• Global community
    • Language:
      • Deutsch
      • English
      • Español
      • Français
      • Português
  • 日本語コミュニティ
  • 한국 커뮤니티
Exit
0
Premiere Elements 11 cutting off last few seconds of video
New Here ,
Apr 22, 2017 Apr 22, 2017
Hey all,
New to forum but i am using Elements 11 and no matter what i put into it, it cuts off a few seconds at the end of the video...but when i play the video without using elements its still there. This is before any editing or uploading..just a simple drag and drop and its missing. Any help will be great!
Views
446
Translate
Translate
Report
Report
Community guidelines
community guidelines
Community Expert , Apr 22, 2017 Apr 22, 2017
Typically screen recording software will record video with a variable frame rate.  That can cause problems with a lot of editors including Premiere Elements.  It might even vary depending on what you are recording.
Premiere Elements is not a universal, edit everything program.  It is aimed at editing footage from video cameras in several common file types.  Screen recorders can have trouble making those standard file types.
A common fix is to process the clips through Handbrake or equivalent to
Votes
Translate
Translate
Community Expert ,
What model of camcorder is the video coming from? What is the file format and resolution of the video?
What operating system are you using?
Do you have Quicktime 7 installed, per the program's requirements?
Votes
Translate
Translate
Report
Report
New Here ,
I do not have quicktime 7..its a recording from bandicam. Ive never had this issue before with bandicam. Send it to elements and it cuts off last few seconds..using windows 10
Votes
Translate
Translate
Report
Report
New Here ,
Still really need help for this
Votes
Translate
Translate
Report
Report
Community Expert ,
A common fix is to process the clips through Handbrake or equivalent to create a file with a fixed frame rate for video editing.
Hope this helps.
Votes
Translate
Translate
Report
Report
New Here ,
Apr 23, 2017 Apr 23, 2017
LATEST
Thank you
Votes
Translate
Translate
Report
Report
Community Expert ,
I agree with Bill. Bandicam's formatting is likely the issue.
Convert the file to a constant frame rate video with Handbrake and your issues will likely disappear.
Votes
Translate
Translate
Report
Report
