3 Replies Latest reply on Apr 24, 2017 9:04 AM by ryanskihead
    PhoneGap Build API - upload zip file failed
    danielem18727002
      I have found similar issues around about this but I have not found a solution yet.
      I am simply trying to upload a zip folder to PhoneGap Build by using the APIs:
      var options = {
         form: {
           data: {
           platforms: ["android", "ios"]
         file: "./www/ppmobilev3.zip"
      api.put('/apps/0123456', options, function(e) { // UPLOADING ZIP FILE
        if (e !== null){
         console.log('error:', e); //e = Error: upload failed; please try again [50]
         return;
        waitingForPendingBuild(api);
      and I randomly getting the error: "Error: upload failed; please try again [50]"
      Now I know the problem is with the zip file because if I zip the folder manually via Window default compressed and then upload it to PhoneGap website, it works correctly...when in my code I use gulp-zip to zip the folder and then the API to upload it then it doesn't work!!
      So the question is:
      what command/application/software I need to zip a folder which is suitable for the PhoneGap Build website? or better what Saint I need to pray to get this fixed?
