I am running Win10 64 using Adobe CC apps LR (release 2015.10) and Photoshop (2017.1.0). ACR version is 9.10. The CC app says all applications are current. However, when I attempt to open up a Canon Raw image (5D MK3) from LR into Photoshop I get the message "This version of Lightroom may require the Photoshop Camera Raw plug-in version for full compatibility. Please update the Camera Raw plug-in using the update tool in the Photoshop help menu" Then in the same message box it gives the following options:
Don't Show Again
Render using Lightroom
Open Anyway,
Cancel
Any suggestions?
Yes, we know. Already several posts with this glitch that was introduced with 6.10.
Until Adobe correct the error message- simply click [Open Anyway]. Edit-in Photoshop will continue as normal.
If one extra mouse click annoys you- Check [Don't Show Again] then [Open Anyway].
Thank you!
Ok ... that might work for Photoshop, but not for Lightroom. There is no "import anyway" button.
Other ideas for Lightroom?
To Atomische,
What do you mean by "Import anyway"?
The 'Lightroom to Photoshop" nag dialog is answered above.
Are you talking about another different problem?
If it is that you cannot Import photos from your camera because -Lightroom does not support your camera- then, yes, entirely different problem. You will need to do either 1) buy a Lightroom update, or 2) convert photos to DNG then import to Lightroom. And ask- with details- in another post.
