ERROR! Some files are not available and cannot be imported at this time. Please download files to your camera roll and try again.
This message keeps coming up all the time, I can only get about 1 in 4 video clips to load into the iPhone Premier Clip App. All my media is from my camera roll. I'm on a WiFi connection and the files play fine right out of my iPhone photos/video gallery.
iPhone 6 IOS 10.3.1
Latest version of Premier Clip download fromApp Store this evening
What am I doing wrong?
Hi Sam,
This error only comes up if you try to import files into Premiere Clip which are not in your Camera Roll.
You can only import the files which are in your Camera Roll.
Regards,
Sheena
Hi Sam,
Regards,
Sheena
If I am correct, iCloud Photo Library is causing this. On my iPhone 6 (iOS 9.3.3) I have enabled "Optimise iPhone Storage" which automatically deletes photos that are uploaded in iCloud. This is very good feature for saving space but it's causing problems with basically every photo/video app that doesn't use stock media picker that is provided in iOS (UIImagePickerController). I've tried a few ways to download the picture I wanted to add into Premiere Clip, I copied it, I duplicated it, I tried to send it via iMessage - every process shows either "Processing..." or "Downloading..." but still no success in Premiere Clip, but you can try it out, maybe Apple fixed it in iOS 10. Other than that I assume the only way to fix this is to set iCloud Photo Library to "Download and Keep Originals", unfortunately I can't try this out for you because I don't have enough space on my iPhone.
I’m having this same issue. My images are in my camera roll but I think I see the issue: with newly shot/imported images — ones that are still in the process of completing their uploa/sync with iCloud, they appear to be unavailable to Adobe Clip/Premiere. You’d think Adobe would fix this as it makes using the mobile app very limited.
I have read the answer that is marked as “correct” but still only getting about 9 clips out of 50 am trying to import ..... so frustrating !!! I am selecting the pictures from my camera roll as instructed but it’s not working ??? Really doesn’t seem like this app is worth using at all unless someone can tell me what I can do ?? Would appreciate any help am trying to do a slide show of my sons wedding. Help !
Janette
same problem an my first exportation on youtube is bad quality
no solution ?
so i don't have yhis probleme with IMOVIE
APPLE will be better than ADOBE ?
i'm really hangry, cause iwant my clip back and export in HD.....
Sorry, but that is not the case. Files from the Camera Roll give the same error message.
if anyone is having the same problem still I know how to fix it
1.go to settings
2.search for photos
3.press on it
4.OFF ICLOUD PHOTO LIBRARY
Now it should work if it is still not working then there is no solution for it
this works for iOS 11
