• Global community
    • Language:
      • Deutsch
      • English
      • Español
      • Français
      • Português
  • 日本語コミュニティ
  • 한국 커뮤니티
Exit
0
Interactive PDF - make objects appear on click?
Community Beginner ,
Apr 19, 2017 Apr 19, 2017
Hello!
I'm making a slide show presentation in InDesign.
Simply I have a page with many dot points, and want each single one to appear on click as I'm talking.
Is there a way to make objects appear on click in an Interactive PDF when set up in InDesign?
I was instead going to put each new dot point on a new page - but it seems excessive.
Thank you
TOPICS
Edit and convert PDFs
Views
4.6K
Translate
Translate
Report
Report
Community guidelines
community guidelines
Community Expert , Apr 19, 2017 Apr 19, 2017
I don't know how InDesign handles interactive documents, my InDesign documents all go to a printer, so I've never experimented with that part of ID. However, in general there are several ways you can show items based on mouse clicks. You've already mentioned one: Having one page per step in your "reveal". This is the method that will always work, regardless of what system you use to view the presentation.
You can use form fields and "wrap" your hidden elements that you want to reveal in e.g. an
Votes
Translate
Translate
Community Expert ,
LATEST
You can use form fields and "wrap" your hidden elements that you want to reveal in e.g. an interactive button, which can show a PDF page or an image once it's display property is set to being visible. This would however require that you take apart your page and isolate the elements that you want to hide/show and then package them up in buttons and add the logic that would show one after the other when you click on the page.
Another method is to use layers in a PDF file. You can show or hide layers using JavaScript, so again, you can add logic to your PDF page that starts with just the background, and then reveals one layer at a time, adding to the background. This also would require that you somehow create these layers based on the content you want to show, one at a time.
Layers and form fields may not work in all PDF viewers, depending on their support for these features and JavaScript.
Unless your application has built-in support to create PDF documents with that functionality already added to the PDF file, using one page at a time is very likely the least complex and time consuming method.
Votes
Translate
Translate
Report
Report
