0 Replies Latest reply on Apr 18, 2017 8:21 AM by frankf53209018
    Workbench ES4 Errors
    frankf53209018 Level 1
      I can checkout/edit/checkin forms.  I cannot create LCAs.  I get errors in Workbench everytime I open it or do anything in it.
      I have used the same installation file using defaults in the installation as others in this group on the same platform as the others.  They can create LCAs and I cannot.  I need help with this desparately.  I've tried adjusting the size parameters in the workbench.ini without help. I even tried using a 64 bit java.  No good there either.
      The .log includes:
      !SESSION 2017-04-17 11:28:53.551 -----------------------------------------------
      eclipse.buildId=unknown
      java.version=1.7.0_21
      java.vendor=Oracle Corporation
      BootLoader constants: OS=win32, ARCH=x86, WS=win32, NL=en_US
      Framework arguments:  #Product Runtime Configuration File
      Command-line arguments:  -os win32 -ws win32 -arch x86 #Product Runtime Configuration File
      !ENTRY org.eclipse.osgi 2 1 2017-04-17 11:28:54.441
      !MESSAGE NLS missing message: Product_ReleaseVersion in: com.adobe.livecycle.workbench.core.messages.messages
      !ENTRY com.adobe.lcide.rcp 1 0 2017-04-17 11:28:54.707
      !MESSAGE Workbench started at: Mon Apr 17 11:28:54 CDT 2017
      !ENTRY com.adobe.ide.singlesignon 1 0 2017-04-17 11:28:55.176
      !MESSAGE Workbench version '11.0.1.v201308300332'
      !ENTRY com.adobe.ape.core 2 1 2017-04-17 11:28:58.567
      !MESSAGE Still waiting for DestinationService after 2 seconds
      !ENTRY org.eclipse.osgi 4 0 2017-04-17 11:43:58.625
      !MESSAGE An error occurred while automatically activating bundle com.adobe.ape.core (6).
      !STACK 0
      org.osgi.framework.BundleException: Exception in com.adobe.ape.osgi.Activator.start() of bundle com.adobe.ape.core.
        at org.eclipse.osgi.framework.internal.core.BundleContextImpl.startActivator(BundleContextIm pl.java:806)
        at org.eclipse.osgi.framework.internal.core.BundleContextImpl.start(BundleContextImpl.java:7 55)
        at org.eclipse.osgi.framework.internal.core.BundleHost.startWorker(BundleHost.java:370)
        at org.eclipse.osgi.framework.internal.core.AbstractBundle.start(AbstractBundle.java:284)
        at org.eclipse.osgi.framework.util.SecureAction.start(SecureAction.java:417)
        at org.eclipse.osgi.internal.loader.BundleLoader.setLazyTrigger(BundleLoader.java:265)
        at org.eclipse.core.runtime.internal.adaptor.EclipseLazyStarter.postFindLocalClass(EclipseLa zyStarter.java:106)
        at org.eclipse.osgi.baseadaptor.loader.ClasspathManager.findLocalClass(ClasspathManager.java :453)
        at org.eclipse.osgi.internal.baseadaptor.DefaultClassLoader.findLocalClass(DefaultClassLoade r.java:216)
        at org.eclipse.osgi.internal.loader.BundleLoader.findLocalClass(BundleLoader.java:393)
        at org.eclipse.osgi.internal.loader.SingleSourcePackage.loadClass(SingleSourcePackage.java:3 3)
        at org.eclipse.osgi.internal.loader.BundleLoader.findClassInternal(BundleLoader.java:466)
        at org.eclipse.osgi.internal.loader.BundleLoader.findClass(BundleLoader.java:422)
        at org.eclipse.osgi.internal.loader.BundleLoader.findClass(BundleLoader.java:410)
        at org.eclipse.osgi.internal.baseadaptor.DefaultClassLoader.loadClass(DefaultClassLoader.jav a:107)
        at java.lang.ClassLoader.loadClass(ClassLoader.java:356)
        at java.lang.ClassLoader.defineClass1(Native Method)
        at java.lang.ClassLoader.defineClass(ClassLoader.java:791)
        at org.eclipse.osgi.internal.baseadaptor.DefaultClassLoader.defineClass(DefaultClassLoader.j ava:188)
        at org.eclipse.osgi.baseadaptor.loader.ClasspathManager.defineClass(ClasspathManager.java:58 0)
        at org.eclipse.osgi.baseadaptor.loader.ClasspathManager.findClassImpl(ClasspathManager.java: 550)
        at org.eclipse.osgi.baseadaptor.loader.ClasspathManager.findLocalClassImpl(ClasspathManager. java:481)
        at org.eclipse.osgi.baseadaptor.loader.ClasspathManager.findLocalClass_LockClassName(Classpa thManager.java:460)
        at org.eclipse.osgi.baseadaptor.loader.ClasspathManager.findLocalClass(ClasspathManager.java :447)
        at org.eclipse.osgi.internal.loader.BundleLoader.findClassInternal(BundleLoader.java:469)
        at com.adobe.workflow.eclipse.views.VariablesView$4.partActivated(VariablesView.java:799)
        at org.eclipse.ui.internal.PartListenerList2$1.run(PartListenerList2.java:70)
        at org.eclipse.core.runtime.SafeRunner.run(SafeRunner.java:42)
        at org.eclipse.core.runtime.Platform.run(Platform.java:888)
        at org.eclipse.ui.internal.PartListenerList2.fireEvent(PartListenerList2.java:55)
        at org.eclipse.ui.internal.PartListenerList2.firePartActivated(PartListenerList2.java:68)
        at org.eclipse.ui.internal.PartService.firePartActivated(PartService.java:192)
        at org.eclipse.ui.internal.PartService.access$0(PartService.java:177)
        at org.eclipse.ui.internal.PartService$PartActivated.fire(PartService.java:100)
        at org.eclipse.ui.internal.PartService.processPartJobs(PartService.java:161)
        at org.eclipse.ui.internal.PartService$PartListener.handleEvent(PartService.java:88)
        at org.eclipse.swt.widgets.EventTable.sendEvent(EventTable.java:84)
        at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:1053)
        at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:1077)
        at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:1058)
        at org.eclipse.swt.widgets.Shell.setActiveControl(Shell.java:1424)
        at org.eclipse.swt.widgets.Control.sendFocusEvent(Control.java:2632)
        at org.eclipse.swt.widgets.Widget.wmSetFocus(Widget.java:2402)
        at org.eclipse.swt.widgets.Control.WM_SETFOCUS(Control.java:4792)
        at org.eclipse.swt.widgets.Control.windowProc(Control.java:4229)
        at org.eclipse.swt.widgets.Display.windowProc(Display.java:4873)
        at org.eclipse.swt.internal.win32.OS.SetFocus(Native Method)
        at org.eclipse.swt.widgets.Control.forceFocus(Control.java:995)
        at org.eclipse.swt.widgets.Control.setFocus(Control.java:3000)
        at org.eclipse.swt.widgets.Composite.setFocus(Composite.java:1053)
        at org.eclipse.swt.browser.IE$5.handleEvent(IE.java:333)
        at org.eclipse.swt.widgets.Control.sendFocusEvent(Control.java:2618)
        at org.eclipse.swt.widgets.Control.setSavedFocus(Control.java:3269)
        at org.eclipse.swt.widgets.Decorations.restoreFocus(Decorations.java:821)
        at org.eclipse.swt.widgets.Shell.open(Shell.java:1225)
        at org.eclipse.jface.window.Window.open(Window.java:797)
        at org.eclipse.ui.internal.WorkbenchWindow.open(WorkbenchWindow.java:790)
        at org.eclipse.ui.internal.Workbench$65.runWithException(Workbench.java:3649)
        at org.eclipse.ui.internal.StartupThreading$StartupRunnable.run(StartupThreading.java:31)
        at org.eclipse.swt.widgets.RunnableLock.run(RunnableLock.java:35)
        at org.eclipse.swt.widgets.Synchronizer.runAsyncMessages(Synchronizer.java:134)
        at org.eclipse.swt.widgets.Display.runAsyncMessages(Display.java:4041)
        at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java:3660)
        at org.eclipse.ui.application.WorkbenchAdvisor.openWindows(WorkbenchAdvisor.java:803)
        at com.adobe.lcide.rcp.ApplicationWorkbenchAdvisor.openWindows(Unknown Source)
        at org.eclipse.ui.internal.Workbench$31.runWithException(Workbench.java:1566)
        at org.eclipse.ui.internal.Workbench.runUI(Workbench.java:2537)
        at org.eclipse.ui.internal.Workbench.access$4(Workbench.java:2427)
        at org.eclipse.ui.internal.Workbench$7.run(Workbench.java:670)
        at org.eclipse.core.databinding.observable.Realm.runWithDefault(Realm.java:332)
        at org.eclipse.ui.internal.Workbench.createAndRunWorkbench(Workbench.java:663)
        at org.eclipse.ui.PlatformUI.createAndRunWorkbench(PlatformUI.java:149)
        at com.adobe.lcide.rcp.startup.internal.WorkbenchRunner.startup(Unknown Source)
        at com.adobe.lcide.rcp.startup.StartupJobChain.startup(Unknown Source)
        at com.adobe.lcide.rcp.Application.start(Unknown Source)
        at org.eclipse.equinox.internal.app.EclipseAppHandle.run(EclipseAppHandle.java:196)
        at org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher.runApplication(EclipseAppLau ncher.java:110)
        at org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher.start(EclipseAppLauncher.jav a:79)
        at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:369)
        at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:179)
        at sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method)
        at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:57)
        at sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMethodAccessorImpl.java:43)
        at java.lang.reflect.Method.invoke(Method.java:601)
        at org.eclipse.equinox.launcher.Main.invokeFramework(Main.java:619)
        at org.eclipse.equinox.launcher.Main.basicRun(Main.java:574)
        at org.eclipse.equinox.launcher.Main.run(Main.java:1407)
        at org.eclipse.equinox.launcher.Main.main(Main.java:1383)
      Caused by: java.lang.NullPointerException
        at com.adobe.lcx.commandservice.domain.LcdsCommandRequestService.init(Unknown Source)
        at com.adobe.lcx.commandservice.domain.LcdsCommandRequestService.registerCommandRequestHandl er(Unknown Source)
        at com.adobe.ape.api.APERegistry.initialize(Unknown Source)
        at com.adobe.ape.osgi.Activator.start(Unknown Source)
        at org.eclipse.osgi.framework.internal.core.BundleContextImpl$1.run(BundleContextImpl.java:7 83)
        at java.security.AccessController.doPrivileged(Native Method)
        at org.eclipse.osgi.framework.internal.core.BundleContextImpl.startActivator(BundleContextIm pl.java:774)
        ... 108 more
      Root exception:
      !ENTRY org.eclipse.ui.workbench 4 2 2017-04-17 11:43:58.630
      !MESSAGE Problems occurred when invoking code from plug-in: "org.eclipse.ui.workbench".
      !STACK 0
      java.lang.NoClassDefFoundError: com/adobe/ape/api/IAPEViewListener
      Caused by: org.eclipse.core.runtime.internal.adaptor.EclipseLazyStarter$TerminatingClassNotFoundExce ption: An error occurred while automatically activating bundle com.adobe.ape.core (6).
        at org.eclipse.core.runtime.internal.adaptor.EclipseLazyStarter.postFindLocalClass(EclipseLa zyStarter.java:121)
        ... 93 more
      Caused by: org.osgi.framework.BundleException: Exception in com.adobe.ape.osgi.Activator.start() of bundle com.adobe.ape.core.
        ... 102 more
        ... 108 more
      !ENTRY org.eclipse.ui.workbench 4 2 2017-04-17 11:50:59.321
      !STACK 0
        at com.adobe.workflow.eclipse.views.VariablesView$5.selectionChanged(VariablesView.java:852)
        at org.eclipse.ui.internal.AbstractSelectionService.firePostSelection(AbstractSelectionServi ce.java:179)
        at org.eclipse.ui.internal.AbstractSelectionService.setActivePart(AbstractSelectionService.j ava:289)
        at org.eclipse.ui.internal.WWinPartService.updateActivePart(WWinPartService.java:134)
        at org.eclipse.ui.internal.WWinPartService.access$0(WWinPartService.java:125)
        at org.eclipse.ui.internal.WWinPartService$WWinListener.partDeactivated(WWinPartService.java :50)
        at org.eclipse.ui.internal.PartListenerList2$4.run(PartListenerList2.java:115)
        at org.eclipse.ui.internal.PartListenerList2.firePartDeactivated(PartListenerList2.java:113)
        at org.eclipse.ui.internal.PartService.firePartDeactivated(PartService.java:242)
        at org.eclipse.ui.internal.PartService.setActivePart(PartService.java:300)
        at org.eclipse.ui.internal.WorkbenchPagePartList.fireActivePartChanged(WorkbenchPagePartList .java:57)
        at org.eclipse.ui.internal.PartList.setActivePart(PartList.java:136)
        at org.eclipse.ui.internal.WorkbenchPage.setActivePart(WorkbenchPage.java:3537)
        at org.eclipse.ui.internal.WorkbenchPage.requestActivation(WorkbenchPage.java:3077)
        at org.eclipse.ui.internal.PartPane.requestActivation(PartPane.java:279)
        at org.eclipse.ui.internal.PartPane.handleEvent(PartPane.java:237)
        at org.eclipse.swt.widgets.Shell.WM_MOUSEACTIVATE(Shell.java:2297)
        at org.eclipse.swt.widgets.Control.windowProc(Control.java:4203)
        at org.eclipse.swt.widgets.Canvas.windowProc(Canvas.java:341)
        at org.eclipse.swt.widgets.Decorations.windowProc(Decorations.java:1598)
        at org.eclipse.swt.widgets.Shell.windowProc(Shell.java:2038)
        at org.eclipse.swt.widgets.Display.windowProc(Display.java:4886)
        at org.eclipse.swt.internal.win32.OS.DefWindowProcW(Native Method)
        at org.eclipse.swt.internal.win32.OS.DefWindowProc(OS.java:2454)
        at org.eclipse.swt.widgets.Scrollable.callWindowProc(Scrollable.java:80)
        at org.eclipse.swt.widgets.Control.windowProc(Control.java:4251)
        at org.eclipse.swt.internal.win32.OS.CallWindowProcW(Native Method)
        at org.eclipse.swt.internal.win32.OS.CallWindowProc(OS.java:2362)
        at org.eclipse.swt.widgets.Link.callWindowProc(Link.java:172)
        at org.eclipse.swt.internal.win32.OS.PeekMessageW(Native Method)
        at org.eclipse.swt.internal.win32.OS.PeekMessage(OS.java:3024)
        at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java:3652)
        at org.eclipse.ui.internal.Workbench.runEventLoop(Workbench.java:2629)
        at org.eclipse.ui.internal.Workbench.runUI(Workbench.java:2593)
        ... 21 more
        ... 102 more
        ... 108 more
      !ENTRY com.adobe.ide.singlesignon 1 0 2017-04-17 11:51:15.135
      !MESSAGE User 'ffuss' logged in to server 'DEV3x' (hostname: '10.166.211.30')
      !ENTRY org.eclipse.jface 4 2 2017-04-17 12:29:56.084
      !MESSAGE Problems occurred when invoking code from plug-in: "org.eclipse.jface".
      !STACK 0
      java.lang.NoClassDefFoundError: com/adobe/workbench/editors/workbenchflexprocessdesigner/FlexProcessDesigner
        at org.eclipse.ui.internal.AbstractSelectionService$2.selectionChanged(AbstractSelectionServ ice.java:71)
        at org.eclipse.jface.viewers.StructuredViewer$3.run(StructuredViewer.java:867)
        at org.eclipse.ui.internal.JFaceUtil$1.run(JFaceUtil.java:49)
        at org.eclipse.jface.util.SafeRunnable.run(SafeRunnable.java:175)
        at org.eclipse.jface.viewers.StructuredViewer.firePostSelectionChanged(StructuredViewer.java :865)
        at org.eclipse.jface.viewers.StructuredViewer.handlePostSelect(StructuredViewer.java:1205)
        at org.eclipse.jface.viewers.StructuredViewer$5.widgetSelected(StructuredViewer.java:1230)
        at org.eclipse.jface.util.OpenStrategy.firePostSelectionEvent(OpenStrategy.java:251)
        at org.eclipse.jface.util.OpenStrategy.access$5(OpenStrategy.java:245)
        at org.eclipse.jface.util.OpenStrategy$3.run(OpenStrategy.java:419)
      !ENTRY com.adobe.livecycle.workbench.applicationview 4 0 2017-04-17 13:25:35.602
      !MESSAGE Export Wizard exception
      !STACK 0
      com.adobe.idp.DocumentError: com.adobe.idp.DocumentError: Failed to connect to LiveCycle server via HTTP URL: http://10.166.211.30:7004/DocumentManager
        at com.adobe.idp.DocumentManagerClient.requestRemotePassivation(DocumentManagerClient.java:6 80)
        at com.adobe.idp.Document.passivate(Document.java:1293)
        at com.adobe.idp.Document.passivate(Document.java:1202)
        at com.adobe.livecycle.workbench.applicationview.wizard.ApplicationExportWizard.improvedExpo rt(ApplicationExportWizard.java:634)
        at com.adobe.livecycle.workbench.applicationview.wizard.ApplicationExportWizard.access$400(A pplicationExportWizard.java:122)
        at com.adobe.livecycle.workbench.applicationview.wizard.ApplicationExportWizard$1.run(Applic ationExportWizard.java:693)
        at org.eclipse.jface.operation.ModalContext$ModalContextThread.run(ModalContext.java:121)
      Caused by: com.adobe.idp.DocumentError: Failed to connect to LiveCycle server via HTTP URL: http://10.166.211.30:7004/DocumentManager
        at com.adobe.idp.DocumentManagerClient.requestRemotePassivation(DocumentManagerClient.java:6 09)
        ... 6 more
      Caused by: java.io.IOException: Server returned HTTP response code: 500 for URL: http://10.166.211.30:7004/DocumentManager/docm1492081052640/2a95f97661585e6447a68353d56aba cd
        at sun.net.www.protocol.http.HttpURLConnection.getInputStream(HttpURLConnection.java:1625)
        at com.adobe.idp.DocumentManagerClient.requestRemotePassivation(DocumentManagerClient.java:5 97)
        ... 6 more
      !ENTRY com.adobe.common.client 2 0 2017-04-17 15:02:39.188
      !MESSAGE Workbench is running low on memory. You have consumed 62% of available memory (442,188,304 of 715,849,728)
      !ENTRY org.eclipse.jface 4 2 2017-04-17 17:03:39.375
      !STACK 0
        at org.eclipse.jface.viewers.StructuredViewer.setSelection(StructuredViewer.java:1700)
        at org.eclipse.jface.viewers.TreeViewer.setSelection(TreeViewer.java:1139)
        at org.eclipse.jface.viewers.Viewer.setSelection(Viewer.java:392)
        at com.adobe.livecycle.workbench.applicationview.views.ApplicationView.preLogOut(Application View.java:1198)
        at com.adobe.ide.singlesignon.IDESession.notifyListenersPreLogout(IDESession.java:831)
        at com.adobe.ide.singlesignon.IDESession.localLogout(IDESession.java:762)
        at com.adobe.ide.singlesignon.IDESession.logout(IDESession.java:207)
        at com.adobe.ide.singlesignon.IDESession.reauthenticate(IDESession.java:237)
        at com.adobe.ide.singlesignon.IDESession$ReauthRunner.run(IDESession.java:286)
        at org.eclipse.ui.internal.UILockListener.doPendingWork(UILockListener.java:164)
        at org.eclipse.ui.internal.UISynchronizer$3.run(UISynchronizer.java:158)
        at org.eclipse.jface.operation.ModalContext$ModalContextThread.block(ModalContext.java:173)
        at org.eclipse.jface.operation.ModalContext.run(ModalContext.java:388)
        at org.eclipse.jface.dialogs.ProgressMonitorDialog.run(ProgressMonitorDialog.java:507)
        at com.adobe.livecycle.workbench.applicationview.wizard.ApplicationExportWizard.executeExpor t(ApplicationExportWizard.java:713)
        at com.adobe.livecycle.workbench.applicationview.wizard.ApplicationExportWizard.performFinis h(ApplicationExportWizard.java:359)
        at org.eclipse.jface.wizard.WizardDialog.finishPressed(WizardDialog.java:811)
        at org.eclipse.jface.wizard.WizardDialog.buttonPressed(WizardDialog.java:430)
        at org.eclipse.jface.dialogs.Dialog$2.widgetSelected(Dialog.java:624)
        at org.eclipse.swt.widgets.TypedListener.handleEvent(TypedListener.java:234)
        at org.eclipse.swt.widgets.Display.runDeferredEvents(Display.java:4066)
        at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java:3657)
        at org.eclipse.jface.window.Window.runEventLoop(Window.java:825)
        at org.eclipse.jface.window.Window.open(Window.java:801)
        at com.adobe.livecycle.workbench.handler.impl.ExportHandlerImpl.instantiateExportWizard(Expo rtHandlerImpl.java:112)
        at com.adobe.livecycle.workbench.handler.impl.ExportHandlerImpl.doHandle(ExportHandlerImpl.j ava:82)
        at com.adobe.livecycle.workbench.handler.core.AnnotationHandlerSupport.handle(AnnotationHand lerSupport.java:67)
        at com.adobe.livecycle.workbench.applicationview.handlers.ExportHandler.execute(ExportHandle r.java:67)
        at org.eclipse.ui.internal.handlers.HandlerProxy.execute(HandlerProxy.java:293)
        at org.eclipse.core.commands.Command.executeWithChecks(Command.java:476)
        at org.eclipse.core.commands.ParameterizedCommand.executeWithChecks(ParameterizedCommand.jav a:508)
        at org.eclipse.ui.internal.handlers.HandlerService.executeCommand(HandlerService.java:169)
        at org.eclipse.ui.internal.handlers.SlaveHandlerService.executeCommand(SlaveHandlerService.j ava:241)
        at org.eclipse.ui.menus.CommandContributionItem.handleWidgetSelection(CommandContributionIte m.java:820)
        at org.eclipse.ui.menus.CommandContributionItem.access$19(CommandContributionItem.java:806)
        at org.eclipse.ui.menus.CommandContributionItem$5.handleEvent(CommandContributionItem.java:7 96)
