4 Replies Latest reply on Apr 21, 2017 7:52 AM by winterm
    fit frame proportionally
      may be winterm can clear me this issue too...
      i'm not able to use ALT+SHIFT+CTRL+C to fit frame proportionally. Simply nothing happens.
      Same problem with CTRL+ALT+C
      ALT+SHIFT+CTRL+E and ALT+CTRL+E works fine.
      The problem occurs when shortcuts are invoked from keyboard. If I select command from contestual menu (right+click) its all right.
      Grazie ancora.
        • 1. Re: fit frame proportionally
          Eternal Warrior Level 4
          Hi milkos59738379
          Have you looked at the keyboard shortcuts?
          EDIT > Keyboard Shortcuts...
          Product Area: Object Menu
          Either try the default shortcut specified or edit it and either change or re-apply and maybe this should fix it?
          Otherwise it may be a case of resetting InDesign Preferences.
          Hope winterm won't mind me butting in here
          • 2. Re: fit frame proportionally
            winterm Level 5
            hey, you're mostly welcome!
            I must confess I have my kb shortcut set customized pretty much, and it was years ago.
            So now I'm not sure about ALL my kb commands, which are 'standard' and which are not. Sorry for that.
            And yes, I think, I changed something in 'frame fitting options', too.
            Just check what command you see in a menu list? (before going to Edit Shortcuts window...).
            • 3. Re: fit frame proportionally
              milkos59738379 Level 1
              hello Eternal Warrior
              thanks for your suggestion. what means "won't mind me butting in here" ?
              it's a common saying ?
              Yes, i've search inside kb shcut and always looks ok.
              Maiusc+Ctrl+Alt+C is assigned to the correct function.
              I was been lazy and i have supposed everybody hade the solutions at finger tips. may be i've to search deeper to find the solution.
              if i delete the shcut sequence i notice i can't reassign it to the same sequence ALT+SHIFT+CTRL+C. i've solved assigning ALT+SHIFT+CTRL+N. but only for now...
              ot: what about my english ?
              • 4. Re: fit frame proportionally
                winterm Level 5
                It's about what I'm doing right now
                You mentioned me in your question. Eternal Warrior answered, despite you didn't ask him. He may feel a bit uncomfortable for that, so he asks if I don't mind.
                Now I'm answering to your question you asked him, so I:
                Hope Eternal Warrior won't mind me butting in here
