8 Replies Latest reply on May 10, 2017 5:55 AM by Woye
    Shortcuts suddenly prompts different tools [OSX and Wacom]
    Woye
      Hi
      My shortcuts have been acting weird the last week or so. When I press "T", 1 out of 3 times it chooses the type-tool, but often it will choose the Rectangle tool. If I press T a second time (because it chose the Rectangle tool), it will choose the text tool. This happens to most of the shortcuts I've tried. It's not random which tool it chooses - E (eraser) becomes "F"/Screenmode, M (marque) becomes "O"/Dodgetool and so on.
      I've tried different things without luck: Reset shortcuts, reset preferences, installed a plugin to fix a problem with Wacom tablets.....but nothing is working.
      Hope you can help me, cause shortcuts is a really important part of my workflow.
      Charlotte
        • 1. Re: Shortcuts suddenly prompts different tools
          Trevor.Dennis Adobe Community Professional (Moderator)
          Hi Charlotte
          If this is Photoshop CC, the first thing to try is to click on the three dots at the bottom of the Toolbar and choose Edit Toolbar and the then click on Restore Defaults
          Otherwise, can you confirm what version of Photoshop, and what operatin system you are using?
          • 2. Re: Shortcuts suddenly prompts different tools
            Woye Level 1
            Hi
            Thank you so much for your quick answer!
            I've restored defaults but unfortunately, the shortcuts are still not working properly.
            My Photoshop is version 2017.1.0 and I'm using macOS Sierra (10.12.4).
            Thanks again.
            • 3. Re: Shortcuts suddenly prompts different tools
              I've read your post again, and I am guessing that you are using a Mac, and have installed the White Window plug-in.  Is that right?
              Have you tried opening the Edit > Edit Shortcuts and using the drop-down towards the top right and choosing Photoshop Defaults?
              Also select the Essentials workspace, and then Reset Essentials workspace.
              If you are still in trouble after that it might be timer to reinstall, but try starting Photoshop with the Shift key held down to force Photoshop to ignore any third party plug-ins and Extensions.
              Did you have a particular reason for installing the White Window plug-in (if you have in fact done so).  Did you have any of the symptoms described on the plug-in page?  Have you tried disconnecting the tablet?
              Did you restart Photoshop after making earlier changes?  In fact restart the computer just to be sure.
              • 4. Re: Shortcuts suddenly prompts different tools
                Woye Level 1
                I've tried reset essential workspace, Photoshop default shortcuts and starting with Shift Key held down, restarting both computer and Photoshop, but alas no change.
                Your'e right, it's the White window plugin I've installed. To be honest, I just tried to install it because I couldn't find other solutions. I didn't recognise any of the symptoms, but was hoping it would help anyway.
                So I guess its time for a reinstall:)  - I'll try that, and get back to you.
                Again - thanks!
                • 5. Re: Shortcuts suddenly prompts different tools
                  Woye Level 1
                  Hi again.
                  Tried to uninstall and reinstall Photoshop, but the shortcuts are still broken. Same behaviour as described before.
                  Does anybody have any other solutions?:)
                  • 6. Re: Shortcuts suddenly prompts different tools
                    I should have mentioned that it would be a good idea to use the Cleaner tool when reinstalling
                    Use the Creative Cloud Cleaner Tool to solve installation problems
                    Sorry, but try reinstalling again using the cleaner tool.  I am a Windows user so out of my depth with OSX, but I'll edit your subject to reflect that you are a Mac user.  My gut tells me that it is related to your Wacom tablet though.  If you were using Windows I'd suggest disconnecting the tablet, and using Task manager to 'End any Wacom Processes' but I don't know how that works with OSX.
                    Can you tell us what tablet you are using and its driver version?
                    • 7. Re: Shortcuts suddenly prompts different tools
                      Woye Level 1
                      Sorry for the slow response - had to do some work.:)
                      I tried to run the Cleaner tool + uninstalled wacom driver and software + disconnected the tablet - but sadly nothing worked.
                      I work on 2 different tablets: Wacom Intous 5 and a Wacom Intous 3 - but the issue is the same, weather I use tablet, mouse or the track pad on my laptop. The wacom driver is 6.3.20-11.
                      When I started Photoshop after reinstalling and Cleaner tool, it actually seemed to work...but after a few minutes it started to act up again.
                      • 8. Re: Shortcuts suddenly prompts different tools [OSX and Wacom]
                        Woye Level 1
                        Hi again
                        It seems to have fixed it self. Photoshop had an update earlier this week, which I installed, and there hasn't been any issues since. Let's hope it was a bug in the previous update, and that it doesn't come back
                        Thanks again for the help and advise.
