Hi
I'm having trouble with lightroom using 64 bit Photoshop. I'm trying to merge a panorama in Photoshop but every time I do it says;
"this version of lightroom may require the Photoshop camera raw plug in version 9.10 for full compatibility"
I've downloaded this a number of times but will only install in PS 32 bit!
the only download for PS 64 bit I can find is 8.5 all the rest will only install on PS 32 bit
any advice would be much appreciated!
If you are using the actual version of Lightroom CC (CC2015.10) then it's a known bug.
Camera Raw 9.10https://helpx.adobe.com/lightroom/kb/compatibility-warning-with-edit-in.html
Regards
Axel
Regards
Axel
thanks Axel Matt!
How annoying!!
in the link you attached the photo is usually how it comes up if I just click edit in PS but when I go to export a Panorama there in no "render in light room" button.
hopefully this is fixed soon!
would you know anything about lightroom slowing down computer?
I have a windows that was build for doing just editing but it seems to always have a lag and seems to be getting worse, but it was a high end build..
some specs:
windows 10 pro
Processor Intel(R) Core(TM) i7-7700 CPU @ 3.60GHz, 3601 Mhz, 4 Core(s), 8 Logical Processor(s)
Installed Physical Memory (RAM) 24.0 GB
intel 750 ssd as boot drive
with all photos stored on a separate hard drive in computer
again thanks!
some specs:
windows 10 pro
again thanks!
Sorry but I don't have any experience about this. My computer is 4 years old and has only 16GB RAM and a slower CPU than yours. I'm happy with the perfomance.
Take a look here: https://www.lightroomqueen.com/lightroom/performance/
thanks Axel Matt
your help is much appreciated!!
