I'm a very basic user of InDesign. I essentially just use it to mock-up my printed portfolio - I'm a professional photographer. As I use double sided paper to print my portfolio, in Indesign I created a document that is made up of double page spreads. Sometimes there's one photograph on a page, sometime a photograph is a double page spread.
What I want to is simply output a PDF of the portfolio that maintains the format of a book, so the double page spreads are seen as a single "page", so as the user scrolls through the document, they see each spread in order.
The other thing I'm wondering is what options do I have to set how the document is viewed once I send it? I don't want to send potential clients a list of setting they need to plug into Reader etc just to see the PDF the way I intend.
Thanks!
When you Export your Document you can try use Spreads option instead of Pages in General settings of PDF Export window
Pawel
Have a look at Publish Online, it may suit your requirements.
Pawel
You have to set up your document in the size of a SINGLE page, not in the size of a spread.
You have to set up the document with facing pages.
Then you can export as PDF with single pages or with spreads.
