0 Replies Latest reply on Apr 22, 2017 4:02 PM by veerr28307328
    Batch Data Merge Script to export JPEG files Directly From CSV Not From Merged Doc
    veerr28307328
      What i am doing is
      - Use csv to Data merge and then export the JPG from merged data.
      Limitation of this is
      - After 10 thousand Row my Indesign crash if i try to datamerge a big CSV FILE.
      - Without data merge i can not export.
      I use this script to export the PDF directly without doing data merge.  (See Code no.1 In Bottom)
      http://www.kahrel.plus.com/indesign/batch_convert.html
      along with this script joined
      https://forums.adobe.com/thread/1891948
      But there is limitation, I can not export JPG (but can do PDF) directly without creating merged document.
      I want You to write a script which can either
      - Do data merge in batch (data merge 500 rows of the csv and then then export directly)
      OR
      - Do not data merge Just directly export from csv (just like this pdf export script)
      OR
      (following is possible in PDF case - See Code Number 2 in Bottom)
      - The script which pickup csv + indesign document data merge it in batch and export image in a specified folder where image names are from a column of csv.
      for example
      Document Banana.indd
      picks data from
      banana.csv
      I checked the following links too. They work only on merged Document.
      Gilbert Consulting - Software training and consulting - InDesign, InCopy, Photoshop, Illustrator, Acrobat, Flash, Quark  ****
      **** Please note that script in these websites Only work for Merged Document not Direct CSV Input.
      #################### Script Code No. 1 - Used with http://www.kahrel.plus.com/indesign/batch_convert.html ###########
      if(app.documents.length != 0){
              app.dataMergeOptions.removeBlankLines = true;
              var myDataFile = File.openDialog("Select a data file")
              var myLocation = "E:/111/"
              var myName = myDoc.name
              var myExport = myLocation + myName +".jpg"
              if(myDataFile != ""){
                      myDoc.dataMergeProperties.selectDataSource(myDataFile,);
                      myDoc.dataMergeProperties.exportFile(myExport, ExportFormat.JPG, );
      ################# Script code no. 2 for picking data from same name csv############################################
              var myLocation = "YOURFOLDERHERE"
              var myExport = myLocation + myName + ".pdf"
              var myImport = myLocation + myName + ".txt"
              var myDataFile = myImport
                      myDoc.dataMergeProperties.exportFile(myExport, "[High Quality Print]", );
