4 Replies Latest reply on Apr 18, 2017 6:57 AM by mobilef79798704
    Error: Variable(s) missing: SENDER_ID
    joãos28403031 Level 1
      Hello,
      Today I'm getting the error of the sender_ID when I try to compile my app using build.phonegap.com for ios...
      For the android app it works fine, also in last week it worked fine, but today, I changed one thing on my code and now phonegap doesn't compile for ios...
      Also, tried to upload my last week code to phonegap since I had a backup and it still wont work...
      It gives the sender_id error but it's in my config file...
      Any solutions or someone else noticed that?
      Thank you in advance for the help.
        • 1. Re: Error: Variable(s) missing: SENDER_ID
          mobilef79798704 Level 1
          Same problem here. It worked fine until last week.
          • 2. Re: Error: Variable(s) missing: SENDER_ID
            ryanskihead Adobe Employee
            Unable to reproduce, can you verify, or share an App ID of an app in the failure state?
            • 3. Re: Error: Variable(s) missing: SENDER_ID
              Hello,
              Well... today for an unknown reason it's working again...
              Yesterday I spend 8 hours trying to make it work and couldn't and now when I arrive at work, I just tried to rebuild the same project/code and It worked...
              I guess it was just a bug or something.
              Since I can't reproduce it at the moment too I guess you can close the topic.
              Thank you for the help.
              • 4. Re: Error: Variable(s) missing: SENDER_ID
                Yes... the problem has magically gone today!
                To get the things done yesterday I had to build without these settings in my config.xml:
                <gap:config-file platform="ios" parent="CFBundleAllowMixedLocalizations" overwrite="true">
                        <array>
                          <string>Yes</string>
                        </array>
                      </gap:config-file>
                     <gap:config-file platform="ios" parent="CFBundleLocalizations">
                        <array>
                          <string>pt</string>
                        </array>
                      </gap:config-file>
                      <gap:config-file platform="ios" parent="CFBundleDevelopmentRegion">
                        <array>
                          <string>pt_BR</string>
                        </array>
                      </gap:config-file>
                      <gap:config-file platform="ios" parent="NSPhotoLibraryUsageDescription" overwrite="true">
                          <string>Selecionar imagens para catalogar no aplicativo</string>
                      </gap:config-file>
                      <gap:config-file platform="ios" parent="NSCameraUsageDescription" overwrite="true">
                          <string>Incluir imagens para catalogar no aplicativo</string>
                      </gap:config-file>
