3 Replies Latest reply on Apr 26, 2017 8:12 AM by milkos59738379
    Find next
      good morning prepress comunity
      i'm using indesign cs6 and i've got this problem:
      when i setup a grep search string (e.g. [aeiou]') i'm not able to find next occurrence of the string using shortcut ALT+CTRL+F
      if i try to use it i receive a Adobe Indesign window saying "l'elemento cercato non è stato trovato" (searched element not find).
      it's a know problem or it occours only to me ?
        • 1. Re: Find next
          winterm Level 5
          Notice that Find and Find Next shares the same button in F/C dialog. So you can’t invoke Find Next in a state when there isn’t Find Next button.
          After you click Find (and button changes to Find Next), you can use command Ctrl+Alt+F (or Alt+N) successfully while Find/Change dialog is open and active.
          That said, behavior is rather complicated, and you may not like it, however, I believe, your InDesign is acting „normally”, as it supposed to be.
          • 2. Re: Find next
            milkos59738379 Level 1
            really thank you,
            i was'nt smarties
            • 3. Re: Find next
              how to keep findnext button active without the window dialog active ?
              in this way i can findnext occurrence, manual replace it and so on...
              yesterday i was able to do it, today not
