3 Replies Latest reply on Dec 16, 2008 9:04 AM by mIIwaukee
    Illustrator Transparency Question
    PAB1953 Level 1
      I have a basic transparency question re Illustrator CS3 ... but no one seemed to have an answer when I posted the question in that forum. Maybe someone here will.
      In Fireworks, when you have an irregular object, you can easily get rid of the white space inside the bounding box by selecting and deleting it and saving the file as a GIF with alpha transparency. I want to do the same in Illustrator with a vector image. Any ideas how?
        • 1. Re: Illustrator Transparency Question
          pixlor Level 4
          If you have an irregular vector object in Illustrator, you should be able to set the fill to none. That will make the interior of the object transparent. Is that what you want?
          • 2. Re: Illustrator Transparency Question
            PAB1953 Level 1
            Pixlor, thanks for your reply. It's the space around the outside of an object that I'm trying to make transparent. Example: Draw a filled circle (in FW or IL) and you have a filled circle in a square bounding box. The four corners of the bounding box each will have a space -- from the corners of the bounding box to the edge of the circle. That's what I want to make transparent in IL (and which is easy to do in FW).
            • 3. Re: Illustrator Transparency Question
              mIIwaukee Level 1
              Vector images in Illustrator don't have filled areas in their bounding boxes. They're natively transparent there. The canvas color is usually always white. Export to web as a transparent gif and you'll see.
              To my knowledge the only way to make a bitmap transparent in Illustrator is to draw and apply a mask for the bitmap. Would love a magic wand.
