• Global community
    • Language:
      • Deutsch
      • English
      • Español
      • Français
      • Português
  • 日本語コミュニティ
  • 한국 커뮤니티
Exit
0
X bar (mean symbol)
Community Beginner ,
Apr 18, 2017 Apr 18, 2017
Hi
I can't find the x-bar (mean symbol) in Indesign.
Anyone know how to locate this symbol in glyphs?
(Indesign CC 2017)
Roger
Views
6.3K
Translate
Translate
Report
Report
Community guidelines
community guidelines
Guide , Apr 18, 2017 Apr 18, 2017
In addition, using Rorohiko's cool (and free) script "UnicodeInjector" (https://www.rorohiko.com/wordpress/manuals/unicodeinjector-easily-insert-any-unicode-character-into-indesign) makes things so easy.
You can even assign a shortcut (CTRL + / in my example below) to type your "combined glyph".
See:
Votes
Translate
Translate
Mentor ,
This?
Votes
Translate
Translate
Report
Report
Adobe Employee ,
I guess the need is for a symbol like
I guess you first need to check if the font you have choosen has this glyph or not.
As far as I know, this symbol this glyph isnt assigned a unicode yet.
As a workaround you can any of the following:
1. Enter x. Type bar - and then kern the pair to a negative value it to make it overlapping. This is what i could achieve with this method:
2. Make a glyph using indiscripts http://www.indiscripts.com/category/projects/IndyFont​
-Aman
Votes
Translate
Translate
Report
Report
Mentor ,
ha, my first post is still 'being moderated" so it's not clear what I meant.
(that moderating thing is obviously not fast enough).
however, it seems I misunderstood the question, so you're absolutely right.
Votes
Translate
Translate
Report
Report
I discovered kern and did it manually which solved the problem, another suggestion or easier workaround would be appreciated.
Roger
Votes
Translate
Translate
Report
Report
Mentor ,
If you need to use specific font, and it hasn't that glyph, I'd vote for amaarora's second option. It's far more safe and robust solution. Depends on the volume of your project and workflow, though.
Votes
Translate
Translate
Report
Report
Mentor ,
Also it can be inserted using KB command Alt+0215
Votes
Translate
Translate
Report
Report
Community Expert ,
I've never had to use this character but I would think that maybe a math-based font in the OpenType format would definitely have it. I can't find a fond that does. That being said, if you open up the Glyphs panel in InDesign, you can search for the character by name or unicode value.
Votes
Translate
Translate
Report
Report
Guide ,
Hi
This spectific Glyph doesn't exist.
You need to combine two glyphs : x and "Macron" (Unicode 0304). Of course make sure your font has this "macron" glyph.
No need for kerning.
For a faster workaround, IndyFont would be a great tool.
Autocorrect could be handy too.
Votes
Translate
Translate
Report
Report
Guide ,
LATEST
In addition, using Rorohiko's cool (and free) script "UnicodeInjector" (https://www.rorohiko.com/wordpress/manuals/unicodeinjector-easily-insert-any-unicode-character-into-... makes things so easy.
See:
Votes
Translate
Translate
Report
Report
