I have several old journals, typed on an 1970 typewriter. I want to digitize these. I suppose I can scan them into Acrobat, creating a pdf file. But how do I get them into a doc file with having to retype them? OCC? Then what? I can't figure this one out.
Sorry. I meant OCR...
You are on the right track. A typewritten page that is scanned to a PDF will initially be an image-based document. Luckily Acrobat Pro has the OCR process built in, and it can do a very nice job of converting images of words into searchable, and for your needs, exportable text. If you have Acrobat Pro DC, you can find the OCR feature (actually called Recognize Text) in the Enhance Scans tool set. Once you run this process (and it may actually be set to run automatically when you scan), you can then click File>Export to>Microsoft Word.
I hope this is helpful.
My best,
Dave
The problem now is the software will recognize my scanner, but will not scan.
Try to poke around the scanner settings in Acrobat. With some scanners, you will have better luck asking Acrobat to "Show scanner's user interface". Others wok well by letting Adobe handle the scanning process without calling the scanner manufacturer's interface.
My best,
Dave
We would like to help you in the issue you are facing.Please share some required information:
1) Acrobat DC Pro version information
2) Operating System
For primary troubleshooting at your end you can use these steps:
Troubleshooting tips for scanner issues when using Acrobat
Rishabh
Dave, that is what I am looking for... I was looking for OCR, not Recognize Text. Let me take that route. Thanks
Yes, I have Adobe Acrobat DC, specifically for this purpose.
