Hello,
New APE user, I have a big problem with the burning of an Iso image in Blu-ray format of the film of 1h15mn I realized with APE 14.1 .... and that I have to present in public (about 300 spectators) in 3 weeks.
The APE online help does not address this problem (incompletely updated, it often refers to APE 13!) and no answer to my problem on the forum in French.
Although not very fluent in English, I found two discussions on this english forum but one is very centered on APE 13 and proves that burning ISO image > 1 GB does not work (but it is written that the problem is solved with APE 14). The other only concerns a small Iso image (film with menus, which will concern me) with burning a DVD (successful) and not a Blu-ray. I have implemented the recommendations of these two discussions but Iso image burning does not work.
Here are some informations about my material, my project and what I did taking into account my readings :
Preparation made:
Burn button -> ‘’Media encoding’’ and then ‘’Burning in progress’’. Ends after 4 to 5 hours with the laconic message ''Burning in progress / Error''
Thank you in advance for your support
I can confirm that at least this is true as it happened to me.
With PE 13.1 one could neither succesfully burn directly to a Blu-Ray nor via the image (the >1GB issue).
With PE 14 (& 14.1) both these methods work - for me. As is generally advised I create an ISO image & then use ImgBurn.
For the rest you'll need to see how the others chime in.
Thank you.
So I have done many tests to get to burn an iso H264 - Blu-ray file of my movie of 1h15 (13 GB - 20 Mbps). For this I removed two small "parasite" elements of 1/25 sec on the editing table and I made a global rendering of the film before export, after erasing the preview files.
On the other hand, I can’t burn a Blu-ray image of the movie with six scene markers (but no stop mark) with or without menu. I've done some tests with a short editing of 2 minutes (about 30 pictures and videos) and two scene markers or two time markers: I have an error message at the end of the burning process ! While this works for an iso DVD image burning!
Can an APE 14 (or 14.1) user tell me if he has successfully burned a movie with menu and menu markers into Blu-ray? If so, what should I do to make it work ?
If we can not do such an engraving with APE 14.1, is there a software (free if possible) that allows to integrate a menu to be realized and two images iso (the film and a teaser of 1mn26) on a disk Blu-ray?
Thanks in advance.
Hello,
Not having been able to burn with APE 14.1 a Blu-ray disc image of my movie with menus and menu markers, I switched to Nero Video. I finalized my movie with two menus and six chapters from two mp4 files made with APE. No problem burning a disk image and then burning Blu-ray with Nero Burning Rom !!!
Hi ,OP ,for me that i never used the APE 14.1 to burn ISO image,from what you said,this tool is not ideal either.
I know a better tool than that :
