1. Re: New Bug in Photoshop 2017 Move Tool
camp89422048 Apr 18, 2017 7:18 PM (in response to camp89422048)Also the layer is not locked if that was what you were thinking
2. Re: New Bug in Photoshop 2017 Move Tool
jbm007 Apr 18, 2017 7:25 PM (in response to camp89422048)Works fine on my windows machine.
Have you tried resetting your preferences?
3. Re: New Bug in Photoshop 2017 Move Tool
camp89422048 Apr 18, 2017 7:28 PM (in response to jbm007)How would i do that?
4. Re: New Bug in Photoshop 2017 Move Tool
jbm007 Apr 18, 2017 7:30 PM (in response to camp89422048)This should help you.
http://www.photoshopessentials.com/basics/photoshop-troubleshooting-resetting-preferences/
Jim
5. Re: New Bug in Photoshop 2017 Move Tool
camp89422048 Apr 18, 2017 7:36 PM (in response to jbm007)I reset them and it still does not work. I also uninstalled it and reinstalled it and it still did not work
6. Re: New Bug in Photoshop 2017 Move Tool
jbm007 Apr 18, 2017 7:41 PM (in response to camp89422048)Can you post a screen shot of your layers panel?
8. Re: New Bug in Photoshop 2017 Move Tool
Mohammad.Harb Apr 18, 2017 7:43 PM (in response to camp89422048) -
9. Re: New Bug in Photoshop 2017 Move Tool
camp89422048 Apr 18, 2017 7:44 PM (in response to Mohammad.Harb)That still does not allow me to move layers
10. Re: New Bug in Photoshop 2017 Move Tool
jbm007 Apr 18, 2017 7:48 PM (in response to Mohammad.Harb) -
11. Re: New Bug in Photoshop 2017 Move Tool
camp89422048 Apr 18, 2017 7:51 PM (in response to jbm007)I don't know if this helps but when i try to drag my cursor goes white much like the direct selection tool
12. Re: New Bug in Photoshop 2017 Move Tool
camp89422048 Apr 18, 2017 8:25 PM (in response to camp89422048) -
13. Re: New Bug in Photoshop 2017 Move Tool
Trevor.Dennis Apr 18, 2017 8:28 PM (in response to camp89422048)Can we clarify exactly what your issue is? Are you saying that you are unable to drag an object around the canvas with the Move tool? And you have Auto select turned off in the Options bar?
The white cursor arrow is correct, and changes to white from the Move tool cursor as you start dragging the layer content. With Auto Select unchecked, you can enable it by Ctrl clicking the layer content, (which is my preferred way of working).
This is so unusual, I strongly suspect something else is going on, like you have a Copy-merged layer at the top of the stack which is hiding the movement. If you open Layer Panel Options and chose the large thumb nail, does the object move in the thumbnail, or is it definitely static?
If you still have the issue, a screen shot of your entire workspace might help. Un dock the layers panel and expand it so we can see as many layers as possible, and perhaps twirl shut the layer effects. There is something a bit weird going on here methinks.
14. Re: New Bug in Photoshop 2017 Move Tool
Trevor.Dennis Apr 18, 2017 8:30 PM (in response to camp89422048)camp89422048 wrote
Also there is no photoshop icon
Tiny screen shots like that are not helpful. We need to see the context to understand what is going on. Just grab the entire screen, and paste to this thread with Ctrl v (Cmd v). You don't need to use the third part image hosting site.
15. Re: New Bug in Photoshop 2017 Move Tool
camp89422048 Apr 18, 2017 8:33 PM (in response to Trevor.Dennis)Here if a video of it not working
16. Re: New Bug in Photoshop 2017 Move Tool
camp89422048 Apr 18, 2017 8:54 PM (in response to Trevor.Dennis)Also if i select part of a layer i can move the selected part around
17. Re: New Bug in Photoshop 2017 Move Tool
Trevor.Dennis Apr 18, 2017 9:45 PM (in response to camp89422048)camp89422048 wrote
Thanks for the video. I have watched it several times and can see nothing wrong with your workflow. We can see the cursor change to the white arrow indicating that you have the mouse button pressed. The layer is not locked. AFAICT it should work, but it doesn't.
It looks like Windows 10. What have you tried? I believe you have reset Preferences?
Have you reinstalled Photoshop?
Have you restarted your computer and Photoshop?
Have you tried a new image document?
Are you using a mouse, or tablet, and have you tried a different mouse?
First thing to try is starting Photoshop with the Shift key depressed to force it to ignore any third party plug-ins and extensions. If that gets it working, then you'll obviously have to uninstall them one at a time to see which one is the problem. If that makes no difference, reinstall Photoshop but run the Cleaner tool.
Use the Creative Cloud Cleaner Tool to solve installation problems
Fingers crossed that fixes it, because I am struggling to think what else might be causing this.
Good luck
19. Re: New Bug in Photoshop 2017 Move Tool
camp89422048 Apr 19, 2017 7:36 AM (in response to Jeff Arola)It looks like Windows 10. What have you tried? I believe you have reset Preferences?
I have done all of these and it still does not work and the condensed bar did not do anything just made it look different
20. Re: New Bug in Photoshop 2017 Move Tool
camp89422048 Apr 19, 2017 10:11 AM (in response to Trevor.Dennis)Is there a way to downgrade PS to see if it really is 2017 or nor
22. Re: New Bug in Photoshop 2017 Move Tool
Trevor.Dennis Apr 19, 2017 2:48 PM (in response to camp89422048)camp89422048 wrote
The thing is, those of us that have responded and are using Windows 10 with CC 2017, are not having this issue. So it seems to me that there is either something happening with your operating system, like a broken API, or that Photoshop is broken. If you have not already done so, it really doesn't take long to reinstall, but be sure to run the cleaner tool (linked in post #17).
I assume you have tried starting Photoshop with the Shift key depressed to rule out third party plug-ins and extensions?
23. Re: New Bug in Photoshop 2017 Move Tool
jbm007 Apr 19, 2017 4:05 PM (in response to Trevor.Dennis)If he decides to go that route he should also use the ACC cleaner tool, reboot and then re-install PS.
he might also run a registry cleaner for added effectiveness.
Jim
24. Re: New Bug in Photoshop 2017 Move Tool
camp89422048 Apr 19, 2017 4:14 PM (in response to camp89422048)Ok figured it out. I recently installed a Wacom Tablet Driver and when im not using it it dissallowed me to move things in photoshop but i just had to uninstall it.
25. Re: New Bug in Photoshop 2017 Move Tool
jbm007 Apr 19, 2017 4:20 PM (in response to camp89422048)Hooray!!!!!!!!!!!!!!!!!!!!
Glad you figured it out.
Jim
