2 Replies Latest reply on Apr 23, 2017 2:35 AM by mnuk
    Hi ... I want to consult about updating the video card ?
    mnuk
      Hi ... I want to consult about updating the video card .. for ppro, ae. c4d
      I have 3570k (4,5), 16 gb, 650 ti 1 gb.
      There is an error when working in 4k + lumetri (cuda error)
      In fulHD + lumetri all is well.
      What video card will be optimal for my processor ?
      Thank you.. )
        • 1. Re: Hi ... I want to consult about updating the video card ?
          RjL190365 Level 5
          GeForce GTX 1050 Ti. Don't go any higher unless you're planning to also upgrade the CPU, motherboard and RAM in the near future.
          By the way, with your workflow from 4K sources you really need that GTX 1050 Ti since the plain GTX 1050 is only available with 2GB of VRAM at this point, and that your current GTX 650 Ti cannot cut it at all for 4K because it has a woefully insufficient 1GB of VRAM. If your GPU is either too old or lacks sufficient VRAM for the workflow, then you will experience either rendering errors or a massive slowdown in rendering performance due to the automatic without notification switch of the renderer from MPE GPU acceleration to MPE software only.
          Randall
          • 2. Re: Hi ... I want to consult about updating the video card ?
            mnuk Level 1
            Thank you Randall .
            I will probably add more memory, and cpu update to 3770 will not .. I will later collect a completely new computer.
