2 Replies Latest reply on Apr 20, 2017 8:09 AM by Jacki_Felice
    CFChart - Need to know how to pass NULL values from a query in CF11
    Jacki_Felice Level 1
      HI Everyone,
      I am really hoping this is an easy question to answer because I have been searching everywhere and all I try is not working.
      I have a SQL query (created by Oracle DB) that creates multiple cfchartseries using date as the column item and a number for the value. My issue is there are null values for the value field but I need it to plot
      <cfchartseries
        label="LRF"
        scales= "x,y"
             <cfloop query="qTrend">
                  <cfif qTrend.LRF gt 0>
                       <cfchartdata item="#qTrend.report_date#" value="#qTrend.LRF#">
                  <cfelse>
                       (i have tried:
                           <cfchartdata item="#qTrend.report_date#" value=" ">
      <cfchartdata item="#qTrend.report_date#" value="null">
      <cfchartdata item="#qTrend.report_date#" value="">
      <cfchartdata item="#qTrend.report_date#" value="0">
      and none work)
                  </cfif>
             </cfloop>
        </cfchartseries>
      The ERROR I get is
      Attribute validation error for CFCHARTDATA. The value of the VALUE attribute is invalid. The value cannot be converted to a numeric because it is not a simple value.Simple values are booleans, numbers, strings, and date-time values
      The Chart will display when I use the value ="0" but this pulls the line down instead of just STOPPING and then starting again when a numeric value is in the next record.
      Here is my query
      THANKS for help... I need it quickly if possible
      JV
        • 1. Re: CFChart - Need to know how to pass NULL values from a query in CF11
          WolfShade Level 4
          I suspect that the issue lies in how you are comparing values in your conditional.
          Change this: <cfif qTrend.LRF gt 0>  to this: <cfif val(qTrend.LRF) gt 0> to force the value to numeric.  If it's blank (CF interprets database nulls as empty strings), then val('') is 0.
          HTH,
          ^_^
          • 2. Re: CFChart - Need to know how to pass NULL values from a query in CF11
            The issues is that when using the <cfchartdata> tag it will not accept a blank, null, space without creating an error. I did not find a resolve in using this method to insert my chart values so I created a work around that is working.
            I removed the <cfchartdata> tag all together and built an ArrayNew(2) to pass both item and value data. Like shown here
            <cfset a_data=ArrayNew(2)>
                   <cfset a_data[#qTrend.currentrow#][1]="#qTrend.report_date#">
                        <cfset a_data[#qTrend.currentrow#][2]="#qTrend.LRF#">
                   <cfelse>
                        <cfset a_data[#qTrend.currentrow#][2]="null">
                   </cfif>
              </cfloop>
            THEN pass in the Array in the <cfchartseries> tag as show below:
              <cfchartseries
              label="LRF (InMill)"
              scales= "x,y"
            data=#a_data#
            NOTE: this attribute will only take an Array of Arrays so make sure you do not attempt to insert an Array with a Struct in it... ERROR!
            There were many ways to write this but for some reason between CF11, Tomcat, and ZingCharts this is the only way I found other then completely removing the <cfchartseries> tags and completely working around CF11 and using the "style" .js file to built the entire chart.
            I really hope this helps the next person looking for this FIX....!!
            I am also open to other ways ... so if you like please continue to post to this if you find a better simpler way...THANKS
            JV
