• Global community
    • Language:
      • Deutsch
      • English
      • Español
      • Français
      • Português
  • 日本語コミュニティ
  • 한국 커뮤니티
Exit
0
Populating fields from combo box selection
New Here ,
Apr 20, 2017 Apr 20, 2017
https://acrobatusers.com/tutorials/change_another_field
Being new to all this and not not being a coder by any stretch of the imagination I am feeling very pleased with myself having managed to make one combo box selection populate several other fields using the above tutorial.  My problem is I have several other combo boxes on my form which I am not able to separate from the document code I have followed. Can anyone help please or do I need to start again.
TOPICS
Edit and convert PDFs
Views
737
Translate
Translate
Report
Report
Community guidelines
community guidelines
Community Expert ,
Duplicate the process, giving all functions and doc-level variables new names.
Votes
Translate
Translate
Report
Report
New Here ,
Thankyou I will try that. In the meantime would you know a way I could have the word "Select" as the combo box field you see and none of the fields populated when viewing the form for the first time.
Votes
Translate
Translate
Report
Report
Community Expert ,
Apr 21, 2017 Apr 21, 2017
Just enter it as an option in your drop-down and select it, so it's the default value.
Votes
Translate
Translate
Report
Report
New Here ,
Thanks . When I use the function "Document JavaScripts" I cannot get it to see the other combo box even when I change the names am I doing something incorrectly?
Votes
Translate
Translate
Report
Report
Community Expert ,
What do you mean by "can't get it to see the other combo-box"?
Votes
Translate
Translate
Report
Report
New Here ,
OK when I select "Document JavaScripts" from the menu it comes up with the Script Name "SetFieldValues" and this is reading the code that is used in my first combo box. When I select the next combo box it still reads this same code and I cannot change it separately.
Votes
Translate
Translate
Report
Report
Community Expert ,
The document scripts are not connected to the fields at all. They exist independently of them.
If you have a function there call SetFieldValues that you're calling from Dropdown1 and you want to create a new function for Dropdown2, just duplicate it, renaming it from SetFieldValues to SetFieldValues2, or whatever. The name doesn't matter, as long as its unique.
Votes
Translate
Translate
Report
Report
New Here ,
Test
Votes
Translate
Translate
Report
Report
New Here ,
I have copied and paste document script to different name. How do I attach the document script to the appropriate combo box please?
Votes
Translate
Translate
Report
Report
Community Expert ,
Same as before, just using the new function name you've used for the second script...
Votes
Translate
Translate
Report
Report
New Here ,
Thanks for help but I am getting nowhere and I am wondering if it would be best to start again and explain what I am after rather than modifying a solution already posted.
My form has 2 separate combo boxes. One combo box selects one of say 3 manufacturers of temperature measuring equipment and populates the respective fields :Model, Serial Number, Calibration Certficate Number and Next calibration due date. The other combo box is exactly the same but for pressure measuring equipment. What is the best way to achieve this please?
Votes
Translate
Translate
Report
Report
Community Expert ,
If you don't want to mess around writing or editing code yourself, you can use this tool I've developed which allows you to set it up quite easily, and for multiple fields: Custom-made Adobe Scripts: Acrobat -- Populate Fields From Dropdown
Votes
Translate
Translate
Report
Report
New Here ,
LATEST
Thanks I am going to get one of your tools as that will save my sanity.
Cheers for your help
Votes
Translate
Translate
Report
Report
