I am using Windows 7. I loaded the program and not get all kinds of error messages when using the software: The main message I get [over and over and over] is:
C:\Windows\system32\api-ms-win-core-synch-I1-2-0.DLL is either not designed to run on Windows or it contains an error. Try installing the program again using the original installation media or contact your system administrator or the software vendor for support.
Alright Adobe, my administrator has no clue what is causing this or how to fix this. How about someone there help with this. I have unistalled and reinstalled Acrobat X Pro and now it has problems (Watermarks don't work) but otherwise is OK. I have reinstalled DC several times after uninstalling Acrobat X. I am also now getting error messages like this simply browsing the web.
By the way, this all started with a Reader DC update to my computer several days ago that disabled Acrobat X's full function capability. So I decided to go to the Acrobat DC. Now that appears to have been a mistake. Not intuitively as user friendly and now nothing works properly.
What the happened with this product!!!!!
Hi Odelltrclan,
Edited-
As explained above, the error message seems to be appearing because of the corrupted DLL file.
You have already tried uninstall reinstall of the application and it didn't fix, so I would suggest you to try installing the new copy of DLL file api-ms-win-core-synch-I1-2-0.DLL and see if that helps.
Also, There is a chance that your api-ms-win-core-synch-l1-2-0.dll error could be related to a malware infection on your PC. These malicious intruders can damage, corrupt, or even delete DLL-related files.
Conduct a full malware scan of your PC.
Let us know if it still doesn't work.
Regards,
Akanchha
Thanks. I have tried this but it has not worked. My computer is not allowing the file to be installed. I cannot delete it because of TrustedInstaller and reinstalling any program that uses it does nothing. I have tried things on various forums for the TrustedInstaller but those things are not working as well. Very frustrating. This all started because of an Adobe Reader DC update that happened to my computer automatically and now I have several programs that don't work and error messages galore.
Hi Odelltrclan,
I apologize for the delay in response to your last message.
As added in above solution, please try running a complete scan of your PC.
and if that doesn't help, you may follow the steps mentioned below and try Manually Register Api-ms-win-core-synch-l1-2-0.dll Using Microsoft Register Server.
When you install software that uses the api-ms-win-core-synch-l1-2-0.dll dependency, the software should automatically register the file for you. In some cases your DLL file may not register properly, and as a result, will provide a "api-ms-win-core-synch-l1-2-0.dll not registered" error.
Check again.
-Akanchha
