5 Replies Latest reply on Apr 20, 2017 11:54 PM by Rob Hecker2
    How do I configure the form validation to only accept letters for firstname and lastname?
    kims22993834
      I'm working in Dreamweaver CS6 and have a question in regards to the form validation. I already have a hidden input field in place and with the coding in my formmail script it has stopped spam over the years. At the moment however, I'm getting spam where the firstname and lastname fields present with a mixture of numbers and letters.  This spam seems to be only targeting my "Required" fields. Is there a way to specify that the name fields type:text be only letters a to z?
      The form validation at the moment is:
      function MM_validateForm() { //v4.0
        if (document.getElementById){
          var i,p,q,nm,test,num,min,max,errors='',args=MM_validateForm.arguments;
          for (i=0; i<(args.length-2); i+=3) { test=args[i+2]; val=document.getElementById(args[i]);
            if (val) { nm=val.name; if ((val=val.value)!="") {
              if (test.indexOf('isEmail')!=-1) { p=val.indexOf('@');
                if (p<1 || p==(val.length-1)) errors+='- '+nm+' must contain an e-mail address.\n';
              } else if (test!='R') { num = parseFloat(val);
                if (isNaN(val)) errors+='- '+nm+' must contain a number.\n';
                if (test.indexOf('inRange') != -1) { p=test.indexOf(':');
                  min=test.substring(8,p); max=test.substring(p+1);
                  if (num<min || max<num) errors+='- '+nm+' must contain a number between '+min+' and '+max+'.\n';
            } } } else if (test.charAt(0) == 'R') errors += '- '+nm+' is required.\n'; }
          } if (errors) alert('The following error(s) occurred:\n'+errors);
          document.MM_returnValue = (errors == '');
      If anyone can help it's greatly appreciated.
        • 1. Re: How do I configure the form validation to only accept letters for firstname and lastname?
          Rob Hecker2 Adobe Community Professional & MVP
          You are using machine-generated javascript validation. I use PHP validation, not javascript, and the generated code is not human friendly, so I would not try to modify that function. (but I will provide a solution). Do you understand what I mean? People write code that is easy to understand and modify  by other people. That code isn't written with that objective.
          Validation can happen on the form, after the form has been submitted, or both. I will provide a solution that happens on the form.
          Remember that names may contain more than just alphabetical characters. They may contain dashes, apostrophes, empty spaces, accented characters and non-latin characters like umlaut (Klein-Smith, O'brien, Del Oro, Züm).
          The following example uses a regular expression to match the name. Note that it explicitly includes accented characters for European languages, but it would reject names using, for instance, Vietnamese characters. It will not allow a name with more than 80 characters. This solution requires the HTML5 doctype. It will not work with XHTML or HTML4.
          <input type='text' name='lastname' id='lastname' pattern="[A-Za-zéèàùâêîôûçëïüæœÀÂÆÉÈÊËÏÎÔŒÙÛÜŸ'\s*]{1,80}" title='Some characters may be rejected'/>
          An alternative method would be to explicitly reject certain characters, such as <>?*&%. Read up on regular expressions if you want to explore that option.
          • 2. Re: How do I configure the form validation to only accept letters for firstname and lastname?
            pziecina Level 6
            For client side form validation use the html5 doctype and html5 form elements as these have built-in client side form validation, (just requires you to say what) see -
            https://developer.mozilla.org/en-US/docs/Learn/HTML/Forms/Form_validation
            You must use server side validation also.
            • 3. Re: How do I configure the form validation to only accept letters for firstname and lastname?
              kims22993834 Level 1
              Thank you for your information Rob, greatly appreciated.
              I was wrong, it’s not targeting ‘required’ fields. The spam bot is only filling in last_name, first_name and email. These are required, however I have the enquiry field (textfield) as a required field as well and it’s left out.
              I added your code and even though it won’t let me enter numbers and submit the form (...it works for users), the spam bot is still getting through.
              This is one of them:
              Subject: Enquiry_form1
              email: mike@infocapsys.com
              realname:
              first_name: 58f90f011a573
              last_name: 58f90f011a5b5
              submit: Submit
              reset: Reset
              I'm using tectite formmail  and have set a few conditions to stop spam. As mentioned above it has worked over the years. Someone mentioned adding a form check function that you can call on the submit button to check the time taken to submit.
              function formCheck(){
              var timeStart;
              var timediff;
              $("input").bind('click keyup', function () {
                  timeStart = new Date().getTime();
              timediff= Math.round((new Date().getTime() - timeStart)/1000);
                if(timediff < 3) {
                  //throw a warning or don't submit the form
                else submit(); // some submit function
              Do you think something like this will work Rob? When the bot is filling in the form errors arise, however the form is still sent, so I'm assuming that this time check is independent of the form and should work. My site is html5. If you think it will work do I place it in the <head> section (does it need to be read before the form on the page), or a the base of the page? Also where they have - //throw a warning or don't submit the form... is there some code I need to place here to have it not submit the form?
              Thanks so much Rob for your advice.
              Kim
              • 4. Re: How do I configure the form validation to only accept letters for firstname and lastname?
                Hi Rob and Pziecina,
                Tectite.com have sent through a php file to upload with my existing tectite formmail php, which targets the issue. They're calling it the hexidecimal attack and have a solution you can download here - look under tweet - "Getting spam with "58" at the start of the name field?" Russell Robinson (@tectitecom) | Twitter .
                My client hasn't mentioned any more spam, so we'll see how it goes.
                Thanks again for all your advice.
                Cheers,
                kim
                • 5. Re: How do I configure the form validation to only accept letters for firstname and lastname?
                  I use a honeypot field on forms, and that has worked very well. On the actual form I usually only make the email field the email type, then let PHP do the real work of validation and sanitation on the POST array.
                  In your case, since you are getting numbers in the name field, it's easy to find out if there are numbers in the field and then reject submissions that contain them. preg_match() could be used for this, or strpbrk(). The function from Russel Robinson probably works in a similar way.
                  PHP has a set of filter functions for handling form data. https://www.w3schools.com/php/php_ref_filter.asp
