intermediates/ArchiveIntermediates/RBBranch/IntermediateBuildFilesPath/CordovaLib .build/Release-iphoneos/CordovaLib.build/DerivedSources/arm64 -I/Users/phonegap/Library/Developer/Xcode/DerivedData/RBBranch-eoelrkktfohkitdezostyrfmsi de/Build/Intermediates/ArchiveIntermediates/RBBranch/IntermediateBuildFilesPath/CordovaLib .build/Release-iphoneos/CordovaLib.build/DerivedSources -F/tmp/gimlet/1645041/project/build -include /private/tmp/gimlet/1645041/project/build/sharedpch/CordovaLib_Prefix-hagqdysfamtkhngolen foajtzops/CordovaLib_Prefix.pch -MMD -MT dependencies -MF /Users/phonegap/Library/Developer/Xcode/DerivedData/RBBranch-eoelrkktfohkitdezostyrfmside /Build/Intermediates/ArchiveIntermediates/RBBranch/IntermediateBuildFilesPath/CordovaLib.b uild/Release-iphoneos/CordovaLib.build/Objects-normal/arm64/CDVConfigParser.d --serialize-diagnostics /Users/phonegap/Library/Developer/Xcode/DerivedData/RBBranch-eoelrkktfohkitdezostyrfmside /Build/Intermediates/ArchiveIntermediates/RBBranch/IntermediateBuildFilesPath/CordovaLib.b uild/Release-iphoneos/CordovaLib.build/Objects-normal/arm64/CDVConfigParser.dia -c /tmp/gimlet/1645041/project/CordovaLib/Classes/Public/CDVConfigParser.m -o /Users/phonegap/Library/Developer/Xcode/DerivedData/RBBranch-eoelrkktfohkitdezostyrfmside /Build/Intermediates/ArchiveIntermediates/RBBranch/IntermediateBuildFilesPath/CordovaLib.b uild/Release-iphoneos/CordovaLib.build/Objects-normal/arm64/CDVConfigParser.o
      CompileC /Users/phonegap/Library/Developer/Xcode/DerivedData/RBBranch-eoelrkktfohkitdezostyrfmside /Build/Intermediates/ArchiveIntermediates/RBBranch/IntermediateBuildFilesPath/CordovaLib.b uild/Release-iphoneos/CordovaLib.build/Objects-normal/arm64/CDVGestureHandler.o Classes/Private/Plugins/CDVGestureHandler/CDVGestureHandler.m normal arm64 objective-c com.apple.compilers.llvm.clang.1_0.compiler
        /Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/bin/cl ang -x objective-c -arch arm64 -fmessage-length=0 -fdiagnostics-show-note-include-stack -fmacro-backtrace-limit=0 -std=c99 -fobjc-arc -fmodules -fmodules-cache-path=/Users/phonegap/Library/Developer/Xcode/DerivedData/ModuleCache -fmodules-prune-interval=86400 -fmodules-prune-after=345600 -fbuild-session-file=/Users/phonegap/Library/Developer/Xcode/DerivedData/ModuleCache/Sess ion.modulevalidation -fmodules-validate-once-per-build-session -Wno-trigraphs -fpascal-strings -Os -Wno-missing-field-initializers -Wno-missing-prototypes -Wno-implicit-atomic-properties -Wno-arc-repeated-use-of-weak -Wduplicate-method-match -Wno-missing-braces -Wparentheses -Wswitch -Wunused-function -Wno-unused-label -Wno-unused-parameter -Wunused-variable -Wunused-value -Wempty-body -Wuninitialized -Wno-unknown-pragmas -Wno-shadow -Wno-four-char-constants -Wno-conversion -Wconstant-conversion -Wint-conversion -Wbool-conversion -Wenum-conversion -Wshorten-64-to-32 -Wpointer-sign -Wno-newline-eof -Wno-selector -Wno-strict-selector-match -Wundeclared-selector -Wno-deprecated-implementations -isysroot /Applications/Xcode.app/Contents/Developer/Platforms/iPhoneOS.platform/Developer/SDKs/iPh oneOS10.1.sdk -fstrict-aliasing -Wprotocol -Wdeprecated-declarations -miphoneos-version-min=8.0 -g -Wno-sign-conversion -Wno-infinite-recursion -iquote /Users/phonegap/Library/Developer/Xcode/DerivedData/RBBranch-eoelrkktfohkitdezostyrfmside /Build/Intermediates/ArchiveIntermediates/RBBranch/IntermediateBuildFilesPath/CordovaLib.b uild/Release-iphoneos/CordovaLib.build/Cordova-generated-files.hmap -I/Users/phonegap/Library/Developer/Xcode/DerivedData/RBBranch-eoelrkktfohkitdezostyrfmsi de/Build/Intermediates/ArchiveIntermediates/RBBranch/IntermediateBuildFilesPath/CordovaLib .build/Release-iphoneos/CordovaLib.build/Cordova-own-target-headers.hmap -I/Users/phonegap/Library/Developer/Xcode/DerivedData/RBBranch-eoelrkktfohkitdezostyrfmsi de/Build/Intermediates/ArchiveIntermediates/RBBranch/IntermediateBuildFilesPath/CordovaLib .build/Release-iphoneos/CordovaLib.build/Cordova-all-target-headers.hmap -iquote /Users/phonegap/Library/Developer/Xcode/DerivedData/RBBranch-eoelrkktfohkitdezostyrfmside /Build/Intermediates/ArchiveIntermediates/RBBranch/IntermediateBuildFilesPath/CordovaLib.b uild/Release-iphoneos/CordovaLib.build/Cordova-project-headers.hmap -I/tmp/gimlet/1645041/project/build/include -I/Users/phonegap/Library/Developer/Xcode/DerivedData/RBBranch-eoelrkktfohkitdezostyrfmsi de/Build/Intermediates/ArchiveIntermediates/RBBranch/IntermediateBuildFilesPath/Uninstalle dProducts/iphoneos/usr/local/lib/include -I/Users/phonegap/Library/Developer/Xcode/DerivedData/RBBranch-eoelrkktfohkitdezostyrfmsi de/Build/Intermediates/ArchiveIntermediates/RBBranch/IntermediateBuildFilesPath/Uninstalle dProducts/include -I/Users/phonegap/Library/Developer/Xcode/DerivedData/RBBranch-eoelrkktfohkitdezostyrfmsi de/Build/Intermediates/ArchiveIntermediates/RBBranch/IntermediateBuildFilesPath/Uninstalle dProducts/iphoneos/include -I/tmp/gimlet/1645041/project/build -I/Users/phonegap/Library/Developer/Xcode/DerivedData/RBBranch-eoelrkktfohkitdezostyrfmsi de/Build/Intermediates/ArchiveIntermediates/RBBranch/IntermediateBuildFilesPath/CordovaLib .build/Release-iphoneos/CordovaLib.build/DerivedSources/arm64 -I/Users/phonegap/Library/Developer/Xcode/DerivedData/RBBranch-eoelrkktfohkitdezostyrfmsi de/Build/Intermediates/ArchiveIntermediates/RBBranch/IntermediateBuildFilesPath/CordovaLib .build/Release-iphoneos/CordovaLib.build/DerivedSources -F/tmp/gimlet/1645041/project/build -include /private/tmp/gimlet/1645041/project/build/sharedpch/CordovaLib_Prefix-hagqdysfamtkhngolen foajtzops/CordovaLib_Prefix.pch -MMD -MT dependencies -MF /Users/phonegap/Library/Developer/Xcode/DerivedData/RBBranch-eoelrkktfohkitdezostyrfmside /Build/Intermediates/ArchiveIntermediates/RBBranch/IntermediateBuildFilesPath/CordovaLib.b uild/Release-iphoneos/CordovaLib.build/Objects-normal/arm64/CDVGestureHandler.d --serialize-diagnostics /Users/phonegap/Library/Developer/Xcode/DerivedData/RBBranch-eoelrkktfohkitdezostyrfmside /Build/Intermediates/ArchiveIntermediates/RBBranch/IntermediateBuildFilesPath/CordovaLib.b uild/Release-iphoneos/CordovaLib.build/Objects-normal/arm64/CDVGestureHandler.dia -c /tmp/gimlet/1645041/project/CordovaLib/Classes/Private/Plugins/CDVGestureHandler/CDVGestu reHandler.m -o /Users/phonegap/Library/Developer/Xcode/DerivedData/RBBranch-eoelrkktfohkitdezostyrfmside /Build/Intermediates/ArchiveIntermediates/RBBranch/IntermediateBuildFilesPath/CordovaLib.b uild/Release-iphoneos/CordovaLib.build/Objects-normal/arm64/CDVGestureHandler.o
      CompileC /Users/phonegap/Library/Developer/Xcode/DerivedData/RBBranch-eoelrkktfohkitdezostyrfmside /Build/Intermediates/ArchiveIntermediates/RBBranch/IntermediateBuildFilesPath/CordovaLib.b uild/Release-iphoneos/CordovaLib.build/Objects-normal/arm64/CDVHandleOpenURL.o Classes/Private/Plugins/CDVHandleOpenURL/CDVHandleOpenURL.m normal arm64 objective-c com.apple.compilers.llvm.clang.1_0.compiler
        export LANG=en_US.US-ASCII
        /Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/bin/cl ang -x objective-c -arch arm64 -fmessage-length=0 -fdiagnostics-show-note-include-stack -fmacro-backtrace-limit=0 -std=c99 -fobjc-arc -fmodules -fmodules-cache-path=/Users/phonegap/Library/Developer/Xcode/DerivedData/ModuleCache -fmodules-prune-interval=86400 -fmodules-prune-after=345600 -fbuild-session-file=/Users/phonegap/Library/Developer/Xcode/DerivedData/ModuleCache/Sess ion.modulevalidation -fmodules-validate-once-per-build-session -Wno-trigraphs -fpascal-strings -Os -Wno-missing-field-initializers -Wno-missing-prototypes -Wno-implicit-atomic-properties -Wno-arc-repeated-use-of-weak -Wduplicate-method-match -Wno-missing-braces -Wparentheses -Wswitch -Wunused-function -Wno-unused-label -Wno-unused-parameter -Wunused-variable -Wunused-value -Wempty-body -Wuninitialized -Wno-unknown-pragmas -Wno-shadow -Wno-four-char-constants -Wno-conversion -Wconstant-conversion -Wint-conversion -Wbool-conversion -Wenum-conversion -Wshorten-64-to-32 -Wpointer-sign -Wno-newline-eof -Wno-selector -Wno-strict-selector-match -Wundeclared-selector -Wno-deprecated-implementations -isysroot /Applications/Xcode.app/Contents/Developer/Platforms/iPhoneOS.platform/Developer/SDKs/iPh oneOS10.1.sdk -fstrict-aliasing -Wprotocol -Wdeprecated-declarations -miphoneos-version-min=8.0 -g -Wno-sign-conversion -Wno-infinite-recursion -iquote /Users/phonegap/Library/Developer/Xcode/DerivedData/RBBranch-eoelrkktfohkitdezostyrfmside /Build/Intermediates/ArchiveIntermediates/RBBranch/IntermediateBuildFilesPath/CordovaLib.b uild/Release-iphoneos/CordovaLib.build/Cordova-generated-files.hmap -I/Users/phonegap/Library/Developer/Xcode/DerivedData/RBBranch-eoelrkktfohkitdezostyrfmsi de/Build/Intermediates/ArchiveIntermediates/RBBranch/IntermediateBuildFilesPath/CordovaLib .build/Release-iphoneos/CordovaLib.build/Cordova-own-target-headers.hmap -I/Users/phonegap/Library/Developer/Xcode/DerivedData/RBBranch-eoelrkktfohkitdezostyrfmsi de/Build/Intermediates/ArchiveIntermediates/RBBranch/IntermediateBuildFilesPath/CordovaLib .build/Release-iphoneos/CordovaLib.build/Cordova-all-target-headers.hmap -iquote /Users/phonegap/Library/Developer/Xcode/DerivedData/RBBranch-eoelrkktfohkitdezostyrfmside /Build/Intermediates/ArchiveIntermediates/RBBranch/IntermediateBuildFilesPath/CordovaLib.b uild/Release-iphoneos/CordovaLib.build/Cordova-project-headers.hmap -I/tmp/gimlet/1645041/project/build/include -I/Users/phonegap/Library/Developer/Xcode/DerivedData/RBBranch-eoelrkktfohkitdezostyrfmsi de/Build/Intermediates/ArchiveIntermediates/RBBranch/IntermediateBuildFilesPath/Uninstalle dProducts/iphoneos/usr/local/lib/include -I/Users/phonegap/Library/Developer/Xcode/DerivedData/RBBranch-eoelrkktfohkitdezostyrfmsi de/Build/Intermediates/ArchiveIntermediates/RBBranch/IntermediateBuildFilesPath/Uninstalle dProducts/include -I/Users/phonegap/Library/Developer/Xcode/DerivedData/RBBranch-eoelrkktfohkitdezostyrfmsi de/Build/Intermediates/ArchiveIntermediates/RBBranch/IntermediateBuildFilesPath/Uninstalle dProducts/iphoneos/include -I/tmp/gimlet/1645041/project/build -I/Users/phonegap/Library/Developer/Xcode/DerivedData/RBBranch-eoelrkktfohkitdezostyrfmsi de/Build/Intermediates/ArchiveIntermediates/RBBranch/IntermediateBuildFilesPath/CordovaLib .build/Release-iphoneos/CordovaLib.build/DerivedSources/arm64 -I/Users/phonegap/Library/Developer/Xcode/DerivedData/RBBranch-eoelrkktfohkitdezostyrfmsi de/Build/Intermediates/ArchiveIntermediates/RBBranch/IntermediateBuildFilesPath/CordovaLib .build/Release-iphoneos/CordovaLib.build/DerivedSources -F/tmp/gimlet/1645041/project/build -include /private/tmp/gimlet/1645041/project/build/sharedpch/CordovaLib_Prefix-hagqdysfamtkhngolen foajtzops/CordovaLib_Prefix.pch -MMD -MT dependencies -MF /Users/phonegap/Library/Developer/Xcode/DerivedData/RBBranch-eoelrkktfohkitdezostyrfmside /Build/Intermediates/ArchiveIntermediates/RBBranch/IntermediateBuildFilesPath/CordovaLib.b uild/Release-iphoneos/CordovaLib.build/Objects-normal/arm64/CDVHandleOpenURL.d --serialize-diagnostics /Users/phonegap/Library/Developer/Xcode/DerivedData/RBBranch-eoelrkktfohkitdezostyrfmside /Build/Intermediates/ArchiveIntermediates/RBBranch/IntermediateBuildFilesPath/CordovaLib.b uild/Release-iphoneos/CordovaLib.build/Objects-normal/arm64/CDVHandleOpenURL.dia -c /tmp/gimlet/1645041/project/CordovaLib/Classes/Private/Plugins/CDVHandleOpenURL/CDVHandle OpenURL.m -o /Users/phonegap/Library/Developer/Xcode/DerivedData/RBBranch-eoelrkktfohkitdezostyrfmside /Build/Intermediates/ArchiveIntermediates/RBBranch/IntermediateBuildFilesPath/CordovaLib.b uild/Release-iphoneos/CordovaLib.build/Objects-normal/arm64/CDVHandleOpenURL.o
      CompileC /Users/phonegap/Library/Developer/Xcode/DerivedData/RBBranch-eoelrkktfohkitdezostyrfmside /Build/Intermediates/ArchiveIntermediates/RBBranch/IntermediateBuildFilesPath/CordovaLib.b uild/Release-iphoneos/CordovaLib.build/Objects-normal/arm64/CDVUIWebViewNavigationDelegate .o Classes/Private/Plugins/CDVUIWebViewEngine/CDVUIWebViewNavigationDelegate.m normal arm64 objective-c com.apple.compilers.llvm.clang.1_0.compiler
        /Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/bin/cl ang -x objective-c -arch arm64 -fmessage-length=0 -fdiagnostics-show-note-include-stack -fmacro-backtrace-limit=0 -std=c99 -fobjc-arc -fmodules -fmodules-cache-path=/Users/phonegap/Library/Developer/Xcode/DerivedData/ModuleCache -fmodules-prune-interval=86400 -fmodules-prune-after=345600 -fbuild-session-file=/Users/phonegap/Library/Developer/Xcode/DerivedData/ModuleCache/Sess ion.modulevalidation -fmodules-validate-once-per-build-session -Wno-trigraphs -fpascal-strings -Os -Wno-missing-field-initializers -Wno-missing-prototypes -Wno-implicit-atomic-properties -Wno-arc-repeated-use-of-weak -Wduplicate-method-match -Wno-missing-braces -Wparentheses -Wswitch -Wunused-function -Wno-unused-label -Wno-unused-parameter -Wunused-variable -Wunused-value -Wempty-body -Wuninitialized -Wno-unknown-pragmas -Wno-shadow -Wno-four-char-constants -Wno-conversion -Wconstant-conversion -Wint-conversion -Wbool-conversion -Wenum-conversion -Wshorten-64-to-32 -Wpointer-sign -Wno-newline-eof -Wno-selector -Wno-strict-selector-match -Wundeclared-selector -Wno-deprecated-implementations -isysroot /Applications/Xcode.app/Contents/Developer/Platforms/iPhoneOS.platform/Developer/SDKs/iPh oneOS10.1.sdk -fstrict-aliasing -Wprotocol -Wdeprecated-declarations -miphoneos-version-min=8.0 -g -Wno-sign-conversion -Wno-infinite-recursion -iquote /Users/phonegap/Library/Developer/Xcode/DerivedData/RBBranch-eoelrkktfohkitdezostyrfmside /Build/Intermediates/ArchiveIntermediates/RBBranch/IntermediateBuildFilesPath/CordovaLib.b uild/Release-iphoneos/CordovaLib.build/Cordova-generated-files.hmap -I/Users/phonegap/Library/Developer/Xcode/DerivedData/RBBranch-eoelrkktfohkitdezostyrfmsi de/Build/Intermediates/ArchiveIntermediates/RBBranch/IntermediateBuildFilesPath/CordovaLib .build/Release-iphoneos/CordovaLib.build/Cordova-own-target-headers.hmap -I/Users/phonegap/Library/Developer/Xcode/DerivedData/RBBranch-eoelrkktfohkitdezostyrfmsi de/Build/Intermediates/ArchiveIntermediates/RBBranch/IntermediateBuildFilesPath/CordovaLib .build/Release-iphoneos/CordovaLib.build/Cordova-all-target-headers.hmap -iquote /Users/phonegap/Library/Developer/Xcode/DerivedData/RBBranch-eoelrkktfohkitdezostyrfmside /Build/Intermediates/ArchiveIntermediates/RBBranch/IntermediateBuildFilesPath/CordovaLib.b uild/Release-iphoneos/CordovaLib.build/Cordova-project-headers.hmap -I/tmp/gimlet/1645041/project/build/include -I/Users/phonegap/Library/Developer/Xcode/DerivedData/RBBranch-eoelrkktfohkitdezostyrfmsi de/Build/Intermediates/ArchiveIntermediates/RBBranch/IntermediateBuildFilesPath/Uninstalle dProducts/iphoneos/usr/local/lib/include -I/Users/phonegap/Library/Developer/Xcode/DerivedData/RBBranch-eoelrkktfohkitdezostyrfmsi de/Build/Intermediates/ArchiveIntermediates/RBBranch/IntermediateBuildFilesPath/Uninstalle dProducts/include -I/Users/phonegap/Library/Developer/Xcode/DerivedData/RBBranch-eoelrkktfohkitdezostyrfmsi de/Build/Intermediates/ArchiveIntermediates/RBBranch/IntermediateBuildFilesPath/Uninstalle dProducts/iphoneos/include -I/tmp/gimlet/1645041/project/build -I/Users/phonegap/Library/Developer/Xcode/DerivedData/RBBranch-eoelrkktfohkitdezostyrfmsi de/Build/Intermediates/ArchiveIntermediates/RBBranch/IntermediateBuildFilesPath/CordovaLib .build/Release-iphoneos/CordovaLib.build/DerivedSources/arm64 -I/Users/phonegap/Library/Developer/Xcode/DerivedData/RBBranch-eoelrkktfohkitdezostyrfmsi de/Build/Intermediates/ArchiveIntermediates/RBBranch/IntermediateBuildFilesPath/CordovaLib .build/Release-iphoneos/CordovaLib.build/DerivedSources -F/tmp/gimlet/1645041/project/build -include /private/tmp/gimlet/1645041/project/build/sharedpch/CordovaLib_Prefix-hagqdysfamtkhngolen foajtzops/CordovaLib_Prefix.pch -MMD -MT dependencies -MF /Users/phonegap/Library/Developer/Xcode/DerivedData/RBBranch-eoelrkktfohkitdezostyrfmside /Build/Intermediates/ArchiveIntermediates/RBBranch/IntermediateBuildFilesPath/CordovaLib.b uild/Release-iphoneos/CordovaLib.build/Objects-normal/arm64/CDVUIWebViewNavigationDelegate .d --serialize-diagnostics /Users/phonegap/Library/Developer/Xcode/DerivedData/RBBranch-eoelrkktfohkitdezostyrfmside /Build/Intermediates/ArchiveIntermediates/RBBranch/IntermediateBuildFilesPath/CordovaLib.b uild/Release-iphoneos/CordovaLib.build/Objects-normal/arm64/CDVUIWebViewNavigationDelegate .dia -c /tmp/gimlet/1645041/project/CordovaLib/Classes/Private/Plugins/CDVUIWebViewEngine/CDVUIWe bViewNavigationDelegate.m -o /Users/phonegap/Library/Developer/Xcode/DerivedData/RBBranch-eoelrkktfohkitdezostyrfmside /Build/Intermediates/ArchiveIntermediates/RBBranch/IntermediateBuildFilesPath/CordovaLib.b uild/Release-iphoneos/CordovaLib.build/Objects-normal/arm64/CDVUIWebViewNavigationDelegate .o
      CompileC /Users/phonegap/Library/Developer/Xcode/DerivedData/RBBranch-eoelrkktfohkitdezostyrfmside /Build/Intermediates/ArchiveIntermediates/RBBranch/IntermediateBuildFilesPath/CordovaLib.b uild/Release-iphoneos/CordovaLib.build/Objects-normal/arm64/CDVPluginResult.o Classes/Public/CDVPluginResult.m normal arm64 objective-c com.apple.compilers.llvm.clang.1_0.compiler
        /Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/bin/cl ang -x objective-c -arch arm64 -fmessage-length=0 -fdiagnostics-show-note-include-stack -fmacro-backtrace-limit=0 -std=c99 -fobjc-arc -fmodules -fmodules-cache-path=/Users/phonegap/Library/Developer/Xcode/DerivedData/ModuleCache -fmodules-prune-interval=86400 -fmodules-prune-after=345600 -fbuild-session-file=/Users/phonegap/Library/Developer/Xcode/DerivedData/ModuleCache/Sess ion.modulevalidation -fmodules-validate-once-per-build-session -Wno-trigraphs -fpascal-strings -Os -Wno-missing-field-initializers -Wno-missing-prototypes -Wno-implicit-atomic-properties -Wno-arc-repeated-use-of-weak -Wduplicate-method-match -Wno-missing-braces -Wparentheses -Wswitch -Wunused-function -Wno-unused-label -Wno-unused-parameter -Wunused-variable -Wunused-value -Wempty-body -Wuninitialized -Wno-unknown-pragmas -Wno-shadow -Wno-four-char-constants -Wno-conversion -Wconstant-conversion -Wint-conversion -Wbool-conversion -Wenum-conversion -Wshorten-64-to-32 -Wpointer-sign -Wno-newline-eof -Wno-selector -Wno-strict-selector-match -Wundeclared-selector -Wno-deprecated-implementations -isysroot /Applications/Xcode.app/Contents/Developer/Platforms/iPhoneOS.platform/Developer/SDKs/iPh oneOS10.1.sdk -fstrict-aliasing -Wprotocol -Wdeprecated-declarations -miphoneos-version-min=8.0 -g -Wno-sign-conversion -Wno-infinite-recursion -iquote /Users/phonegap/Library/Developer/Xcode/DerivedData/RBBranch-eoelrkktfohkitdezostyrfmside /Build/Intermediates/ArchiveIntermediates/RBBranch/IntermediateBuildFilesPath/CordovaLib.b uild/Release-iphoneos/CordovaLib.build/Cordova-generated-files.hmap -I/Users/phonegap/Library/Developer/Xcode/DerivedData/RBBranch-eoelrkktfohkitdezostyrfmsi de/Build/Intermediates/ArchiveIntermediates/RBBranch/IntermediateBuildFilesPath/CordovaLib .build/Release-iphoneos/CordovaLib.build/Cordova-own-target-headers.hmap -I/Users/phonegap/Library/Developer/Xcode/DerivedData/RBBranch-eoelrkktfohkitdezostyrfmsi de/Build/Intermediates/ArchiveIntermediates/RBBranch/IntermediateBuildFilesPath/CordovaLib .build/Release-iphoneos/CordovaLib.build/Cordova-all-target-headers.hmap -iquote /Users/phonegap/Library/Developer/Xcode/DerivedData/RBBranch-eoelrkktfohkitdezostyrfmside /Build/Intermediates/ArchiveIntermediates/RBBranch/IntermediateBuildFilesPath/CordovaLib.b uild/Release-iphoneos/CordovaLib.build/Cordova-project-headers.hmap -I/tmp/gimlet/1645041/project/build/include -I/Users/phonegap/Library/Developer/Xcode/DerivedData/RBBranch-eoelrkktfohkitdezostyrfmsi de/Build/Intermediates/ArchiveIntermediates/RBBranch/IntermediateBuildFilesPath/Uninstalle dProducts/iphoneos/usr/local/lib/include -I/Users/phonegap/Library/Developer/Xcode/DerivedData/RBBranch-eoelrkktfohkitdezostyrfmsi de/Build/Intermediates/ArchiveIntermediates/RBBranch/IntermediateBuildFilesPath/Uninstalle dProducts/include -I/Users/phonegap/Library/Developer/Xcode/DerivedData/RBBranch-eoelrkktfohkitdezostyrfmsi de/Build/Intermediates/ArchiveIntermediates/RBBranch/IntermediateBuildFilesPath/Uninstalle dProducts/iphoneos/include -I/tmp/gimlet/1645041/project/build -I/Users/phonegap/Library/Developer/Xcode/DerivedData/RBBranch-eoelrkktfohkitdezostyrfmsi de/Build/Intermediates/ArchiveIntermediates/RBBranch/IntermediateBuildFilesPath/CordovaLib .build/Release-iphoneos/CordovaLib.build/DerivedSources/arm64 -I/Users/phonegap/Library/Developer/Xcode/DerivedData/RBBranch-eoelrkktfohkitdezostyrfmsi de/Build/Intermediates/ArchiveIntermediates/RBBranch/IntermediateBuildFilesPath/CordovaLib .build/Release-iphoneos/CordovaLib.build/DerivedSources -F/tmp/gimlet/1645041/project/build -include /private/tmp/gimlet/1645041/project/build/sharedpch/CordovaLib_Prefix-hagqdysfamtkhngolen foajtzops/CordovaLib_Prefix.pch -MMD -MT dependencies -MF /Users/phonegap/Library/Developer/Xcode/DerivedData/RBBranch-eoelrkktfohkitdezostyrfmside /Build/Intermediates/ArchiveIntermediates/RBBranch/IntermediateBuildFilesPath/CordovaLib.b uild/Release-iphoneos/CordovaLib.build/Objects-normal/arm64/CDVPluginResult.d --serialize-diagnostics /Users/phonegap/Library/Developer/Xcode/DerivedData/RBBranch-eoelrkktfohkitdezostyrfmside /Build/Intermediates/ArchiveIntermediates/RBBranch/IntermediateBuildFilesPath/CordovaLib.b uild/Release-iphoneos/CordovaLib.build/Objects-normal/arm64/CDVPluginResult.dia -c /tmp/gimlet/1645041/project/CordovaLib/Classes/Public/CDVPluginResult.m -o /Users/phonegap/Library/Developer/Xcode/DerivedData/RBBranch-eoelrkktfohkitdezostyrfmside /Build/Intermediates/ArchiveIntermediates/RBBranch/IntermediateBuildFilesPath/CordovaLib.b uild/Release-iphoneos/CordovaLib.build/Objects-normal/arm64/CDVPluginResult.o
      CompileC /Users/phonegap/Library/Developer/Xcode/DerivedData/RBBranch-eoelrkktfohkitdezostyrfmside /Build/Intermediates/ArchiveIntermediates/RBBranch/IntermediateBuildFilesPath/CordovaLib.b uild/Release-iphoneos/CordovaLib.build/Objects-normal/arm64/CDVCommandQueue.o Classes/Public/CDVCommandQueue.m normal arm64 objective-c com.apple.compilers.llvm.clang.1_0.compiler
        /Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/bin/cl ang -x objective-c -arch arm64 -fmessage-length=0 -fdiagnostics-show-note-include-stack -fmacro-backtrace-limit=0 -std=c99 -fobjc-arc -fmodules -fmodules-cache-path=/Users/phonegap/Library/Developer/Xcode/DerivedData/ModuleCache -fmodules-prune-interval=86400 -fmodules-prune-after=345600 -fbuild-session-file=/Users/phonegap/Library/Developer/Xcode/DerivedData/ModuleCache/Sess ion.modulevalidation -fmodules-validate-once-per-build-session -Wno-trigraphs -fpascal-strings -Os -Wno-missing-field-initializers -Wno-missing-prototypes -Wno-implicit-atomic-properties -Wno-arc-repeated-use-of-weak -Wduplicate-method-match -Wno-missing-braces -Wparentheses -Wswitch -Wunused-function -Wno-unused-label -Wno-unused-parameter -Wunused-variable -Wunused-value -Wempty-body -Wuninitialized -Wno-unknown-pragmas -Wno-shadow -Wno-four-char-constants -Wno-conversion -Wconstant-conversion -Wint-conversion -Wbool-conversion -Wenum-conversion -Wshorten-64-to-32 -Wpointer-sign -Wno-newline-eof -Wno-selector -Wno-strict-selector-match -Wundeclared-selector -Wno-deprecated-implementations -isysroot /Applications/Xcode.app/Contents/Developer/Platforms/iPhoneOS.platform/Developer/SDKs/iPh oneOS10.1.sdk -fstrict-aliasing -Wprotocol -Wdeprecated-declarations -miphoneos-version-min=8.0 -g -Wno-sign-conversion -Wno-infinite-recursion -iquote /Users/phonegap/Library/Developer/Xcode/DerivedData/RBBranch-eoelrkktfohkitdezostyrfmside /Build/Intermediates/ArchiveIntermediates/RBBranch/IntermediateBuildFilesPath/CordovaLib.b uild/Release-iphoneos/CordovaLib.build/Cordova-generated-files.hmap -I/Users/phonegap/Library/Developer/Xcode/DerivedData/RBBranch-eoelrkktfohkitdezostyrfmsi de/Build/Intermediates/ArchiveIntermediates/RBBranch/IntermediateBuildFilesPath/CordovaLib .build/Release-iphoneos/CordovaLib.build/Cordova-own-target-headers.hmap -I/Users/phonegap/Library/Developer/Xcode/DerivedData/RBBranch-eoelrkktfohkitdezostyrfmsi de/Build/Intermediates/ArchiveIntermediates/RBBranch/IntermediateBuildFilesPath/CordovaLib .build/Release-iphoneos/CordovaLib.build/Cordova-all-target-headers.hmap -iquote /Users/phonegap/Library/Developer/Xcode/DerivedData/RBBranch-eoelrkktfohkitdezostyrfmside /Build/Intermediates/ArchiveIntermediates/RBBranch/IntermediateBuildFilesPath/CordovaLib.b uild/Release-iphoneos/CordovaLib.build/Cordova-project-headers.hmap -I/tmp/gimlet/1645041/project/build/include -I/Users/phonegap/Library/Developer/Xcode/DerivedData/RBBranch-eoelrkktfohkitdezostyrfmsi de/Build/Intermediates/ArchiveIntermediates/RBBranch/IntermediateBuildFilesPath/Uninstalle dProducts/iphoneos/usr/local/lib/include -I/Users/phonegap/Library/Developer/Xcode/DerivedData/RBBranch-eoelrkktfohkitdezostyrfmsi de/Build/Intermediates/ArchiveIntermediates/RBBranch/IntermediateBuildFilesPath/Uninstalle dProducts/include -I/Users/phonegap/Library/Developer/Xcode/DerivedData/RBBranch-eoelrkktfohkitdezostyrfmsi de/Build/Intermediates/ArchiveIntermediates/RBBranch/IntermediateBuildFilesPath/Uninstalle dProducts/iphoneos/include -I/tmp/gimlet/1645041/project/build -I/Users/phonegap/Library/Developer/Xcode/DerivedData/RBBranch-eoelrkktfohkitdezostyrfmsi de/Build/Intermediates/ArchiveIntermediates/RBBranch/IntermediateBuildFilesPath/CordovaLib .build/Release-iphoneos/CordovaLib.build/DerivedSources/arm64 -I/Users/phonegap/Library/Developer/Xcode/DerivedData/RBBranch-eoelrkktfohkitdezostyrfmsi de/Build/Intermediates/ArchiveIntermediates/RBBranch/IntermediateBuildFilesPath/CordovaLib .build/Release-iphoneos/CordovaLib.build/DerivedSources -F/tmp/gimlet/1645041/project/build -include /private/tmp/gimlet/1645041/project/build/sharedpch/CordovaLib_Prefix-hagqdysfamtkhngolen foajtzops/CordovaLib_Prefix.pch -MMD -MT dependencies -MF /Users/phonegap/Library/Developer/Xcode/DerivedData/RBBranch-eoelrkktfohkitdezostyrfmside /Build/Intermediates/ArchiveIntermediates/RBBranch/IntermediateBuildFilesPath/CordovaLib.b uild/Release-iphoneos/CordovaLib.build/Objects-normal/arm64/CDVCommandQueue.d --serialize-diagnostics /Users/phonegap/Library/Developer/Xcode/DerivedData/RBBranch-eoelrkktfohkitdezostyrfmside /Build/Intermediates/ArchiveIntermediates/RBBranch/IntermediateBuildFilesPath/CordovaLib.b uild/Release-iphoneos/CordovaLib.build/Objects-normal/arm64/CDVCommandQueue.dia -c /tmp/gimlet/1645041/project/CordovaLib/Classes/Public/CDVCommandQueue.m -o /Users/phonegap/Library/Developer/Xcode/DerivedData/RBBranch-eoelrkktfohkitdezostyrfmside /Build/Intermediates/ArchiveIntermediates/RBBranch/IntermediateBuildFilesPath/CordovaLib.b uild/Release-iphoneos/CordovaLib.build/Objects-normal/arm64/CDVCommandQueue.o
      CompileC /Users/phonegap/Library/Developer/Xcode/DerivedData/RBBranch-eoelrkktfohkitdezostyrfmside /Build/Intermediates/ArchiveIntermediates/RBBranch/IntermediateBuildFilesPath/CordovaLib.b uild/Release-iphoneos/CordovaLib.build/Objects-normal/arm64/NSMutableArray+QueueAdditions. o Classes/Public/NSMutableArray+QueueAdditions.m normal arm64 objective-c com.apple.compilers.llvm.clang.1_0.compiler
        /Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/bin/cl ang -x objective-c -arch arm64 -fmessage-length=0 -fdiagnostics-show-note-include-stack -fmacro-backtrace-limit=0 -std=c99 -fobjc-arc -fmodules -fmodules-cache-path=/Users/phonegap/Library/Developer/Xcode/DerivedData/ModuleCache -fmodules-prune-interval=86400 -fmodules-prune-after=345600 -fbuild-session-file=/Users/phonegap/Library/Developer/Xcode/DerivedData/ModuleCache/Sess ion.modulevalidation -fmodules-validate-once-per-build-session -Wno-trigraphs -fpascal-strings -Os -Wno-missing-field-initializers -Wno-missing-prototypes -Wno-implicit-atomic-properties -Wno-arc-repeated-use-of-weak -Wduplicate-method-match -Wno-missing-braces -Wparentheses -Wswitch -Wunused-function -Wno-unused-label -Wno-unused-parameter -Wunused-variable -Wunused-value -Wempty-body -Wuninitialized -Wno-unknown-pragmas -Wno-shadow -Wno-four-char-constants -Wno-conversion -Wconstant-conversion -Wint-conversion -Wbool-conversion -Wenum-conversion -Wshorten-64-to-32 -Wpointer-sign -Wno-newline-eof -Wno-selector -Wno-strict-selector-match -Wundeclared-selector -Wno-deprecated-implementations -isysroot /Applications/Xcode.app/Contents/Developer/Platforms/iPhoneOS.platform/Developer/SDKs/iPh oneOS10.1.sdk -fstrict-aliasing -Wprotocol -Wdeprecated-declarations -miphoneos-version-min=8.0 -g -Wno-sign-conversion -Wno-infinite-recursion -iquote /Users/phonegap/Library/Developer/Xcode/DerivedData/RBBranch-eoelrkktfohkitdezostyrfmside /Build/Intermediates/ArchiveIntermediates/RBBranch/IntermediateBuildFilesPath/CordovaLib.b uild/Release-iphoneos/CordovaLib.build/Cordova-generated-files.hmap -I/Users/phonegap/Library/Developer/Xcode/DerivedData/RBBranch-eoelrkktfohkitdezostyrfmsi de/Build/Intermediates/ArchiveIntermediates/RBBranch/IntermediateBuildFilesPath/CordovaLib .build/Release-iphoneos/CordovaLib.build/Cordova-own-target-headers.hmap -I/Users/phonegap/Library/Developer/Xcode/DerivedData/RBBranch-eoelrkktfohkitdezostyrfmsi de/Build/Intermediates/ArchiveIntermediates/RBBranch/IntermediateBuildFilesPath/CordovaLib .build/Release-iphoneos/CordovaLib.build/Cordova-all-target-headers.hmap -iquote /Users/phonegap/Library/Developer/Xcode/DerivedData/RBBranch-eoelrkktfohkitdezostyrfmside /Build/Intermediates/ArchiveIntermediates/RBBranch/IntermediateBuildFilesPath/CordovaLib.b uild/Release-iphoneos/CordovaLib.build/Cordova-project-headers.hmap -I/tmp/gimlet/1645041/project/build/include -I/Users/phonegap/Library/Developer/Xcode/DerivedData/RBBranch-eoelrkktfohkitdezostyrfmsi de/Build/Intermediates/ArchiveIntermediates/RBBranch/IntermediateBuildFilesPath/Uninstalle dProducts/iphoneos/usr/local/lib/include -I/Users/phonegap/Library/Developer/Xcode/DerivedData/RBBranch-eoelrkktfohkitdezostyrfmsi de/Build/Intermediates/ArchiveIntermediates/RBBranch/IntermediateBuildFilesPath/Uninstalle dProducts/include -I/Users/phonegap/Library/Developer/Xcode/DerivedData/RBBranch-eoelrkktfohkitdezostyrfmsi de/Build/Intermediates/ArchiveIntermediates/RBBranch/IntermediateBuildFilesPath/Uninstalle dProducts/iphoneos/include -I/tmp/gimlet/1645041/project/build -I/Users/phonegap/Library/Developer/Xcode/DerivedData/RBBranch-eoelrkktfohkitdezostyrfmsi de/Build/Intermediates/ArchiveIntermediates/RBBranch/IntermediateBuildFilesPath/CordovaLib .build/Release-iphoneos/CordovaLib.build/DerivedSources/arm64 -I/Users/phonegap/Library/Developer/Xcode/DerivedData/RBBranch-eoelrkktfohkitdezostyrfmsi de/Build/Intermediates/ArchiveIntermediates/RBBranch/IntermediateBuildFilesPath/CordovaLib .build/Release-iphoneos/CordovaLib.build/DerivedSources -F/tmp/gimlet/1645041/project/build -include /private/tmp/gimlet/1645041/project/build/sharedpch/CordovaLib_Prefix-hagqdysfamtkhngolen foajtzops/CordovaLib_Prefix.pch -MMD -MT dependencies -MF /Users/phonegap/Library/Developer/Xcode/DerivedData/RBBranch-eoelrkktfohkitdezostyrfmside /Build/Intermediates/ArchiveIntermediates/RBBranch/IntermediateBuildFilesPath/CordovaLib.b uild/Release-iphoneos/CordovaLib.build/Objects-normal/arm64/NSMutableArray+QueueAdditions. d --serialize-diagnostics /Users/phonegap/Library/Developer/Xcode/DerivedData/RBBranch-eoelrkktfohkitdezostyrfmside /Build/Intermediates/ArchiveIntermediates/RBBranch/IntermediateBuildFilesPath/CordovaLib.b uild/Release-iphoneos/CordovaLib.build/Objects-normal/arm64/NSMutableArray+QueueAdditions. dia -c /tmp/gimlet/1645041/project/CordovaLib/Classes/Public/NSMutableArray+QueueAdditions.m -o /Users/phonegap/Library/Developer/Xcode/DerivedData/RBBranch-eoelrkktfohkitdezostyrfmside /Build/Intermediates/ArchiveIntermediates/RBBranch/IntermediateBuildFilesPath/CordovaLib.b uild/Release-iphoneos/CordovaLib.build/Objects-normal/arm64/NSMutableArray+QueueAdditions. o
      CompileC /Users/phonegap/Library/Developer/Xcode/DerivedData/RBBranch-eoelrkktfohkitdezostyrfmside /Build/Intermediates/ArchiveIntermediates/RBBranch/IntermediateBuildFilesPath/CordovaLib.b uild/Release-iphoneos/CordovaLib.build/Objects-normal/arm64/CDVPlugin+Resources.o Classes/Public/CDVPlugin+Resources.m normal arm64 objective-c com.apple.compilers.llvm.clang.1_0.compiler
        /Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/bin/cl ang -x objective-c -arch arm64 -fmessage-length=0 -fdiagnostics-show-note-include-stack -fmacro-backtrace-limit=0 -std=c99 -fobjc-arc -fmodules -fmodules-cache-path=/Users/phonegap/Library/Developer/Xcode/DerivedData/ModuleCache -fmodules-prune-interval=86400 -fmodules-prune-after=345600 -fbuild-session-file=/Users/phonegap/Library/Developer/Xcode/DerivedData/ModuleCache/Sess ion.modulevalidation -fmodules-validate-once-per-build-session -Wno-trigraphs -fpascal-strings -Os -Wno-missing-field-initializers -Wno-missing-prototypes -Wno-implicit-atomic-properties -Wno-arc-repeated-use-of-weak -Wduplicate-method-match -Wno-missing-braces -Wparentheses -Wswitch -Wunused-function -Wno-unused-label -Wno-unused-parameter -Wunused-variable -Wunused-value -Wempty-body -Wuninitialized -Wno-unknown-pragmas -Wno-shadow -Wno-four-char-constants -Wno-conversion -Wconstant-conversion -Wint-conversion -Wbool-conversion -Wenum-conversion -Wshorten-64-to-32 -Wpointer-sign -Wno-newline-eof -Wno-selector -Wno-strict-selector-match -Wundeclared-selector -Wno-deprecated-implementations -isysroot /Applications/Xcode.app/Contents/Developer/Platforms/iPhoneOS.platform/Developer/SDKs/iPh oneOS10.1.sdk -fstrict-aliasing -Wprotocol -Wdeprecated-declarations -miphoneos-version-min=8.0 -g -Wno-sign-conversion -Wno-infinite-recursion -iquote /Users/phonegap/Library/Developer/Xcode/DerivedData/RBBranch-eoelrkktfohkitdezostyrfmside /Build/Intermediates/ArchiveIntermediates/RBBranch/IntermediateBuildFilesPath/CordovaLib.b uild/Release-iphoneos/CordovaLib.build/Cordova-generated-files.hmap -I/Users/phonegap/Library/Developer/Xcode/DerivedData/RBBranch-eoelrkktfohkitdezostyrfmsi de/Build/Intermediates/ArchiveIntermediates/RBBranch/IntermediateBuildFilesPath/CordovaLib .build/Release-iphoneos/CordovaLib.build/Cordova-own-target-headers.hmap -I/Users/phonegap/Library/Developer/Xcode/DerivedData/RBBranch-eoelrkktfohkitdezostyrfmsi de/Build/Intermediates/ArchiveIntermediates/RBBranch/IntermediateBuildFilesPath/CordovaLib .build/Release-iphoneos/CordovaLib.build/Cordova-all-target-headers.hmap -iquote /Users/phonegap/Library/Developer/Xcode/DerivedData/RBBranch-eoelrkktfohkitdezostyrfmside /Build/Intermediates/ArchiveIntermediates/RBBranch/IntermediateBuildFilesPath/CordovaLib.b uild/Release-iphoneos/CordovaLib.build/Cordova-project-headers.hmap -I/tmp/gimlet/1645041/project/build/include -I/Users/phonegap/Library/Developer/Xcode/DerivedData/RBBranch-eoelrkktfohkitdezostyrfmsi de/Build/Intermediates/ArchiveIntermediates/RBBranch/IntermediateBuildFilesPath/Uninstalle dProducts/iphoneos/usr/local/lib/include -I/Users/phonegap/Library/Developer/Xcode/DerivedData/RBBranch-eoelrkktfohkitdezostyrfmsi de/Build/Intermediates/ArchiveIntermediates/RBBranch/IntermediateBuildFilesPath/Uninstalle dProducts/include -I/Users/phonegap/Library/Developer/Xcode/DerivedData/RBBranch-eoelrkktfohkitdezostyrfmsi de/Build/Intermediates/ArchiveIntermediates/RBBranch/IntermediateBuildFilesPath/Uninstalle dProducts/iphoneos/include -I/tmp/gimlet/1645041/project/build -I/Users/phonegap/Library/Developer/Xcode/DerivedData/RBBranch-eoelrkktfohkitdezostyrfmsi de/Build/Intermediates/ArchiveIntermediates/RBBranch/IntermediateBuildFilesPath/CordovaLib .build/Release-iphoneos/CordovaLib.build/DerivedSources/arm64 -I/Users/phonegap/Library/Developer/Xcode/DerivedData/RBBranch-eoelrkktfohkitdezostyrfmsi de/Build/Intermediates/ArchiveIntermediates/RBBranch/IntermediateBuildFilesPath/CordovaLib .build/Release-iphoneos/CordovaLib.build/DerivedSources -F/tmp/gimlet/1645041/project/build -include /private/tmp/gimlet/1645041/project/build/sharedpch/CordovaLib_Prefix-hagqdysfamtkhngolen foajtzops/CordovaLib_Prefix.pch -MMD -MT dependencies -MF /Users/phonegap/Library/Developer/Xcode/DerivedData/RBBranch-eoelrkktfohkitdezostyrfmside /Build/Intermediates/ArchiveIntermediates/RBBranch/IntermediateBuildFilesPath/CordovaLib.b uild/Release-iphoneos/CordovaLib.build/Objects-normal/arm64/CDVPlugin+Resources.d --serialize-diagnostics /Users/phonegap/Library/Developer/Xcode/DerivedData/RBBranch-eoelrkktfohkitdezostyrfmside /Build/Intermediates/ArchiveIntermediates/RBBranch/IntermediateBuildFilesPath/CordovaLib.b uild/Release-iphoneos/CordovaLib.build/Objects-normal/arm64/CDVPlugin+Resources.dia -c /tmp/gimlet/1645041/project/CordovaLib/Classes/Public/CDVPlugin+Resources.m -o /Users/phonegap/Library/Developer/Xcode/DerivedData/RBBranch-eoelrkktfohkitdezostyrfmside /Build/Intermediates/ArchiveIntermediates/RBBranch/IntermediateBuildFilesPath/CordovaLib.b uild/Release-iphoneos/CordovaLib.build/Objects-normal/arm64/CDVPlugin+Resources.o
      CompileC /Users/phonegap/Library/Developer/Xcode/DerivedData/RBBranch-eoelrkktfohkitdezostyrfmside /Build/Intermediates/ArchiveIntermediates/RBBranch/IntermediateBuildFilesPath/CordovaLib.b uild/Release-iphoneos/CordovaLib.build/Objects-normal/arm64/CDVURLProtocol.o Classes/Public/CDVURLProtocol.m normal arm64 objective-c com.apple.compilers.llvm.clang.1_0.compiler
        /Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/bin/cl ang -x objective-c -arch arm64 -fmessage-length=0 -fdiagnostics-show-note-include-stack -fmacro-backtrace-limit=0 -std=c99 -fobjc-arc -fmodules -fmodules-cache-path=/Users/phonegap/Library/Developer/Xcode/DerivedData/ModuleCache -fmodules-prune-interval=86400 -fmodules-prune-after=345600 -fbuild-session-file=/Users/phonegap/Library/Developer/Xcode/DerivedData/ModuleCache/Sess ion.modulevalidation -fmodules-validate-once-per-build-session -Wno-trigraphs -fpascal-strings -Os -Wno-missing-field-initializers -Wno-missing-prototypes -Wno-implicit-atomic-properties -Wno-arc-repeated-use-of-weak -Wduplicate-method-match -Wno-missing-braces -Wparentheses -Wswitch -Wunused-function -Wno-unused-label -Wno-unused-parameter -Wunused-variable -Wunused-value -Wempty-body -Wuninitialized -Wno-unknown-pragmas -Wno-shadow -Wno-four-char-constants -Wno-conversion -Wconstant-conversion -Wint-conversion -Wbool-conversion -Wenum-conversion -Wshorten-64-to-32 -Wpointer-sign -Wno-newline-eof -Wno-selector -Wno-strict-selector-match -Wundeclared-selector -Wno-deprecated-implementations -isysroot /Applications/Xcode.app/Contents/Developer/Platforms/iPhoneOS.platform/Developer/SDKs/iPh oneOS10.1.sdk -fstrict-aliasing -Wprotocol -Wdeprecated-declarations -miphoneos-version-min=8.0 -g -Wno-sign-conversion -Wno-infinite-recursion -iquote /Users/phonegap/Library/Developer/Xcode/DerivedData/RBBranch-eoelrkktfohkitdezostyrfmside /Build/Intermediates/ArchiveIntermediates/RBBranch/IntermediateBuildFilesPath/CordovaLib.b uild/Release-iphoneos/CordovaLib.build/Cordova-generated-files.hmap -I/Users/phonegap/Library/Developer/Xcode/DerivedData/RBBranch-eoelrkktfohkitdezostyrfmsi de/Build/Intermediates/ArchiveIntermediates/RBBranch/IntermediateBuildFilesPath/CordovaLib .build/Release-iphoneos/CordovaLib.build/Cordova-own-target-headers.hmap -I/Users/phonegap/Library/Developer/Xcode/DerivedData/RBBranch-eoelrkktfohkitdezostyrfmsi de/Build/Intermediates/ArchiveIntermediates/RBBranch/IntermediateBuildFilesPath/CordovaLib .build/Release-iphoneos/CordovaLib.build/Cordova-all-target-headers.hmap -iquote /Users/phonegap/Library/Developer/Xcode/DerivedData/RBBranch-eoelrkktfohkitdezostyrfmside /Build/Intermediates/ArchiveIntermediates/RBBranch/IntermediateBuildFilesPath/CordovaLib.b uild/Release-iphoneos/CordovaLib.build/Cordova-project-headers.hmap -I/tmp/gimlet/1645041/project/build/include -I/Users/phonegap/Library/Developer/Xcode/DerivedData/RBBranch-eoelrkktfohkitdezostyrfmsi de/Build/Intermediates/ArchiveIntermediates/RBBranch/IntermediateBuildFilesPath/Uninstalle dProducts/iphoneos/usr/local/lib/include -I/Users/phonegap/Library/Developer/Xcode/DerivedData/RBBranch-eoelrkktfohkitdezostyrfmsi de/Build/Intermediates/ArchiveIntermediates/RBBranch/IntermediateBuildFilesPath/Uninstalle dProducts/include -I/Users/phonegap/Library/Developer/Xcode/DerivedData/RBBranch-eoelrkktfohkitdezostyrfmsi de/Build/Intermediates/ArchiveIntermediates/RBBranch/IntermediateBuildFilesPath/Uninstalle dProducts/iphoneos/include -I/tmp/gimlet/1645041/project/build -I/Users/phonegap/Library/Developer/Xcode/DerivedData/RBBranch-eoelrkktfohkitdezostyrfmsi de/Build/Intermediates/ArchiveIntermediates/RBBranch/IntermediateBuildFilesPath/CordovaLib .build/Release-iphoneos/CordovaLib.build/DerivedSources/arm64 -I/Users/phonegap/Library/Developer/Xcode/DerivedData/RBBranch-eoelrkktfohkitdezostyrfmsi de/Build/Intermediates/ArchiveIntermediates/RBBranch/IntermediateBuildFilesPath/CordovaLib .build/Release-iphoneos/CordovaLib.build/DerivedSources -F/tmp/gimlet/1645041/project/build -include /private/tmp/gimlet/1645041/project/build/sharedpch/CordovaLib_Prefix-hagqdysfamtkhngolen foajtzops/CordovaLib_Prefix.pch -MMD -MT dependencies -MF /Users/phonegap/Library/Developer/Xcode/DerivedData/RBBranch-eoelrkktfohkitdezostyrfmside /Build/Intermediates/ArchiveIntermediates/RBBranch/IntermediateBuildFilesPath/CordovaLib.b uild/Release-iphoneos/CordovaLib.build/Objects-normal/arm64/CDVURLProtocol.d --serialize-diagnostics /Users/phonegap/Library/Developer/Xcode/DerivedData/RBBranch-eoelrkktfohkitdezostyrfmside /Build/Intermediates/ArchiveIntermediates/RBBranch/IntermediateBuildFilesPath/CordovaLib.b uild/Release-iphoneos/CordovaLib.build/Objects-normal/arm64/CDVURLProtocol.dia -c /tmp/gimlet/1645041/project/CordovaLib/Classes/Public/CDVURLProtocol.m -o /Users/phonegap/Library/Developer/Xcode/DerivedData/RBBranch-eoelrkktfohkitdezostyrfmside /Build/Intermediates/ArchiveIntermediates/RBBranch/IntermediateBuildFilesPath/CordovaLib.b uild/Release-iphoneos/CordovaLib.build/Objects-normal/arm64/CDVURLProtocol.o
      CompileC /Users/phonegap/Library/Developer/Xcode/DerivedData/RBBranch-eoelrkktfohkitdezostyrfmside /Build/Intermediates/ArchiveIntermediates/RBBranch/IntermediateBuildFilesPath/CordovaLib.b uild/Release-iphoneos/CordovaLib.build/Objects-normal/arm64/CDVUIWebViewEngine.o Classes/Private/Plugins/CDVUIWebViewEngine/CDVUIWebViewEngine.m normal arm64 objective-c com.apple.compilers.llvm.clang.1_0.compiler
        /Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/bin/cl ang -x objective-c -arch arm64 -fmessage-length=0 -fdiagnostics-show-note-include-stack -fmacro-backtrace-limit=0 -std=c99 -fobjc-arc -fmodules -fmodules-cache-path=/Users/phonegap/Library/Developer/Xcode/DerivedData/ModuleCache -fmodules-prune-interval=86400 -fmodules-prune-after=345600 -fbuild-session-file=/Users/phonegap/Library/Developer/Xcode/DerivedData/ModuleCache/Sess ion.modulevalidation -fmodules-validate-once-per-build-session -Wno-trigraphs -fpascal-strings -Os -Wno-missing-field-initializers -Wno-missing-prototypes -Wno-implicit-atomic-properties -Wno-arc-repeated-use-of-weak -Wduplicate-method-match -Wno-missing-braces -Wparentheses -Wswitch -Wunused-function -Wno-unused-label -Wno-unused-parameter -Wunused-variable -Wunused-value -Wempty-body -Wuninitialized -Wno-unknown-pragmas -Wno-shadow -Wno-four-char-constants -Wno-conversion -Wconstant-conversion -Wint-conversion -Wbool-conversion -Wenum-conversion -Wshorten-64-to-32 -Wpointer-sign -Wno-newline-eof -Wno-selector -Wno-strict-selector-match -Wundeclared-selector -Wno-deprecated-implementations -isysroot /Applications/Xcode.app/Contents/Developer/Platforms/iPhoneOS.platform/Developer/SDKs/iPh oneOS10.1.sdk -fstrict-aliasing -Wprotocol -Wdeprecated-declarations -miphoneos-version-min=8.0 -g -Wno-sign-conversion -Wno-infinite-recursion -iquote /Users/phonegap/Library/Developer/Xcode/DerivedData/RBBranch-eoelrkktfohkitdezostyrfmside /Build/Intermediates/ArchiveIntermediates/RBBranch/IntermediateBuildFilesPath/CordovaLib.b uild/Release-iphoneos/CordovaLib.build/Cordova-generated-files.hmap -I/Users/phonegap/Library/Developer/Xcode/DerivedData/RBBranch-eoelrkktfohkitdezostyrfmsi de/Build/Intermediates/ArchiveIntermediates/RBBranch/IntermediateBuildFilesPath/CordovaLib .build/Release-iphoneos/CordovaLib.build/Cordova-own-target-headers.hmap -I/Users/phonegap/Library/Developer/Xcode/DerivedData/RBBranch-eoelrkktfohkitdezostyrfmsi de/Build/Intermediates/ArchiveIntermediates/RBBranch/IntermediateBuildFilesPath/CordovaLib .build/Release-iphoneos/CordovaLib.build/Cordova-all-target-headers.hmap -iquote /Users/phonegap/Library/Developer/Xcode/DerivedData/RBBranch-eoelrkktfohkitdezostyrfmside /Build/Intermediates/ArchiveIntermediates/RBBranch/IntermediateBuildFilesPath/CordovaLib.b uild/Release-iphoneos/CordovaLib.build/Cordova-project-headers.hmap -I/tmp/gimlet/1645041/project/build/include -I/Users/phonegap/Library/Developer/Xcode/DerivedData/RBBranch-eoelrkktfohkitdezostyrfmsi de/Build/Intermediates/ArchiveIntermediates/RBBranch/IntermediateBuildFilesPath/Uninstalle dProducts/iphoneos/usr/local/lib/include -I/Users/phonegap/Library/Developer/Xcode/DerivedData/RBBranch-eoelrkktfohkitdezostyrfmsi de/Build/Intermediates/ArchiveIntermediates/RBBranch/IntermediateBuildFilesPath/Uninstalle dProducts/include -I/Users/phonegap/Library/Developer/Xcode/DerivedData/RBBranch-eoelrkktfohkitdezostyrfmsi de/Build/Intermediates/ArchiveIntermediates/RBBranch/IntermediateBuildFilesPath/Uninstalle dProducts/iphoneos/include -I/tmp/gimlet/1645041/project/build -I/Users/phonegap/Library/Developer/Xcode/DerivedData/RBBranch-eoelrkktfohkitdezostyrfmsi de/Build/Intermediates/ArchiveIntermediates/RBBranch/IntermediateBuildFilesPath/CordovaLib .build/Release-iphoneos/CordovaLib.build/DerivedSources/arm64 -I/Users/phonegap/Library/Developer/Xcode/DerivedData/RBBranch-eoelrkktfohkitdezostyrfmsi de/Build/Intermediates/ArchiveIntermediates/RBBranch/IntermediateBuildFilesPath/CordovaLib .build/Release-iphoneos/CordovaLib.build/DerivedSources -F/tmp/gimlet/1645041/project/build -include /private/tmp/gimlet/1645041/project/build/sharedpch/CordovaLib_Prefix-hagqdysfamtkhngolen foajtzops/CordovaLib_Prefix.pch -MMD -MT dependencies -MF /Users/phonegap/Library/Developer/Xcode/DerivedData/RBBranch-eoelrkktfohkitdezostyrfmside /Build/Intermediates/ArchiveIntermediates/RBBranch/IntermediateBuildFilesPath/CordovaLib.b uild/Release-iphoneos/CordovaLib.build/Objects-normal/arm64/CDVUIWebViewEngine.d --serialize-diagnostics /Users/phonegap/Library/Developer/Xcode/DerivedData/RBBranch-eoelrkktfohkitdezostyrfmside /Build/Intermediates/ArchiveIntermediates/RBBranch/IntermediateBuildFilesPath/CordovaLib.b uild/Release-iphoneos/CordovaLib.build/Objects-normal/arm64/CDVUIWebViewEngine.dia -c /tmp/gimlet/1645041/project/CordovaLib/Classes/Private/Plugins/CDVUIWebViewEngine/CDVUIWe bViewEngine.m -o /Users/phonegap/Library/Developer/Xcode/DerivedData/RBBranch-eoelrkktfohkitdezostyrfmside /Build/Intermediates/ArchiveIntermediates/RBBranch/IntermediateBuildFilesPath/CordovaLib.b uild/Release-iphoneos/CordovaLib.build/Objects-normal/arm64/CDVUIWebViewEngine.o
      CompileC /Users/phonegap/Library/Developer/Xcode/DerivedData/RBBranch-eoelrkktfohkitdezostyrfmside /Build/Intermediates/ArchiveIntermediates/RBBranch/IntermediateBuildFilesPath/CordovaLib.b uild/Release-iphoneos/CordovaLib.build/Objects-normal/arm64/CDVPlugin.o Classes/Public/CDVPlugin.m normal arm64 objective-c com.apple.compilers.llvm.clang.1_0.compiler
        cd /tmp/gimlet/1645041/project/CordovaLib
        /Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/bin/cl ang -x objective-c -arch arm64 -fmessage-length=0 -fdiagnostics-show-note-include-stack -fmacro-backtrace-limit=0 -std=c99 -fobjc-arc -fmodules -fmodules-cache-path=/Users/phonegap/Library/Developer/Xcode/DerivedData/ModuleCache -fmodules-prune-interval=86400 -fmodules-prune-after=345600 -fbuild-session-file=/Users/phonegap/Library/Developer/Xcode/DerivedData/ModuleCache/Sess ion.modulevalidation -fmodules-validate-once-per-build-session -Wno-trigraphs -fpascal-strings -Os -Wno-missing-field-initializers -Wno-missing-prototypes -Wno-implicit-atomic-properties -Wno-arc-repeated-use-of-weak -Wduplicate-method-match -Wno-missing-braces -Wparentheses -Wswitch -Wunused-function -Wno-unused-label -Wno-unused-parameter -Wunused-variable -Wunused-value -Wempty-body -Wuninitialized -Wno-unknown-pragmas -Wno-shadow -Wno-four-char-constants -Wno-conversion -Wconstant-conversion -Wint-conversion -Wbool-conversion -Wenum-conversion -Wshorten-64-to-32 -Wpointer-sign -Wno-newline-eof -Wno-selector -Wno-strict-selector-match -Wundeclared-selector -Wno-deprecated-implementations -isysroot /Applications/Xcode.app/Contents/Developer/Platforms/iPhoneOS.platform/Developer/SDKs/iPh oneOS10.1.sdk -fstrict-aliasing -Wprotocol -Wdeprecated-declarations -miphoneos-version-min=8.0 -g -Wno-sign-conversion -Wno-infinite-recursion -iquote /Users/phonegap/Library/Developer/Xcode/DerivedData/RBBranch-eoelrkktfohkitdezostyrfmside /Build/Intermediates/ArchiveIntermediates/RBBranch/IntermediateBuildFilesPath/CordovaLib.b uild/Release-iphoneos/CordovaLib.build/Cordova-generated-files.hmap -I/Users/phonegap/Library/Developer/Xcode/DerivedData/RBBranch-eoelrkktfohkitdezostyrfmsi de/Build/Intermediates/ArchiveIntermediates/RBBranch/IntermediateBuildFilesPath/CordovaLib .build/Release-iphoneos/CordovaLib.build/Cordova-own-target-headers.hmap -I/Users/phonegap/Library/Developer/Xcode/DerivedData/RBBranch-eoelrkktfohkitdezostyrfmsi de/Build/Intermediates/ArchiveIntermediates/RBBranch/IntermediateBuildFilesPath/CordovaLib .build/Release-iphoneos/CordovaLib.build/Cordova-all-target-headers.hmap -iquote /Users/phonegap/Library/Developer/Xcode/DerivedData/RBBranch-eoelrkktfohkitdezostyrfmside /Build/Intermediates/ArchiveIntermediates/RBBranch/IntermediateBuildFilesPath/CordovaLib.b uild/Release-iphoneos/CordovaLib.build/Cordova-project-headers.hmap -I/tmp/gimlet/1645041/project/build/include -I/Users/phonegap/Library/Developer/Xcode/DerivedData/RBBranch-eoelrkktfohkitdezostyrfmsi de/Build/Intermediates/ArchiveIntermediates/RBBranch/IntermediateBuildFilesPath/Uninstalle dProducts/iphoneos/usr/local/lib/include -I/Users/phonegap/Library/Developer/Xcode/DerivedData/RBBranch-eoelrkktfohkitdezostyrfmsi de/Build/Intermediates/ArchiveIntermediates/RBBranch/IntermediateBuildFilesPath/Uninstalle dProducts/include -I/Users/phonegap/Library/Developer/Xcode/DerivedData/RBBranch-eoelrkktfohkitdezostyrfmsi de/Build/Intermediates/ArchiveIntermediates/RBBranch/IntermediateBuildFilesPath/Uninstalle dProducts/iphoneos/include -I/tmp/gimlet/1645041/project/build -I/Users/phonegap/Library/Developer/Xcode/DerivedData/RBBranch-eoelrkktfohkitdezostyrfmsi de/Build/Intermediates/ArchiveIntermediates/RBBranch/IntermediateBuildFilesPath/CordovaLib .build/Release-iphoneos/CordovaLib.build/DerivedSources/arm64 -I/Users/phonegap/Library/Developer/Xcode/DerivedData/RBBranch-eoelrkktfohkitdezostyrfmsi de/Build/Intermediates/ArchiveIntermediates/RBBranch/IntermediateBuildFilesPath/CordovaLib .build/Release-iphoneos/CordovaLib.build/DerivedSources -F/tmp/gimlet/1645041/project/build -include /private/tmp/gimlet/1645041/project/build/sharedpch/CordovaLib_Prefix-hagqdysfamtkhngolen foajtzops/CordovaLib_Prefix.pch -MMD -MT dependencies -MF /Users/phonegap/Library/Developer/Xcode/DerivedData/RBBranch-eoelrkktfohkitdezostyrfmside /Build/Intermediates/ArchiveIntermediates/RBBranch/IntermediateBuildFilesPath/CordovaLib.b uild/Release-iphoneos/CordovaLib.build/Objects-normal/arm64/CDVPlugin.d --serialize-diagnostics /Users/phonegap/Library/Developer/Xcode/DerivedData/RBBranch-eoelrkktfohkitdezostyrfmside /Build/Intermediates/ArchiveIntermediates/RBBranch/IntermediateBuildFilesPath/CordovaLib.b uild/Release-iphoneos/CordovaLib.build/Objects-normal/arm64/CDVPlugin.dia -c /tmp/gimlet/1645041/project/CordovaLib/Classes/Public/CDVPlugin.m -o /Users/phonegap/Library/Developer/Xcode/DerivedData/RBBranch-eoelrkktfohkitdezostyrfmside /Build/Intermediates/ArchiveIntermediates/RBBranch/IntermediateBuildFilesPath/CordovaLib.b uild/Release-iphoneos/CordovaLib.build/Objects-normal/arm64/CDVPlugin.o
      CompileC /Users/phonegap/Library/Developer/Xcode/DerivedData/RBBranch-eoelrkktfohkitdezostyrfmside /Build/Intermediates/ArchiveIntermediates/RBBranch/IntermediateBuildFilesPath/CordovaLib.b uild/Release-iphoneos/CordovaLib.build/Objects-normal/arm64/CDVLocalStorage.o Classes/Private/Plugins/CDVLocalStorage/CDVLocalStorage.m normal arm64 objective-c com.apple.compilers.llvm.clang.1_0.compiler
        /Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/bin/cl ang -x objective-c -arch arm64 -fmessage-length=0 -fdiagnostics-show-note-include-stack -fmacro-backtrace-limit=0 -std=c99 -fobjc-arc -fmodules -fmodules-cache-path=/Users/phonegap/Library/Developer/Xcode/DerivedData/ModuleCache -fmodules-prune-interval=86400 -fmodules-prune-after=345600 -fbuild-session-file=/Users/phonegap/Library/Developer/Xcode/DerivedData/ModuleCache/Sess ion.modulevalidation -fmodules-validate-once-per-build-session -Wno-trigraphs -fpascal-strings -Os -Wno-missing-field-initializers -Wno-missing-prototypes -Wno-implicit-atomic-properties -Wno-arc-repeated-use-of-weak -Wduplicate-method-match -Wno-missing-braces -Wparentheses -Wswitch -Wunused-function -Wno-unused-label -Wno-unused-parameter -Wunused-variable -Wunused-value -Wempty-body -Wuninitialized -Wno-unknown-pragmas -Wno-shadow -Wno-four-char-constants -Wno-conversion -Wconstant-conversion -Wint-conversion -Wbool-conversion -Wenum-conversion -Wshorten-64-to-32 -Wpointer-sign -Wno-newline-eof -Wno-selector -Wno-strict-selector-match -Wundeclared-selector -Wno-deprecated-implementations -isysroot /Applications/Xcode.app/Contents/Developer/Platforms/iPhoneOS.platform/Developer/SDKs/iPh oneOS10.1.sdk -fstrict-aliasing -Wprotocol -Wdeprecated-declarations -miphoneos-version-min=8.0 -g -Wno-sign-conversion -Wno-infinite-recursion -iquote /Users/phonegap/Library/Developer/Xcode/DerivedData/RBBranch-eoelrkktfohkitdezostyrfmside /Build/Intermediates/ArchiveIntermediates/RBBranch/IntermediateBuildFilesPath/CordovaLib.b uild/Release-iphoneos/CordovaLib.build/Cordova-generated-files.hmap -I/Users/phonegap/Library/Developer/Xcode/DerivedData/RBBranch-eoelrkktfohkitdezostyrfmsi de/Build/Intermediates/ArchiveIntermediates/RBBranch/IntermediateBuildFilesPath/CordovaLib .build/Release-iphoneos/CordovaLib.build/Cordova-own-target-headers.hmap -I/Users/phonegap/Library/Developer/Xcode/DerivedData/RBBranch-eoelrkktfohkitdezostyrfmsi de/Build/Intermediates/ArchiveIntermediates/RBBranch/IntermediateBuildFilesPath/CordovaLib .build/Release-iphoneos/CordovaLib.build/Cordova-all-target-headers.hmap -iquote /Users/phonegap/Library/Developer/Xcode/DerivedData/RBBranch-eoelrkktfohkitdezostyrfmside /Build/Intermediates/ArchiveIntermediates/RBBranch/IntermediateBuildFilesPath/CordovaLib.b uild/Release-iphoneos/CordovaLib.build/Cordova-project-headers.hmap -I/tmp/gimlet/1645041/project/build/include -I/Users/phonegap/Library/Developer/Xcode/DerivedData/RBBranch-eoelrkktfohkitdezostyrfmsi de/Build/Intermediates/ArchiveIntermediates/RBBranch/IntermediateBuildFilesPath/Uninstalle dProducts/iphoneos/usr/local/lib/include -I/Users/phonegap/Library/Developer/Xcode/DerivedData/RBBranch-eoelrkktfohkitdezostyrfmsi de/Build/Intermediates/ArchiveIntermediates/RBBranch/IntermediateBuildFilesPath/Uninstalle dProducts/include -I/Users/phonegap/Library/Developer/Xcode/DerivedData/RBBranch-eoelrkktfohkitdezostyrfmsi de/Build/Intermediates/ArchiveIntermediates/RBBranch/IntermediateBuildFilesPath/Uninstalle dProducts/iphoneos/include -I/tmp/gimlet/1645041/project/build -I/Users/phonegap/Library/Developer/Xcode/DerivedData/RBBranch-eoelrkktfohkitdezostyrfmsi de/Build/Intermediates/ArchiveIntermediates/RBBranch/IntermediateBuildFilesPath/CordovaLib .build/Release-iphoneos/CordovaLib.build/DerivedSources/arm64 -I/Users/phonegap/Library/Developer/Xcode/DerivedData/RBBranch-eoelrkktfohkitdezostyrfmsi de/Build/Intermediates/ArchiveIntermediates/RBBranch/IntermediateBuildFilesPath/CordovaLib .build/Release-iphoneos/CordovaLib.build/DerivedSources -F/tmp/gimlet/1645041/project/build -include /private/tmp/gimlet/1645041/project/build/sharedpch/CordovaLib_Prefix-hagqdysfamtkhngolen foajtzops/CordovaLib_Prefix.pch -MMD -MT dependencies -MF /Users/phonegap/Library/Developer/Xcode/DerivedData/RBBranch-eoelrkktfohkitdezostyrfmside /Build/Intermediates/ArchiveIntermediates/RBBranch/IntermediateBuildFilesPath/CordovaLib.b uild/Release-iphoneos/CordovaLib.build/Objects-normal/arm64/CDVLocalStorage.d --serialize-diagnostics /Users/phonegap/Library/Developer/Xcode/DerivedData/RBBranch-eoelrkktfohkitdezostyrfmside /Build/Intermediates/ArchiveIntermediates/RBBranch/IntermediateBuildFilesPath/CordovaLib.b uild/Release-iphoneos/CordovaLib.build/Objects-normal/arm64/CDVLocalStorage.dia -c /tmp/gimlet/1645041/project/CordovaLib/Classes/Private/Plugins/CDVLocalStorage/CDVLocalSt orage.m -o /Users/phonegap/Library/Developer/Xcode/DerivedData/RBBranch-eoelrkktfohkitdezostyrfmside /Build/Intermediates/ArchiveIntermediates/RBBranch/IntermediateBuildFilesPath/CordovaLib.b uild/Release-iphoneos/CordovaLib.build/Objects-normal/arm64/CDVLocalStorage.o
      CompileC /Users/phonegap/Library/Developer/Xcode/DerivedData/RBBranch-eoelrkktfohkitdezostyrfmside /Build/Intermediates/ArchiveIntermediates/RBBranch/IntermediateBuildFilesPath/CordovaLib.b uild/Release-iphoneos/CordovaLib.build/Objects-normal/arm64/CDVIntentAndNavigationFilter.o Classes/Private/Plugins/CDVIntentAndNavigationFilter/CDVIntentAndNavigationFilter.m normal arm64 objective-c com.apple.compilers.llvm.clang.1_0.compiler
        /Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/bin/cl ang -x objective-c -arch arm64 -fmessage-length=0 -fdiagnostics-show-note-include-stack -fmacro-backtrace-limit=0 -std=c99 -fobjc-arc -fmodules -fmodules-cache-path=/Users/phonegap/Library/Developer/Xcode/DerivedData/ModuleCache -fmodules-prune-interval=86400 -fmodules-prune-after=345600 -fbuild-session-file=/Users/phonegap/Library/Developer/Xcode/DerivedData/ModuleCache/Sess ion.modulevalidation -fmodules-validate-once-per-build-session -Wno-trigraphs -fpascal-strings -Os -Wno-missing-field-initializers -Wno-missing-prototypes -Wno-implicit-atomic-properties -Wno-arc-repeated-use-of-weak -Wduplicate-method-match -Wno-missing-braces -Wparentheses -Wswitch -Wunused-function -Wno-unused-label -Wno-unused-parameter -Wunused-variable -Wunused-value -Wempty-body -Wuninitialized -Wno-unknown-pragmas -Wno-shadow -Wno-four-char-constants -Wno-conversion -Wconstant-conversion -Wint-conversion -Wbool-conversion -Wenum-conversion -Wshorten-64-to-32 -Wpointer-sign -Wno-newline-eof -Wno-selector -Wno-strict-selector-match -Wundeclared-selector -Wno-deprecated-implementations -isysroot /Applications/Xcode.app/Contents/Developer/Platforms/iPhoneOS.platform/Developer/SDKs/iPh oneOS10.1.sdk -fstrict-aliasing -Wprotocol -Wdeprecated-declarations -miphoneos-version-min=8.0 -g -Wno-sign-conversion -Wno-infinite-recursion -iquote /Users/phonegap/Library/Developer/Xcode/DerivedData/RBBranch-eoelrkktfohkitdezostyrfmside /Build/Intermediates/ArchiveIntermediates/RBBranch/IntermediateBuildFilesPath/CordovaLib.b uild/Release-iphoneos/CordovaLib.build/Cordova-generated-files.hmap -I/Users/phonegap/Library/Developer/Xcode/DerivedData/RBBranch-eoelrkktfohkitdezostyrfmsi de/Build/Intermediates/ArchiveIntermediates/RBBranch/IntermediateBuildFilesPath/CordovaLib .build/Release-iphoneos/CordovaLib.build/Cordova-own-target-headers.hmap -I/Users/phonegap/Library/Developer/Xcode/DerivedData/RBBranch-eoelrkktfohkitdezostyrfmsi de/Build/Intermediates/ArchiveIntermediates/RBBranch/IntermediateBuildFilesPath/CordovaLib .build/Release-iphoneos/CordovaLib.build/Cordova-all-target-headers.hmap -iquote /Users/phonegap/Library/Developer/Xcode/DerivedData/RBBranch-eoelrkktfohkitdezostyrfmside /Build/Intermediates/ArchiveIntermediates/RBBranch/IntermediateBuildFilesPath/CordovaLib.b uild/Release-iphoneos/CordovaLib.build/Cordova-project-headers.hmap -I/tmp/gimlet/1645041/project/build/include -I/Users/phonegap/Library/Developer/Xcode/DerivedData/RBBranch-eoelrkktfohkitdezostyrfmsi de/Build/Intermediates/ArchiveIntermediates/RBBranch/IntermediateBuildFilesPath/Uninstalle dProducts/iphoneos/usr/local/lib/include -I/Users/phonegap/Library/Developer/Xcode/DerivedData/RBBranch-eoelrkktfohkitdezostyrfmsi de/Build/Intermediates/ArchiveIntermediates/RBBranch/IntermediateBuildFilesPath/Uninstalle dProducts/include -I/Users/phonegap/Library/Developer/Xcode/DerivedData/RBBranch-eoelrkktfohkitdezostyrfmsi de/Build/Intermediates/ArchiveIntermediates/RBBranch/IntermediateBuildFilesPath/Uninstalle dProducts/iphoneos/include -I/tmp/gimlet/1645041/project/build -I/Users/phonegap/Library/Developer/Xcode/DerivedData/RBBranch-eoelrkktfohkitdezostyrfmsi de/Build/Intermediates/ArchiveIntermediates/RBBranch/IntermediateBuildFilesPath/CordovaLib .build/Release-iphoneos/CordovaLib.build/DerivedSources/arm64 -I/Users/phonegap/Library/Developer/Xcode/DerivedData/RBBranch-eoelrkktfohkitdezostyrfmsi de/Build/Intermediates/ArchiveIntermediates/RBBranch/IntermediateBuildFilesPath/CordovaLib .build/Release-iphoneos/CordovaLib.build/DerivedSources -F/tmp/gimlet/1645041/project/build -include /private/tmp/gimlet/1645041/project/build/sharedpch/CordovaLib_Prefix-hagqdysfamtkhngolen foajtzops/CordovaLib_Prefix.pch -MMD -MT dependencies -MF /Users/phonegap/Library/Developer/Xcode/DerivedData/RBBranch-eoelrkktfohkitdezostyrfmside /Build/Intermediates/ArchiveIntermediates/RBBranch/IntermediateBuildFilesPath/CordovaLib.b uild/Release-iphoneos/CordovaLib.build/Objects-normal/arm64/CDVIntentAndNavigationFilter.d --serialize-diagnostics /Users/phonegap/Library/Developer/Xcode/DerivedData/RBBranch-eoelrkktfohkitdezostyrfmside /Build/Intermediates/ArchiveIntermediates/RBBranch/IntermediateBuildFilesPath/CordovaLib.b uild/Release-iphoneos/CordovaLib.build/Objects-normal/arm64/CDVIntentAndNavigationFilter.d ia -c /tmp/gimlet/1645041/project/CordovaLib/Classes/Private/Plugins/CDVIntentAndNavigationFilt er/CDVIntentAndNavigationFilter.m -o /Users/phonegap/Library/Developer/Xcode/DerivedData/RBBranch-eoelrkktfohkitdezostyrfmside /Build/Intermediates/ArchiveIntermediates/RBBranch/IntermediateBuildFilesPath/CordovaLib.b uild/Release-iphoneos/CordovaLib.build/Objects-normal/arm64/CDVIntentAndNavigationFilter.o
      Libtool /Users/phonegap/Library/Developer/Xcode/DerivedData/RBBranch-eoelrkktfohkitdezostyrfmside /Build/Intermediates/ArchiveIntermediates/RBBranch/IntermediateBuildFilesPath/CordovaLib.b uild/Release-iphoneos/CordovaLib.build/Objects-normal/arm64/libCordova.a normal arm64
        export IPHONEOS_DEPLOYMENT_TARGET=8.0
        /Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/bin/li btool -static -arch_only arm64 -syslibroot /Applications/Xcode.app/Contents/Developer/Platforms/iPhoneOS.platform/Developer/SDKs/iPh oneOS10.1.sdk -L/tmp/gimlet/1645041/project/build -filelist /Users/phonegap/Library/Developer/Xcode/DerivedData/RBBranch-eoelrkktfohkitdezostyrfmside /Build/Intermediates/ArchiveIntermediates/RBBranch/IntermediateBuildFilesPath/CordovaLib.b uild/Release-iphoneos/CordovaLib.build/Objects-normal/arm64/Cordova.LinkFileList -o /Users/phonegap/Library/Developer/Xcode/DerivedData/RBBranch-eoelrkktfohkitdezostyrfmside /Build/Intermediates/ArchiveIntermediates/RBBranch/IntermediateBuildFilesPath/CordovaLib.b uild/Release-iphoneos/CordovaLib.build/Objects-normal/arm64/libCordova.a
      Libtool /Users/phonegap/Library/Developer/Xcode/DerivedData/RBBranch-eoelrkktfohkitdezostyrfmside /Build/Intermediates/ArchiveIntermediates/RBBranch/IntermediateBuildFilesPath/CordovaLib.b uild/Release-iphoneos/CordovaLib.build/Objects-normal/armv7/libCordova.a normal armv7
        /Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/bin/li btool -static -arch_only armv7 -syslibroot /Applications/Xcode.app/Contents/Developer/Platforms/iPhoneOS.platform/Developer/SDKs/iPh oneOS10.1.sdk -L/tmp/gimlet/1645041/project/build -filelist /Users/phonegap/Library/Developer/Xcode/DerivedData/RBBranch-eoelrkktfohkitdezostyrfmside /Build/Intermediates/ArchiveIntermediates/RBBranch/IntermediateBuildFilesPath/CordovaLib.b uild/Release-iphoneos/CordovaLib.build/Objects-normal/armv7/Cordova.LinkFileList -o /Users/phonegap/Library/Developer/Xcode/DerivedData/RBBranch-eoelrkktfohkitdezostyrfmside /Build/Intermediates/ArchiveIntermediates/RBBranch/IntermediateBuildFilesPath/CordovaLib.b uild/Release-iphoneos/CordovaLib.build/Objects-normal/armv7/libCordova.a
      CreateUniversalBinary /Users/phonegap/Library/Developer/Xcode/DerivedData/RBBranch-eoelrkktfohkitdezostyrfmside /Build/Intermediates/ArchiveIntermediates/RBBranch/IntermediateBuildFilesPath/UninstalledP roducts/iphoneos/libCordova.a normal armv7\ arm64
        /Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/bin/li btool -static /Users/phonegap/Library/Developer/Xcode/DerivedData/RBBranch-eoelrkktfohkitdezostyrfmside /Build/Intermediates/ArchiveIntermediates/RBBranch/IntermediateBuildFilesPath/CordovaLib.b uild/Release-iphoneos/CordovaLib.build/Objects-normal/armv7/libCordova.a /Users/phonegap/Library/Developer/Xcode/DerivedData/RBBranch-eoelrkktfohkitdezostyrfmside /Build/Intermediates/ArchiveIntermediates/RBBranch/IntermediateBuildFilesPath/CordovaLib.b uild/Release-iphoneos/CordovaLib.build/Objects-normal/arm64/libCordova.a -o /Users/phonegap/Library/Developer/Xcode/DerivedData/RBBranch-eoelrkktfohkitdezostyrfmside /Build/Intermediates/ArchiveIntermediates/RBBranch/IntermediateBuildFilesPath/UninstalledP roducts/iphoneos/libCordova.a
      Strip /Users/phonegap/Library/Developer/Xcode/DerivedData/RBBranch-eoelrkktfohkitdezostyrfmside /Build/Intermediates/ArchiveIntermediates/RBBranch/IntermediateBuildFilesPath/UninstalledP roducts/iphoneos/libCordova.a
        /Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/bin/st rip -S /Users/phonegap/Library/Developer/Xcode/DerivedData/RBBranch-eoelrkktfohkitdezostyrfmside /Build/Intermediates/ArchiveIntermediates/RBBranch/IntermediateBuildFilesPath/UninstalledP roducts/iphoneos/libCordova.a
      SetOwnerAndGroup phonegap:staff /Users/phonegap/Library/Developer/Xcode/DerivedData/RBBranch-eoelrkktfohkitdezostyrfmside /Build/Intermediates/ArchiveIntermediates/RBBranch/IntermediateBuildFilesPath/UninstalledP roducts/iphoneos/libCordova.a
        /usr/sbin/chown -RH phonegap:staff /Users/phonegap/Library/Developer/Xcode/DerivedData/RBBranch-eoelrkktfohkitdezostyrfmside /Build/Intermediates/ArchiveIntermediates/RBBranch/IntermediateBuildFilesPath/UninstalledP roducts/iphoneos/libCordova.a
      SetMode u+w,go-w,a+rX /Users/phonegap/Library/Developer/Xcode/DerivedData/RBBranch-eoelrkktfohkitdezostyrfmside /Build/Intermediates/ArchiveIntermediates/RBBranch/IntermediateBuildFilesPath/UninstalledP roducts/iphoneos/libCordova.a
        /bin/chmod -RH u+w,go-w,a+rX /Users/phonegap/Library/Developer/Xcode/DerivedData/RBBranch-eoelrkktfohkitdezostyrfmside /Build/Intermediates/ArchiveIntermediates/RBBranch/IntermediateBuildFilesPath/UninstalledP roducts/iphoneos/libCordova.a
      === BUILD TARGET RBBranch OF PROJECT RBBranch WITH CONFIGURATION Release ===
      Check dependencies
      Write auxiliary files
      write-file /Users/phonegap/Library/Developer/Xcode/DerivedData/RBBranch-eoelrkktfohkitdezostyrfmside /Build/Intermediates/ArchiveIntermediates/RBBranch/IntermediateBuildFilesPath/RBBranch.bui ld/Release-iphoneos/RBBranch.build/RBBranch.hmap
      write-file /Users/phonegap/Library/Developer/Xcode/DerivedData/RBBranch-eoelrkktfohkitdezostyrfmside /Build/Intermediates/ArchiveIntermediates/RBBranch/IntermediateBuildFilesPath/RBBranch.bui ld/Release-iphoneos/RBBranch.build/RBBranch-all-target-headers.hmap
      write-file /Users/phonegap/Library/Developer/Xcode/DerivedData/RBBranch-eoelrkktfohkitdezostyrfmside /Build/Intermediates/ArchiveIntermediates/RBBranch/IntermediateBuildFilesPath/RBBranch.bui ld/Release-iphoneos/RBBranch.build/RBBranch-own-target-headers.hmap
      write-file /Users/phonegap/Library/Developer/Xcode/DerivedData/RBBranch-eoelrkktfohkitdezostyrfmside /Build/Intermediates/ArchiveIntermediates/RBBranch/IntermediateBuildFilesPath/RBBranch.bui ld/Release-iphoneos/RBBranch.build/RBBranch-all-non-framework-target-headers.hmap
      /bin/mkdir -p /private/tmp/gimlet/1645041/project/build/sharedpch/RBBranch-Prefix-bxipgofhldvqpyftoubeh sovzhwb
      write-file /private/tmp/gimlet/1645041/project/build/sharedpch/RBBranch-Prefix-bxipgofhldvqpyftoubeh sovzhwb/RBBranch-Prefix.pch.pch.hash-criteria
      write-file /Users/phonegap/Library/Developer/Xcode/DerivedData/RBBranch-eoelrkktfohkitdezostyrfmside /Build/Intermediates/ArchiveIntermediates/RBBranch/IntermediateBuildFilesPath/RBBranch.bui ld/Release-iphoneos/RBBranch.build/RBBranch-project-headers.hmap
      write-file /Users/phonegap/Library/Developer/Xcode/DerivedData/RBBranch-eoelrkktfohkitdezostyrfmside /Build/Intermediates/ArchiveIntermediates/RBBranch/IntermediateBuildFilesPath/RBBranch.bui ld/Release-iphoneos/RBBranch.build/Script-304B58A110DAC018002A0835.sh
      chmod 0755 /Users/phonegap/Library/Developer/Xcode/DerivedData/RBBranch-eoelrkktfohkitdezostyrfmside /Build/Intermediates/ArchiveIntermediates/RBBranch/IntermediateBuildFilesPath/RBBranch.bui ld/Release-iphoneos/RBBranch.build/Script-304B58A110DAC018002A0835.sh
      /bin/mkdir -p /private/tmp/gimlet/1645041/project/build/sharedpch/RBBranch-Prefix-bctufqggxowwjdgkckato drhjpmt
      write-file /private/tmp/gimlet/1645041/project/build/sharedpch/RBBranch-Prefix-bctufqggxowwjdgkckato drhjpmt/RBBranch-Prefix.pch.pch.hash-criteria
      /bin/mkdir -p /Users/phonegap/Library/Developer/Xcode/DerivedData/RBBranch-eoelrkktfohkitdezostyrfmside /Build/Intermediates/ArchiveIntermediates/RBBranch/IntermediateBuildFilesPath/RBBranch.bui ld/Release-iphoneos/RBBranch.build/Objects-normal/armv7
      write-file /Users/phonegap/Library/Developer/Xcode/DerivedData/RBBranch-eoelrkktfohkitdezostyrfmside /Build/Intermediates/ArchiveIntermediates/RBBranch/IntermediateBuildFilesPath/RBBranch.bui ld/Release-iphoneos/RBBranch.build/Objects-normal/armv7/RBBranch.LinkFileList
      /bin/mkdir -p /Users/phonegap/Library/Developer/Xcode/DerivedData/RBBranch-eoelrkktfohkitdezostyrfmside /Build/Intermediates/ArchiveIntermediates/RBBranch/IntermediateBuildFilesPath/RBBranch.bui ld/Release-iphoneos/RBBranch.build/Objects-normal/arm64
      write-file /Users/phonegap/Library/Developer/Xcode/DerivedData/RBBranch-eoelrkktfohkitdezostyrfmside /Build/Intermediates/ArchiveIntermediates/RBBranch/IntermediateBuildFilesPath/RBBranch.bui ld/Release-iphoneos/RBBranch.build/Objects-normal/arm64/RBBranch.LinkFileList
      write-file /Users/phonegap/Library/Developer/Xcode/DerivedData/RBBranch-eoelrkktfohkitdezostyrfmside /Build/Intermediates/ArchiveIntermediates/RBBranch/IntermediateBuildFilesPath/RBBranch.bui ld/Release-iphoneos/RBBranch.build/RBBranch-generated-files.hmap
      Create product structure
      /bin/mkdir -p /Users/phonegap/Library/Developer/Xcode/DerivedData/RBBranch-eoelrkktfohkitdezostyrfmside /Build/Intermediates/ArchiveIntermediates/RBBranch/InstallationBuildProductsLocation/Appli cations/RBBranch.app
      SymLink build/RBBranch.app /Users/phonegap/Library/Developer/Xcode/DerivedData/RBBranch-eoelrkktfohkitdezostyrfmside /Build/Intermediates/ArchiveIntermediates/RBBranch/InstallationBuildProductsLocation/Appli cations/RBBranch.app
        /bin/ln -sfh /Users/phonegap/Library/Developer/Xcode/DerivedData/RBBranch-eoelrkktfohkitdezostyrfmside /Build/Intermediates/ArchiveIntermediates/RBBranch/InstallationBuildProductsLocation/Appli cations/RBBranch.app /tmp/gimlet/1645041/project/build/RBBranch.app
      PhaseScriptExecution Copy\ www\ directory /Users/phonegap/Library/Developer/Xcode/DerivedData/RBBranch-eoelrkktfohkitdezostyrfmside /Build/Intermediates/ArchiveIntermediates/RBBranch/IntermediateBuildFilesPath/RBBranch.bui ld/Release-iphoneos/RBBranch.build/Script-304B58A110DAC018002A0835.sh
        /bin/sh -c /Users/phonegap/Library/Developer/Xcode/DerivedData/RBBranch-eoelrkktfohkitdezostyrfmside /Build/Intermediates/ArchiveIntermediates/RBBranch/IntermediateBuildFilesPath/RBBranch.bui ld/Release-iphoneos/RBBranch.build/Script-304B58A110DAC018002A0835.sh
      CopyPlistFile /Users/phonegap/Library/Developer/Xcode/DerivedData/RBBranch-eoelrkktfohkitdezostyrfmside /Build/Intermediates/ArchiveIntermediates/RBBranch/InstallationBuildProductsLocation/Appli cations/RBBranch.app/GoogleService-Info.plist RBBranch/Resources/GoogleService-Info.plist
        builtin-copyPlist --convert binary1 --outdir /Users/phonegap/Library/Developer/Xcode/DerivedData/RBBranch-eoelrkktfohkitdezostyrfmside /Build/Intermediates/ArchiveIntermediates/RBBranch/InstallationBuildProductsLocation/Appli cations/RBBranch.app -- RBBranch/Resources/GoogleService-Info.plist
      CompileXIB RBBranch/Classes/MainViewController.xib
        export XCODE_DEVELOPER_USR_PATH=/Applications/Xcode.app/Contents/Developer/usr/bin/..
        /Applications/Xcode.app/Contents/Developer/usr/bin/ibtool --errors --warnings --notices --module RBBranch --output-partial-info-plist /Users/phonegap/Library/Developer/Xcode/DerivedData/RBBranch-eoelrkktfohkitdezostyrfmside /Build/Intermediates/ArchiveIntermediates/RBBranch/IntermediateBuildFilesPath/RBBranch.bui ld/Release-iphoneos/RBBranch.build/MainViewController-PartialInfo.plist --auto-activate-custom-fonts --target-device iphone --minimum-deployment-target 8.0 --output-format human-readable-text --compile /Users/phonegap/Library/Developer/Xcode/DerivedData/RBBranch-eoelrkktfohkitdezostyrfmside /Build/Intermediates/ArchiveIntermediates/RBBranch/InstallationBuildProductsLocation/Appli cations/RBBranch.app/MainViewController.nib /tmp/gimlet/1645041/project/RBBranch/Classes/MainViewController.xib
      CompileStoryboard RBBranch/CDVLaunchScreen.storyboard
        /Applications/Xcode.app/Contents/Developer/usr/bin/ibtool --errors --warnings --notices --module RBBranch --output-partial-info-plist /Users/phonegap/Library/Developer/Xcode/DerivedData/RBBranch-eoelrkktfohkitdezostyrfmside /Build/Intermediates/ArchiveIntermediates/RBBranch/IntermediateBuildFilesPath/RBBranch.bui ld/Release-iphoneos/RBBranch.build/CDVLaunchScreen-SBPartialInfo.plist --auto-activate-custom-fonts --target-device iphone --minimum-deployment-target 8.0 --output-format human-readable-text --compilation-directory /Users/phonegap/Library/Developer/Xcode/DerivedData/RBBranch-eoelrkktfohkitdezostyrfmside /Build/Intermediates/ArchiveIntermediates/RBBranch/IntermediateBuildFilesPath/RBBranch.bui ld/Release-iphoneos/RBBranch.build /tmp/gimlet/1645041/project/RBBranch/CDVLaunchScreen.storyboard
      CompileAssetCatalog /Users/phonegap/Library/Developer/Xcode/DerivedData/RBBranch-eoelrkktfohkitdezostyrfmside /Build/Intermediates/ArchiveIntermediates/RBBranch/InstallationBuildProductsLocation/Appli cations/RBBranch.app RBBranch/Images.xcassets
        /Applications/Xcode.app/Contents/Developer/usr/bin/actool --output-format human-readable-text --notices --warnings --export-dependency-info /Users/phonegap/Library/Developer/Xcode/DerivedData/RBBranch-eoelrkktfohkitdezostyrfmside /Build/Intermediates/ArchiveIntermediates/RBBranch/IntermediateBuildFilesPath/RBBranch.bui ld/Release-iphoneos/RBBranch.build/assetcatalog_dependencies --output-partial-info-plist /Users/phonegap/Library/Developer/Xcode/DerivedData/RBBranch-eoelrkktfohkitdezostyrfmside /Build/Intermediates/ArchiveIntermediates/RBBranch/IntermediateBuildFilesPath/RBBranch.bui ld/Release-iphoneos/RBBranch.build/assetcatalog_generated_info.plist --app-icon AppIcon --launch-image LaunchImage --compress-pngs --enable-on-demand-resources YES --sticker-pack-identifier-prefix .sticker-pack. --target-device iphone --minimum-deployment-target 8.0 --platform iphoneos --product-type com.apple.product-type.application --compile /Users/phonegap/Library/Developer/Xcode/DerivedData/RBBranch-eoelrkktfohkitdezostyrfmside /Build/Intermediates/ArchiveIntermediates/RBBranch/InstallationBuildProductsLocation/Appli cations/RBBranch.app /tmp/gimlet/1645041/project/RBBranch/Images.xcassets
      /* com.apple.actool.document.notices */
      /tmp/gimlet/1645041/project/RBBranch/Images.xcassets:./AppIcon.appiconset/[][iphone][57x57 ][][][1x]: notice: 57x57 app icons only apply to iPhone apps targeting releases of iOS prior to 7.0
      /tmp/gimlet/1645041/project/RBBranch/Images.xcassets:./AppIcon.appiconset/[][iphone][57x57 ][][][2x]: notice: 57x57@2x app icons only apply to iPhone apps targeting releases of iOS prior to 7.0
      /tmp/gimlet/1645041/project/RBBranch/Images.xcassets:./LaunchImage.launchimage/[iphone][][ 1x][portrait][full-screen][]: notice: This launch image only applies to iOS 6.x and prior but the minimum deployment is 7.0 or later.
      /tmp/gimlet/1645041/project/RBBranch/Images.xcassets:./LaunchImage.launchimage/[iphone][][ 2x][portrait][full-screen][]: notice: This launch image only applies to iOS 6.x and prior but the minimum deployment is 7.0 or later.
      /tmp/gimlet/1645041/project/RBBranch/Images.xcassets:./LaunchImage.launchimage/[iphone][re tina4][2x][portrait][full-screen][]: notice: This launch image only applies to iOS 6.x and prior but the minimum deployment is 7.0 or later.
      /tmp/gimlet/1645041/project/RBBranch/Images.xcassets:./LaunchImage.launchimage/[iphone][73 6h][3x][portrait][full-screen][8.0]: notice: This launch image only applies to iOS 6.x and prior but the minimum deployment is 7.0 or later.
      /tmp/gimlet/1645041/project/RBBranch/Images.xcassets:./LaunchImage.launchimage/[iphone][73 6h][3x][landscape][full-screen][8.0]: notice: This launch image only applies to iOS 6.x and prior but the minimum deployment is 7.0 or later.
      /tmp/gimlet/1645041/project/RBBranch/Images.xcassets:./LaunchImage.launchimage/[iphone][66 7h][2x][portrait][full-screen][8.0]: notice: This launch image only applies to iOS 6.x and prior but the minimum deployment is 7.0 or later.
      /* com.apple.actool.compilation-results */
      /Users/phonegap/Library/Developer/Xcode/DerivedData/RBBranch-eoelrkktfohkitdezostyrfmside/ Build/Intermediates/ArchiveIntermediates/RBBranch/InstallationBuildProductsLocation/Applic ations/RBBranch.app/AppIcon29x29.png
      /Users/phonegap/Library/Developer/Xcode/DerivedData/RBBranch-eoelrkktfohkitdezostyrfmside/ Build/Intermediates/ArchiveIntermediates/RBBranch/InstallationBuildProductsLocation/Applic ations/RBBranch.app/AppIcon29x29@2x.png
      /Users/phonegap/Library/Developer/Xcode/DerivedData/RBBranch-eoelrkktfohkitdezostyrfmside/ Build/Intermediates/ArchiveIntermediates/RBBranch/InstallationBuildProductsLocation/Applic ations/RBBranch.app/AppIcon29x29@3x.png
      /Users/phonegap/Library/Developer/Xcode/DerivedData/RBBranch-eoelrkktfohkitdezostyrfmside/ Build/Intermediates/ArchiveIntermediates/RBBranch/InstallationBuildProductsLocation/Applic ations/RBBranch.app/AppIcon40x40@2x.png
      /Users/phonegap/Library/Developer/Xcode/DerivedData/RBBranch-eoelrkktfohkitdezostyrfmside/ Build/Intermediates/ArchiveIntermediates/RBBranch/InstallationBuildProductsLocation/Applic ations/RBBranch.app/AppIcon40x40@3x.png
      /Users/phonegap/Library/Developer/Xcode/DerivedData/RBBranch-eoelrkktfohkitdezostyrfmside/ Build/Intermediates/ArchiveIntermediates/RBBranch/InstallationBuildProductsLocation/Applic ations/RBBranch.app/AppIcon57x57.png
      /Users/phonegap/Library/Developer/Xcode/DerivedData/RBBranch-eoelrkktfohkitdezostyrfmside/ Build/Intermediates/ArchiveIntermediates/RBBranch/InstallationBuildProductsLocation/Applic ations/RBBranch.app/AppIcon57x57@2x.png
      /Users/phonegap/Library/Developer/Xcode/DerivedData/RBBranch-eoelrkktfohkitdezostyrfmside/ Build/Intermediates/ArchiveIntermediates/RBBranch/InstallationBuildProductsLocation/Applic ations/RBBranch.app/AppIcon60x60@2x.png
      /Users/phonegap/Library/Developer/Xcode/DerivedData/RBBranch-eoelrkktfohkitdezostyrfmside/ Build/Intermediates/ArchiveIntermediates/RBBranch/InstallationBuildProductsLocation/Applic ations/RBBranch.app/AppIcon60x60@3x.png
      /Users/phonegap/Library/Developer/Xcode/DerivedData/RBBranch-eoelrkktfohkitdezostyrfmside/ Build/Intermediates/ArchiveIntermediates/RBBranch/InstallationBuildProductsLocation/Applic ations/RBBranch.app/AppIcon29x29~ipad.png
      /Users/phonegap/Library/Developer/Xcode/DerivedData/RBBranch-eoelrkktfohkitdezostyrfmside/ Build/Intermediates/ArchiveIntermediates/RBBranch/InstallationBuildProductsLocation/Applic ations/RBBranch.app/AppIcon29x29@2x~ipad.png
      /Users/phonegap/Library/Developer/Xcode/DerivedData/RBBranch-eoelrkktfohkitdezostyrfmside/ Build/Intermediates/ArchiveIntermediates/RBBranch/InstallationBuildProductsLocation/Applic ations/RBBranch.app/AppIcon40x40~ipad.png
      /Users/phonegap/Library/Developer/Xcode/DerivedData/RBBranch-eoelrkktfohkitdezostyrfmside/ Build/Intermediates/ArchiveIntermediates/RBBranch/InstallationBuildProductsLocation/Applic ations/RBBranch.app/AppIcon40x40@2x~ipad.png
      /Users/phonegap/Library/Developer/Xcode/DerivedData/RBBranch-eoelrkktfohkitdezostyrfmside/ Build/Intermediates/ArchiveIntermediates/RBBranch/InstallationBuildProductsLocation/Applic ations/RBBranch.app/AppIcon50x50~ipad.png
      /Users/phonegap/Library/Developer/Xcode/DerivedData/RBBranch-eoelrkktfohkitdezostyrfmside/ Build/Intermediates/ArchiveIntermediates/RBBranch/InstallationBuildProductsLocation/Applic ations/RBBranch.app/AppIcon50x50@2x~ipad.png
      /Users/phonegap/Library/Developer/Xcode/DerivedData/RBBranch-eoelrkktfohkitdezostyrfmside/ Build/Intermediates/ArchiveIntermediates/RBBranch/InstallationBuildProductsLocation/Applic ations/RBBranch.app/AppIcon72x72~ipad.png
      /Users/phonegap/Library/Developer/Xcode/DerivedData/RBBranch-eoelrkktfohkitdezostyrfmside/ Build/Intermediates/ArchiveIntermediates/RBBranch/InstallationBuildProductsLocation/Applic ations/RBBranch.app/AppIcon72x72@2x~ipad.png
      /Users/phonegap/Library/Developer/Xcode/DerivedData/RBBranch-eoelrkktfohkitdezostyrfmside/ Build/Intermediates/ArchiveIntermediates/RBBranch/InstallationBuildProductsLocation/Applic ations/RBBranch.app/AppIcon76x76~ipad.png
      /Users/phonegap/Library/Developer/Xcode/DerivedData/RBBranch-eoelrkktfohkitdezostyrfmside/ Build/Intermediates/ArchiveIntermediates/RBBranch/InstallationBuildProductsLocation/Applic ations/RBBranch.app/AppIcon76x76@2x~ipad.png
      /Users/phonegap/Library/Developer/Xcode/DerivedData/RBBranch-eoelrkktfohkitdezostyrfmside/ Build/Intermediates/ArchiveIntermediates/RBBranch/InstallationBuildProductsLocation/Applic ations/RBBranch.app/AppIcon83.5x83.5@2x~ipad.png
      /Users/phonegap/Library/Developer/Xcode/DerivedData/RBBranch-eoelrkktfohkitdezostyrfmside/ Build/Intermediates/ArchiveIntermediates/RBBranch/InstallationBuildProductsLocation/Applic ations/RBBranch.app/LaunchImage.png
      /Users/phonegap/Library/Developer/Xcode/DerivedData/RBBranch-eoelrkktfohkitdezostyrfmside/ Build/Intermediates/ArchiveIntermediates/RBBranch/InstallationBuildProductsLocation/Applic ations/RBBranch.app/LaunchImage@2x.png
      /Users/phonegap/Library/Developer/Xcode/DerivedData/RBBranch-eoelrkktfohkitdezostyrfmside/ Build/Intermediates/ArchiveIntermediates/RBBranch/InstallationBuildProductsLocation/Applic ations/RBBranch.app/LaunchImage-568h@2x.png
      /Users/phonegap/Library/Developer/Xcode/DerivedData/RBBranch-eoelrkktfohkitdezostyrfmside/ Build/Intermediates/ArchiveIntermediates/RBBranch/InstallationBuildProductsLocation/Applic ations/RBBranch.app/LaunchImage-800-Portrait-736h@3x.png
      /Users/phonegap/Library/Developer/Xcode/DerivedData/RBBranch-eoelrkktfohkitdezostyrfmside/ Build/Intermediates/ArchiveIntermediates/RBBranch/InstallationBuildProductsLocation/Applic ations/RBBranch.app/LaunchImage-800-Landscape-736h@3x.png
      /Users/phonegap/Library/Developer/Xcode/DerivedData/RBBranch-eoelrkktfohkitdezostyrfmside/ Build/Intermediates/ArchiveIntermediates/RBBranch/InstallationBuildProductsLocation/Applic ations/RBBranch.app/LaunchImage-800-667h@2x.png
      /Users/phonegap/Library/Developer/Xcode/DerivedData/RBBranch-eoelrkktfohkitdezostyrfmside/ Build/Intermediates/ArchiveIntermediates/RBBranch/InstallationBuildProductsLocation/Applic ations/RBBranch.app/LaunchImage-700@2x.png
      /Users/phonegap/Library/Developer/Xcode/DerivedData/RBBranch-eoelrkktfohkitdezostyrfmside/ Build/Intermediates/ArchiveIntermediates/RBBranch/InstallationBuildProductsLocation/Applic ations/RBBranch.app/LaunchImage-700-568h@2x.png
      /Users/phonegap/Library/Developer/Xcode/DerivedData/RBBranch-eoelrkktfohkitdezostyrfmside/ Build/Intermediates/ArchiveIntermediates/RBBranch/IntermediateBuildFilesPath/RBBranch.buil d/Release-iphoneos/RBBranch.build/assetcatalog_generated_info.plist
      ProcessInfoPlistFile /Users/phonegap/Library/Developer/Xcode/DerivedData/RBBranch-eoelrkktfohkitdezostyrfmside /Build/Intermediates/ArchiveIntermediates/RBBranch/InstallationBuildProductsLocation/Appli cations/RBBranch.app/Info.plist RBBranch/RBBranch-Info.plist
        builtin-infoPlistUtility /tmp/gimlet/1645041/project/RBBranch/RBBranch-Info.plist -genpkginfo /Users/phonegap/Library/Developer/Xcode/DerivedData/RBBranch-eoelrkktfohkitdezostyrfmside /Build/Intermediates/ArchiveIntermediates/RBBranch/InstallationBuildProductsLocation/Appli cations/RBBranch.app/PkgInfo -expandbuildsettings -format binary -platform iphoneos -additionalcontentfile /Users/phonegap/Library/Developer/Xcode/DerivedData/RBBranch-eoelrkktfohkitdezostyrfmside /Build/Intermediates/ArchiveIntermediates/RBBranch/IntermediateBuildFilesPath/RBBranch.bui ld/Release-iphoneos/RBBranch.build/MainViewController-PartialInfo.plist -additionalcontentfile /Users/phonegap/Library/Developer/Xcode/DerivedData/RBBranch-eoelrkktfohkitdezostyrfmside /Build/Intermediates/ArchiveIntermediates/RBBranch/IntermediateBuildFilesPath/RBBranch.bui ld/Release-iphoneos/RBBranch.build/CDVLaunchScreen-SBPartialInfo.plist -additionalcontentfile /Users/phonegap/Library/Developer/Xcode/DerivedData/RBBranch-eoelrkktfohkitdezostyrfmside /Build/Intermediates/ArchiveIntermediates/RBBranch/IntermediateBuildFilesPath/RBBranch.bui ld/Release-iphoneos/RBBranch.build/assetcatalog_generated_info.plist -o /Users/phonegap/Library/Developer/Xcode/DerivedData/RBBranch-eoelrkktfohkitdezostyrfmside /Build/Intermediates/ArchiveIntermediates/RBBranch/InstallationBuildProductsLocation/Appli cations/RBBranch.app/Info.plist
      LinkStoryboards
        /Applications/Xcode.app/Contents/Developer/usr/bin/ibtool --errors --warnings --notices --module RBBranch --target-device iphone --minimum-deployment-target 8.0 --output-format human-readable-text --link /Users/phonegap/Library/Developer/Xcode/DerivedData/RBBranch-eoelrkktfohkitdezostyrfmside /Build/Intermediates/ArchiveIntermediates/RBBranch/InstallationBuildProductsLocation/Appli cations/RBBranch.app /Users/phonegap/Library/Developer/Xcode/DerivedData/RBBranch-eoelrkktfohkitdezostyrfmside /Build/Intermediates/ArchiveIntermediates/RBBranch/IntermediateBuildFilesPath/RBBranch.bui ld/Release-iphoneos/RBBranch.build/CDVLaunchScreen.storyboardc
      CopyPlistFile /Users/phonegap/Library/Developer/Xcode/DerivedData/RBBranch-eoelrkktfohkitdezostyrfmside /Build/Intermediates/ArchiveIntermediates/RBBranch/InstallationBuildProductsLocation/Appli cations/RBBranch.app/GoogleService-Info.plist RBBranch/Plugins/cordova-plugin-fcm-config/GoogleService-Info.plist
        builtin-copyPlist --convert binary1 --outdir /Users/phonegap/Library/Developer/Xcode/DerivedData/RBBranch-eoelrkktfohkitdezostyrfmside /Build/Intermediates/ArchiveIntermediates/RBBranch/InstallationBuildProductsLocation/Appli cations/RBBranch.app -- RBBranch/Plugins/cordova-plugin-fcm-config/GoogleService-Info.plist
      error: failed to remove /Users/phonegap/Library/Developer/Xcode/DerivedData/RBBranch-eoelrkktfohkitdezostyrfmside /Build/Intermediates/ArchiveIntermediates/RBBranch/InstallationBuildProductsLocation/Appli cations/RBBranch.app/GoogleService-Info.plist: “GoogleService-Info.plist” couldn’t be removed.
      ProcessPCH /private/tmp/gimlet/1645041/project/build/sharedpch/RBBranch-Prefix-bctufqggxowwjdgkckato drhjpmt/RBBranch-Prefix.pch.pch RBBranch/RBBranch-Prefix.pch normal armv7 objective-c com.apple.compilers.llvm.clang.1_0.compiler
        export LANG=en_US.US-ASCII
        /Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/bin/cl ang -x objective-c-header -arch armv7 -fmessage-length=0 -fdiagnostics-show-note-include-stack -fmacro-backtrace-limit=0 -std=c99 -fobjc-arc -fmodules -gmodules -fmodules-cache-path=/Users/phonegap/Library/Developer/Xcode/DerivedData/ModuleCache -fmodules-prune-interval=86400 -fmodules-prune-after=345600 -fbuild-session-file=/Users/phonegap/Library/Developer/Xcode/DerivedData/ModuleCache/Sess ion.modulevalidation -fmodules-validate-once-per-build-session -Wno-trigraphs -fpascal-strings -Os -Wno-missing-field-initializers -Wno-missing-prototypes -Wno-implicit-atomic-properties -Wno-arc-repeated-use-of-weak -Wduplicate-method-match -Wno-missing-braces -Wparentheses -Wswitch -Wunused-function -Wno-unused-label -Wno-unused-parameter -Wunused-variable -Wunused-value -Wempty-body -Wuninitialized -Wno-unknown-pragmas -Wno-shadow -Wno-four-char-constants -Wno-conversion -Wconstant-conversion -Wint-conversion -Wbool-conversion -Wenum-conversion -Wno-shorten-64-to-32 -Wpointer-sign -Wno-newline-eof -Wno-selector -Wno-strict-selector-match -Wundeclared-selector -Wno-deprecated-implementations -isysroot /Applications/Xcode.app/Contents/Developer/Platforms/iPhoneOS.platform/Developer/SDKs/iPh oneOS10.1.sdk -fstrict-aliasing -Wprotocol -Wdeprecated-declarations -miphoneos-version-min=8.0 -g -fvisibility=hidden -Wno-sign-conversion -Wno-infinite-recursion -iquote /Users/phonegap/Library/Developer/Xcode/DerivedData/RBBranch-eoelrkktfohkitdezostyrfmside /Build/Intermediates/ArchiveIntermediates/RBBranch/IntermediateBuildFilesPath/RBBranch.bui ld/Release-iphoneos/RBBranch.build/RBBranch-generated-files.hmap -I/Users/phonegap/Library/Developer/Xcode/DerivedData/RBBranch-eoelrkktfohkitdezostyrfmsi de/Build/Intermediates/ArchiveIntermediates/RBBranch/IntermediateBuildFilesPath/RBBranch.b uild/Release-iphoneos/RBBranch.build/RBBranch-own-target-headers.hmap -I/Users/phonegap/Library/Developer/Xcode/DerivedData/RBBranch-eoelrkktfohkitdezostyrfmsi de/Build/Intermediates/ArchiveIntermediates/RBBranch/IntermediateBuildFilesPath/RBBranch.b uild/Release-iphoneos/RBBranch.build/RBBranch-all-target-headers.hmap -iquote /Users/phonegap/Library/Developer/Xcode/DerivedData/RBBranch-eoelrkktfohkitdezostyrfmside /Build/Intermediates/ArchiveIntermediates/RBBranch/IntermediateBuildFilesPath/RBBranch.bui ld/Release-iphoneos/RBBranch.build/RBBranch-project-headers.hmap -I/tmp/gimlet/1645041/project/build/include -I/Users/phonegap/Library/Developer/Xcode/DerivedData/RBBranch-eoelrkktfohkitdezostyrfmsi de/Build/Intermediates/ArchiveIntermediates/RBBranch/InstallationBuildProductsLocation/App lications/usr/local/lib/include -I/Users/phonegap/Library/Developer/Xcode/DerivedData/RBBranch-eoelrkktfohkitdezostyrfmsi de/Build/Intermediates/ArchiveIntermediates/RBBranch/IntermediateBuildFilesPath/Uninstalle dProducts/include -I/Users/phonegap/Library/Developer/Xcode/DerivedData/RBBranch-eoelrkktfohkitdezostyrfmsi de/Build/Intermediates/ArchiveIntermediates/RBBranch/IntermediateBuildFilesPath/Uninstalle dProducts/iphoneos/include -I/tmp/gimlet/1645041/project/build -I/Users/phonegap/Library/Developer/Xcode/DerivedData/RBBranch-eoelrkktfohkitdezostyrfmsi de/Build/Intermediates/ArchiveIntermediates/RBBranch/IntermediateBuildFilesPath/RBBranch.b uild/Release-iphoneos/RBBranch.build/DerivedSources/armv7 -I/Users/phonegap/Library/Developer/Xcode/DerivedData/RBBranch-eoelrkktfohkitdezostyrfmsi de/Build/Intermediates/ArchiveIntermediates/RBBranch/IntermediateBuildFilesPath/RBBranch.b uild/Release-iphoneos/RBBranch.build/DerivedSources -F/tmp/gimlet/1645041/project/build -FRBBranch/Plugins/cordova-plugin-fcm -MD -MT dependencies -MF /private/tmp/gimlet/1645041/project/build/sharedpch/RBBranch-Prefix-bctufqggxowwjdgkckato drhjpmt/RBBranch-Prefix.pch.d -c /tmp/gimlet/1645041/project/RBBranch/RBBranch-Prefix.pch -o /private/tmp/gimlet/1645041/project/build/sharedpch/RBBranch-Prefix-bctufqggxowwjdgkckato drhjpmt/RBBranch-Prefix.pch.pch --serialize-diagnostics /private/tmp/gimlet/1645041/project/build/sharedpch/RBBranch-Prefix-bctufqggxowwjdgkckato drhjpmt/RBBranch-Prefix.pch.dia
      ProcessPCH /private/tmp/gimlet/1645041/project/build/sharedpch/RBBranch-Prefix-bxipgofhldvqpyftoubeh sovzhwb/RBBranch-Prefix.pch.pch RBBranch/RBBranch-Prefix.pch normal arm64 objective-c com.apple.compilers.llvm.clang.1_0.compiler
        /Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/bin/cl ang -x objective-c-header -arch arm64 -fmessage-length=0 -fdiagnostics-show-note-include-stack -fmacro-backtrace-limit=0 -std=c99 -fobjc-arc -fmodules -gmodules -fmodules-cache-path=/Users/phonegap/Library/Developer/Xcode/DerivedData/ModuleCache -fmodules-prune-interval=86400 -fmodules-prune-after=345600 -fbuild-session-file=/Users/phonegap/Library/Developer/Xcode/DerivedData/ModuleCache/Sess ion.modulevalidation -fmodules-validate-once-per-build-session -Wno-trigraphs -fpascal-strings -Os -Wno-missing-field-initializers -Wno-missing-prototypes -Wno-implicit-atomic-properties -Wno-arc-repeated-use-of-weak -Wduplicate-method-match -Wno-missing-braces -Wparentheses -Wswitch -Wunused-function -Wno-unused-label -Wno-unused-parameter -Wunused-variable -Wunused-value -Wempty-body -Wuninitialized -Wno-unknown-pragmas -Wno-shadow -Wno-four-char-constants -Wno-conversion -Wconstant-conversion -Wint-conversion -Wbool-conversion -Wenum-conversion -Wshorten-64-to-32 -Wpointer-sign -Wno-newline-eof -Wno-selector -Wno-strict-selector-match -Wundeclared-selector -Wno-deprecated-implementations -isysroot /Applications/Xcode.app/Contents/Developer/Platforms/iPhoneOS.platform/Developer/SDKs/iPh oneOS10.1.sdk -fstrict-aliasing -Wprotocol -Wdeprecated-declarations -miphoneos-version-min=8.0 -g -fvisibility=hidden -Wno-sign-conversion -Wno-infinite-recursion -iquote /Users/phonegap/Library/Developer/Xcode/DerivedData/RBBranch-eoelrkktfohkitdezostyrfmside /Build/Intermediates/ArchiveIntermediates/RBBranch/IntermediateBuildFilesPath/RBBranch.bui ld/Release-iphoneos/RBBranch.build/RBBranch-generated-files.hmap -I/Users/phonegap/Library/Developer/Xcode/DerivedData/RBBranch-eoelrkktfohkitdezostyrfmsi de/Build/Intermediates/ArchiveIntermediates/RBBranch/IntermediateBuildFilesPath/RBBranch.b uild/Release-iphoneos/RBBranch.build/RBBranch-own-target-headers.hmap -I/Users/phonegap/Library/Developer/Xcode/DerivedData/RBBranch-eoelrkktfohkitdezostyrfmsi de/Build/Intermediates/ArchiveIntermediates/RBBranch/IntermediateBuildFilesPath/RBBranch.b uild/Release-iphoneos/RBBranch.build/RBBranch-all-target-headers.hmap -iquote /Users/phonegap/Library/Developer/Xcode/DerivedData/RBBranch-eoelrkktfohkitdezostyrfmside /Build/Intermediates/ArchiveIntermediates/RBBranch/IntermediateBuildFilesPath/RBBranch.bui ld/Release-iphoneos/RBBranch.build/RBBranch-project-headers.hmap -I/tmp/gimlet/1645041/project/build/include -I/Users/phonegap/Library/Developer/Xcode/DerivedData/RBBranch-eoelrkktfohkitdezostyrfmsi de/Build/Intermediates/ArchiveIntermediates/RBBranch/InstallationBuildProductsLocation/App lications/usr/local/lib/include -I/Users/phonegap/Library/Developer/Xcode/DerivedData/RBBranch-eoelrkktfohkitdezostyrfmsi de/Build/Intermediates/ArchiveIntermediates/RBBranch/IntermediateBuildFilesPath/Uninstalle dProducts/include -I/Users/phonegap/Library/Developer/Xcode/DerivedData/RBBranch-eoelrkktfohkitdezostyrfmsi de/Build/Intermediates/ArchiveIntermediates/RBBranch/IntermediateBuildFilesPath/Uninstalle dProducts/iphoneos/include -I/tmp/gimlet/1645041/project/build -I/Users/phonegap/Library/Developer/Xcode/DerivedData/RBBranch-eoelrkktfohkitdezostyrfmsi de/Build/Intermediates/ArchiveIntermediates/RBBranch/IntermediateBuildFilesPath/RBBranch.b uild/Release-iphoneos/RBBranch.build/DerivedSources/arm64 -I/Users/phonegap/Library/Developer/Xcode/DerivedData/RBBranch-eoelrkktfohkitdezostyrfmsi de/Build/Intermediates/ArchiveIntermediates/RBBranch/IntermediateBuildFilesPath/RBBranch.b uild/Release-iphoneos/RBBranch.build/DerivedSources -F/tmp/gimlet/1645041/project/build -FRBBranch/Plugins/cordova-plugin-fcm -MD -MT dependencies -MF /private/tmp/gimlet/1645041/project/build/sharedpch/RBBranch-Prefix-bxipgofhldvqpyftoubeh sovzhwb/RBBranch-Prefix.pch.d -c /tmp/gimlet/1645041/project/RBBranch/RBBranch-Prefix.pch -o /private/tmp/gimlet/1645041/project/build/sharedpch/RBBranch-Prefix-bxipgofhldvqpyftoubeh sovzhwb/RBBranch-Prefix.pch.pch --serialize-diagnostics /private/tmp/gimlet/1645041/project/build/sharedpch/RBBranch-Prefix-bxipgofhldvqpyftoubeh sovzhwb/RBBranch-Prefix.pch.dia
      ** ARCHIVE FAILED **
      The following build commands failed:
      (1 failure)
      Error code 65 for command: xcodebuild with args: -xcconfig,/private/tmp/gimlet/1645041/project/cordova/build-release.xcconfig,-workspace,R BBranch.xcworkspace,-scheme,RBBranch,-configuration,Release,-destination,generic/platform= iOS,-archivePath,RBBranch.xcarchive,archive,CONFIGURATION_BUILD_DIR=/private/tmp/gimlet/16 45041/project/build/device,SHARED_PRECOMPS_DIR=/private/tmp/gimlet/1645041/project/build/s haredpch
