2 Replies Latest reply on Apr 19, 2017 6:05 AM by trevreav
    Semi transparent object, is it possible?
    trevreav Level 1
      Hi, I'm very new to Animate - so be gentle with me please!!
      I have all of the illustrations prepared in Illustrator which I'm importing through CC library into Animate.
      I'm trying to get something to animate with movement and a change of transparency if possible. Imagine a bull running with steam coming out of it's nose, so appearing quickly from 0% opacity to about 75% opacity and back again.
      Is this possible in Animate?
      Many thanks.
        • 1. Re: Semi transparent object, is it possible?
          macpawel Adobe Community Professional
          Yes, off course,
          First start to change your graphic into e symbol. If you don't plan to add any interactivity - use Graphic Symbol in this case.
          Then
          Select your symbol in timeline window and use right mouse buton to turn it into a Tween. Select Create Motion Tween options.
          Go to last frame (your tween probably is 24 frames long - your Frame Rate settings) - maybe 24 select symbol on Stage and chage it's opacity in Properties Panel to 75%. Finally go to first frame and change Opaity to 0%
          You can adjust length of your animation (speed) by dragging last frame of your Tween in timeline
          Pawel
          • 2. Re: Semi transparent object, is it possible?
            trevreav Level 1
            Marvellous, and thanks very much fro the info - That's the sort of thing I would have expected, but I wasn't converting it to a symbol.
            Many thanks and have a good day.
            Trev
