3 Replies Latest reply on Apr 18, 2017 1:30 PM by johnrellis
    Backslash/Forward slash as hierarchical tag
    raldo Level 1
      I have tagged thousands of photos using a hierarchichal keyword scheme. Example: !Events/Birthday
      Lightroom does not display and recogize this as a hierarchical keyword. Even after I select the option edit\Preferences\FileHandling\Treat'/'AsAKeywordSeparator
      Does this only work on Import? Any ideas?
        • 1. Re: Backslash/Forward slash as hierarchical tag
          johnrellis Most Valuable Participant
          That's right.  The description in Preferences > File Handling says:
          By "reading metadata", that's referring to the command Metadata > Read Metadata From File.  So LR will interpret "/" as a hierarchical separator when importing pics or using the Read Metadata From File command.  (It never interprets "\" as a hierarchical separator, and I've filed a bug report on that.)
          When entering keywords in LR's Keywording panel (right column of Library), you need to use "<" or ">" as the hierarchical separator.  To enter the hierarchical keyword A > B, you could type "A > B" or "B < A" (in both cases, A is the parent and B is the child).
          If you want to correct the thousands of photos you've already tagged using "\", you could do the following:
          1. In LR, select all the photos and do Metadata > Write Metadata To File.
          2. Use ExifTool to remove the fields XMP:Subject and IPTC:Keywords from the photos, leaving just the field XMP:HierarchicalSubject.
          3. Use ExifTool and some other command-line tools like "sed" to replace all occurrences of "\" with "|" in XMP:HiearchicalSubject.  This step requires you to be experienced with command-line scripting and to invest at least an hour learning ExifTool, if you don't know it already.
          4. In LR, select all the photos and do Metadata > Read Metadata From File.
          Of course, make sure you've backed up your catalog and all your photos before you start this.
          • 2. Re: Backslash/Forward slash as hierarchical tag
            raldo Level 1
            Ok. I'll just check the checkbox and reimport.
            • 3. Re: Backslash/Forward slash as hierarchical tag
              If you're using forward slash, you don't need to reimport -- just select the files and do Metadata > Read Metadata From File.
              If you're using backward slash, you'll have to use the steps I outlined above.
