13 Replies Latest reply on May 22, 2018 10:35 PM by ETUD
    Photoshop 2017 freezing frequently (30s-1min)
    Brounzer Level 1
      Hi all,
      Windows 10 64-bit
      16GB Ram, i7, Quadro M1200
      SSD M2 with read/write rates around 1gb/s
      I keep having the issue that Photoshop 2017.1 starts fast but then hangs for 30 seconds straight. I'm not opening a document.
      The document that I open afterwards causes similar issues to occur, even though the document is just a few MB big.
      Documents are all stored on my local drive. There are a few network drives installed on my system, but they do are not output paths / file paths.
      I've analysed the process and the following occurs:
      It's clearly reporting Not responding but only little CPU use.
      The wait chain reports it's 'waiting for Network I/O'.
      What exactly is it doing and what can I try to further analyze the root-cause of the issue?
      I know you guys may consider this insufficient information to address the issue. But any word on how to further analyze the issue?
      EDIT: New insights
      - Issue does not occur when I disable all my network adapters.
      - Issue does not occur with Illustrator or After Effects, which I also use frequently.
      - Issue always seems to take the exact same time (I could hold a stopwatch and measure the same time every time it freezes)
