12 Replies Latest reply on May 2, 2017 4:00 PM by mauricior6328708
    Adding images to buttons
    mauricior6328708 Level 1
      Greetings everyone! User interface curiosity about customizing each button state. In a future project, I intend to use a ScriptUI script that contains a few buttons, however, I have difficulty understanding how to add images.PNG to buttons, eg "b1-normal.png", "b1-rollover.png", and "b1 - pressed.png ", no button due, and so on.
      Has anyone had this experience, how can I do this, any ideas?
      The camino dos imgens would be this:
      ("~ / AppData / Roaming / Adobe / CEP / extensions / Ps-fxrios / icons / b1-normal.png")
      I know it's not easy: It would be something like this:
      https://pastebin.com/raw/RWBpzxQx
      But I need to do every process on every button in this script that is pretty easy to understand and edit:
      var dlg = new Window ("dialog", "My dialog", [0,0,0,0])
      dlg.size = [150,300]
      dlg.location = [600,260]
      var dlgborda = dlg.add('panel', [10,5,140,280], '');
      var b1 = dlgborda.add("button", [0,0,0,0], " ")
      b1.location = [10, 12]
      b1.size = [50, 50]
      var b2 = dlgborda.add("button", [0,0,0,0], " ")
      b2.location = [65,12]
      b2.size = [50, 50]
      var b3 = dlgborda.add("button", [0,0,0,0], " ")
      b3.location = [65,70]
      b3.size = [50, 50]
      var b4 = dlgborda.add("button", [0,0,0,0], " ")
      b4.location = [10,70]
      b4.size = [50, 50]
      dlg.show()
      Thank you:
        • 1. Re: Adding images to buttons
          smithcgl9043167 Level 2
          Hi .. I believe this should be very complex. I would also like to know how you do it! I found this example, however it shows only on a button: I do not know if this process would be possible for other images with other buttons: https://forums.adobe.com/message/5638494#5638494
          • 2. Re: Adding images to buttons
            Did you try to add a second button to Davide's example script and event listeners to see if it may be possible? to use his code?  If it can then you would just need to modify the code to use your icons for the second button and do what you want to do when the buttons are used. Not just change the icon.
            var dir = "" + File($.fileName).path + "/img/";
            var icons =  { normal: File(dir + "createNew_normal.png"),
                           disable: File(dir + "createNew_normal.png"),
                           pressed: File(dir + "createNew_pressed.png"),
                           rollover: File(dir + "createNew_rollover.png")
            var w = new Window("dialog");
            b = w.add ('button'); // works for customButton, iconButton, button
            b.preferredSize = [200,100];
            c = w.add ('button'); // works for customButton, iconButton, button
            c.preferredSize = [200,100];
            var roll = ScriptUI.newImage(icons.rollover);
            var norm = ScriptUI.newImage(icons.normal);
            var down = ScriptUI.newImage(icons.pressed);
            b.image = norm;
            b.size = [140, 40]
            b.onDraw = function (state) {
                this.graphics.drawImage(this.image,0,0);
            c.image = norm;
            c.size = [140, 40]
            c.onDraw = function (state) {
            var mouseEventHandler = function(event) {
                switch (event.type) {
                    case 'mouseover':
                        event.target.image = roll;
                        break;
                    case 'mouseout':
                        event.target.image = norm;
                        break;
                    case 'mousedown':
                        event.target.image = down;
                        break;
                    case 'mouseup':
                        break;
                    default:
                event.target.notify("onDraw");
            b.addEventListener('mouseover', mouseEventHandler, false);
            b.addEventListener('mouseout', mouseEventHandler, false);
            b.addEventListener('mousedown', mouseEventHandler, false);
            b.addEventListener('mouseup', mouseEventHandler, false);
            c.addEventListener('mouseover', mouseEventHandler, false);
            c.addEventListener('mouseout', mouseEventHandler, false);
            c.addEventListener('mousedown', mouseEventHandler, false);
            c.addEventListener('mouseup', mouseEventHandler, false);
            w.show();
            • 3. Re: Adding images to buttons
              With html and CSS with the minimum and effort I would coseguiria but with Java Script, I confess that I have not the slightest idea how to add the second, third ... button! JJMack , if you had to modify and add some buttons like you would do this with this script ??
              • 4. Re: Adding images to buttons
                Ps-Design Level 1
                I have a similar question!
                How do I add an image to a button? Could someone share an example?
                • 5. Re: Adding images to buttons
                  The example script posted does.  Three png image file in an img folder on your desktop are used.
                  • 6. Re: Adding images to buttons
                    Ps-Design Level 1
                    The example above shows that effects on buttons are possible, but they do not show how this would work with a second button.
                    Simpler type: an image in the buddy button as above friend:
                    Var dlg = new Window ("dialog", "My dialog", [0,0,0,0])
                    Dlg.size = [150,300]
                    Dlg.location = [600,260]
                    Var dlgborda = dlg.add ('panel', [10,5,140,280], '');
                    Var b1 = dlgborda.add ("button", [0,0,0,0], "")
                    B1.location = [10,12]
                    B1.size = [50, 50]
                    dlg.show()
                    • 7. Re: Adding images to buttons
                      The events for the second buttons are the same as the first button,  The changes I made shows that I use the same graphics for the two buttons still they work independently.  You could use different graphics and do more that just change the graphic for an event.  All the script currently does is change the graphics.  The Script perform no other function.   Mouse events trigger no other function. You would add that.  Where you would add that code I'm not sure I would have to read  Adobe ScriptUI documentation.
                      • 8. Re: Adding images to buttons
                        Ps-Design Level 1
                        Hi JJMack Thank you skin attention. I have to create a dialog box, which contains six buttons, each button will perform its due function through the Photoshop action that I created, however it is fundamental that each button has a different image or icon so I can identify the action : That would give a more attractive look. Thank you.
                        I tried to do using the above script, just left to add to each button a different image:
                        • 9. Re: Adding images to buttons
                          Hi ... If it's just to add a simple image ...
                          The problem is always that by hovering the mouse or clicking the button the same button is hidden and I do not know how to solve this.
                          Save the script and use this image on your desktop, and check yourself:
                          var b1 = File (Folder.desktop + "/icon_fx.png");
                          var b1 = dlgborda.add("iconbutton", [0,0,0,0], ScriptUI.newImage(b1),)
                          b1.location = [5, 8]
                          b1.size = [50, 50]
                          var b2 =  File (Folder.desktop + "/icon_fx.png");
                          var b2 = dlgborda.add("iconbutton", [0,0,0,0], ScriptUI.newImage(b2),)
                          b2.location = [65,8]
                          b2.size = [50, 50]
                          var b3 =  File (Folder.desktop + "/icon_fx.png");
                          var b3 = dlgborda.add("iconbutton", [0,0,0,0], ScriptUI.newImage(b3),)
                          b3.location = [65,62]
                          b3.size = [50, 50]
                          var b4 =  File (Folder.desktop + "/icon_fx.png");
                          var b4 = dlgborda.add("iconbutton", [0,0,0,0], ScriptUI.newImage(b4),)
                          b4.location = [5,62]
                          b4.size = [50, 50]
                          dlg.show()
                          • 10. Re: Adding images to buttons
                            Did you even look at Davide's example script?  Your script has no mouse event code. A mouse click is not magical.  You need to code the script to do what you want the click or mouse over to do.
                            By the way all his script does is change the button icon on mouse events like mouse over mouse no longer over mouse click etc  the button perform no other function.
                            • 11. Re: Adding images to buttons
                              DBarranca Level 4
                              Mauricio,
                              give the following a try:
                              function drawButton() {
                              b1.size = [50, 50]
                              b1.onDraw = drawButton;
                              b2.size = [50, 50]
                              b2.onDraw = drawButton;
                              b3.size = [50, 50]
                              b3.onDraw = drawButton;
                              b4.size = [50, 50]
                              b4.onDraw = drawButton;
                              For some reason something weird happens in the second row in CC 2017, but with manual positioning I think you can workaround it.
                              Hope this helps!
                              Davide Barranca
                              • 12. Re: Adding images to buttons
                                Thank you skin attention .... Actually was not quite what I needed, but the same will be quite useful on another occasion: Did you read the post at the beginning?
                                I have already been able to find the answer that meets my needs on page 18 of this PDF Guide:
                                https://indd.adobe.com/view/a0207571-ff5b-4bbf-a540-07079bd21d75
                                For me it worked very well this way:
                                var icons = {
                                    a1: File ("~/AppData/Roaming/Adobe/CEP/extensions/Ps-fxrios/assets/icon-a.png"), // normal
                                    b1: File ("~/AppData/Roaming/Adobe/CEP/extensions/Ps-fxrios/assets/icon-b.png"), // enabled
                                    c1: File ("~/AppData/Roaming/Adobe/CEP/extensions/Ps-fxrios/assets/icon-c.png"), // pressed
                                    d1: File ("~/AppData/Roaming/Adobe/CEP/extensions/Ps-fxrios/assets/icon-d.png"), // rollover
                                    a2: File ("~/AppData/Roaming/Adobe/CEP/extensions/Ps-fxrios/assets/icon-a2.png"), // normal
                                    b2: File ("~/AppData/Roaming/Adobe/CEP/extensions/Ps-fxrios/assets/icon-b2.png"), // enabled
                                    c2: File ("~/AppData/Roaming/Adobe/CEP/extensions/Ps-fxrios/assets/icon-c2.png"), // pressed
                                    d2: File ("~/AppData/Roaming/Adobe/CEP/extensions/Ps-fxrios/assets/icon-d2.png"), // rollover
                                var w = new Window ("dialog", "My Buttons", [0,0,0,0])
                                 w.size = [230,253]
                                 w.location = [650,300]
                                 var wborda = w.add('panel', [6,9,140,246], '');
                                 //Buttons
                                 btn1 = wborda.add ("iconbutton", [0,0,0,0], ScriptUI.newImage (icons.a1, icons.b1, icons.c1, icons.d1),)
                                 btn1.location = [0, 0]
                                 btn2 = wborda.add ("iconbutton", [0,0,0,0], ScriptUI.newImage (icons.a2, icons.b2, icons.c2, icons.d2),)
                                 btn2.location = [65, 0]
                                 w.show();
                                Anyway, I'm very grateful for the help! A hug.
