9 Replies Latest reply on Nov 14, 2017 1:11 AM by ccced
    mercury greyed out on gtx1080 cc2017
    ccced Level 1
      Mercury Playback is greyed out.
      My rig is z840 2x Xeon
      7 x nvidia gtx 1080
      Latest Nvidia Drivers (381.65)
      I can't understand why Premiere does not see it / use it.
        • 1. Re: mercury greyed out on gtx1080 cc2017
          You have 7 videocards?
          Moved to Hardware forum for expert advice.
          • 2. Re: mercury greyed out on gtx1080 cc2017
            ccced Level 1
            Yes, I use GPU's for rendering (Octane).
            1 1080 is in PCIe in motherboard, and the other 6 are in Cubix Xpanders.
            However the fact that Mercury is not using even one of them is a bitter surprise.
            Thanks for moving it to the correct forum.
            Cheers
            • 3. Re: mercury greyed out on gtx1080 cc2017
              Bill Gehrke Adobe Community Professional & MVP
              Run Adobe's GPUSniffer.exe in a CMD window and show us the results
              • 4. Re: mercury greyed out on gtx1080 cc2017
                ccced Level 1
                As friend adviced me I got older Nvidia driver: 378.78
                and now it's all working fine!
                Crazy that newer drivers are not working well!
                C
                • 5. Re: mercury greyed out on gtx1080 cc2017
                  ccced Level 1
                  Hey guys, the problem is back... I don't know how or why but it's just greyed out again.
                  This is the gpusniffer info, please help:
                  Vendor: NVIDIA Corporation
                  Renderer: GeForce GTX 1080/PCIe/SSE2
                  OpenGL Version: 2.1.2 NVIDIA 378.78 21.21.13.7878
                  GLSL Version: 1.20 NVIDIA via Cg compiler
                  Monitors: 2
                  Monitor 0 properties -
                     Size: (0, 0, 2560, 1600)
                     Max texture size: 32768
                     Supports non-power of two: 1
                     Shaders 444: 1
                     Shaders 422: 1
                     Shaders 420: 1
                  Monitor 1 properties -
                     Size: (-2560, 274, 2560, 1080)
                     Shaders 444: 1
                     Shaders 422: 1
                     Shaders 420: 1
                  --- GPU Computation Info ---
                  Found 7 devices supporting GPU computation.
                  CUDA Device 0 -
                     Name: GeForce GTX 1080
                     Vendor: NVIDIA
                     Capability: 6.1
                     Driver: 8
                     Total Video Memory: 8192MB
                  CUDA Device 1 -
                     Vendor: NVIDIA
                     Capability: 6.1
                     Driver: 8
                  CUDA Device 2 -
                     Vendor: NVIDIA
                     Capability: 6.1
                     Driver: 8
                  CUDA Device 3 -
                     Vendor: NVIDIA
                     Capability: 6.1
                     Driver: 8
                  CUDA Device 4 -
                     Vendor: NVIDIA
                     Capability: 6.1
                     Driver: 8
                     * Not chosen because it exceeds the maximum device count.
                  CUDA Device 5 -
                     Vendor: NVIDIA
                     Capability: 6.1
                     Driver: 8
                  CUDA Device 6 -
                     Vendor: NVIDIA
                     Capability: 6.1
                     Driver: 8
                  • 6. Re: mercury greyed out on gtx1080 cc2017
                    I would just temporarily disconnect your second monitor and see if that might be your problem, it has occured with s few setups.
                    • 7. Re: mercury greyed out on gtx1080 cc2017
                      ccced Level 1
                      Thanks Bill,
                      What I did now is to switch off one monitor and detach one Cubix so I have 5 x1080 working. It has solved the problem, I can use the GPU's in Premiere and the playback of 4k material is very smooth.
                      However this is a problem since I use this workstation for GPU rendering as well and needles to say every additional render node saves precious time.
                      I can see that GPU sniffer says that only 4 GPUs can be supported by premiere, but this is still 5 GPUs.
                      I tried earlier to install the latest NVIDIA drivers and that just caused my entire system to crash, and I had to restore Windows.
                      I know it's not a common setup, but it would be helpful to have someone from official Adobe support to intervene on this. I'm sure I'm not the only one with multi-gpu rig.
                      Ced
                      • 8. Re: mercury greyed out on gtx1080 cc2017
                        chrisw44157881 Level 4
                        have you tried setting nvidia control panel premiere.exe as primary gfx app for just 4 cards?
                        • 9. Re: mercury greyed out on gtx1080 cc2017
                          ccced Level 1
                          Hey guys,
                          Just to let you know that Mercury works in CC Premiere 2018. It is flying with different layers of 4k and lumetri. Finally...
                          Ced
