I'm converting PDF files into 1, but I seem to get error message "CONVERSION FAILURE
Hi Markl38688703,
I assume you are trying to combine multiple pdf files to one? Or are you trying to convert the pdf files to word using the "Export pdf"?
If that is the case, then you may go through the help document File conversion error | ExportPDF
Also confirm the size of the files that you are trying to convert.
Regards,
Akanchha
Yes, Sometimes it works, sometimes I get error message.
The files are 5 1 pagers
Sorry for the inconvenience caused to you.
Please try : https://cloud.acrobat.com/exportpdf
Keep us updated if it works.
-Thanks
Sunil Soni
No, still not working. This is frustrating that we are paying for a service that doesn't seem to work. Can you get this resolved asap?
can someone remote connect to my computer and get this figured out?
thanks
Fran
HI Fran,
I sent you an email to you regarding this.
Thank you.
Hisami
HI Hisami,
I tried the link and still not working. Can you remote connect to my computer and try to figure this out?
thanks
Fran
It seems that one of the files was set page extraction not allowed.
To find out the setting:
1. Open a PDF file in Adobe Reader (you can download Reader from www.adobe.com)
2. Select "File" menu
3. Select "Properties..."
4. Select "Security" tab
5. Check "Document Restrictions Summary"
Thank you.
Hisami
